Mail Relaying Issue between two domain on same server
I have mail relaying enabled for two domains on my server. I cannot send mail from domain A to domain B. The error message I get back states that the user is unknown. I can successfully send mail to domain B from domains outside the Virtualmin server just fine. I can also send from Domain B to Domain A without any problems. Any thoughts on where I can start?
Thanks,
Nathan
The user you attempted to email from domain A – is that the same user you can successfully email from the outside world?
You may want to take a peek at the email logs in /var/log, they may have more details for you regarding the issue.
Eric,
Thanks for the reply. I’ve since found out that it wasn’t mail to all users, but only one specific user I was testing with. I’ve got to dig a little deeper to see what the overall issue with that user is, but for now I’m good. I will check the logs and see if there is anything there the next time I go to test for that user.
Thanks,
Nathan
