Okay, I was able to login to Username using username: test.domain rather than test@domain.tld.
After logging in with test.domain, I can now also log in with test@domain.tld.
However, there is no test email I sent to test@domain.tld?
http://www.virtualmin.com/documentation/id,webmail_and_virtualmin/#webmail_and_virtualmin says Usermin uses IMAP server by default if Dovecot is running and properly configured.
I am using whatever the default configuration is, so if I need to configure something, I can’t find any instructions how to?
I checked the Virtualmin mail logs in /var/log/maillog. Here is some of the log errors. I couldn’t paste all of the logs as it’s 2710 lines of code from 5065-7775:
1st part of log files:
Nov 27 08:04:02 localhost dovecot: master: Dovecot v2.0.9 starting up (core dumps disabled)
Nov 27 08:04:07 localhost postfix/postfix-script[1900]: starting the Postfix mail system
Nov 27 08:04:07 localhost postfix/master[1901]: daemon started -- version 2.6.6, configuration /etc/postfix
Nov 27 08:04:08 localhost postfix/qmgr[1910]: 3F8CCFE45: from=<domain@centos.com>, size=1373, nrcpt=1 (queue active)
Nov 27 08:04:08 localhost postfix/qmgr[1910]: 36DB713497: from=<domain@centos.com>, size=1419, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: 3D16410331: from=<domain@centos.com>, size=1384, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: 3609110333: from=<domain@centos.com>, size=1405, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: C663C1346C: from=<domain@centos.com>, size=1385, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: CD7731349C: from=<domain@centos.com>, size=1419, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: C9FC613494: from=<domain@centos.com>, size=1422, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: CE6DA1348A: from=<domain@centos.com>, size=1420, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: 755CF12726: from=<domain@centos.com>, size=1399, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: 6A15613498: from=<domain@centos.com>, size=1414, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: 6A08D13486: from=<domain@centos.com>, size=1415, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: 69E9AD0CD: from=<domain@centos.com>, size=1414, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: 11B2A12E74: from=<domain@centos.com>, size=1404, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: 195091348B: from=<domain@centos.com>, size=1419, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: 19C521348D: from=<domain@centos.com>, size=1419, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: 1A0261348C: from=<domain@centos.com>, size=1417, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: 154E413499: from=<domain@centos.com>, size=1416, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: 0159E10334: from=<domain@centos.com>, size=1416, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: 04C4A13490: from=<domain@centos.com>, size=1417, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: A00A51349F: from=<domain@centos.com>, size=1418, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: EC74F1349D: from=<domain@centos.com>, size=1420, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: EDE10F834: from=<domain@centos.com>, size=1379, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: 8E118102A6: from=<domain@centos.com>, size=1418, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: 8D34813491: from=<domain@centos.com>, size=1421, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: 5A37D13496: from=<domain@centos.com>, size=1416, nrcpt=1 (queue active)
Nov 27 08:04:09 localhost postfix/qmgr[1910]: 52A80100CD: from=<domain@centos.com>, size=1400, nrcpt=1 (queue active)
Nov 27 08:04:10 localhost postfix/qmgr[1910]: 551F3FE32: from=<domain@centos.com>, size=1376, nrcpt=1 (queue active)
Nov 27 08:04:10 localhost postfix/qmgr[1910]: 4F24410337: from=<domain@centos.com>, size=1385, nrcpt=1 (queue active)
Nov 27 08:04:10 localhost postfix/qmgr[1910]: B90DC1348F: from=<domain@centos.com>, size=1415, nrcpt=1 (queue active)
Nov 27 08:04:10 localhost postfix/qmgr[1910]: B48CBE45A: from=<domain@centos.com>, size=1420, nrcpt=1 (queue active)
Nov 27 08:04:11 localhost postfix/smtp[1921]: connect to gmail-smtp-in.l.google.com[2607:f8b0:4002:c01::1b]:25: Network is unreachable
Nov 27 08:04:11 localhost postfix/smtp[1913]: connect to gmail-smtp-in.l.google.com[2607:f8b0:4002:c01::1b]:25: Network is unreachable
Nov 27 08:04:11 localhost postfix/smtp[1915]: connect to gmail-smtp-in.l.google.com[2607:f8b0:4002:c01::1b]:25: Network is unreachable
Nov 27 08:04:11 localhost postfix/smtp[1918]: connect to gmail-smtp-in.l.google.com[2607:f8b0:4002:c01::1b]:25: Network is unreachable
Nov 27 08:04:11 localhost postfix/smtp[1919]: connect to gmail-smtp-in.l.google.com[2607:f8b0:4002:c01::1b]:25: Network is unreachable
Nov 27 08:04:11 localhost postfix/smtp[1914]: 3D16410331: host mailin-01.mx.aol.com[205.188.159.42] refused to talk to me: 554- (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html 554 Connecting IP: 124.191.169.67
Nov 27 08:04:11 localhost postfix/smtp[1917]: CD7731349C: host mailin-02.mx.aol.com[64.12.137.162] refused to talk to me: 554- (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html 554 Connecting IP: 124.191.169.67
Nov 27 08:04:12 localhost postfix/smtp[1912]: 3F8CCFE45: host mailin-02.mx.aol.com[64.12.88.164] refused to talk to me: 554 5.7.1 : (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html
Nov 27 08:04:12 localhost postfix/smtp[1917]: CD7731349C: host mailin-03.mx.aol.com[64.12.91.196] refused to talk to me: 554 5.7.1 : (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html
Nov 27 08:04:12 localhost postfix/smtp[1923]: connect to ymail.net[222.231.2.126]:25: Connection refused
Nov 27 08:04:12 localhost postfix/smtp[1914]: 3D16410331: host mailin-01.mx.aol.com[205.188.155.110] refused to talk to me: 554- (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html 554 Connecting IP: 124.191.169.67
Nov 27 08:04:12 localhost postfix/smtp[1916]: C663C1346C: host mailin-04.mx.aol.com[64.12.88.132] refused to talk to me: 554 5.7.1 : (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html
Nov 27 08:04:12 localhost postfix/smtp[1915]: 3609110333: host gmail-smtp-in.l.google.com[74.125.129.26] said: 450-4.2.1 The user you are trying to contact is receiving mail at a rate that 450-4.2.1 prevents additional messages from being delivered. Please resend your 450-4.2.1 message at a later time. If the user is able to receive mail at that 450-4.2.1 time, your message will be delivered. For more information, please 450 4.2.1 visit http://support.google.com/mail/bin/answer.py?answer=6592 v7si31816841pbi.68 - gsmtp (in reply to RCPT TO command)
Nov 27 08:04:12 localhost postfix/smtp[1920]: 755CF12726: host mailin-02.mx.aol.com[64.12.88.163] refused to talk to me: 554 5.7.1 : (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html
Nov 27 08:04:12 localhost postfix/smtp[1923]: 4F24410337: to=<velesyandextay@ymail.net>, relay=none, delay=321603, delays=321601/1.5/0.99/0, dsn=4.4.1, status=deferred (connect to ymail.net[222.231.2.126]:25: Connection refused)
