Mailman and Virtualmin
I have virtualmin setup on Debian 5.0, my problem is i could not use port 10000 so i disabled SSL and used apache to reverse proxy.
Everything seems to work fine, however when someone subscribes to the list it sends out a URL to mailman interface that tries to redirect to SSL port 10000.
The Question is how do i change this?
Many Thanks, Dan
I’m not sure there’s a way to change that as of today – you may want to file a bug report so that Jamie can look into offering you a solution of some sort for that.
thats crazy! I got a dozens of people in a University and halls of residence waiting to use this, but that port appears to be blocked!
Is there a temporary solution IE. altering the mailman config…?
Well, again, I recommend filing a bug report so that you and Jamie can go over the details here :slight_smile:
You can do that using the Support link above.
Ive posted a bug report, thanks :slight_smile:
