Sorry, I tried to switch language back to English but somehow it wouldn’t do it properly so there’s a bit of German in it as well. But I guess you know the usual output and can solve the puzzle.
Installiere Skript
Virtueller Server: verleihnix.club
http://www.magentocommerce.com:80/downloads/assets/1.9.1.0/magento-1.9.1.0.tar.gz gefunden in Cache …
Configuring webserver PHP settings …
… bereits fertig.
Webserver wird neu gestartet … Bitte überprüfen Sie dies ggfs zusätzlich manuell auf einer Unix-Konsole!
… Fertig!
Installiere jetzt Magento Version 1.9.1.0 …
Installation script failed :
<pre>Zend_Db_Statement_Exception Object
[_previous:Zend_Exception:private] =>
[message:protected] => SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry 'AD' for key 'PRIMARY', query was: INSERT INTO `magento_directory_country` (`country_id`,`iso2_code`,`iso3_code`) VALUES (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?)
[string:Exception:private] =>
[code:protected] => 23000
[file:protected] => /home/verleihnix/public_html/lib/Zend/Db/Statement/Pdo.php
[line:protected] => 235
[trace:Exception:private] => Array
[0] => Array
[file] => /home/verleihnix/public_html/lib/Varien/Db/Statement/Pdo/Mysql.php
[line] => 110
[function] => _execute
[class] => Zend_Db_Statement_Pdo
[type] => ->
[args] => Array
[0] => Array
[0] => AD
[1] => AD
[2] => AND
[3] => AE
[4] => AE
[5] => ARE
[6] => AF
[7] => AF
[8] => AFG
[9] => AG
[10] => AG
[11] => ATG
[12] => AI
[13] => AI
[14] => AIA
[15] => AL
[16] => AL
[17] => ALB
[18] => AM
[19] => AM
[20] => ARM
[21] => AN
[22] => AN
[23] => ANT
[24] => AO
[25] => AO
[26] => AGO
[27] => AQ
[28] => AQ
[29] => ATA
[30] => AR
[31] => AR
[32] => ARG
[33] => AS
[34] => AS
[35] => ASM
[36] => AT
[37] => AT
[38] => AUT
[39] => AU
[40] => AU
[41] => AUS
[42] => AW
[43] => AW
[44] => ABW
[45] => AX
[46] => AX
[47] => ALA
[48] => AZ
[49] => AZ
[50] => AZE
[51] => BA
[52] => BA
[53] => BIH
[54] => BB
[55] => BB
[56] => BRB
[57] => BD
[58] => BD
[59] => BGD
[60] => BE
[61] => BE
[62] => BEL
[63] => BF
[64] => BF
[65] => BFA
[66] => BG
[67] => BG
[68] => BGR
[69] => BH
[70] => BH
[71] => BHR
[72] => BI
[73] => BI
[74] => BDI
[75] => BJ
[76] => BJ
[77] => BEN
[78] => BL
[79] => BL
[80] => BLM
[81] => BM
[82] => BM
[83] => BMU
[84] => BN
[85] => BN
[86] => BRN
[87] => BO
[88] => BO
[89] => BOL
[90] => BR
[91] => BR
[92] => BRA
[93] => BS
[94] => BS
[95] => BHS
[96] => BT
[97] => BT
[98] => BTN
[99] => BV
[100] => BV
[101] => BVT
[102] => BW
[103] => BW
[104] => BWA
[105] => BY
[106] => BY
[107] => BLR
[108] => BZ
[109] => BZ
[110] => BLZ
[111] => CA
[112] => CA
[113] => CAN
[114] => CC
[115] => CC
[116] => CCK
[117] => CD
[118] => CD
[119] => COD
[120] => CF
[121] => CF
[122] => CAF
[123] => CG
[124] => CG
[125] => COG
[126] => CH
[127] => CH
[128] => CHE
[129] => CI
[130] => CI
[131] => CIV
[132] => CK
[133] => CK
[134] => COK
[135] => CL
[136] => CL
[137] => CHL
[138] => CM
[139] => CM
[140] => CMR
[141] => CN
[142] => CN
[143] => CHN
[144] => CO
[145] => CO
[146] => COL
[147] => CR
[148] => CR
[149] => CRI
[150] => CU
[151] => CU
[152] => CUB
[153] => CV
[154] => CV
[155] => CPV
[156] => CX
[157] => CX
[158] => CXR
[159] => CY
[160] => CY
[161] => CYP
[162] => CZ
[163] => CZ
[164] => CZE
[165] => DE
[166] => DE
[167] => DEU
[168] => DJ
[169] => DJ
[170] => DJI
[171] => DK
[172] => DK
[173] => DNK
[174] => DM
[175] => DM
[176] => DMA
[177] => DO
[178] => DO
[179] => DOM
[180] => DZ
[181] => DZ
[182] => DZA
[183] => EC
[184] => EC
[185] => ECU
[186] => EE
[187] => EE
[188] => EST
[189] => EG
[190] => EG
[191] => EGY
[192] => EH
[193] => EH
[194] => ESH
[195] => ER
[196] => ER
[197] => ERI
[198] => ES
[199] => ES
[200] => ESP
[201] => ET
[202] => ET
[203] => ETH
[204] => FI
[205] => FI
[206] => FIN
[207] => FJ
[208] => FJ
[209] => FJI
[210] => FK
[211] => FK
[212] => FLK
[213] => FM
[214] => FM
[215] => FSM
[216] => FO
[217] => FO
[218] => FRO
[219] => FR
[220] => FR
[221] => FRA
[222] => GA
[223] => GA
[224] => GAB
[225] => GB
[226] => GB
[227] => GBR
[228] => GD
[229] => GD
[230] => GRD
[231] => GE
[232] => GE
[233] => GEO
[234] => GF
[235] => GF
[236] => GUF
[237] => GG
[238] => GG
[239] => GGY
[240] => GH
[241] => GH
[242] => GHA
[243] => GI
[244] => GI
[245] => GIB
[246] => GL
[247] => GL
[248] => GRL
[249] => GM
[250] => GM
[251] => GMB
[252] => GN
[253] => GN
[254] => GIN
[255] => GP
[256] => GP
[257] => GLP
[258] => GQ
[259] => GQ
[260] => GNQ
[261] => GR
[262] => GR
[263] => GRC
[264] => GS
[265] => GS
[266] => SGS
[267] => GT
[268] => GT
[269] => GTM
[270] => GU
[271] => GU
[272] => GUM
[273] => GW
[274] => GW
[275] => GNB
[276] => GY
[277] => GY
[278] => GUY
[279] => HK
[280] => HK
[281] => HKG
[282] => HM
[283] => HM
[284] => HMD
[285] => HN
[286] => HN
[287] => HND
[288] => HR
[289] => HR
[290] => HRV
[291] => HT
[292] => HT
[293] => HTI
[294] => HU
[295] => HU
[296] => HUN
[297] => ID
[298] => ID
[299] => IDN
[300] => IE
[301] => IE
[302] => IRL
[303] => IL
[304] => IL
[305] => ISR
[306] => IM
[307] => IM
[308] => IMN
[309] => IN
[310] => IN
[311] => IND
[312] => IO
[313] => IO
[314] => IOT
[315] => IQ
[316] => IQ
[317] => IRQ
[318] => IR
[319] => IR
[320] => IRN
[321] => IS
[322] => IS
[323] => ISL
[324] => IT
[325] => IT
[326] => ITA
[327] => JE
[328] => JE
[329] => JEY
[330] => JM
[331] => JM
[332] => JAM
[333] => JO
[334] => JO
[335] => JOR
[336] => JP
[337] => JP
[338] => JPN
[339] => KE
[340] => KE
[341] => KEN
[342] => KG
[343] => KG
[344] => KGZ
[345] => KH
[346] => KH
[347] => KHM
[348] => KI
[349] => KI
[350] => KIR
[351] => KM
[352] => KM
[353] => COM
[354] => KN
[355] => KN
[356] => KNA
[357] => KP
[358] => KP
[359] => PRK
[360] => KR
[361] => KR
[362] => KOR
[363] => KW
[364] => KW
[365] => KWT
[366] => KY
[367] => KY
[368] => CYM
[369] => KZ
[370] => KZ
[371] => KAZ
[372] => LA
[373] => LA
[374] => LAO
[375] => LB
[376] => LB
[377] => LBN
[378] => LC
[379] => LC
[380] => LCA
[381] => LI
[382] => LI
[383] => LIE
[384] => LK
[385] => LK
[386] => LKA
[387] => LR
[388] => LR
[389] => LBR
[390] => LS
[391] => LS
[392] => LSO
[393] => LT
[394] => LT
[395] => LTU
[396] => LU
[397] => LU
[398] => LUX
[399] => LV
[400] => LV
[401] => LVA
[402] => LY
[403] => LY
[404] => LBY
[405] => MA
[406] => MA
[407] => MAR
[408] => MC
[409] => MC
[410] => MCO
[411] => MD
[412] => MD
[413] => MDA
[414] => ME
[415] => ME
[416] => MNE
[417] => MF
[418] => MF
[419] => MAF
[420] => MG
[421] => MG
[422] => MDG
[423] => MH
[424] => MH
[425] => MHL
[426] => MK
[427] => MK
[428] => MKD
[429] => ML
[430] => ML
[431] => MLI
[432] => MM
[433] => MM
[434] => MMR
[435] => MN
[436] => MN
[437] => MNG
[438] => MO
[439] => MO
[440] => MAC
[441] => MP
[442] => MP
[443] => MNP
[444] => MQ
[445] => MQ
[446] => MTQ
[447] => MR
[448] => MR
[449] => MRT
[450] => MS
[451] => MS
[452] => MSR
[453] => MT
[454] => MT
[455] => MLT
[456] => MU
[457] => MU
[458] => MUS
[459] => MV
[460] => MV
[461] => MDV
[462] => MW
[463] => MW
[464] => MWI
[465] => MX
[466] => MX
[467] => MEX
[468] => MY
[469] => MY
[470] => MYS
[471] => MZ
[472] => MZ
[473] => MOZ
[474] => NA
[475] => NA
[476] => NAM
[477] => NC
[478] => NC
[479] => NCL
[480] => NE
[481] => NE
[482] => NER
[483] => NF
[484] => NF
[485] => NFK
[486] => NG
[487] => NG
[488] => NGA
[489] => NI
[490] => NI
[491] => NIC
[492] => NL
[493] => NL
[494] => NLD
[495] => NO
[496] => NO
[497] => NOR
[498] => NP
[499] => NP
[500] => NPL
[501] => NR
[502] => NR
[503] => NRU
[504] => NU
[505] => NU
[506] => NIU
[507] => NZ
[508] => NZ
[509] => NZL
[510] => OM
[511] => OM
[512] => OMN
[513] => PA
[514] => PA
[515] => PAN
[516] => PE
[517] => PE
[518] => PER
[519] => PF
[520] => PF
[521] => PYF
[522] => PG
[523] => PG
[524] => PNG
[525] => PH
[526] => PH
[527] => PHL
[528] => PK
[529] => PK
[530] => PAK
[531] => PL
[532] => PL
[533] => POL
[534] => PM
[535] => PM
[536] => SPM
[537] => PN
[538] => PN
[539] => PCN
[540] => PR
[541] => PR
[542] => PRI
[543] => PS
[544] => PS
[545] => PSE
[546] => PT
[547] => PT
[548] => PRT
[549] => PW
[550] => PW
[551] => PLW
[552] => PY
[553] => PY
[554] => PRY
[555] => QA
[556] => QA
[557] => QAT
[558] => RE
[559] => RE
[560] => REU
[561] => RO
[562] => RO
[563] => ROU
[564] => RS
[565] => RS
[566] => SRB
[567] => RU
[568] => RU
[569] => RUS
[570] => RW
[571] => RW
[572] => RWA
[573] => SA
[574] => SA
[575] => SAU
[576] => SB
[577] => SB
[578] => SLB
[579] => SC
[580] => SC
[581] => SYC
[582] => SD
[583] => SD
[584] => SDN
[585] => SE
[586] => SE
[587] => SWE
[588] => SG
[589] => SG
[590] => SGP
[591] => SH
[592] => SH
[593] => SHN
[594] => SI
[595] => SI
[596] => SVN
[597] => SJ
[598] => SJ
[599] => SJM
[600] => SK
[601] => SK
[602] => SVK
[603] => SL
[604] => SL
[605] => SLE
[606] => SM
[607] => SM
[608] => SMR
[609] => SN
[610] => SN
[611] => SEN
[612] => SO
[613] => SO
[614] => SOM
[615] => SR
[616] => SR
[617] => SUR
[618] => ST
[619] => ST
[620] => STP
[621] => SV
[622] => SV
[623] => SLV
[624] => SY
[625] => SY
[626] => SYR
[627] => SZ
[628] => SZ
[629] => SWZ
[630] => TC
[631] => TC
[632] => TCA
[633] => TD
[634] => TD
[635] => TCD
[636] => TF
[637] => TF
[638] => ATF
[639] => TG
[640] => TG
[641] => TGO
[642] => TH
[643] => TH
[644] => THA
[645] => TJ
[646] => TJ
[647] => TJK
[648] => TK
[649] => TK
[650] => TKL
[651] => TL
[652] => TL
[653] => TLS
[654] => TM
[655] => TM
[656] => TKM
[657] => TN
[658] => TN
[659] => TUN
[660] => TO
[661] => TO
[662] => TON
[663] => TR
[664] => TR
[665] => TUR
[666] => TT
[667] => TT
[668] => TTO
[669] => TV
[670] => TV
[671] => TUV
[672] => TW
[673] => TW
[674] => TWN
[675] => TZ
[676] => TZ
[677] => TZA
[678] => UA
[679] => UA
[680] => UKR
[681] => UG
[682] => UG
[683] => UGA
[684] => UM
[685] => UM
[686] => UMI
[687] => US
[688] => US
[689] => USA
[690] => UY
[691] => UY
[692] => URY
[693] => UZ
[694] => UZ
[695] => UZB
[696] => VA
[697] => VA
[698] => VAT
[699] => VC
[700] => VC
[701] => VCT
[702] => VE
[703] => VE
[704] => VEN
[705] => VG
[706] => VG
[707] => VGB
[708] => VI
[709] => VI
[710] => VIR
[711] => VN
[712] => VN
[713] => VNM
[714] => VU
[715] => VU
[716] => VUT
[717] => WF
[718] => WF
[719] => WLF
[720] => WS
[721] => WS
[722] => WSM
[723] => YE
[724] => YE
[725] => YEM
[726] => YT
[727] => YT
[728] => MYT
[729] => ZA
[730] => ZA
[731] => ZAF
[732] => ZM
[733] => ZM
[734] => ZMB
[735] => ZW
[736] => ZW
[737] => ZWE
[1] => Array
[file] => /home/verleihnix/public_html/app/code/core/Zend/Db/Statement.php
[line] => 291
[class] => Varien_Db_Statement_Pdo_Mysql
[type] => ->
[args] => Array
[0] => Array
[0] => AD
[1] => AD
[2] => AND
[3] => AE
[4] => AE
[5] => ARE
[6] => AF
[7] => AF
[8] => AFG
[9] => AG
[10] => AG
[11] => ATG
[12] => AI
[13] => AI
[14] => AIA
[15] => AL
[16] => AL
[17] => ALB
[18] => AM
[19] => AM
[20] => ARM
[21] => AN
[22] => AN
[23] => ANT
[24] => AO
[25] => AO
[26] => AGO
[27] => AQ
[28] => AQ
[29] => ATA
[30] => AR
[31] => AR
[32] => ARG
[33] => AS
[34] => AS
[35] => ASM
[36] => AT
[37] => AT
[38] => AUT
[39] => AU
[40] => AU
[41] => AUS
[42] => AW
[43] => AW
[44] => ABW
[45] => AX
[46] => AX
[47] => ALA
[48] => AZ
[49] => AZ
[50] => AZE
[51] => BA
[52] => BA
[53] => BIH
[54] => BB
[55] => BB
[56] => BRB
[57] => BD
[58] => BD
[59] => BGD
[60] => BE
[61] => BE
[62] => BEL
[63] => BF
[64] => BF
[65] => BFA
[66] => BG
[67] => BG
[68] => BGR
[69] => BH
[70] => BH
[71] => BHR
[72] => BI
[73] => BI
[74] => BDI
[75] => BJ
[76] => BJ
[77] => BEN
[78] => BL
[79] => BL
[80] => BLM
[81] => BM
[82] => BM
[83] => BMU
[84] => BN
[85] => BN
[86] => BRN
[87] => BO
[88] => BO
[89] => BOL
[90] => BR
[91] => BR
[92] => BRA
[93] => BS
[94] => BS
[95] => BHS
[96] => BT
[97] => BT
[98] => BTN
[99] => BV
[100] => BV
[101] => BVT
[102] => BW
[103] => BW
[104] => BWA
[105] => BY
[106] => BY
[107] => BLR
[108] => BZ
[109] => BZ
[110] => BLZ
[111] => CA
[112] => CA
[113] => CAN
[114] => CC
[115] => CC
[116] => CCK
[117] => CD
[118] => CD
[119] => COD
[120] => CF
[121] => CF
[122] => CAF
[123] => CG
[124] => CG
[125] => COG
[126] => CH
[127] => CH
[128] => CHE
[129] => CI
[130] => CI
[131] => CIV
[132] => CK
[133] => CK
[134] => COK
[135] => CL
[136] => CL
[137] => CHL
[138] => CM
[139] => CM
[140] => CMR
[141] => CN
[142] => CN
[143] => CHN
[144] => CO
[145] => CO
[146] => COL
[147] => CR
[148] => CR
[149] => CRI
[150] => CU
[151] => CU
[152] => CUB
[153] => CV
[154] => CV
[155] => CPV
[156] => CX
[157] => CX
[158] => CXR
[159] => CY
[160] => CY
[161] => CYP
[162] => CZ
[163] => CZ
[164] => CZE
[165] => DE
[166] => DE
[167] => DEU
[168] => DJ
[169] => DJ
[170] => DJI
[171] => DK
[172] => DK
[173] => DNK
[174] => DM
[175] => DM
[176] => DMA
[177] => DO
[178] => DO
[179] => DOM
[180] => DZ
[181] => DZ
[182] => DZA
[183] => EC
[184] => EC
[185] => ECU
[186] => EE
[187] => EE
[188] => EST
[189] => EG
[190] => EG
[191] => EGY
[192] => EH
[193] => EH
[194] => ESH
[195] => ER
[196] => ER
[197] => ERI
[198] => ES
[199] => ES
[200] => ESP
[201] => ET
[202] => ET
[203] => ETH
[204] => FI
[205] => FI
[206] => FIN
[207] => FJ
[208] => FJ
[209] => FJI
[210] => FK
[211] => FK
[212] => FLK
[213] => FM
[214] => FM
[215] => FSM
[216] => FO
[217] => FO
[218] => FRO
[219] => FR
[220] => FR
[221] => FRA
[222] => GA
[223] => GA
[224] => GAB
[225] => GB
[226] => GB
[227] => GBR
[228] => GD
[229] => GD
[230] => GRD
[231] => GE
[232] => GE
[233] => GEO
[234] => GF
[235] => GF
[236] => GUF
[237] => GG
[238] => GG
[239] => GGY
[240] => GH
[241] => GH
[242] => GHA
[243] => GI
[244] => GI
[245] => GIB
[246] => GL
[247] => GL
[248] => GRL
[249] => GM
[250] => GM
[251] => GMB
[252] => GN
[253] => GN
[254] => GIN
[255] => GP
[256] => GP
[257] => GLP
[258] => GQ
[259] => GQ
[260] => GNQ
[261] => GR
[262] => GR
[263] => GRC
[264] => GS
[265] => GS
[266] => SGS
[267] => GT
[268] => GT
[269] => GTM
[270] => GU
[271] => GU
[272] => GUM
[273] => GW
[274] => GW
[275] => GNB
[276] => GY
[277] => GY
[278] => GUY
[279] => HK
[280] => HK
[281] => HKG
[282] => HM
[283] => HM
[284] => HMD
[285] => HN
[286] => HN
[287] => HND
[288] => HR
[289] => HR
[290] => HRV
[291] => HT
[292] => HT
[293] => HTI
[294] => HU
[295] => HU
[296] => HUN
[297] => ID
[298] => ID
[299] => IDN
[300] => IE
[301] => IE
[302] => IRL
[303] => IL
[304] => IL
[305] => ISR
[306] => IM
[307] => IM
[308] => IMN
[309] => IN
[310] => IN
[311] => IND
[312] => IO
[313] => IO
[314] => IOT
[315] => IQ
[316] => IQ
[317] => IRQ
[318] => IR
[319] => IR
[320] => IRN
[321] => IS
[322] => IS
[323] => ISL
[324] => IT
[325] => IT
[326] => ITA
[327] => JE
[328] => JE
[329] => JEY
[330] => JM
[331] => JM
[332] => JAM
[333] => JO
[334] => JO
[335] => JOR
[336] => JP
[337] => JP
[338] => JPN
[339] => KE
[340] => KE
[341] => KEN
[342] => KG
[343] => KG
[344] => KGZ
[345] => KH
[346] => KH
[347] => KHM
[348] => KI
[349] => KI
[350] => KIR
[351] => KM
[352] => KM
[353] => COM
[354] => KN
[355] => KN
[356] => KNA
[357] => KP
[358] => KP
[359] => PRK
[360] => KR
[361] => KR
[362] => KOR
[363] => KW
[364] => KW
[365] => KWT
[366] => KY
[367] => KY
[368] => CYM
[369] => KZ
[370] => KZ
[371] => KAZ
[372] => LA
[373] => LA
[374] => LAO
[375] => LB
[376] => LB
[377] => LBN
[378] => LC
[379] => LC
[380] => LCA
[381] => LI
[382] => LI
[383] => LIE
[384] => LK
[385] => LK
[386] => LKA
[387] => LR
[388] => LR
[389] => LBR
[390] => LS
[391] => LS
[392] => LSO
[393] => LT
[394] => LT
[395] => LTU
[396] => LU
[397] => LU
[398] => LUX
[399] => LV
[400] => LV
[401] => LVA
[402] => LY
[403] => LY
[404] => LBY
[405] => MA
[406] => MA
[407] => MAR
[408] => MC
[409] => MC
[410] => MCO
[411] => MD
[412] => MD
[413] => MDA
[414] => ME
[415] => ME
[416] => MNE
[417] => MF
[418] => MF
[419] => MAF
[420] => MG
[421] => MG
[422] => MDG
[423] => MH
[424] => MH
[425] => MHL
[426] => MK
[427] => MK
[428] => MKD
[429] => ML
[430] => ML
[431] => MLI
[432] => MM
[433] => MM
[434] => MMR
[435] => MN
[436] => MN
[437] => MNG
[438] => MO
[439] => MO
[440] => MAC
[441] => MP
[442] => MP
[443] => MNP
[444] => MQ
[445] => MQ
[446] => MTQ
[447] => MR
[448] => MR
[449] => MRT
[450] => MS
[451] => MS
[452] => MSR
[453] => MT
[454] => MT
[455] => MLT
[456] => MU
[457] => MU
[458] => MUS
[459] => MV
[460] => MV
[461] => MDV
[462] => MW
[463] => MW
[464] => MWI
[465] => MX
[466] => MX
[467] => MEX
[468] => MY
[469] => MY
[470] => MYS
[471] => MZ
[472] => MZ
[473] => MOZ
[474] => NA
[475] => NA
[476] => NAM
[477] => NC
[478] => NC
[479] => NCL
[480] => NE
[481] => NE
[482] => NER
[483] => NF
[484] => NF
[485] => NFK
[486] => NG
[487] => NG
[488] => NGA
[489] => NI
[490] => NI
[491] => NIC
[492] => NL
[493] => NL
[494] => NLD
[495] => NO
[496] => NO
[497] => NOR
[498] => NP
[499] => NP
[500] => NPL
[501] => NR
[502] => NR
[503] => NRU
[504] => NU
[505] => NU
[506] => NIU
[507] => NZ
[508] => NZ
[509] => NZL
[510] => OM
[511] => OM
[512] => OMN
[513] => PA
[514] => PA
[515] => PAN
[516] => PE
[517] => PE
[518] => PER
[519] => PF
[520] => PF
[521] => PYF
[522] => PG
[523] => PG
[524] => PNG
[525] => PH
[526] => PH
[527] => PHL
[528] => PK
[529] => PK
[530] => PAK
[531] => PL
[532] => PL
[533] => POL
[534] => PM
[535] => PM
[536] => SPM
[537] => PN
[538] => PN
[539] => PCN
[540] => PR
[541] => PR
[542] => PRI
[543] => PS
[544] => PS
[545] => PSE
[546] => PT
[547] => PT
[548] => PRT
[549] => PW
[550] => PW
[551] => PLW
[552] => PY
[553] => PY
[554] => PRY
[555] => QA
[556] => QA
[557] => QAT
[558] => RE
[559] => RE
[560] => REU
[561] => RO
[562] => RO
[563] => ROU
[564] => RS
[565] => RS
[566] => SRB
[567] => RU
[568] => RU
[569] => RUS
[570] => RW
[571] => RW
[572] => RWA
[573] => SA
[574] => SA
[575] => SAU
[576] => SB
[577] => SB
[578] => SLB
[579] => SC
[580] => SC
[581] => SYC
[582] => SD
[583] => SD
[584] => SDN
[585] => SE
[586] => SE
[587] => SWE
[588] => SG
[589] => SG
[590] => SGP
[591] => SH
[592] => SH
[593] => SHN
[594] => SI
[595] => SI
[596] => SVN
[597] => SJ
[598] => SJ
[599] => SJM
[600] => SK
[601] => SK
[602] => SVK
[603] => SL
[604] => SL
[605] => SLE
[606] => SM
[607] => SM
[608] => SMR
[609] => SN
[610] => SN
[611] => SEN
[612] => SO
[613] => SO
[614] => SOM
[615] => SR
[616] => SR
[617] => SUR
[618] => ST
[619] => ST
[620] => STP
[621] => SV
[622] => SV
[623] => SLV
[624] => SY
[625] => SY
[626] => SYR
[627] => SZ
[628] => SZ
[629] => SWZ
[630] => TC
[631] => TC
[632] => TCA
[633] => TD
[634] => TD
[635] => TCD
[636] => TF
[637] => TF
[638] => ATF
[639] => TG
[640] => TG
[641] => TGO
[642] => TH
[643] => TH
[644] => THA
[645] => TJ
[646] => TJ
[647] => TJK
[648] => TK
[649] => TK
[650] => TKL
[651] => TL
[652] => TL
[653] => TLS
[654] => TM
[655] => TM
[656] => TKM
[657] => TN
[658] => TN
[659] => TUN
[660] => TO
[661] => TO
[662] => TON
[663] => TR
[664] => TR
[665] => TUR
[666] => TT
[667] => TT
[668] => TTO
[669] => TV
[670] => TV
[671] => TUV
[672] => TW
[673] => TW
[674] => TWN
[675] => TZ
[676] => TZ
[677] => TZA
[678] => UA
[679] => UA
[680] => UKR
[681] => UG
[682] => UG
[683] => UGA
[684] => UM
[685] => UM
[686] => UMI
[687] => US
[688] => US
[689] => USA
[690] => UY
[691] => UY
[692] => URY
[693] => UZ
[694] => UZ
[695] => UZB
[696] => VA
[697] => VA
[698] => VAT
[699] => VC
[700] => VC
[701] => VCT
[702] => VE
[703] => VE
[704] => VEN
[705] => VG
[706] => VG
[707] => VGB
[708] => VI
[709] => VI
[710] => VIR
[711] => VN
[712] => VN
[713] => VNM
[714] => VU
[715] => VU
[716] => VUT
[717] => WF
[718] => WF
[719] => WLF
[720] => WS
[721] => WS
[722] => WSM
[723] => YE
[724] => YE
[725] => YEM
[726] => YT
[727] => YT
[728] => MYT
[729] => ZA
[730] => ZA
[731] => ZAF
[732] => ZM
[733] => ZM
[734] => ZMB
[735] => ZW
[736] => ZW
[737] => ZWE
[2] => Array
[file] => /home/verleihnix/public_html/lib/Zend/Db/Adapter/Abstract.php
[line] => 480
[function] => execute
[type] => ->
[args] => Array
[0] => Array
[0] => AD
[1] => AD
[2] => AND
[3] => AE
[4] => AE
[5] => ARE
[6] => AF
[7] => AF
[8] => AFG
[9] => AG
[10] => AG
[11] => ATG
[12] => AI
[13] => AI
[14] => AIA
[15] => AL
[16] => AL
[17] => ALB
[18] => AM
[19] => AM
[20] => ARM
[21] => AN
[22] => AN
[23] => ANT
[24] => AO
[25] => AO
[26] => AGO
[27] => AQ
[28] => AQ
[29] => ATA
[30] => AR
[31] => AR
[32] => ARG
[33] => AS
[34] => AS
[35] => ASM
[36] => AT
[37] => AT
[38] => AUT
[39] => AU
[40] => AU
[41] => AUS
[42] => AW
[43] => AW
[44] => ABW
[45] => AX
[46] => AX
[47] => ALA
[48] => AZ
[49] => AZ
[50] => AZE
[51] => BA
[52] => BA
[53] => BIH
[54] => BB
[55] => BB
[56] => BRB
[57] => BD
[58] => BD
[59] => BGD
[60] => BE
[61] => BE
[62] => BEL
[63] => BF
[64] => BF
[65] => BFA
[66] => BG
[67] => BG
[68] => BGR
[69] => BH
[70] => BH
[71] => BHR
[72] => BI
[73] => BI
[74] => BDI
[75] => BJ
[76] => BJ
[77] => BEN
[78] => BL
[79] => BL
[80] => BLM
[81] => BM
[82] => BM
[83] => BMU
[84] => BN
[85] => BN
[86] => BRN
[87] => BO
[88] => BO
[89] => BOL
[90] => BR
[91] => BR
[92] => BRA
[93] => BS
[94] => BS
[95] => BHS
[96] => BT
[97] => BT
[98] => BTN
[99] => BV
[100] => BV
[101] => BVT
[102] => BW
[103] => BW
[104] => BWA
[105] => BY
[106] => BY
[107] => BLR
[108] => BZ
[109] => BZ
[110] => BLZ
[111] => CA
[112] => CA
[113] => CAN
[114] => CC
[115] => CC
[116] => CCK
[117] => CD
[118] => CD
[119] => COD
[120] => CF
[121] => CF
[122] => CAF
[123] => CG
[124] => CG
[125] => COG
[126] => CH
[127] => CH
[128] => CHE
[129] => CI
[130] => CI
[131] => CIV
[132] => CK
[133] => CK
[134] => COK
[135] => CL
[136] => CL
[137] => CHL
[138] => CM
[139] => CM
[140] => CMR
[141] => CN
[142] => CN
[143] => CHN
[144] => CO
[145] => CO
[146] => COL
[147] => CR
[148] => CR
[149] => CRI
[150] => CU
[151] => CU
[152] => CUB
[153] => CV
[154] => CV
[155] => CPV
[156] => CX
[157] => CX
[158] => CXR
[159] => CY
[160] => CY
[161] => CYP
[162] => CZ
[163] => CZ
[164] => CZE
[165] => DE
[166] => DE
[167] => DEU
[168] => DJ
[169] => DJ
[170] => DJI
[171] => DK
[172] => DK
[173] => DNK
[174] => DM
[175] => DM
[176] => DMA
[177] => DO
[178] => DO
[179] => DOM
[180] => DZ
[181] => DZ
[182] => DZA
[183] => EC
[184] => EC
[185] => ECU
[186] => EE
[187] => EE
[188] => EST
[189] => EG
[190] => EG
[191] => EGY
[192] => EH
[193] => EH
[194] => ESH
[195] => ER
[196] => ER
[197] => ERI
[198] => ES
[199] => ES
[200] => ESP
[201] => ET
[202] => ET
[203] => ETH
[204] => FI
[205] => FI
[206] => FIN
[207] => FJ
[208] => FJ
[209] => FJI
[210] => FK
[211] => FK
[212] => FLK
[213] => FM
[214] => FM
[215] => FSM
[216] => FO
[217] => FO
[218] => FRO
[219] => FR
[220] => FR
[221] => FRA
[222] => GA
[223] => GA
[224] => GAB
[225] => GB
[226] => GB
[227] => GBR
[228] => GD
[229] => GD
[230] => GRD
[231] => GE
[232] => GE
[233] => GEO
[234] => GF
[235] => GF
[236] => GUF
[237] => GG
[238] => GG
[239] => GGY
[240] => GH
[241] => GH
[242] => GHA
[243] => GI
[244] => GI
[245] => GIB
[246] => GL
[247] => GL
[248] => GRL
[249] => GM
[250] => GM
[251] => GMB
[252] => GN
[253] => GN
[254] => GIN
[255] => GP
[256] => GP
[257] => GLP
[258] => GQ
[259] => GQ
[260] => GNQ
[261] => GR
[262] => GR
[263] => GRC
[264] => GS
[265] => GS
[266] => SGS
[267] => GT
[268] => GT
[269] => GTM
[270] => GU
[271] => GU
[272] => GUM
[273] => GW
[274] => GW
[275] => GNB
[276] => GY
[277] => GY
[278] => GUY
[279] => HK
[280] => HK
[281] => HKG
[282] => HM
[283] => HM
[284] => HMD
[285] => HN
[286] => HN
[287] => HND
[288] => HR
[289] => HR
[290] => HRV
[291] => HT
[292] => HT
[293] => HTI
[294] => HU
[295] => HU
[296] => HUN
[297] => ID
[298] => ID
[299] => IDN
[300] => IE
[301] => IE
[302] => IRL
[303] => IL
[304] => IL
[305] => ISR
[306] => IM
[307] => IM
[308] => IMN
[309] => IN
[310] => IN
[311] => IND
[312] => IO
[313] => IO
[314] => IOT
[315] => IQ
[316] => IQ
[317] => IRQ
[318] => IR
[319] => IR
[320] => IRN
[321] => IS
[322] => IS
[323] => ISL
[324] => IT
[325] => IT
[326] => ITA
[327] => JE
[328] => JE
[329] => JEY
[330] => JM
[331] => JM
[332] => JAM
[333] => JO
[334] => JO
[335] => JOR
[336] => JP
[337] => JP
[338] => JPN
[339] => KE
[340] => KE
[341] => KEN
[342] => KG
[343] => KG
[344] => KGZ
[345] => KH
[346] => KH
[347] => KHM
[348] => KI
[349] => KI
[350] => KIR
[351] => KM
[352] => KM
[353] => COM
[354] => KN
[355] => KN
[356] => KNA
[357] => KP
[358] => KP
[359] => PRK
[360] => KR
[361] => KR
[362] => KOR
[363] => KW
[364] => KW
[365] => KWT
[366] => KY
[367] => KY
[368] => CYM
[369] => KZ
[370] => KZ
[371] => KAZ
[372] => LA
[373] => LA
[374] => LAO
[375] => LB
[376] => LB
[377] => LBN
[378] => LC
[379] => LC
[380] => LCA
[381] => LI
[382] => LI
[383] => LIE
[384] => LK
[385] => LK
[386] => LKA
[387] => LR
[388] => LR
[389] => LBR
[390] => LS
[391] => LS
[392] => LSO
[393] => LT
[394] => LT
[395] => LTU
[396] => LU
[397] => LU
[398] => LUX
[399] => LV
[400] => LV
[401] => LVA
[402] => LY
[403] => LY
[404] => LBY
[405] => MA
[406] => MA
[407] => MAR
[408] => MC
[409] => MC
[410] => MCO
[411] => MD
[412] => MD
[413] => MDA
[414] => ME
[415] => ME
[416] => MNE
[417] => MF
[418] => MF
[419] => MAF
[420] => MG
[421] => MG
[422] => MDG
[423] => MH
[424] => MH
[425] => MHL
[426] => MK
[427] => MK
[428] => MKD
[429] => ML
[430] => ML
[431] => MLI
[432] => MM
[433] => MM
[434] => MMR
[435] => MN
[436] => MN
[437] => MNG
[438] => MO
[439] => MO
[440] => MAC
[441] => MP
[442] => MP
[443] => MNP
[444] => MQ
[445] => MQ
[446] => MTQ
[447] => MR
[448] => MR
[449] => MRT
[450] => MS
[451] => MS
[452] => MSR
[453] => MT
[454] => MT
[455] => MLT
[456] => MU
[457] => MU
[458] => MUS
[459] => MV
[460] => MV
[461] => MDV
[462] => MW
[463] => MW
[464] => MWI
[465] => MX
[466] => MX
[467] => MEX
[468] => MY
[469] => MY
[470] => MYS
[471] => MZ
[472] => MZ
[473] => MOZ
[474] => NA
[475] => NA
[476] => NAM
[477] => NC
[478] => NC
[479] => NCL
[480] => NE
[481] => NE
[482] => NER
[483] => NF
[484] => NF
[485] => NFK
[486] => NG
[487] => NG
[488] => NGA
[489] => NI
[490] => NI
[491] => NIC
[492] => NL
[493] => NL
[494] => NLD
[495] => NO
[496] => NO
[497] => NOR
[498] => NP
[499] => NP
[500] => NPL
[501] => NR
[502] => NR
[503] => NRU
[504] => NU
[505] => NU
[506] => NIU
[507] => NZ
[508] => NZ
[509] => NZL
[510] => OM
[511] => OM
[512] => OMN
[513] => PA
[514] => PA
[515] => PAN
[516] => PE
[517] => PE
[518] => PER
[519] => PF
[520] => PF
[521] => PYF
[522] => PG
[523] => PG
[524] => PNG
[525] => PH
[526] => PH
[527] => PHL
[528] => PK
[529] => PK
[530] => PAK
[531] => PL
[532] => PL
[533] => POL
[534] => PM
[535] => PM
[536] => SPM
[537] => PN
[538] => PN
[539] => PCN
[540] => PR
[541] => PR
[542] => PRI
[543] => PS
[544] => PS
[545] => PSE
[546] => PT
[547] => PT
[548] => PRT
[549] => PW
[550] => PW
[551] => PLW
[552] => PY
[553] => PY
[554] => PRY
[555] => QA
[556] => QA
[557] => QAT
[558] => RE
[559] => RE
[560] => REU
[561] => RO
[562] => RO
[563] => ROU
[564] => RS
[565] => RS
[566] => SRB
[567] => RU
[568] => RU
[569] => RUS
[570] => RW
[571] => RW
[572] => RWA
[573] => SA
[574] => SA
[575] => SAU
[576] => SB
[577] => SB
[578] => SLB
[579] => SC
[580] => SC
[581] => SYC
[582] => SD
[583] => SD
[584] => SDN
[585] => SE
[586] => SE
[587] => SWE
[588] => SG
[589] => SG
[590] => SGP
[591] => SH
[592] => SH
[593] => SHN
[594] => SI
[595] => SI
[596] => SVN
[597] => SJ
[598] => SJ
[599] => SJM
[600] => SK
[601] => SK
[602] => SVK
[603] => SL
[604] => SL
[605] => SLE
[606] => SM
[607] => SM
[608] => SMR
[609] => SN
[610] => SN
[611] => SEN
[612] => SO
[613] => SO
[614] => SOM
[615] => SR
[616] => SR
[617] => SUR
[618] => ST
[619] => ST
[620] => STP
[621] => SV
[622] => SV
[623] => SLV
[624] => SY
[625] => SY
[626] => SYR
[627] => SZ
[628] => SZ
[629] => SWZ
[630] => TC
[631] => TC
[632] => TCA
[633] => TD
[634] => TD
[635] => TCD
[636] => TF
[637] => TF
[638] => ATF
[639] => TG
[640] => TG
[641] => TGO
[642] => TH
[643] => TH
[644] => THA
[645] => TJ
[646] => TJ
[647] => TJK
[648] => TK
[649] => TK
[650] => TKL
[651] => TL
[652] => TL
[653] => TLS
[654] => TM
[655] => TM
[656] => TKM
[657] => TN
[658] => TN
[659] => TUN
[660] => TO
[661] => TO
[662] => TON
[663] => TR
[664] => TR
[665] => TUR
[666] => TT
[667] => TT
[668] => TTO
[669] => TV
[670] => TV
[671] => TUV
[672] => TW
[673] => TW
[674] => TWN
[675] => TZ
[676] => TZ
[677] => TZA
[678] => UA
[679] => UA
[680] => UKR
[681] => UG
[682] => UG
[683] => UGA
[684] => UM
[685] => UM
[686] => UMI
[687] => US
[688] => US
[689] => USA
[690] => UY
[691] => UY
[692] => URY
[693] => UZ
[694] => UZ
[695] => UZB
[696] => VA
[697] => VA
[698] => VAT
[699] => VC
[700] => VC
[701] => VCT
[702] => VE
[703] => VE
[704] => VEN
[705] => VG
[706] => VG
[707] => VGB
[708] => VI
[709] => VI
[710] => VIR
[711] => VN
[712] => VN
[713] => VNM
[714] => VU
[715] => VU
[716] => VUT
[717] => WF
[718] => WF
[719] => WLF
[720] => WS
[721] => WS
[722] => WSM
[723] => YE
[724] => YE
[725] => YEM
[726] => YT
[727] => YT
[728] => MYT
[729] => ZA
[730] => ZA
[731] => ZAF
[732] => ZM
[733] => ZM
[734] => ZMB
[735] => ZW
[736] => ZW
[737] => ZWE
[3] => Array
[file] => /home/verleihnix/public_html/lib/Zend/Db/Adapter/Pdo/Abstract.php
[line] => 238
[function] => query
[class] => Zend_Db_Adapter_Abstract
[type] => ->
[args] => Array
[0] => INSERT INTO `magento_directory_country` (`country_id`,`iso2_code`,`iso3_code`) VALUES (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?)
[1] => Array
[0] => AD
[1] => AD
[2] => AND
[3] => AE
[4] => AE
[5] => ARE
[6] => AF
[7] => AF
[8] => AFG
[9] => AG
[10] => AG
[11] => ATG
[12] => AI
[13] => AI
[14] => AIA
[15] => AL
[16] => AL
[17] => ALB
[18] => AM
[19] => AM
[20] => ARM
[21] => AN
[22] => AN
[23] => ANT
[24] => AO
[25] => AO
[26] => AGO
[27] => AQ
[28] => AQ
[29] => ATA
[30] => AR
[31] => AR
[32] => ARG
[33] => AS
[34] => AS
[35] => ASM
[36] => AT
[37] => AT
[38] => AUT
[39] => AU
[40] => AU
[41] => AUS
[42] => AW
[43] => AW
[44] => ABW
[45] => AX
[46] => AX
[47] => ALA
[48] => AZ
[49] => AZ
[50] => AZE
[51] => BA
[52] => BA
[53] => BIH
[54] => BB
[55] => BB
[56] => BRB
[57] => BD
[58] => BD
[59] => BGD
[60] => BE
[61] => BE
[62] => BEL
[63] => BF
[64] => BF
[65] => BFA
[66] => BG
[67] => BG
[68] => BGR
[69] => BH
[70] => BH
[71] => BHR
[72] => BI
[73] => BI
[74] => BDI
[75] => BJ
[76] => BJ
[77] => BEN
[78] => BL
[79] => BL
[80] => BLM
[81] => BM
[82] => BM
[83] => BMU
[84] => BN
[85] => BN
[86] => BRN
[87] => BO
[88] => BO
[89] => BOL
[90] => BR
[91] => BR
[92] => BRA
[93] => BS
[94] => BS
[95] => BHS
[96] => BT
[97] => BT
[98] => BTN
[99] => BV
[100] => BV
[101] => BVT
[102] => BW
[103] => BW
[104] => BWA
[105] => BY
[106] => BY
[107] => BLR
[108] => BZ
[109] => BZ
[110] => BLZ
[111] => CA
[112] => CA
[113] => CAN
[114] => CC
[115] => CC
[116] => CCK
[117] => CD
[118] => CD
[119] => COD
[120] => CF
[121] => CF
[122] => CAF
[123] => CG
[124] => CG
[125] => COG
[126] => CH
[127] => CH
[128] => CHE
[129] => CI
[130] => CI
[131] => CIV
[132] => CK
[133] => CK
[134] => COK
[135] => CL
[136] => CL
[137] => CHL
[138] => CM
[139] => CM
[140] => CMR
[141] => CN
[142] => CN
[143] => CHN
[144] => CO
[145] => CO
[146] => COL
[147] => CR
[148] => CR
[149] => CRI
[150] => CU
[151] => CU
[152] => CUB
[153] => CV
[154] => CV
[155] => CPV
[156] => CX
[157] => CX
[158] => CXR
[159] => CY
[160] => CY
[161] => CYP
[162] => CZ
[163] => CZ
[164] => CZE
[165] => DE
[166] => DE
[167] => DEU
[168] => DJ
[169] => DJ
[170] => DJI
[171] => DK
[172] => DK
[173] => DNK
[174] => DM
[175] => DM
[176] => DMA
[177] => DO
[178] => DO
[179] => DOM
[180] => DZ
[181] => DZ
[182] => DZA
[183] => EC
[184] => EC
[185] => ECU
[186] => EE
[187] => EE
[188] => EST
[189] => EG
[190] => EG
[191] => EGY
[192] => EH
[193] => EH
[194] => ESH
[195] => ER
[196] => ER
[197] => ERI
[198] => ES
[199] => ES
[200] => ESP
[201] => ET
[202] => ET
[203] => ETH
[204] => FI
[205] => FI
[206] => FIN
[207] => FJ
[208] => FJ
[209] => FJI
[210] => FK
[211] => FK
[212] => FLK
[213] => FM
[214] => FM
[215] => FSM
[216] => FO
[217] => FO
[218] => FRO
[219] => FR
[220] => FR
[221] => FRA
[222] => GA
[223] => GA
[224] => GAB
[225] => GB
[226] => GB
[227] => GBR
[228] => GD
[229] => GD
[230] => GRD
[231] => GE
[232] => GE
[233] => GEO
[234] => GF
[235] => GF
[236] => GUF
[237] => GG
[238] => GG
[239] => GGY
[240] => GH
[241] => GH
[242] => GHA
[243] => GI
[244] => GI
[245] => GIB
[246] => GL
[247] => GL
[248] => GRL
[249] => GM
[250] => GM
[251] => GMB
[252] => GN
[253] => GN
[254] => GIN
[255] => GP
[256] => GP
[257] => GLP
[258] => GQ
[259] => GQ
[260] => GNQ
[261] => GR
[262] => GR
[263] => GRC
[264] => GS
[265] => GS
[266] => SGS
[267] => GT
[268] => GT
[269] => GTM
[270] => GU
[271] => GU
[272] => GUM
[273] => GW
[274] => GW
[275] => GNB
[276] => GY
[277] => GY
[278] => GUY
[279] => HK
[280] => HK
[281] => HKG
[282] => HM
[283] => HM
[284] => HMD
[285] => HN
[286] => HN
[287] => HND
[288] => HR
[289] => HR
[290] => HRV
[291] => HT
[292] => HT
[293] => HTI
[294] => HU
[295] => HU
[296] => HUN
[297] => ID
[298] => ID
[299] => IDN
[300] => IE
[301] => IE
[302] => IRL
[303] => IL
[304] => IL
[305] => ISR
[306] => IM
[307] => IM
[308] => IMN
[309] => IN
[310] => IN
[311] => IND
[312] => IO
[313] => IO
[314] => IOT
[315] => IQ
[316] => IQ
[317] => IRQ
[318] => IR
[319] => IR
[320] => IRN
[321] => IS
[322] => IS
[323] => ISL
[324] => IT
[325] => IT
[326] => ITA
[327] => JE
[328] => JE
[329] => JEY
[330] => JM
[331] => JM
[332] => JAM
[333] => JO
[334] => JO
[335] => JOR
[336] => JP
[337] => JP
[338] => JPN
[339] => KE
[340] => KE
[341] => KEN
[342] => KG
[343] => KG
[344] => KGZ
[345] => KH
[346] => KH
[347] => KHM
[348] => KI
[349] => KI
[350] => KIR
[351] => KM
[352] => KM
[353] => COM
[354] => KN
[355] => KN
[356] => KNA
[357] => KP
[358] => KP
[359] => PRK
[360] => KR
[361] => KR
[362] => KOR
[363] => KW
[364] => KW
[365] => KWT
[366] => KY
[367] => KY
[368] => CYM
[369] => KZ
[370] => KZ
[371] => KAZ
[372] => LA
[373] => LA
[374] => LAO
[375] => LB
[376] => LB
[377] => LBN
[378] => LC
[379] => LC
[380] => LCA
[381] => LI
[382] => LI
[383] => LIE
[384] => LK
[385] => LK
[386] => LKA
[387] => LR
[388] => LR
[389] => LBR
[390] => LS
[391] => LS
[392] => LSO
[393] => LT
[394] => LT
[395] => LTU
[396] => LU
[397] => LU
[398] => LUX
[399] => LV
[400] => LV
[401] => LVA
[402] => LY
[403] => LY
[404] => LBY
[405] => MA
[406] => MA
[407] => MAR
[408] => MC
[409] => MC
[410] => MCO
[411] => MD
[412] => MD
[413] => MDA
[414] => ME
[415] => ME
[416] => MNE
[417] => MF
[418] => MF
[419] => MAF
[420] => MG
[421] => MG
[422] => MDG
[423] => MH
[424] => MH
[425] => MHL
[426] => MK
[427] => MK
[428] => MKD
[429] => ML
[430] => ML
[431] => MLI
[432] => MM
[433] => MM
[434] => MMR
[435] => MN
[436] => MN
[437] => MNG
[438] => MO
[439] => MO
[440] => MAC
[441] => MP
[442] => MP
[443] => MNP
[444] => MQ
[445] => MQ
[446] => MTQ
[447] => MR
[448] => MR
[449] => MRT
[450] => MS
[451] => MS
[452] => MSR
[453] => MT
[454] => MT
[455] => MLT
[456] => MU
[457] => MU
[458] => MUS
[459] => MV
[460] => MV
[461] => MDV
[462] => MW
[463] => MW
[464] => MWI
[465] => MX
[466] => MX
[467] => MEX
[468] => MY
[469] => MY
[470] => MYS
[471] => MZ
[472] => MZ
[473] => MOZ
[474] => NA
[475] => NA
[476] => NAM
[477] => NC
[478] => NC
[479] => NCL
[480] => NE
[481] => NE
[482] => NER
[483] => NF
[484] => NF
[485] => NFK
[486] => NG
[487] => NG
[488] => NGA
[489] => NI
[490] => NI
[491] => NIC
[492] => NL
[493] => NL
[494] => NLD
[495] => NO
[496] => NO
[497] => NOR
[498] => NP
[499] => NP
[500] => NPL
[501] => NR
[502] => NR
[503] => NRU
[504] => NU
[505] => NU
[506] => NIU
[507] => NZ
[508] => NZ
[509] => NZL
[510] => OM
[511] => OM
[512] => OMN
[513] => PA
[514] => PA
[515] => PAN
[516] => PE
[517] => PE
[518] => PER
[519] => PF
[520] => PF
[521] => PYF
[522] => PG
[523] => PG
[524] => PNG
[525] => PH
[526] => PH
[527] => PHL
[528] => PK
[529] => PK
[530] => PAK
[531] => PL
[532] => PL
[533] => POL
[534] => PM
[535] => PM
[536] => SPM
[537] => PN
[538] => PN
[539] => PCN
[540] => PR
[541] => PR
[542] => PRI
[543] => PS
[544] => PS
[545] => PSE
[546] => PT
[547] => PT
[548] => PRT
[549] => PW
[550] => PW
[551] => PLW
[552] => PY
[553] => PY
[554] => PRY
[555] => QA
[556] => QA
[557] => QAT
[558] => RE
[559] => RE
[560] => REU
[561] => RO
[562] => RO
[563] => ROU
[564] => RS
[565] => RS
[566] => SRB
[567] => RU
[568] => RU
[569] => RUS
[570] => RW
[571] => RW
[572] => RWA
[573] => SA
[574] => SA
[575] => SAU
[576] => SB
[577] => SB
[578] => SLB
[579] => SC
[580] => SC
[581] => SYC
[582] => SD
[583] => SD
[584] => SDN
[585] => SE
[586] => SE
[587] => SWE
[588] => SG
[589] => SG
[590] => SGP
[591] => SH
[592] => SH
[593] => SHN
[594] => SI
[595] => SI
[596] => SVN
[597] => SJ
[598] => SJ
[599] => SJM
[600] => SK
[601] => SK
[602] => SVK
[603] => SL
[604] => SL
[605] => SLE
[606] => SM
[607] => SM
[608] => SMR
[609] => SN
[610] => SN
[611] => SEN
[612] => SO
[613] => SO
[614] => SOM
[615] => SR
[616] => SR
[617] => SUR
[618] => ST
[619] => ST
[620] => STP
[621] => SV
[622] => SV
[623] => SLV
[624] => SY
[625] => SY
[626] => SYR
[627] => SZ
[628] => SZ
[629] => SWZ
[630] => TC
[631] => TC
[632] => TCA
[633] => TD
[634] => TD
[635] => TCD
[636] => TF
[637] => TF
[638] => ATF
[639] => TG
[640] => TG
[641] => TGO
[642] => TH
[643] => TH
[644] => THA
[645] => TJ
[646] => TJ
[647] => TJK
[648] => TK
[649] => TK
[650] => TKL
[651] => TL
[652] => TL
[653] => TLS
[654] => TM
[655] => TM
[656] => TKM
[657] => TN
[658] => TN
[659] => TUN
[660] => TO
[661] => TO
[662] => TON
[663] => TR
[664] => TR
[665] => TUR
[666] => TT
[667] => TT
[668] => TTO
[669] => TV
[670] => TV
[671] => TUV
[672] => TW
[673] => TW
[674] => TWN
[675] => TZ
[676] => TZ
[677] => TZA
[678] => UA
[679] => UA
[680] => UKR
[681] => UG
[682] => UG
[683] => UGA
[684] => UM
[685] => UM
[686] => UMI
[687] => US
[688] => US
[689] => USA
[690] => UY
[691] => UY
[692] => URY
[693] => UZ
[694] => UZ
[695] => UZB
[696] => VA
[697] => VA
[698] => VAT
[699] => VC
[700] => VC
[701] => VCT
[702] => VE
[703] => VE
[704] => VEN
[705] => VG
[706] => VG
[707] => VGB
[708] => VI
[709] => VI
[710] => VIR
[711] => VN
[712] => VN
[713] => VNM
[714] => VU
[715] => VU
[716] => VUT
[717] => WF
[718] => WF
[719] => WLF
[720] => WS
[721] => WS
[722] => WSM
[723] => YE
[724] => YE
[725] => YEM
[726] => YT
[727] => YT
[728] => MYT
[729] => ZA
[730] => ZA
[731] => ZAF
[732] => ZM
[733] => ZM
[734] => ZMB
[735] => ZW
[736] => ZW
[737] => ZWE
[4] => Array
[file] => /home/verleihnix/public_html/lib/Varien/Db/Adapter/Pdo/Mysql.php
[line] => 428
[function] => query
[class] => Zend_Db_Adapter_Pdo_Abstract
[type] => ->
[args] => Array
[1] => Array
[0] => AD
[1] => AD
[2] => AND
[3] => AE
[4] => AE
[5] => ARE
[6] => AF
[7] => AF
[8] => AFG
[9] => AG
[10] => AG
[11] => ATG
[12] => AI
[13] => AI
[14] => AIA
[15] => AL
[16] => AL
[17] => ALB
[18] => AM
[19] => AM
[20] => ARM
[21] => AN
[22] => AN
[23] => ANT
[24] => AO
[25] => AO
[26] => AGO
[27] => AQ
[28] => AQ
[29] => ATA
[30] => AR
[31] => AR
[32] => ARG
[33] => AS
[34] => AS
[35] => ASM
[36] => AT
[37] => AT
[38] => AUT
[39] => AU
[40] => AU
[41] => AUS
[42] => AW
[43] => AW
[44] => ABW
[45] => AX
[46] => AX
[47] => ALA
[48] => AZ
[49] => AZ
[50] => AZE
[51] => BA
[52] => BA
[53] => BIH
[54] => BB
[55] => BB
[56] => BRB
[57] => BD
[58] => BD
[59] => BGD
[60] => BE
[61] => BE
[62] => BEL
[63] => BF
[64] => BF
[65] => BFA
[66] => BG
[67] => BG
[68] => BGR
[69] => BH
[70] => BH
[71] => BHR
[72] => BI
[73] => BI
[74] => BDI
[75] => BJ
[76] => BJ
[77] => BEN
[78] => BL
[79] => BL
[80] => BLM
[81] => BM
[82] => BM
[83] => BMU
[84] => BN
[85] => BN
[86] => BRN
[87] => BO
[88] => BO
[89] => BOL
[90] => BR
[91] => BR
[92] => BRA
[93] => BS
[94] => BS
[95] => BHS
[96] => BT
[97] => BT
[98] => BTN
[99] => BV
[100] => BV
[101] => BVT
[102] => BW
[103] => BW
[104] => BWA
[105] => BY
[106] => BY
[107] => BLR
[108] => BZ
[109] => BZ
[110] => BLZ
[111] => CA
[112] => CA
[113] => CAN
[114] => CC
[115] => CC
[116] => CCK
[117] => CD
[118] => CD
[119] => COD
[120] => CF
[121] => CF
[122] => CAF
[123] => CG
[124] => CG
[125] => COG
[126] => CH
[127] => CH
[128] => CHE
[129] => CI
[130] => CI
[131] => CIV
[132] => CK
[133] => CK
[134] => COK
[135] => CL
[136] => CL
[137] => CHL
[138] => CM
[139] => CM
[140] => CMR
[141] => CN
[142] => CN
[143] => CHN
[144] => CO
[145] => CO
[146] => COL
[147] => CR
[148] => CR
[149] => CRI
[150] => CU
[151] => CU
[152] => CUB
[153] => CV
[154] => CV
[155] => CPV
[156] => CX
[157] => CX
[158] => CXR
[159] => CY
[160] => CY
[161] => CYP
[162] => CZ
[163] => CZ
[164] => CZE
[165] => DE
[166] => DE
[167] => DEU
[168] => DJ
[169] => DJ
[170] => DJI
[171] => DK
[172] => DK
[173] => DNK
[174] => DM
[175] => DM
[176] => DMA
[177] => DO
[178] => DO
[179] => DOM
[180] => DZ
[181] => DZ
[182] => DZA
[183] => EC
[184] => EC
[185] => ECU
[186] => EE
[187] => EE
[188] => EST
[189] => EG
[190] => EG
[191] => EGY
[192] => EH
[193] => EH
[194] => ESH
[195] => ER
[196] => ER
[197] => ERI
[198] => ES
[199] => ES
[200] => ESP
[201] => ET
[202] => ET
[203] => ETH
[204] => FI
[205] => FI
[206] => FIN
[207] => FJ
[208] => FJ
[209] => FJI
[210] => FK
[211] => FK
[212] => FLK
[213] => FM
[214] => FM
[215] => FSM
[216] => FO
[217] => FO
[218] => FRO
[219] => FR
[220] => FR
[221] => FRA
[222] => GA
[223] => GA
[224] => GAB
[225] => GB
[226] => GB
[227] => GBR
[228] => GD
[229] => GD
[230] => GRD
[231] => GE
[232] => GE
[233] => GEO
[234] => GF
[235] => GF
[236] => GUF
[237] => GG
[238] => GG
[239] => GGY
[240] => GH
[241] => GH
[242] => GHA
[243] => GI
[244] => GI
[245] => GIB
[246] => GL
[247] => GL
[248] => GRL
[249] => GM
[250] => GM
[251] => GMB
[252] => GN
[253] => GN
[254] => GIN
[255] => GP
[256] => GP
[257] => GLP
[258] => GQ
[259] => GQ
[260] => GNQ
[261] => GR
[262] => GR
[263] => GRC
[264] => GS
[265] => GS
[266] => SGS
[267] => GT
[268] => GT
[269] => GTM
[270] => GU
[271] => GU
[272] => GUM
[273] => GW
[274] => GW
[275] => GNB
[276] => GY
[277] => GY
[278] => GUY
[279] => HK
[280] => HK
[281] => HKG
[282] => HM
[283] => HM
[284] => HMD
[285] => HN
[286] => HN
[287] => HND
[288] => HR
[289] => HR
[290] => HRV
[291] => HT
[292] => HT
[293] => HTI
[294] => HU
[295] => HU
[296] => HUN
[297] => ID
[298] => ID
[299] => IDN
[300] => IE
[301] => IE
[302] => IRL
[303] => IL
[304] => IL
[305] => ISR
[306] => IM
[307] => IM
[308] => IMN
[309] => IN
[310] => IN
[311] => IND
[312] => IO
[313] => IO
[314] => IOT
[315] => IQ
[316] => IQ
[317] => IRQ
[318] => IR
[319] => IR
[320] => IRN
[321] => IS
[322] => IS
[323] => ISL
[324] => IT
[325] => IT
[326] => ITA
[327] => JE
[328] => JE
[329] => JEY
[330] => JM
[331] => JM
[332] => JAM
[333] => JO
[334] => JO
[335] => JOR
[336] => JP
[337] => JP
[338] => JPN
[339] => KE
[340] => KE
[341] => KEN
[342] => KG
[343] => KG
[344] => KGZ
[345] => KH
[346] => KH
[347] => KHM
[348] => KI
[349] => KI
[350] => KIR
[351] => KM
[352] => KM
[353] => COM
[354] => KN
[355] => KN
[356] => KNA
[357] => KP
[358] => KP
[359] => PRK
[360] => KR
[361] => KR
[362] => KOR
[363] => KW
[364] => KW
[365] => KWT
[366] => KY
[367] => KY
[368] => CYM
[369] => KZ
[370] => KZ
[371] => KAZ
[372] => LA
[373] => LA
[374] => LAO
[375] => LB
[376] => LB
[377] => LBN
[378] => LC
[379] => LC
[380] => LCA
[381] => LI
[382] => LI
[383] => LIE
[384] => LK
[385] => LK
[386] => LKA
[387] => LR
[388] => LR
[389] => LBR
[390] => LS
[391] => LS
[392] => LSO
[393] => LT
[394] => LT
[395] => LTU
[396] => LU
[397] => LU
[398] => LUX
[399] => LV
[400] => LV
[401] => LVA
[402] => LY
[403] => LY
[404] => LBY
[405] => MA
[406] => MA
[407] => MAR
[408] => MC
[409] => MC
[410] => MCO
[411] => MD
[412] => MD
[413] => MDA
[414] => ME
[415] => ME
[416] => MNE
[417] => MF
[418] => MF
[419] => MAF
[420] => MG
[421] => MG
[422] => MDG
[423] => MH
[424] => MH
[425] => MHL
[426] => MK
[427] => MK
[428] => MKD
[429] => ML
[430] => ML
[431] => MLI
[432] => MM
[433] => MM
[434] => MMR
[435] => MN
[436] => MN
[437] => MNG
[438] => MO
[439] => MO
[440] => MAC
[441] => MP
[442] => MP
[443] => MNP
[444] => MQ
[445] => MQ
[446] => MTQ
[447] => MR
[448] => MR
[449] => MRT
[450] => MS
[451] => MS
[452] => MSR
[453] => MT
[454] => MT
[455] => MLT
[456] => MU
[457] => MU
[458] => MUS
[459] => MV
[460] => MV
[461] => MDV
[462] => MW
[463] => MW
[464] => MWI
[465] => MX
[466] => MX
[467] => MEX
[468] => MY
[469] => MY
[470] => MYS
[471] => MZ
[472] => MZ
[473] => MOZ
[474] => NA
[475] => NA
[476] => NAM
[477] => NC
[478] => NC
[479] => NCL
[480] => NE
[481] => NE
[482] => NER
[483] => NF
[484] => NF
[485] => NFK
[486] => NG
[487] => NG
[488] => NGA
[489] => NI
[490] => NI
[491] => NIC
[492] => NL
[493] => NL
[494] => NLD
[495] => NO
[496] => NO
[497] => NOR
[498] => NP
[499] => NP
[500] => NPL
[501] => NR
[502] => NR
[503] => NRU
[504] => NU
[505] => NU
[506] => NIU
[507] => NZ
[508] => NZ
[509] => NZL
[510] => OM
[511] => OM
[512] => OMN
[513] => PA
[514] => PA
[515] => PAN
[516] => PE
[517] => PE
[518] => PER
[519] => PF
[520] => PF
[521] => PYF
[522] => PG
[523] => PG
[524] => PNG
[525] => PH
[526] => PH
[527] => PHL
[528] => PK
[529] => PK
[530] => PAK
[531] => PL
[532] => PL
[533] => POL
[534] => PM
[535] => PM
[536] => SPM
[537] => PN
[538] => PN
[539] => PCN
[540] => PR
[541] => PR
[542] => PRI
[543] => PS
[544] => PS
[545] => PSE
[546] => PT
[547] => PT
[548] => PRT
[549] => PW
[550] => PW
[551] => PLW
[552] => PY
[553] => PY
[554] => PRY
[555] => QA
[556] => QA
[557] => QAT
[558] => RE
[559] => RE
[560] => REU
[561] => RO
[562] => RO
[563] => ROU
[564] => RS
[565] => RS
[566] => SRB
[567] => RU
[568] => RU
[569] => RUS
[570] => RW
[571] => RW
[572] => RWA
[573] => SA
[574] => SA
[575] => SAU
[576] => SB
[577] => SB
[578] => SLB
[579] => SC
[580] => SC
[581] => SYC
[582] => SD
[583] => SD
[584] => SDN
[585] => SE
[586] => SE
[587] => SWE
[588] => SG
[589] => SG
[590] => SGP
[591] => SH
[592] => SH
[593] => SHN
[594] => SI
[595] => SI
[596] => SVN
[597] => SJ
[598] => SJ
[599] => SJM
[600] => SK
[601] => SK
[602] => SVK
[603] => SL
[604] => SL
[605] => SLE
[606] => SM
[607] => SM
[608] => SMR
[609] => SN
[610] => SN
[611] => SEN
[612] => SO
[613] => SO
[614] => SOM
[615] => SR
[616] => SR
[617] => SUR
[618] => ST
[619] => ST
[620] => STP
[621] => SV
[622] => SV
[623] => SLV
[624] => SY
[625] => SY
[626] => SYR
[627] => SZ
[628] => SZ
[629] => SWZ
[630] => TC
[631] => TC
[632] => TCA
[633] => TD
[634] => TD
[635] => TCD
[636] => TF
[637] => TF
[638] => ATF
[639] => TG
[640] => TG
[641] => TGO
[642] => TH
[643] => TH
[644] => THA
[645] => TJ
[646] => TJ
[647] => TJK
[648] => TK
[649] => TK
[650] => TKL
[651] => TL
[652] => TL
[653] => TLS
[654] => TM
[655] => TM
[656] => TKM
[657] => TN
[658] => TN
[659] => TUN
[660] => TO
[661] => TO
[662] => TON
[663] => TR
[664] => TR
[665] => TUR
[666] => TT
[667] => TT
[668] => TTO
[669] => TV
[670] => TV
[671] => TUV
[672] => TW
[673] => TW
[674] => TWN
[675] => TZ
[676] => TZ
[677] => TZA
[678] => UA
[679] => UA
[680] => UKR
[681] => UG
[682] => UG
[683] => UGA
[684] => UM
[685] => UM
[686] => UMI
[687] => US
[688] => US
[689] => USA
[690] => UY
[691] => UY
[692] => URY
[693] => UZ
[694] => UZ
[695] => UZB
[696] => VA
[697] => VA
[698] => VAT
[699] => VC
[700] => VC
[701] => VCT
[702] => VE
[703] => VE
[704] => VEN
[705] => VG
[706] => VG
[707] => VGB
[708] => VI
[709] => VI
[710] => VIR
[711] => VN
[712] => VN
[713] => VNM
[714] => VU
[715] => VU
[716] => VUT
[717] => WF
[718] => WF
[719] => WLF
[720] => WS
[721] => WS
[722] => WSM
[723] => YE
[724] => YE
[725] => YEM
[726] => YT
[727] => YT
[728] => MYT
[729] => ZA
[730] => ZA
[731] => ZAF
[732] => ZM
[733] => ZM
[734] => ZMB
[735] => ZW
[736] => ZW
[737] => ZWE
[5] => Array
[line] => 1998
[function] => query
[class] => Varien_Db_Adapter_Pdo_Mysql
[type] => ->
[args] => Array
[1] => Array
[0] => AD
[1] => AD
[2] => AND
[3] => AE
[4] => AE
[5] => ARE
[6] => AF
[7] => AF
[8] => AFG
[9] => AG
[10] => AG
[11] => ATG
[12] => AI
[13] => AI
[14] => AIA
[15] => AL
[16] => AL
[17] => ALB
[18] => AM
[19] => AM
[20] => ARM
[21] => AN
[22] => AN
[23] => ANT
[24] => AO
[25] => AO
[26] => AGO
[27] => AQ
[28] => AQ
[29] => ATA
[30] => AR
[31] => AR
[32] => ARG
[33] => AS
[34] => AS
[35] => ASM
[36] => AT
[37] => AT
[38] => AUT
[39] => AU
[40] => AU
[41] => AUS
[42] => AW
[43] => AW
[44] => ABW
[45] => AX
[46] => AX
[47] => ALA
[48] => AZ
[49] => AZ
[50] => AZE
[51] => BA
[52] => BA
[53] => BIH
[54] => BB
[55] => BB
[56] => BRB
[57] => BD
[58] => BD
[59] => BGD
[60] => BE
[61] => BE
[62] => BEL
[63] => BF
[64] => BF
[65] => BFA
[66] => BG
[67] => BG
[68] => BGR
[69] => BH
[70] => BH
[71] => BHR
[72] => BI
[73] => BI
[74] => BDI
[75] => BJ
[76] => BJ
[77] => BEN
[78] => BL
[79] => BL
[80] => BLM
[81] => BM
[82] => BM
[83] => BMU
[84] => BN
[85] => BN
[86] => BRN
[87] => BO
[88] => BO
[89] => BOL
[90] => BR
[91] => BR
[92] => BRA
[93] => BS
[94] => BS
[95] => BHS
[96] => BT
[97] => BT
[98] => BTN
[99] => BV
[100] => BV
[101] => BVT
[102] => BW
[103] => BW
[104] => BWA
[105] => BY
[106] => BY
[107] => BLR
[108] => BZ
[109] => BZ
[110] => BLZ
[111] => CA
[112] => CA
[113] => CAN
[114] => CC
[115] => CC
[116] => CCK
[117] => CD
[118] => CD
[119] => COD
[120] => CF
[121] => CF
[122] => CAF
[123] => CG
[124] => CG
[125] => COG
[126] => CH
[127] => CH
[128] => CHE
[129] => CI