Nov 27 08:04:12 localhost postfix/smtp[1915]: connect to alt1.gmail-smtp-in.l.google.com[2607:f8b0:4002:c01::1b]:25: Network is unreachable
Nov 27 08:04:13 localhost postfix/smtp[1912]: 3F8CCFE45: host mailin-03.mx.aol.com[64.12.91.196] refused to talk to me: 554 5.7.1 : (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html
Nov 27 08:04:13 localhost postfix/smtp[1914]: 3D16410331: host mailin-01.mx.aol.com[64.12.91.195] refused to talk to me: 554 5.7.1 : (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html
Nov 27 08:04:13 localhost postfix/smtp[1916]: C663C1346C: host mailin-02.mx.aol.com[64.12.91.195] refused to talk to me: 554 5.7.1 : (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html
Last part of log files:
Nov 27 15:04:14 localhost postfix/smtp[26670]: 3609110333: host gmail-smtp-in.l.google.com[74.125.129.27] said: 450-4.2.1 The user you are trying to contact is receiving mail at a rate that 450-4.2.1 prevents additional messages from being delivered. Please resend your 450-4.2.1 message at a later time. If the user is able to receive mail at that 450-4.2.1 time, your message will be delivered. For more information, please 450 4.2.1 visit http://support.google.com/mail/bin/answer.py?answer=6592 it5si32703922pbc.95 - gsmtp (in reply to RCPT TO command)
Nov 27 15:04:14 localhost postfix/smtp[26669]: 3D16410331: host mailin-02.mx.aol.com[64.12.137.162] refused to talk to me: 554- (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html 554 Connecting IP: WAN IP
Nov 27 15:04:14 localhost postfix/smtp[26678]: 2015113492: host gmail-smtp-in.l.google.com[74.125.129.27] said: 450-4.2.1 The user you are trying to contact is receiving mail at a rate that 450-4.2.1 prevents additional messages from being delivered. Please resend your 450-4.2.1 message at a later time. If the user is able to receive mail at that 450-4.2.1 time, your message will be delivered. For more information, please 450 4.2.1 visit http://support.google.com/mail/bin/answer.py?answer=6592 n5si32680877pav.69 - gsmtp (in reply to RCPT TO command)
Nov 27 15:04:14 localhost postfix/smtp[26675]: connect to alt1.gmail-smtp-in.l.google.com[2607:f8b0:4002:c01::1a]:25: Network is unreachable
Nov 27 15:04:14 localhost postfix/smtp[26679]: AAFE613485: host gmail-smtp-in.l.google.com[74.125.129.27] said: 450-4.2.1 The user you are trying to contact is receiving mail at a rate that 450-4.2.1 prevents additional messages from being delivered. Please resend your 450-4.2.1 message at a later time. If the user is able to receive mail at that 450-4.2.1 time, your message will be delivered. For more information, please 450 4.2.1 visit http://support.google.com/mail/bin/answer.py?answer=6592 tr4si4298736pab.92 - gsmtp (in reply to RCPT TO command)
Nov 27 15:04:14 localhost postfix/smtp[26670]: connect to alt1.gmail-smtp-in.l.google.com[2607:f8b0:4002:c01::1a]:25: Network is unreachable
Nov 27 15:04:14 localhost postfix/smtp[26678]: connect to alt1.gmail-smtp-in.l.google.com[2607:f8b0:4002:c01::1a]:25: Network is unreachable
Nov 27 15:04:14 localhost postfix/smtp[26196]: 3F8CCFE45: host mailin-04.mx.aol.com[64.12.91.196] refused to talk to me: 554 5.7.1 : (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html
Nov 27 15:04:14 localhost postfix/smtp[26679]: connect to alt1.gmail-smtp-in.l.google.com[2607:f8b0:4002:c01::1a]:25: Network is unreachable
Nov 27 15:04:14 localhost postfix/smtp[26681]: connect to ymail.net[222.231.2.126]:25: Connection refused
Nov 27 15:04:14 localhost postfix/smtp[26681]: 4F24410337: to=<velesyandextay@ymail.net>, relay=none, delay=346806, delays=346803/1.4/1.1/0, dsn=4.4.1, status=deferred (connect to ymail.net[222.231.2.126]:25: Connection refused)
