I am totally Newbie to VirtualMin and Webmin but I am doing the best to search forums and Google before posting.
But I have a problem here I can’t figure out.
I have installed a CentOS 5.6 server 64 bit and installed VirtualMin with WebMin on a 100GB disk.
I have setup 5 sites and they have been working great until now (only one month), when one of our customers told us that mail suddenly doesn’t work any more.
I looked into the maillog and I can see the following errors
May 25 13:14:16 glolinweb001 postfix/cleanup[15971]: warning: mail_queue_enter: create file incoming/46671.15971: Disk quota exceeded
May 25 13:14:26 glolinweb001 postfix/cleanup[15971]: warning: mail_queue_enter: create file incoming/47729.15971: Disk quota exceeded
May 25 13:14:36 glolinweb001 postfix/cleanup[15971]: warning: mail_queue_enter: create file incoming/49779.15971: Disk quota exceeded
May 25 13:14:46 glolinweb001 postfix/cleanup[15971]: warning: mail_queue_enter: create file incoming/51771.15971: Disk quota exceeded
I can’t see any quota errors in the system information page, but somehow there is not enough space to send mails??
We are using a mail relay server which have been setup in the “General Options” under “Postfix Mail Server” in the entry “Send outgoing mail via host”.
Looking forward for any help regarding the above error.
It sounds like the disk quota for that particular user may have been reached.
You may want to go into Edit Mail and FTP Users for the domain in question to see the quota usage for all the email accounts. From there, you can modify the quota for any users who have reached their limit.
We don’t have mail’s setup for the specific sites on the VirtualMin server.
Only web and FTP have been activated and when I look in the quota area no one have filled out their quotes at all.
There is no visible quote issue when using the interface.
And no one can send mails anymore, even sites which have 1Tb but only uses 10Mb.
So it sounds more to me that it is a temporary area for the postfix program been filled up??
Here is the output
*** Report for user quotas on device /dev/mapper/VolGroup00-LogVol00
Block grace time: 7days; Inode grace time: 7days
Block limits File limits
User used soft hard grace used soft hard grace
Strange, I haven’t set any quota for the root account, that’s kind of strange.
And I agree that it is not something I want
I found the user and I have changed the quota to unlimited.
I better check our other test environment if it has the same “strange” limitation.
If it has, I may have forced the quota to the whole system on a mistake.
I just checked it, and yes same 1Gb quota, I better watch my changes in the future…
Do I have to restart the system to get it working “correctly” again or may I have wrecked it now when there has been a quota enforced on the root user??
I just checked the /var/log/maillog and it still says that the quote have been reached
May 26 15:10:38 glolinweb001 postfix/cleanup[4027]: warning: mail_queue_enter: create file incoming/807995.4027: Disk quota exceeded
May 26 15:10:48 glolinweb001 postfix/cleanup[4027]: warning: mail_queue_enter: create file incoming/809823.4027: Disk quota exceeded
May 26 15:10:50 glolinweb001 postfix/qmgr[4576]: fatal: qmgr_move: rename 061338981DA from active to incoming: Disk quota exceeded
May 26 15:10:51 glolinweb001 postfix/master[3996]: warning: process /usr/libexec/postfix/qmgr pid 4576 exit status 1
May 26 15:10:51 glolinweb001 postfix/master[3996]: warning: /usr/libexec/postfix/qmgr: bad command startup – throttling
May 26 15:10:58 glolinweb001 postfix/cleanup[4027]: warning: mail_queue_enter: create file incoming/811401.4027: Disk quota exceeded
/dev/mapper/VolGroup00-LogVol00 on / type ext3 (rw,grpquota,usrquota)
proc on /proc type proc (rw)
sysfs on /sys type sysfs (rw)
devpts on /dev/pts type devpts (rw,gid=5,mode=620)
/dev/sda1 on /boot type ext3 (rw)
tmpfs on /dev/shm type tmpfs (rw)
none on /proc/sys/fs/binfmt_misc type binfmt_misc (rw)
sunrpc on /var/lib/nfs/rpc_pipefs type rpc_pipefs (rw)
Maybe I need to install a new server and move everything to that one??
Here is the output
May 26 18:21:07 glolinweb001 postfix/qmgr[19952]: fatal: qmgr_move: rename 5769B8981AF from active to incoming: Disk quota exceeded
May 26 18:21:08 glolinweb001 postfix/master[3996]: warning: process /usr/libexec/postfix/qmgr pid 19952 exit status 1
May 26 18:21:08 glolinweb001 postfix/master[3996]: warning: /usr/libexec/postfix/qmgr: bad command startup – throttling
May 26 18:22:08 glolinweb001 postfix/qmgr[20002]: fatal: qmgr_move: rename 5769B8981AF from active to incoming: Disk quota exceeded
May 26 18:22:09 glolinweb001 postfix/master[3996]: warning: process /usr/libexec/postfix/qmgr pid 20002 exit status 1
May 26 18:22:09 glolinweb001 postfix/master[3996]: warning: /usr/libexec/postfix/qmgr: bad command startup – throttling
May 26 18:22:10 glolinweb001 postfix/postsuper[20024]: warning: bogus file name: incoming/530410.19193
May 26 18:22:29 glolinweb001 postfix/smtpd[20092]: warning: database /etc/postfix/virtual.db is older than source file /etc/postfix/virtual
We added the Pro license two days ago on both systems, which now have a corrupted root quote.
If we at some point is not able to get it working again and we have to reinstall the servers again, what do we then do with the license???
Well, I’d like to think that whatever is wrong is solvable… however, you’re certainly welcome to transfer this same Pro license to another server. You’ll see a notice about it being installed on two servers until your old server is decommissioned. But, that’s no problem, we want you to be able to migrate to a new server when necessary