[130] => CI
[131] => CIV
[132] => CK
[133] => CK
[134] => COK
[135] => CL
[136] => CL
[137] => CHL
[138] => CM
[139] => CM
[140] => CMR
[141] => CN
[142] => CN
[143] => CHN
[144] => CO
[145] => CO
[146] => COL
[147] => CR
[148] => CR
[149] => CRI
[150] => CU
[151] => CU
[152] => CUB
[153] => CV
[154] => CV
[155] => CPV
[156] => CX
[157] => CX
[158] => CXR
[159] => CY
[160] => CY
[161] => CYP
[162] => CZ
[163] => CZ
[164] => CZE
[165] => DE
[166] => DE
[167] => DEU
[168] => DJ
[169] => DJ
[170] => DJI
[171] => DK
[172] => DK
[173] => DNK
[174] => DM
[175] => DM
[176] => DMA
[177] => DO
[178] => DO
[179] => DOM
[180] => DZ
[181] => DZ
[182] => DZA
[183] => EC
[184] => EC
[185] => ECU
[186] => EE
[187] => EE
[188] => EST
[189] => EG
[190] => EG
[191] => EGY
[192] => EH
[193] => EH
[194] => ESH
[195] => ER
[196] => ER
[197] => ERI
[198] => ES
[199] => ES
[200] => ESP
[201] => ET
[202] => ET
[203] => ETH
[204] => FI
[205] => FI
[206] => FIN
[207] => FJ
[208] => FJ
[209] => FJI
[210] => FK
[211] => FK
[212] => FLK
[213] => FM
[214] => FM
[215] => FSM
[216] => FO
[217] => FO
[218] => FRO
[219] => FR
[220] => FR
[221] => FRA
[222] => GA
[223] => GA
[224] => GAB
[225] => GB
[226] => GB
[227] => GBR
[228] => GD
[229] => GD
[230] => GRD
[231] => GE
[232] => GE
[233] => GEO
[234] => GF
[235] => GF
[236] => GUF
[237] => GG
[238] => GG
[239] => GGY
[240] => GH
[241] => GH
[242] => GHA
[243] => GI
[244] => GI
[245] => GIB
[246] => GL
[247] => GL
[248] => GRL
[249] => GM
[250] => GM
[251] => GMB
[252] => GN
[253] => GN
[254] => GIN
[255] => GP
[256] => GP
[257] => GLP
[258] => GQ
[259] => GQ
[260] => GNQ
[261] => GR
[262] => GR
[263] => GRC
[264] => GS
[265] => GS
[266] => SGS
[267] => GT
[268] => GT
[269] => GTM
[270] => GU
[271] => GU
[272] => GUM
[273] => GW
[274] => GW
[275] => GNB
[276] => GY
[277] => GY
[278] => GUY
[279] => HK
[280] => HK
[281] => HKG
[282] => HM
[283] => HM
[284] => HMD
[285] => HN
[286] => HN
[287] => HND
[288] => HR
[289] => HR
[290] => HRV
[291] => HT
[292] => HT
[293] => HTI
[294] => HU
[295] => HU
[296] => HUN
[297] => ID
[298] => ID
[299] => IDN
[300] => IE
[301] => IE
[302] => IRL
[303] => IL
[304] => IL
[305] => ISR
[306] => IM
[307] => IM
[308] => IMN
[309] => IN
[310] => IN
[311] => IND
[312] => IO
[313] => IO
[314] => IOT
[315] => IQ
[316] => IQ
[317] => IRQ
[318] => IR
[319] => IR
[320] => IRN
[321] => IS
[322] => IS
[323] => ISL
[324] => IT
[325] => IT
[326] => ITA
[327] => JE
[328] => JE
[329] => JEY
[330] => JM
[331] => JM
[332] => JAM
[333] => JO
[334] => JO
[335] => JOR
[336] => JP
[337] => JP
[338] => JPN
[339] => KE
[340] => KE
[341] => KEN
[342] => KG
[343] => KG
[344] => KGZ
[345] => KH
[346] => KH
[347] => KHM
[348] => KI
[349] => KI
[350] => KIR
[351] => KM
[352] => KM
[353] => COM
[354] => KN
[355] => KN
[356] => KNA
[357] => KP
[358] => KP
[359] => PRK
[360] => KR
[361] => KR
[362] => KOR
[363] => KW
[364] => KW
[365] => KWT
[366] => KY
[367] => KY
[368] => CYM
[369] => KZ
[370] => KZ
[371] => KAZ
[372] => LA
[373] => LA
[374] => LAO
[375] => LB
[376] => LB
[377] => LBN
[378] => LC
[379] => LC
[380] => LCA
[381] => LI
[382] => LI
[383] => LIE
[384] => LK
[385] => LK
[386] => LKA
[387] => LR
[388] => LR
[389] => LBR
[390] => LS
[391] => LS
[392] => LSO
[393] => LT
[394] => LT
[395] => LTU
[396] => LU
[397] => LU
[398] => LUX
[399] => LV
[400] => LV
[401] => LVA
[402] => LY
[403] => LY
[404] => LBY
[405] => MA
[406] => MA
[407] => MAR
[408] => MC
[409] => MC
[410] => MCO
[411] => MD
[412] => MD
[413] => MDA
[414] => ME
[415] => ME
[416] => MNE
[417] => MF
[418] => MF
[419] => MAF
[420] => MG
[421] => MG
[422] => MDG
[423] => MH
[424] => MH
[425] => MHL
[426] => MK
[427] => MK
[428] => MKD
[429] => ML
[430] => ML
[431] => MLI
[432] => MM
[433] => MM
[434] => MMR
[435] => MN
[436] => MN
[437] => MNG
[438] => MO
[439] => MO
[440] => MAC
[441] => MP
[442] => MP
[443] => MNP
[444] => MQ
[445] => MQ
[446] => MTQ
[447] => MR
[448] => MR
[449] => MRT
[450] => MS
[451] => MS
[452] => MSR
[453] => MT
[454] => MT
[455] => MLT
[456] => MU
[457] => MU
[458] => MUS
[459] => MV
[460] => MV
[461] => MDV
[462] => MW
[463] => MW
[464] => MWI
[465] => MX
[466] => MX
[467] => MEX
[468] => MY
[469] => MY
[470] => MYS
[471] => MZ
[472] => MZ
[473] => MOZ
[474] => NA
[475] => NA
[476] => NAM
[477] => NC
[478] => NC
[479] => NCL
[480] => NE
[481] => NE
[482] => NER
[483] => NF
[484] => NF
[485] => NFK
[486] => NG
[487] => NG
[488] => NGA
[489] => NI
[490] => NI
[491] => NIC
[492] => NL
[493] => NL
[494] => NLD
[495] => NO
[496] => NO
[497] => NOR
[498] => NP
[499] => NP
[500] => NPL
[501] => NR
[502] => NR
[503] => NRU
[504] => NU
[505] => NU
[506] => NIU
[507] => NZ
[508] => NZ
[509] => NZL
[510] => OM
[511] => OM
[512] => OMN
[513] => PA
[514] => PA
[515] => PAN
[516] => PE
[517] => PE
[518] => PER
[519] => PF
[520] => PF
[521] => PYF
[522] => PG
[523] => PG
[524] => PNG
[525] => PH
[526] => PH
[527] => PHL
[528] => PK
[529] => PK
[530] => PAK
[531] => PL
[532] => PL
[533] => POL
[534] => PM
[535] => PM
[536] => SPM
[537] => PN
[538] => PN
[539] => PCN
[540] => PR
[541] => PR
[542] => PRI
[543] => PS
[544] => PS
[545] => PSE
[546] => PT
[547] => PT
[548] => PRT
[549] => PW
[550] => PW
[551] => PLW
[552] => PY
[553] => PY
[554] => PRY
[555] => QA
[556] => QA
[557] => QAT
[558] => RE
[559] => RE
[560] => REU
[561] => RO
[562] => RO
[563] => ROU
[564] => RS
[565] => RS
[566] => SRB
[567] => RU
[568] => RU
[569] => RUS
[570] => RW
[571] => RW
[572] => RWA
[573] => SA
[574] => SA
[575] => SAU
[576] => SB
[577] => SB
[578] => SLB
[579] => SC
[580] => SC
[581] => SYC
[582] => SD
[583] => SD
[584] => SDN
[585] => SE
[586] => SE
[587] => SWE
[588] => SG
[589] => SG
[590] => SGP
[591] => SH
[592] => SH
[593] => SHN
[594] => SI
[595] => SI
[596] => SVN
[597] => SJ
[598] => SJ
[599] => SJM
[600] => SK
[601] => SK
[602] => SVK
[603] => SL
[604] => SL
[605] => SLE
[606] => SM
[607] => SM
[608] => SMR
[609] => SN
[610] => SN
[611] => SEN
[612] => SO
[613] => SO
[614] => SOM
[615] => SR
[616] => SR
[617] => SUR
[618] => ST
[619] => ST
[620] => STP
[621] => SV
[622] => SV
[623] => SLV
[624] => SY
[625] => SY
[626] => SYR
[627] => SZ
[628] => SZ
[629] => SWZ
[630] => TC
[631] => TC
[632] => TCA
[633] => TD
[634] => TD
[635] => TCD
[636] => TF
[637] => TF
[638] => ATF
[639] => TG
[640] => TG
[641] => TGO
[642] => TH
[643] => TH
[644] => THA
[645] => TJ
[646] => TJ
[647] => TJK
[648] => TK
[649] => TK
[650] => TKL
[651] => TL
[652] => TL
[653] => TLS
[654] => TM
[655] => TM
[656] => TKM
[657] => TN
[658] => TN
[659] => TUN
[660] => TO
[661] => TO
[662] => TON
[663] => TR
[664] => TR
[665] => TUR
[666] => TT
[667] => TT
[668] => TTO
[669] => TV
[670] => TV
[671] => TUV
[672] => TW
[673] => TW
[674] => TWN
[675] => TZ
[676] => TZ
[677] => TZA
[678] => UA
[679] => UA
[680] => UKR
[681] => UG
[682] => UG
[683] => UGA
[684] => UM
[685] => UM
[686] => UMI
[687] => US
[688] => US
[689] => USA
[690] => UY
[691] => UY
[692] => URY
[693] => UZ
[694] => UZ
[695] => UZB
[696] => VA
[697] => VA
[698] => VAT
[699] => VC
[700] => VC
[701] => VCT
[702] => VE
[703] => VE
[704] => VEN
[705] => VG
[706] => VG
[707] => VGB
[708] => VI
[709] => VI
[710] => VIR
[711] => VN
[712] => VN
[713] => VNM
[714] => VU
[715] => VU
[716] => VUT
[717] => WF
[718] => WF
[719] => WLF
[720] => WS
[721] => WS
[722] => WSM
[723] => YE
[724] => YE
[725] => YEM
[726] => YT
[727] => YT
[728] => MYT
[729] => ZA
[730] => ZA
[731] => ZAF
[732] => ZM
[733] => ZM
[734] => ZMB
[735] => ZW
[736] => ZW
[737] => ZWE
[6] => Array
[file] => /home/verleihnix/public_html/app/code/core/Mage/Directory/data/directory_setup/data-install-1.6.0.0.php
[line] => 99
[function] => insertArray
[type] => ->
[args] => Array
[0] => magento_directory_country
[1] => Array
[0] => country_id
[1] => iso2_code
[2] => iso3_code
[2] => Array
[0] => Array
[0] => AD
[1] => AD
[2] => AND
[1] => Array
[0] => AE
[1] => AE
[2] => ARE
[2] => Array
[0] => AF
[1] => AF
[2] => AFG
[3] => Array
[0] => AG
[1] => AG
[2] => ATG
[4] => Array
[0] => AI
[1] => AI
[2] => AIA
[5] => Array
[0] => AL
[1] => AL
[2] => ALB
[6] => Array
[0] => AM
[1] => AM
[2] => ARM
[7] => Array
[0] => AN
[1] => AN
[2] => ANT
[8] => Array
[0] => AO
[1] => AO
[2] => AGO
[9] => Array
[0] => AQ
[1] => AQ
[2] => ATA
[10] => Array
[0] => AR
[1] => AR
[2] => ARG
[11] => Array
[0] => AS
[1] => AS
[2] => ASM
[12] => Array
[0] => AT
[1] => AT
[2] => AUT
[13] => Array
[0] => AU
[1] => AU
[2] => AUS
[14] => Array
[0] => AW
[1] => AW
[2] => ABW
[15] => Array
[0] => AX
[1] => AX
[2] => ALA
[16] => Array
[0] => AZ
[1] => AZ
[2] => AZE
[17] => Array
[0] => BA
[1] => BA
[2] => BIH
[18] => Array
[0] => BB
[1] => BB
[2] => BRB
[19] => Array
[0] => BD
[1] => BD
[2] => BGD
[20] => Array
[0] => BE
[1] => BE
[2] => BEL
[21] => Array
[0] => BF
[1] => BF
[2] => BFA
[22] => Array
[0] => BG
[1] => BG
[2] => BGR
[23] => Array
[0] => BH
[1] => BH
[2] => BHR
[24] => Array
[0] => BI
[1] => BI
[2] => BDI
[25] => Array
[0] => BJ
[1] => BJ
[2] => BEN
[26] => Array
[0] => BL
[1] => BL
[2] => BLM
[27] => Array
[0] => BM
[1] => BM
[2] => BMU
[28] => Array
[0] => BN
[1] => BN
[2] => BRN
[29] => Array
[0] => BO
[1] => BO
[2] => BOL
[30] => Array
[0] => BR
[1] => BR
[2] => BRA
[31] => Array
[0] => BS
[1] => BS
[2] => BHS
[32] => Array
[0] => BT
[1] => BT
[2] => BTN
[33] => Array
[0] => BV
[1] => BV
[2] => BVT
[34] => Array
[0] => BW
[1] => BW
[2] => BWA
[35] => Array
[0] => BY
[1] => BY
[2] => BLR
[36] => Array
[0] => BZ
[1] => BZ
[2] => BLZ
[37] => Array
[0] => CA
[1] => CA
[2] => CAN
[38] => Array
[0] => CC
[1] => CC
[2] => CCK
[39] => Array
[0] => CD
[1] => CD
[2] => COD
[40] => Array
[0] => CF
[1] => CF
[2] => CAF
[41] => Array
[0] => CG
[1] => CG
[2] => COG
[42] => Array
[0] => CH
[1] => CH
[2] => CHE
[43] => Array
[0] => CI
[1] => CI
[2] => CIV
[44] => Array
[0] => CK
[1] => CK
[2] => COK
[45] => Array
[0] => CL
[1] => CL
[2] => CHL
[46] => Array
[0] => CM
[1] => CM
[2] => CMR
[47] => Array