Nov 27 15:04:14 localhost postfix/smtp[26677]: 2A797134B1: host gmail-smtp-in.l.google.com[74.125.129.27] said: 450-4.2.1 The user you are trying to contact is receiving mail too quickly. 450-4.2.1 Please resend your message at a later time. If the user is able to 450-4.2.1 receive mail at that time, your message will be delivered. For more 450-4.2.1 information, please visit 450 4.2.1 http://support.google.com/mail/bin/answer.py?answer=6592 bt3si10901726pbb.224 - gsmtp (in reply to RCPT TO command)
Nov 27 15:04:14 localhost postfix/smtp[26674]: 755CF12726: host mailin-03.mx.aol.com[64.12.88.163] refused to talk to me: 554 5.7.1 : (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html
Nov 27 15:04:15 localhost postfix/smtp[26677]: connect to alt1.gmail-smtp-in.l.google.com[2607:f8b0:4002:c01::1a]:25: Network is unreachable
Nov 27 15:04:15 localhost postfix/smtp[26673]: CD7731349C: host mailin-03.mx.aol.com[205.188.156.193] refused to talk to me: 554- (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html 554 Connecting IP: WAN IP
ov 27 15:04:15 localhost postfix/smtp[26672]: C663C1346C: host mailin-04.mx.aol.com[64.12.88.131] refused to talk to me: 554 5.7.1 : (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html
Nov 27 15:04:15 localhost postfix/smtp[26669]: 3D16410331: host mailin-01.mx.aol.com[205.188.159.42] refused to talk to me: 554- (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html 554 Connecting IP: WAN IP
Nov 27 15:04:15 localhost postfix/smtp[26674]: 755CF12726: host mailin-02.mx.aol.com[64.12.88.163] refused to talk to me: 554 5.7.1 : (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html
Nov 27 15:04:15 localhost postfix/smtp[26680]: 551F3FE32: host mx00.gmx.com[74.208.5.4] refused to talk to me: 554-gmx.net (mxgmxus003) Nemesis ESMTP Service not available 554-No SMTP service 554-IP address is black listed. 554 For explanation visit http://postmaster.gmx.com/en/error-messages?ip=WAN IP&c=bl
Nov 27 15:04:15 localhost postfix/smtp[26196]: 3F8CCFE45: host mailin-02.mx.aol.com[64.12.137.162] refused to talk to me: 554- (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html 554 Connecting IP: WAN IP
Nov 27 15:04:16 localhost postfix/smtp[26678]: 2015113492: to=<s.h2.6.4.8.z.he6.58j.x.d123.h.q@gmail.com>, relay=alt1.gmail-smtp-in.l.google.com[74.125.142.27]:25, delay=17208, delays=17204/1/2/0.53, dsn=4.2.1, status=deferred (host alt1.gmail-smtp-in.l.google.com[74.125.142.27] said: 450-4.2.1 The user you are trying to contact is receiving mail at a rate that 450-4.2.1 prevents additional messages from being delivered. Please resend your 450-4.2.1 message at a later time. If the user is able to receive mail at that 450-4.2.1 time, your message will be delivered. For more information, please 450 4.2.1 visit http://support.google.com/mail/bin/answer.py?answer=6592 nr6si25810732igb.49 - gsmtp (in reply to RCPT TO command))
Nov 27 15:04:16 localhost postfix/smtp[26670]: 3609110333: to=<d.u.r.dd.d.dd.d.d.dd@gmail.com>, relay=alt1.gmail-smtp-in.l.google.com[74.125.142.27]:25, delay=194030, delays=194026/0.29/2.9/0.54, dsn=4.2.1, status=deferred (host alt1.gmail-smtp-in.l.google.com[74.125.142.27] said: 450-4.2.1 The user you are trying to contact is receiving mail at a rate that 450-4.2.1 prevents additional messages from being delivered. Please resend your 450-4.2.1 message at a later time. If the user is able to receive mail at that 450-4.2.1 time, your message will be delivered. For more information, please 450 4.2.1 visit http://support.google.com/mail/bin/answer.py?answer=6592 vu5si25813763igc.43 - gsmtp (in reply to RCPT TO command))
