Mail problem
Almost from 2 weeks i don`t get any mail on my server.
This happened after making an OS update from centos 5.2 to centos 5.3.
I have:
Webmin version 1.450
Virtualmin version 3.66.gpl GPL
Error log says:
Jun 10 14:58:07 bladeservers postfix/trivial-rewrite[24069]: warning: do not list domain bladeservers.ro in BOTH mydestination and virtual_alias_domains
Jun 10 14:58:07 bladeservers postfix/qmgr[4487]: EF0CC3FC4C6: removed
Jun 10 14:58:08 bladeservers postfix/local[24125]: 426A63FC01F: to=tehnic.bladeservers@bladeservers.ro, orig_to=, relay=local, delay=6.8, delays=0.03/0.01/0/6.8, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME)
Jun 10 14:58:08 bladeservers postfix/local[24071]: 426A63FC01F: to=admin.bladeservers@bladeservers.ro, orig_to=, relay=local, delay=7.2, delays=0.03/0/0/7.2, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME)
Jun 10 14:58:08 bladeservers postfix/qmgr[4487]: 426A63FC01F: removed
Jun 10 14:58:13 bladeservers postfix/local[24187]: 87CEF3FC4C5: to=tehnic.bladeservers@bladeservers.ro, orig_to=, relay=local, delay=7.2, delays=0.03/0.03/0/7.2, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME)
Jun 10 14:58:16 bladeservers postfix/local[24185]: 87CEF3FC4C5: to=admin.bladeservers@bladeservers.ro, orig_to=, relay=local, delay=10, delays=0.03/0/0/10, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME)
Jun 10 14:58:16 bladeservers postfix/qmgr[4487]: 87CEF3FC4C5: removed
Jun 10 14:58:17 bladeservers postfix/local[24195]: B19AE3FC4C3: to=tehnic.bladeservers@bladeservers.ro, orig_to=, relay=local, delay=11, delays=0.04/1.4/0/9.1, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME)
Jun 10 14:58:17 bladeservers postfix/local[24125]: B19AE3FC4C3: to=admin.bladeservers@bladeservers.ro, orig_to=, relay=local, delay=11, delays=0.04/1.7/0/9.2, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME)
Jun 10 14:58:17 bladeservers postfix/qmgr[4487]: B19AE3FC4C3: removed
Jun 10 14:58:20 bladeservers postfix/local[24071]: 034CC3FC4C4: to=tehnic.bladeservers@bladeservers.ro, orig_to=, relay=local, delay=14, delays=0.03/6.7/0/6.8, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME)
Jun 10 14:58:21 bladeservers postfix/local[24187]: 034CC3FC4C4: to=admin.bladeservers@bladeservers.ro, orig_to=, relay=local, delay=14, delays=0.03/9.7/0/4.6, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME)
Jun 10 14:58:21 bladeservers postfix/qmgr[4487]: 034CC3FC4C4: removed
Jun 10 15:01:20 bladeservers postfix/anvil[24068]: statistics: max connection rate 1/60s for (smtp:207.106.200.8) at Jun 10 14:57:54
Jun 10 15:01:20 bladeservers postfix/anvil[24068]: statistics: max connection count 1 for (smtp:207.106.200.8) at Jun 10 14:57:54
Jun 10 15:01:20 bladeservers postfix/anvil[24068]: statistics: max cache size 1 at Jun 10 14:57:54
Jun 10 15:09:38 bladeservers postfix/pickup[23347]: 5D63C3FC4C3: uid=0 from=
Jun 10 15:09:38 bladeservers postfix/cleanup[24937]: 5D63C3FC4C3: message-id=20090610120938.5D63C3FC4C3@bladeservers.ro
Jun 10 15:09:38 bladeservers postfix/qmgr[4487]: 5D63C3FC4C3: from=root@bladeservers.ro, size=497, nrcpt=1 (queue active)
Jun 10 15:09:38 bladeservers postfix/trivial-rewrite[24938]: warning: do not list domain bladeservers.ro in BOTH mydestination and virtual_alias_domains
Jun 10 15:09:38 bladeservers last message repeated 2 times
Jun 10 15:09:38 bladeservers postfix/cleanup[24937]: 67F283FC01F: message-id=20090610120938.5D63C3FC4C3@bladeservers.ro
Jun 10 15:09:38 bladeservers postfix/local[24939]: 5D63C3FC4C3: to=root@bladeservers.ro, orig_to=, relay=local, delay=0.12, delays=0.08/0.01/0/0.03, dsn=2.0.0, status=sent (forwarded as 67F283FC01F)
Jun 10 15:09:38 bladeservers postfix/qmgr[4487]: 67F283FC01F: from=root@bladeservers.ro, size=630, nrcpt=2 (queue active)
Jun 10 15:09:38 bladeservers postfix/qmgr[4487]: 5D63C3FC4C3: removed
Jun 10 15:09:43 bladeservers postfix/local[24940]: 67F283FC01F: to=tehnic.bladeservers@bladeservers.ro, orig_to=, relay=local, delay=4.9, delays=0.03/0.01/0/4.9, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME)
Jun 10 15:09:44 bladeservers postfix/local[24939]: 67F283FC01F: to=admin.bladeservers@bladeservers.ro, orig_to=, relay=local, delay=6.4, delays=0.03/0/0/6.4, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME)
Jun 10 15:09:44 bladeservers postfix/qmgr[4487]: 67F283FC01F: removed
Jun 10 15:13:25 bladeservers postfix/smtpd[25153]: connect from static-72-90-96-3.ptldor.fios.verizon.net[72.90.96.3]
Jun 10 15:13:26 bladeservers postfix/smtpd[25153]: 42A023FC01F: client=static-72-90-96-3.ptldor.fios.verizon.net[72.90.96.3]
Jun 10 15:13:26 bladeservers postfix/cleanup[25157]: 42A023FC01F: message-id=CCSRVPrjF68V22fcoXp00000853@mail.crittercabana.com
Jun 10 15:13:26 bladeservers postfix/qmgr[4487]: 42A023FC01F: from=office@euro-gadgets.org, size=7627, nrcpt=1 (queue active)
Jun 10 15:13:26 bladeservers postfix/trivial-rewrite[25156]: warning: do not list domain bladeservers.ro in BOTH mydestination and virtual_alias_domains
Jun 10 15:13:27 bladeservers postfix/smtpd[25153]: disconnect from static-72-90-96-3.ptldor.fios.verizon.net[72.90.96.3]
Jun 10 15:13:27 bladeservers postfix/local[25158]: 42A023FC01F: to=links.mybookmarks@bladeservers.ro, orig_to=links@mybookmarks.ro, relay=local, delay=1.2, delays=0.92/0.01/0/0.23, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME)
Jun 10 15:13:27 bladeservers postfix/qmgr[4487]: 42A023FC01F: removed
I tried to search an solution for this but i did not find anything.
I removed the bladeservers.ro from mydestination, restarted postfix but still nothing.
Any help is appreciated.
Well, the mydestination thing is just a warning, not an error that would be causing the issue you’re seeing.
Also, I see this a few times in there:
“delivered to command: /usr/bin/procmail-wrapper”
Which implies that Postfix received an email, and attempted to deliver it to procmail.
Are you seeing any errors in the procmail logfile, /var/log/procmail.log?
Well there is no file /var/log/procmail.log .
The weird think is that is i started to receive email again.
I did not do anything.
Any idea why this happened?
Thanks.
Nope, no idea what happened :wink:
But, I’m glad it’s working!
