I would like to set users’ mailbox quotas for different virtual servers email users. I understand that Virtualmin sets the quotas for the user’s home directory (unix style) which includes the Maildir directory.
In Virtualmin, I select the desired virtual server on the drop down menu. Then I go to “Edit users” -> “Quotas and home directory settings”.
Unfortunately, in the quota tab, all i have is "Home directory Automatic Subdirectory of server’s home " to set the home directory path. But nothing that allows me set the quota limits in Gb.
note: the users I have tested with are ‘Email only’ and I also tested ‘Email, FTP’ users
Q1. How do I go about setting the quotas for email users?
Q2. Is there a way to set quotas for FTP users who have their FTP folder outside of their “home” folder
If you go into System Settings -> Virtualmin Config, does it say anything about quotas in there? It might be good to verify that it says quotas are working on /home.
When you go to create new user for the server you should have option to set their quota but this is not available if you want to create FTP only user, in this case your only option is to set their home directory.
i build a brand new virtualmin server and if i go on “edit user” ,Under “Quota and home directory settings” the “Home Directory quota” for all users is not showing. The only option available is “Home directory”. I ve seen quite a few people having the same issue, is it something that needs to be activated somewhere etc…