Nov 27 15:04:16 localhost postfix/smtp[26673]: CD7731349C: host mailin-01.mx.aol.com[205.188.155.110] refused to talk to me: 554- (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html 554 Connecting IP: WAN IP
Nov 27 15:04:16 localhost postfix/smtp[26672]: C663C1346C: host mailin-02.mx.aol.com[64.12.139.193] refused to talk to me: 554- (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html 554 Connecting IP: WAN IP
Nov 27 15:04:16 localhost postfix/smtp[26679]: AAFE613485: to=<s.h.2648.zh.e.65.8jx.d12.3h.q@gmail.com>, relay=alt1.gmail-smtp-in.l.google.com[74.125.142.27]:25, delay=21514, delays=21510/1.2/2/0.5, dsn=4.2.1, status=deferred (host alt1.gmail-smtp-in.l.google.com[74.125.142.27] said: 450-4.2.1 The user you are trying to contact is receiving mail at a rate that 450-4.2.1 prevents additional messages from being delivered. Please resend your 450-4.2.1 message at a later time. If the user is able to receive mail at that 450-4.2.1 time, your message will be delivered. For more information, please 450 4.2.1 visit http://support.google.com/mail/bin/answer.py?answer=6592 lz8si36365465icc.112 - gsmtp (in reply to RCPT TO command))
Nov 27 15:04:16 localhost postfix/smtp[26669]: 3D16410331: host mailin-02.mx.aol.com[64.12.88.164] refused to talk to me: 554 5.7.1 : (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html
Nov 27 15:04:16 localhost postfix/smtp[26675]: 79412134B3: to=<sh.26.48.z.h.e.6.5.8jx.d1.23h.q@gmail.com>, relay=alt1.gmail-smtp-in.l.google.com[74.125.142.27]:25, delay=502, delays=498/0.67/2.4/0.94, dsn=4.2.1, status=deferred (host alt1.gmail-smtp-in.l.google.com[74.125.142.27] said: 450-4.2.1 The user you are trying to contact is receiving mail too quickly. 450-4.2.1 Please resend your message at a later time. If the user is able to 450-4.2.1 receive mail at that time, your message will be delivered. For more 450-4.2.1 information, please visit 450 4.2.1 http://support.google.com/mail/bin/answer.py?answer=6592 d4si25831291igr.0 - gsmtp (in reply to RCPT TO command))
Nov 27 15:04:16 localhost postfix/smtp[26674]: 755CF12726: host mailin-01.mx.aol.com[205.188.159.42] refused to talk to me: 554- (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html 554 Connecting IP: WAN IP
Nov 27 15:04:16 localhost postfix/smtp[26676]: connect to gmail-smtp-in.l.google.com[2607:f8b0:4002:c01::1b]:25: Network is unreachable
Nov 27 15:04:16 localhost postfix/smtp[26673]: CD7731349C: to=<udonthavetobeashell@aol.com>, relay=mailin-03.mx.aol.com[64.12.88.164]:25, delay=88583, delays=88579/0.47/3.8/0, dsn=4.7.1, status=deferred (host mailin-03.mx.aol.com[64.12.88.164] refused to talk to me: 554 5.7.1 : (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html)
Nov 27 15:04:16 localhost postfix/smtp[26677]: 2A797134B1: to=<s.h2648z.h.e6.5.8j.x.d.1.23.h.q@gmail.com>, relay=alt1.gmail-smtp-in.l.google.com[74.125.142.27]:25, delay=1047, delays=1042/0.91/2.5/0.82, dsn=4.2.1, status=deferred (host alt1.gmail-smtp-in.l.google.com[74.125.142.27] said: 450-4.2.1 The user you are trying to contact is receiving mail too quickly. 450-4.2.1 Please resend your message at a later time. If the user is able to 450-4.2.1 receive mail at that time, your message will be delivered. For more 450-4.2.1 information, please visit 450 4.2.1 http://support.google.com/mail/bin/answer.py?answer=6592 q10si25829488ign.5 - gsmtp (in reply to RCPT TO command))
Nov 27 15:04:16 localhost postfix/pickup[25074]: A29F2134B7: uid=502 from=<domain>
Nov 27 15:04:16 localhost postfix/cleanup[26254]: A29F2134B7: message-id=<16855c7911a10a77e8881e8a7691a18c@localhost>