[0] => CN
[1] => CN
[2] => CHN
[48] => Array
[0] => CO
[1] => CO
[2] => COL
[49] => Array
[0] => CR
[1] => CR
[2] => CRI
[50] => Array
[0] => CU
[1] => CU
[2] => CUB
[51] => Array
[0] => CV
[1] => CV
[2] => CPV
[52] => Array
[0] => CX
[1] => CX
[2] => CXR
[53] => Array
[0] => CY
[1] => CY
[2] => CYP
[54] => Array
[0] => CZ
[1] => CZ
[2] => CZE
[55] => Array
[0] => DE
[1] => DE
[2] => DEU
[56] => Array
[0] => DJ
[1] => DJ
[2] => DJI
[57] => Array
[0] => DK
[1] => DK
[2] => DNK
[58] => Array
[0] => DM
[1] => DM
[2] => DMA
[59] => Array
[0] => DO
[1] => DO
[2] => DOM
[60] => Array
[0] => DZ
[1] => DZ
[2] => DZA
[61] => Array
[0] => EC
[1] => EC
[2] => ECU
[62] => Array
[0] => EE
[1] => EE
[2] => EST
[63] => Array
[0] => EG
[1] => EG
[2] => EGY
[64] => Array
[0] => EH
[1] => EH
[2] => ESH
[65] => Array
[0] => ER
[1] => ER
[2] => ERI
[66] => Array
[0] => ES
[1] => ES
[2] => ESP
[67] => Array
[0] => ET
[1] => ET
[2] => ETH
[68] => Array
[0] => FI
[1] => FI
[2] => FIN
[69] => Array
[0] => FJ
[1] => FJ
[2] => FJI
[70] => Array
[0] => FK
[1] => FK
[2] => FLK
[71] => Array
[0] => FM
[1] => FM
[2] => FSM
[72] => Array
[0] => FO
[1] => FO
[2] => FRO
[73] => Array
[0] => FR
[1] => FR
[2] => FRA
[74] => Array
[0] => GA
[1] => GA
[2] => GAB
[75] => Array
[0] => GB
[1] => GB
[2] => GBR
[76] => Array
[0] => GD
[1] => GD
[2] => GRD
[77] => Array
[0] => GE
[1] => GE
[2] => GEO
[78] => Array
[0] => GF
[1] => GF
[2] => GUF
[79] => Array
[0] => GG
[1] => GG
[2] => GGY
[80] => Array
[0] => GH
[1] => GH
[2] => GHA
[81] => Array
[0] => GI
[1] => GI
[2] => GIB
[82] => Array
[0] => GL
[1] => GL
[2] => GRL
[83] => Array
[0] => GM
[1] => GM
[2] => GMB
[84] => Array
[0] => GN
[1] => GN
[2] => GIN
[85] => Array
[0] => GP
[1] => GP
[2] => GLP
[86] => Array
[0] => GQ
[1] => GQ
[2] => GNQ
[87] => Array
[0] => GR
[1] => GR
[2] => GRC
[88] => Array
[0] => GS
[1] => GS
[2] => SGS
[89] => Array
[0] => GT
[1] => GT
[2] => GTM
[90] => Array
[0] => GU
[1] => GU
[2] => GUM
[91] => Array
[0] => GW
[1] => GW
[2] => GNB
[92] => Array
[0] => GY
[1] => GY
[2] => GUY
[93] => Array
[0] => HK
[1] => HK
[2] => HKG
[94] => Array
[0] => HM
[1] => HM
[2] => HMD
[95] => Array
[0] => HN
[1] => HN
[2] => HND
[96] => Array
[0] => HR
[1] => HR
[2] => HRV
[97] => Array
[0] => HT
[1] => HT
[2] => HTI
[98] => Array
[0] => HU
[1] => HU
[2] => HUN
[99] => Array
[0] => ID
[1] => ID
[2] => IDN
[100] => Array
[0] => IE
[1] => IE
[2] => IRL
[101] => Array
[0] => IL
[1] => IL
[2] => ISR
[102] => Array
[0] => IM
[1] => IM
[2] => IMN
[103] => Array
[0] => IN
[1] => IN
[2] => IND
[104] => Array
[0] => IO
[1] => IO
[2] => IOT
[105] => Array
[0] => IQ
[1] => IQ
[2] => IRQ
[106] => Array
[0] => IR
[1] => IR
[2] => IRN
[107] => Array
[0] => IS
[1] => IS
[2] => ISL
[108] => Array
[0] => IT
[1] => IT
[2] => ITA
[109] => Array
[0] => JE
[1] => JE
[2] => JEY
[110] => Array
[0] => JM
[1] => JM
[2] => JAM
[111] => Array
[0] => JO
[1] => JO
[2] => JOR
[112] => Array
[0] => JP
[1] => JP
[2] => JPN
[113] => Array
[0] => KE
[1] => KE
[2] => KEN
[114] => Array
[0] => KG
[1] => KG
[2] => KGZ
[115] => Array
[0] => KH
[1] => KH
[2] => KHM
[116] => Array
[0] => KI
[1] => KI
[2] => KIR
[117] => Array
[0] => KM
[1] => KM
[2] => COM
[118] => Array
[0] => KN
[1] => KN
[2] => KNA
[119] => Array
[0] => KP
[1] => KP
[2] => PRK
[120] => Array
[0] => KR
[1] => KR
[2] => KOR
[121] => Array
[0] => KW
[1] => KW
[2] => KWT
[122] => Array
[0] => KY
[1] => KY
[2] => CYM
[123] => Array
[0] => KZ
[1] => KZ
[2] => KAZ
[124] => Array
[0] => LA
[1] => LA
[2] => LAO
[125] => Array
[0] => LB
[1] => LB
[2] => LBN
[126] => Array
[0] => LC
[1] => LC
[2] => LCA
[127] => Array
[0] => LI
[1] => LI
[2] => LIE
[128] => Array
[0] => LK
[1] => LK
[2] => LKA
[129] => Array
[0] => LR
[1] => LR
[2] => LBR
[130] => Array
[0] => LS
[1] => LS
[2] => LSO
[131] => Array
[0] => LT
[1] => LT
[2] => LTU
[132] => Array
[0] => LU
[1] => LU
[2] => LUX
[133] => Array
[0] => LV
[1] => LV
[2] => LVA
[134] => Array
[0] => LY
[1] => LY
[2] => LBY
[135] => Array
[0] => MA
[1] => MA
[2] => MAR
[136] => Array
[0] => MC
[1] => MC
[2] => MCO
[137] => Array
[0] => MD
[1] => MD
[2] => MDA
[138] => Array
[0] => ME
[1] => ME
[2] => MNE
[139] => Array
[0] => MF
[1] => MF
[2] => MAF
[140] => Array
[0] => MG
[1] => MG
[2] => MDG
[141] => Array
[0] => MH
[1] => MH
[2] => MHL
[142] => Array
[0] => MK
[1] => MK
[2] => MKD
[143] => Array
[0] => ML
[1] => ML
[2] => MLI
[144] => Array
[0] => MM
[1] => MM
[2] => MMR
[145] => Array
[0] => MN
[1] => MN
[2] => MNG
[146] => Array
[0] => MO
[1] => MO
[2] => MAC
[147] => Array
[0] => MP
[1] => MP
[2] => MNP
[148] => Array
[0] => MQ
[1] => MQ
[2] => MTQ
[149] => Array
[0] => MR
[1] => MR
[2] => MRT
[150] => Array
[0] => MS
[1] => MS
[2] => MSR
[151] => Array
[0] => MT
[1] => MT
[2] => MLT
[152] => Array
[0] => MU
[1] => MU
[2] => MUS
[153] => Array
[0] => MV
[1] => MV
[2] => MDV
[154] => Array
[0] => MW
[1] => MW
[2] => MWI
[155] => Array
[0] => MX
[1] => MX
[2] => MEX
[156] => Array
[0] => MY
[1] => MY
[2] => MYS
[157] => Array
[0] => MZ
[1] => MZ
[2] => MOZ
[158] => Array
[0] => NA
[1] => NA
[2] => NAM
[159] => Array
[0] => NC
[1] => NC
[2] => NCL
[160] => Array
[0] => NE
[1] => NE
[2] => NER
[161] => Array
[0] => NF
[1] => NF
[2] => NFK
[162] => Array
[0] => NG
[1] => NG
[2] => NGA
[163] => Array
[0] => NI
[1] => NI
[2] => NIC
[164] => Array
[0] => NL
[1] => NL
[2] => NLD
[165] => Array
[0] => NO
[1] => NO
[2] => NOR
[166] => Array
[0] => NP
[1] => NP
[2] => NPL
[167] => Array
[0] => NR
[1] => NR
[2] => NRU
[168] => Array
[0] => NU
[1] => NU
[2] => NIU
[169] => Array
[0] => NZ
[1] => NZ
[2] => NZL
[170] => Array
[0] => OM
[1] => OM
[2] => OMN
[171] => Array
[0] => PA
[1] => PA
[2] => PAN
[172] => Array
[0] => PE
[1] => PE
[2] => PER
[173] => Array
[0] => PF
[1] => PF
[2] => PYF
[174] => Array
[0] => PG
[1] => PG
[2] => PNG
[175] => Array
[0] => PH
[1] => PH
[2] => PHL
[176] => Array
[0] => PK
[1] => PK
[2] => PAK
[177] => Array
[0] => PL
[1] => PL
[2] => POL
[178] => Array
[0] => PM
[1] => PM
[2] => SPM
[179] => Array
[0] => PN
[1] => PN
[2] => PCN
[180] => Array
[0] => PR
[1] => PR
[2] => PRI
[181] => Array
[0] => PS
[1] => PS
[2] => PSE
[182] => Array
[0] => PT
[1] => PT
[2] => PRT
[183] => Array
[0] => PW
[1] => PW
[2] => PLW
[184] => Array
[0] => PY
[1] => PY
[2] => PRY
[185] => Array
[0] => QA
[1] => QA
[2] => QAT
[186] => Array
[0] => RE
[1] => RE
[2] => REU
[187] => Array
[0] => RO
[1] => RO
[2] => ROU
[188] => Array
[0] => RS
[1] => RS
[2] => SRB
[189] => Array
[0] => RU
[1] => RU
[2] => RUS
[190] => Array
[0] => RW
[1] => RW
[2] => RWA
[191] => Array
[0] => SA
[1] => SA
[2] => SAU
[192] => Array
[0] => SB
[1] => SB
[2] => SLB
[193] => Array
[0] => SC
[1] => SC
[2] => SYC
[194] => Array
[0] => SD
[1] => SD
[2] => SDN
[195] => Array
[0] => SE
[1] => SE
[2] => SWE
[196] => Array
[0] => SG
[1] => SG
[2] => SGP
[197] => Array
[0] => SH
[1] => SH
[2] => SHN
[198] => Array
[0] => SI
[1] => SI
[2] => SVN
[199] => Array
[0] => SJ
[1] => SJ
[2] => SJM
[200] => Array
[0] => SK
[1] => SK
[2] => SVK
[201] => Array
[0] => SL
[1] => SL
[2] => SLE
[202] => Array
[0] => SM
[1] => SM
[2] => SMR
[203] => Array
[0] => SN
[1] => SN
[2] => SEN
[204] => Array
[0] => SO
[1] => SO
[2] => SOM
[205] => Array
[0] => SR
[1] => SR
[2] => SUR
[206] => Array
[0] => ST
[1] => ST
[2] => STP
[207] => Array
[0] => SV
[1] => SV
[2] => SLV
[208] => Array
[0] => SY
[1] => SY
[2] => SYR
[209] => Array
[0] => SZ
[1] => SZ
[2] => SWZ
[210] => Array
[0] => TC
[1] => TC
[2] => TCA
[211] => Array
[0] => TD
[1] => TD
[2] => TCD
[212] => Array
[0] => TF
[1] => TF
[2] => ATF
[213] => Array
[0] => TG
[1] => TG
[2] => TGO
[214] => Array
[0] => TH
[1] => TH
[2] => THA
[215] => Array
[0] => TJ
[1] => TJ
[2] => TJK
[216] => Array
[0] => TK
[1] => TK
[2] => TKL
[217] => Array
[0] => TL
[1] => TL
[2] => TLS
[218] => Array
[0] => TM
[1] => TM
[2] => TKM
[219] => Array
[0] => TN
[1] => TN
[2] => TUN
[220] => Array
[0] => TO
[1] => TO
[2] => TON
[221] => Array
[0] => TR
[1] => TR
[2] => TUR
[222] => Array
[0] => TT
[1] => TT
[2] => TTO
[223] => Array
[0] => TV
[1] => TV
[2] => TUV
[224] => Array
[0] => TW
[1] => TW
[2] => TWN
[225] => Array
[0] => TZ
[1] => TZ
[2] => TZA
[226] => Array
[0] => UA
[1] => UA
[2] => UKR
[227] => Array
[0] => UG
[1] => UG
[2] => UGA
[228] => Array
[0] => UM
[1] => UM
[2] => UMI
[229] => Array
[0] => US
[1] => US
[2] => USA
[230] => Array
[0] => UY
[1] => UY
[2] => URY
[231] => Array
[0] => UZ
[1] => UZ
[2] => UZB
[232] => Array
[0] => VA
[1] => VA
[2] => VAT
[233] => Array
[0] => VC
[1] => VC
[2] => VCT
[234] => Array
[0] => VE
[1] => VE
[2] => VEN
[235] => Array
[0] => VG
[1] => VG
[2] => VGB
[236] => Array
[0] => VI
[1] => VI
[2] => VIR
[237] => Array
[0] => VN
[1] => VN
[2] => VNM
[238] => Array
[0] => VU
[1] => VU
[2] => VUT
[239] => Array
[0] => WF
[1] => WF
[2] => WLF
[240] => Array
[0] => WS
[1] => WS
[2] => WSM
[241] => Array
[0] => YE
[1] => YE
[2] => YEM
[242] => Array
[0] => YT
[1] => YT
[2] => MYT
[243] => Array
[0] => ZA
[1] => ZA
[2] => ZAF
[244] => Array
[0] => ZM
[1] => ZM
[2] => ZMB
[245] => Array
[0] => ZW
[1] => ZW
[2] => ZWE
[7] => Array
[file] => /home/verleihnix/public_html/app/code/core/Mage/Core/Model/Resource/Setup.php
[line] => 624
[args] => Array
[0] => /home/verleihnix/public_html/app/code/core/Mage/Directory/data/directory_setup/data-install-1.6.0.0.php
[function] => include
[8] => Array
[line] => 391
[function] => _modifyResourceDb
[class] => Mage_Core_Model_Resource_Setup
[type] => ->
[args] => Array
[0] => data-install
[1] =>
[2] => 1.6.0.2
[9] => Array
[line] => 289
[function] => _installData
[type] => ->
[args] => Array
[0] => 1.6.0.2
[10] => Array
[line] => 269
[function] => applyDataUpdates
[type] => ->
[args] => Array
[11] => Array
[file] => /home/verleihnix/public_html/app/code/core/Mage/Install/Model/Installer/Console.php
[line] => 383
[function] => applyAllDataUpdates
[type] => ::
[args] => Array
[12] => Array