Nov 27 15:04:16 localhost postfix/qmgr[1910]: A29F2134B7: from=<domain@centos.com>, size=1399, nrcpt=1 (queue active)
Nov 27 15:04:16 localhost postfix/smtp[26672]: C663C1346C: to=<ddshre@aol.com>, relay=mailin-04.mx.aol.com[64.12.91.196]:25, delay=339611, delays=339607/0.39/4/0, dsn=4.7.1, status=deferred (host mailin-04.mx.aol.com[64.12.91.196] refused to talk to me: 554 5.7.1 : (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html)
Nov 27 15:04:16 localhost postfix/smtp[26680]: 551F3FE32: to=<tyzba1@mail.com>, relay=mx01.gmx.com[74.208.5.27]:25, delay=252511, delays=252507/1.3/3/0, dsn=4.0.0, status=deferred (host mx01.gmx.com[74.208.5.27] refused to talk to me: 554-gmx.net (mxgmxus001) Nemesis ESMTP Service not available 554-No SMTP service 554-IP address is black listed. 554 For explanation visit http://postmaster.gmx.com/en/error-messages?ip=WAN IP&c=bl)
Nov 27 15:04:16 localhost postfix/smtp[26669]: 3D16410331: to=<jknkd@aol.com>, relay=mailin-02.mx.aol.com[64.12.88.163]:25, delay=182980, delays=182975/0.18/4.4/0, dsn=4.7.1, status=deferred (host mailin-02.mx.aol.com[64.12.88.163] refused to talk to me: 554 5.7.1 : (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html)
Nov 27 15:04:16 localhost postfix/error[26689]: EDE10F834: to=<thoshl960@aol.com>, relay=none, delay=262970, delays=262966/4.5/0/0.01, dsn=4.7.1, status=deferred (delivery temporarily suspended: host mailin-02.mx.aol.com[64.12.88.163] refused to talk to me: 554 5.7.1 : (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html)
Nov 27 15:04:17 localhost postfix/smtp[26674]: 755CF12726: to=<thebestishere555@aol.com>, relay=mailin-02.mx.aol.com[64.12.139.193]:25, delay=344537, delays=344532/0.54/4.3/0, dsn=4.0.0, status=deferred (host mailin-02.mx.aol.com[64.12.139.193] refused to talk to me: 554- (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html 554 Connecting IP: WAN IP)
Nov 27 15:04:17 localhost postfix/smtp[26681]: A29F2134B7: to=<ugaldetpsad@hotmail.com>, relay=mx2.hotmail.com[65.55.37.88]:25, delay=1.3, delays=0.02/0.2/0.87/0.2, dsn=5.0.0, status=bounced (host mx2.hotmail.com[65.55.37.88] said: 550 OU-002 (COL0-MC2-F9) Unfortunately, messages from WAN IP weren't sent. Please contact your Internet service provider since part of their network is on our block list. You can also refer your provider to http://mail.live.com/mail/troubleshooting.aspx#errors. (in reply to MAIL FROM command))
Nov 27 15:04:17 localhost postfix/smtp[26681]: A29F2134B7: lost connection with mx2.hotmail.com[65.55.37.88] while sending RCPT TO
Nov 27 15:04:17 localhost postfix/cleanup[26254]: E6B71134B8: message-id=<20131127050417.E6B71134B8@centos.com>
Nov 27 15:04:17 localhost postfix/qmgr[1910]: E6B71134B8: from=<>, size=3772, nrcpt=1 (queue active)
Nov 27 15:04:17 localhost postfix/bounce[26640]: A29F2134B7: sender non-delivery notification: E6B71134B8
Nov 27 15:04:17 localhost postfix/qmgr[1910]: A29F2134B7: removed
Nov 27 15:04:18 localhost postfix/smtp[26676]: BC18D134AF: host gmail-smtp-in.l.google.com[74.125.129.27] said: 450-4.2.1 The user you are trying to contact is receiving mail too quickly. 450-4.2.1 Please resend your message at a later time. If the user is able to 450-4.2.1 receive mail at that time, your message will be delivered. For more 450-4.2.1 information, please visit 450 4.2.1 http://support.google.com/mail/bin/answer.py?answer=6592 sl10si3627877pab.244 - gsmtp (in reply to RCPT TO command)
Nov 27 15:04:18 localhost postfix/smtp[26676]: connect to alt1.gmail-smtp-in.l.google.com[2607:f8b0:4002:c01::1a]:25: Network is unreachable
Nov 27 15:04:19 localhost postfix/smtp[26676]: BC18D134AF: to=<sh.2.6.48z.he.6.58.jx.d.1.23.hq@gmail.com>, relay=alt1.gmail-smtp-in.l.google.com[74.125.142.27]:25, delay=2116, delays=2109/3.8/2.7/0.83, dsn=4.2.1, status=deferred (host alt1.gmail-smtp-in.l.google.com[74.125.142.27] said: 450-4.2.1 The user you are trying to contact is receiving mail too quickly. 450-4.2.1 Please resend your message at a later time. If the user is able to 450-4.2.1 receive mail at that time, your message will be delivered. For more 450-4.2.1 information, please visit 450 4.2.1 http://support.google.com/mail/bin/answer.py?answer=6592 f7si25805111igg.64 - gsmtp (in reply to RCPT TO command))
Nov 27 15:04:21 localhost postfix/smtp[26196]: 3F8CCFE45: to=<amba@aol.com>, relay=mailin-03.mx.aol.com[149.174.159.98]:25, delay=244428, delays=244419/0.11/9.4/0, dsn=4.7.1, status=deferred (host mailin-03.mx.aol.com[149.174.159.98] refused to talk to me: 554 5.7.1 : (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html)
Nov 27 15:04:50 localhost postfix/local[26258]: 2405E134B6: to=<domain@centos.com>, relay=local, delay=50, delays=0.01/0/0/50, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME)
Nov 27 15:04:50 localhost postfix/qmgr[1910]: 2405E134B6: removed
Nov 27 15:04:59 localhost postfix/local[26514]: E6B71134B8: to=<domain@centos.com>, relay=local, delay=41, delays=0.01/0/0/41, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME)
Nov 27 15:04:59 localhost postfix/qmgr[1910]: E6B71134B8: removed
Nov 27 15:07:38 localhost postfix/scache[26686]: statistics: start interval Nov 27 15:04:16
Nov 27 15:07:38 localhost postfix/scache[26686]: statistics: domain lookup hits=0 miss=1 success=0%
Nov 27 15:07:38 localhost postfix/scache[26686]: statistics: address lookup hits=0 miss=4 success=0%
Nov 27 15:07:38 localhost postfix/scache[26686]: statistics: max simultaneous domains=1 addresses=2 connection=2
Nov 27 15:09:12 localhost postfix/qmgr[1910]: 63B54134A0: from=<domain@centos.com>, size=1419, nrcpt=1 (queue active)
Nov 27 15:09:12 localhost postfix/qmgr[1910]: 9E782134AB: from=<domain@centos.com>, size=1420, nrcpt=1 (queue active)
Nov 27 15:09:12 localhost postfix/qmgr[1910]: EC77A102A6: from=<domain@centos.com>, size=1417, nrcpt=1 (queue active)
Nov 27 15:09:12 localhost postfix/qmgr[1910]: BC94A1349D: from=<domain@centos.com>, size=1377, nrcpt=1 (queue active)
Nov 27 15:09:12 localhost postfix/error[26987]: BC94A1349D: to=<sjojol@aol.com>, relay=none, delay=1106, delays=1106/0.07/0/0.09, dsn=4.7.1, status=deferred (delivery temporarily suspended: host mailin-02.mx.aol.com[64.12.88.163] refused to talk to me: 554 5.7.1 : (RTR:DU) http://postmaster.info.aol.com/errors/554rtrdu.html)
Nov 27 15:09:12 localhost postfix/smtp[26990]: connect to gmail-smtp-in.l.google.com[2607:f8b0:4002:c01::1b]:25: Network is unreachable
Nov 27 15:09:12 localhost postfix/smtp[26988]: connect to gmail-smtp-in.l.google.com[2607:f8b0:4002:c01::1b]:25: Network is unreachable
Nov 27 15:09:12 localhost postfix/smtp[26986]: connect to gmail-smtp-in.l.google.com[2607:f8b0:4002:c01::1b]:25: Network is unreachable
Nov 27 15:09:14 localhost postfix/smtp[26988]: 9E782134AB: host gmail-smtp-in.l.google.com[74.125.129.26] said: 450-4.2.1 The user you are trying to contact is receiving mail too quickly. 450-4.2.1 Please resend your message at a later time. If the user is able to 450-4.2.1 receive mail at that time, your message will be delivered. For more 450-4.2.1 information, please visit 450 4.2.1 http://support.google.com/mail/bin/answer.py?answer=6592 gn4si32632764pbc.321 - gsmtp (in reply to RCPT TO command)
Nov 27 15:09:14 localhost postfix/smtp[26990]: EC77A102A6: host gmail-smtp-in.l.google.com[74.125.129.26] said: 450-4.2.1 The user you are trying to contact is receiving mail too quickly. 450-4.2.1 Please resend your message at a later time. If the user is able to 450-4.2.1 receive mail at that time, your message will be delivered. For more 450-4.2.1 information, please visit 450 4.2.1 http://support.google.com/mail/bin/answer.py?answer=6592 bt3si10909407pbb.314 - gsmtp (in reply to RCPT TO command)
Nov 27 15:09:14 localhost postfix/smtp[26986]: 63B54134A0: host gmail-smtp-in.l.google.com[74.125.129.26] said: 450-4.2.1 The user you are trying to contact is receiving mail too quickly. 450-4.2.1 Please resend your message at a later time. If the user is able to 450-4.2.1 receive mail at that time, your message will be delivered. For more 450-4.2.1 information, please visit 450 4.2.1 http://support.google.com/mail/bin/answer.py?answer=6592 bt3si10912255pbb.284 - gsmtp (in reply to RCPT TO command)
Nov 27 15:09:14 localhost postfix/smtp[26990]: connect to alt1.gmail-smtp-in.l.google.com[2607:f8b0:4002:c01::1b]:25: Network is unreachable
Nov 27 15:09:14 localhost postfix/smtp[26988]: connect to alt1.gmail-smtp-in.l.google.com[2607:f8b0:4002:c01::1b]:25: Network is unreachable
Nov 27 15:09:14 localhost postfix/smtp[26986]: connect to alt1.gmail-smtp-in.l.google.com[2607:f8b0:4002:c01::1b]:25: Network is unreachable
Nov 27 15:09:15 localhost postfix/smtp[26990]: EC77A102A6: to=<s.h26.4.8.zh.e65.8jx.d1.23.h.q@gmail.com>, relay=alt1.gmail-smtp-in.l.google.com[74.125.142.26]:25, delay=23402, delays=23398/0.19/2.7/0.42, dsn=4.2.1, status=deferred (host alt1.gmail-smtp-in.l.google.com[74.125.142.26] said: 450-4.2.1 The user you are trying to contact is receiving mail at a rate that 450-4.2.1 prevents additional messages from being delivered. Please resend your 450-4.2.1 message at a later time. If the user is able to receive mail at that 450-4.2.1 time, your message will be delivered. For more information, please 450 4.2.1 visit http://support.google.com/mail/bin/answer.py?answer=6592 if8si23970897icb.132 - gsmtp (in reply to RCPT TO command))
Nov 27 15:09:15 localhost postfix/smtp[26986]: 63B54134A0: to=<s.h264.8.z.he.6.58.j.x.d.1.23h.q@gmail.com>, relay=alt1.gmail-smtp-in.l.google.com[74.125.142.26]:25, delay=8943, delays=8939/0.11/3.2/0.51, dsn=4.2.1, status=deferred (host alt1.gmail-smtp-in.l.google.com[74.125.142.26] said: 450-4.2.1 The user you are trying to contact is receiving mail at a rate that 450-4.2.1 prevents additional messages from being delivered. Please resend your 450-4.2.1 message at a later time. If the user is able to receive mail at that 450-4.2.1 time, your message will be delivered. For more information, please 450 4.2.1 visit http://support.google.com/mail/bin/answer.py?answer=6592 if8si23971123icb.15 - gsmtp (in reply to RCPT TO command))
Nov 27 15:09:16 localhost postfix/smtp[26988]: 9E782134AB: to=<sh.2.6.48z.h.e.6.5.8.jxd.1.2.3h.q@gmail.com>, relay=alt1.gmail-smtp-in.l.google.com[74.125.142.27]:25, delay=4553, delays=4549/0.14/2.9/0.9, dsn=4.2.1, status=deferred (host alt1.gmail-smtp-in.l.google.com[74.125.142.27] said: 450-4.2.1 The user you are trying to contact is receiving mail too quickly. 450-4.2.1 Please resend your message at a later time. If the user is able to 450-4.2.1 receive mail at that time, your message will be delivered. For more 450-4.2.1 information, please visit 450 4.2.1 http://support.google.com/mail/bin/answer.py?answer=6592 g11si25818989igt.68 - gsmtp (in reply to RCPT TO command))