[file] => /home/verleihnix/public_html/install.php
[line] => 136
[function] => install
[class] => Mage_Install_Model_Installer_Console
[type] => ->
[args] => Array
[previous:Exception:private] => PDOException Object
[message:protected] => SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry 'AD' for key 'PRIMARY'
[string:Exception:private] =>
[code:protected] => 23000
[file:protected] => /home/verleihnix/public_html/lib/Zend/Db/Statement/Pdo.php
[line:protected] => 228
[trace:Exception:private] => Array
[0] => Array
[file] => /home/verleihnix/public_html/lib/Zend/Db/Statement/Pdo.php
[line] => 228
[class] => PDOStatement
[type] => ->
[args] => Array
[0] => Array
[0] => AD
[1] => AD
[2] => AND
[3] => AE
[4] => AE
[5] => ARE
[6] => AF
[7] => AF
[8] => AFG
[9] => AG
[10] => AG
[11] => ATG
[12] => AI
[13] => AI
[14] => AIA
[15] => AL
[16] => AL
[17] => ALB
[18] => AM
[19] => AM
[20] => ARM
[21] => AN
[22] => AN
[23] => ANT
[24] => AO
[25] => AO
[26] => AGO
[27] => AQ
[28] => AQ
[29] => ATA
[30] => AR
[31] => AR
[32] => ARG
[33] => AS
[34] => AS
[35] => ASM
[36] => AT
[37] => AT
[38] => AUT
[39] => AU
[40] => AU
[41] => AUS
[42] => AW
[43] => AW
[44] => ABW
[45] => AX
[46] => AX
[47] => ALA
[48] => AZ
[49] => AZ
[50] => AZE
[51] => BA
[52] => BA
[53] => BIH
[54] => BB
[55] => BB
[56] => BRB
[57] => BD
[58] => BD
[59] => BGD
[60] => BE
[61] => BE
[62] => BEL
[63] => BF
[64] => BF
[65] => BFA
[66] => BG
[67] => BG
[68] => BGR
[69] => BH
[70] => BH
[71] => BHR
[72] => BI
[73] => BI
[74] => BDI
[75] => BJ
[76] => BJ
[77] => BEN
[78] => BL
[79] => BL
[80] => BLM
[81] => BM
[82] => BM
[83] => BMU
[84] => BN
[85] => BN
[86] => BRN
[87] => BO
[88] => BO
[89] => BOL
[90] => BR
[91] => BR
[92] => BRA
[93] => BS
[94] => BS
[95] => BHS
[96] => BT
[97] => BT
[98] => BTN
[99] => BV
[100] => BV
[101] => BVT
[102] => BW
[103] => BW
[104] => BWA
[105] => BY
[106] => BY
[107] => BLR
[108] => BZ
[109] => BZ
[110] => BLZ
[111] => CA
[112] => CA
[113] => CAN
[114] => CC
[115] => CC
[116] => CCK
[117] => CD
[118] => CD
[119] => COD
[120] => CF
[121] => CF
[122] => CAF
[123] => CG
[124] => CG
[125] => COG
[126] => CH
[127] => CH
[128] => CHE
[129] => CI
[130] => CI
[131] => CIV
[132] => CK
[133] => CK
[134] => COK
[135] => CL
[136] => CL
[137] => CHL
[138] => CM
[139] => CM
[140] => CMR
[141] => CN
[142] => CN
[143] => CHN
[144] => CO
[145] => CO
[146] => COL
[147] => CR
[148] => CR
[149] => CRI
[150] => CU
[151] => CU
[152] => CUB
[153] => CV
[154] => CV
[155] => CPV
[156] => CX
[157] => CX
[158] => CXR
[159] => CY
[160] => CY
[161] => CYP
[162] => CZ
[163] => CZ
[164] => CZE
[165] => DE
[166] => DE
[167] => DEU
[168] => DJ
[169] => DJ
[170] => DJI
[171] => DK
[172] => DK
[173] => DNK
[174] => DM
[175] => DM
[176] => DMA
[177] => DO
[178] => DO
[179] => DOM
[180] => DZ
[181] => DZ
[182] => DZA
[183] => EC
[184] => EC
[185] => ECU
[186] => EE
[187] => EE
[188] => EST
[189] => EG
[190] => EG
[191] => EGY
[192] => EH
[193] => EH
[194] => ESH
[195] => ER
[196] => ER
[197] => ERI
[198] => ES
[199] => ES
[200] => ESP
[201] => ET
[202] => ET
[203] => ETH
[204] => FI
[205] => FI
[206] => FIN
[207] => FJ
[208] => FJ
[209] => FJI
[210] => FK
[211] => FK
[212] => FLK
[213] => FM
[214] => FM
[215] => FSM
[216] => FO
[217] => FO
[218] => FRO
[219] => FR
[220] => FR
[221] => FRA
[222] => GA
[223] => GA
[224] => GAB
[225] => GB
[226] => GB
[227] => GBR
[228] => GD
[229] => GD
[230] => GRD
[231] => GE
[232] => GE
[233] => GEO
[234] => GF
[235] => GF
[236] => GUF
[237] => GG
[238] => GG
[239] => GGY
[240] => GH
[241] => GH
[242] => GHA
[243] => GI
[244] => GI
[245] => GIB
[246] => GL
[247] => GL
[248] => GRL
[249] => GM
[250] => GM
[251] => GMB
[252] => GN
[253] => GN
[254] => GIN
[255] => GP
[256] => GP
[257] => GLP
[258] => GQ
[259] => GQ
[260] => GNQ
[261] => GR
[262] => GR
[263] => GRC
[264] => GS
[265] => GS
[266] => SGS
[267] => GT
[268] => GT
[269] => GTM
[270] => GU
[271] => GU
[272] => GUM
[273] => GW
[274] => GW
[275] => GNB
[276] => GY
[277] => GY
[278] => GUY
[279] => HK
[280] => HK
[281] => HKG
[282] => HM
[283] => HM
[284] => HMD
[285] => HN
[286] => HN
[287] => HND
[288] => HR
[289] => HR
[290] => HRV
[291] => HT
[292] => HT
[293] => HTI
[294] => HU
[295] => HU
[296] => HUN
[297] => ID
[298] => ID
[299] => IDN
[300] => IE
[301] => IE
[302] => IRL
[303] => IL
[304] => IL
[305] => ISR
[306] => IM
[307] => IM
[308] => IMN
[309] => IN
[310] => IN
[311] => IND
[312] => IO
[313] => IO
[314] => IOT
[315] => IQ
[316] => IQ
[317] => IRQ
[318] => IR
[319] => IR
[320] => IRN
[321] => IS
[322] => IS
[323] => ISL
[324] => IT
[325] => IT
[326] => ITA
[327] => JE
[328] => JE
[329] => JEY
[330] => JM
[331] => JM
[332] => JAM
[333] => JO
[334] => JO
[335] => JOR
[336] => JP
[337] => JP
[338] => JPN
[339] => KE
[340] => KE
[341] => KEN
[342] => KG
[343] => KG
[344] => KGZ
[345] => KH
[346] => KH
[347] => KHM
[348] => KI
[349] => KI
[350] => KIR
[351] => KM
[352] => KM
[353] => COM
[354] => KN
[355] => KN
[356] => KNA
[357] => KP
[358] => KP
[359] => PRK
[360] => KR
[361] => KR
[362] => KOR
[363] => KW
[364] => KW
[365] => KWT
[366] => KY
[367] => KY
[368] => CYM
[369] => KZ
[370] => KZ
[371] => KAZ
[372] => LA
[373] => LA
[374] => LAO
[375] => LB
[376] => LB
[377] => LBN
[378] => LC
[379] => LC
[380] => LCA
[381] => LI
[382] => LI
[383] => LIE
[384] => LK
[385] => LK
[386] => LKA
[387] => LR
[388] => LR
[389] => LBR
[390] => LS
[391] => LS
[392] => LSO
[393] => LT
[394] => LT
[395] => LTU
[396] => LU
[397] => LU
[398] => LUX
[399] => LV
[400] => LV
[401] => LVA
[402] => LY
[403] => LY
[404] => LBY
[405] => MA
[406] => MA
[407] => MAR
[408] => MC
[409] => MC
[410] => MCO
[411] => MD
[412] => MD
[413] => MDA
[414] => ME
[415] => ME
[416] => MNE
[417] => MF
[418] => MF
[419] => MAF
[420] => MG
[421] => MG
[422] => MDG
[423] => MH
[424] => MH
[425] => MHL
[426] => MK
[427] => MK
[428] => MKD
[429] => ML
[430] => ML
[431] => MLI
[432] => MM
[433] => MM
[434] => MMR
[435] => MN
[436] => MN
[437] => MNG
[438] => MO
[439] => MO
[440] => MAC
[441] => MP
[442] => MP
[443] => MNP
[444] => MQ
[445] => MQ
[446] => MTQ
[447] => MR
[448] => MR
[449] => MRT
[450] => MS
[451] => MS
[452] => MSR
[453] => MT
[454] => MT
[455] => MLT
[456] => MU
[457] => MU
[458] => MUS
[459] => MV
[460] => MV
[461] => MDV
[462] => MW
[463] => MW
[464] => MWI
[465] => MX
[466] => MX
[467] => MEX
[468] => MY
[469] => MY
[470] => MYS
[471] => MZ
[472] => MZ
[473] => MOZ
[474] => NA
[475] => NA
[476] => NAM
[477] => NC
[478] => NC
[479] => NCL
[480] => NE
[481] => NE
[482] => NER
[483] => NF
[484] => NF
[485] => NFK
[486] => NG
[487] => NG
[488] => NGA
[489] => NI
[490] => NI
[491] => NIC
[492] => NL
[493] => NL
[494] => NLD
[495] => NO
[496] => NO
[497] => NOR
[498] => NP
[499] => NP
[500] => NPL
[501] => NR
[502] => NR
[503] => NRU
[504] => NU
[505] => NU
[506] => NIU
[507] => NZ
[508] => NZ
[509] => NZL
[510] => OM
[511] => OM
[512] => OMN
[513] => PA
[514] => PA
[515] => PAN
[516] => PE
[517] => PE
[518] => PER
[519] => PF
[520] => PF
[521] => PYF
[522] => PG
[523] => PG
[524] => PNG
[525] => PH
[526] => PH
[527] => PHL
[528] => PK
[529] => PK
[530] => PAK
[531] => PL
[532] => PL
[533] => POL
[534] => PM
[535] => PM
[536] => SPM
[537] => PN
[538] => PN
[539] => PCN
[540] => PR
[541] => PR
[542] => PRI
[543] => PS
[544] => PS
[545] => PSE
[546] => PT
[547] => PT
[548] => PRT
[549] => PW
[550] => PW
[551] => PLW
[552] => PY
[553] => PY
[554] => PRY
[555] => QA
[556] => QA
[557] => QAT
[558] => RE
[559] => RE
[560] => REU
[561] => RO
[562] => RO
[563] => ROU
[564] => RS
[565] => RS
[566] => SRB
[567] => RU
[568] => RU
[569] => RUS
[570] => RW
[571] => RW
[572] => RWA
[573] => SA
[574] => SA
[575] => SAU
[576] => SB
[577] => SB
[578] => SLB
[579] => SC
[580] => SC
[581] => SYC
[582] => SD
[583] => SD
[584] => SDN
[585] => SE
[586] => SE
[587] => SWE
[588] => SG
[589] => SG
[590] => SGP
[591] => SH
[592] => SH
[593] => SHN
[594] => SI
[595] => SI
[596] => SVN
[597] => SJ
[598] => SJ
[599] => SJM
[600] => SK
[601] => SK
[602] => SVK
[603] => SL
[604] => SL
[605] => SLE
[606] => SM
[607] => SM
[608] => SMR
[609] => SN
[610] => SN
[611] => SEN
[612] => SO
[613] => SO
[614] => SOM
[615] => SR
[616] => SR
[617] => SUR
[618] => ST
[619] => ST
[620] => STP
[621] => SV
[622] => SV
[623] => SLV
[624] => SY
[625] => SY
[626] => SYR
[627] => SZ
[628] => SZ
[629] => SWZ
[630] => TC
[631] => TC
[632] => TCA
[633] => TD
[634] => TD
[635] => TCD
[636] => TF
[637] => TF
[638] => ATF
[639] => TG
[640] => TG
[641] => TGO
[642] => TH
[643] => TH
[644] => THA
[645] => TJ
[646] => TJ
[647] => TJK
[648] => TK
[649] => TK
[650] => TKL
[651] => TL
[652] => TL
[653] => TLS
[654] => TM
[655] => TM
[656] => TKM
[657] => TN
[658] => TN
[659] => TUN
[660] => TO
[661] => TO
[662] => TON
[663] => TR
[664] => TR
[665] => TUR
[666] => TT
[667] => TT
[668] => TTO
[669] => TV
[670] => TV
[671] => TUV
[672] => TW
[673] => TW
[674] => TWN
[675] => TZ
[676] => TZ
[677] => TZA
[678] => UA
[679] => UA
[680] => UKR
[681] => UG
[682] => UG
[683] => UGA
[684] => UM
[685] => UM
[686] => UMI
[687] => US
[688] => US
[689] => USA
[690] => UY
[691] => UY
[692] => URY
[693] => UZ
[694] => UZ
[695] => UZB
[696] => VA
[697] => VA
[698] => VAT
[699] => VC
[700] => VC
[701] => VCT
[702] => VE
[703] => VE
[704] => VEN
[705] => VG
[706] => VG
[707] => VGB
[708] => VI
[709] => VI
[710] => VIR
[711] => VN
[712] => VN
[713] => VNM
[714] => VU
[715] => VU
[716] => VUT
[717] => WF
[718] => WF
[719] => WLF
[720] => WS
[721] => WS
[722] => WSM
[723] => YE
[724] => YE
[725] => YEM
[726] => YT
[727] => YT
[728] => MYT
[729] => ZA
[730] => ZA
[731] => ZAF
[732] => ZM
[733] => ZM
[734] => ZMB
[735] => ZW
[736] => ZW
[737] => ZWE
[1] => Array
[file] => /home/verleihnix/public_html/lib/Varien/Db/Statement/Pdo/Mysql.php
[line] => 110
[function] => _execute
[class] => Zend_Db_Statement_Pdo
[type] => ->
[args] => Array
[0] => Array
[0] => AD
[1] => AD
[2] => AND
[3] => AE
[4] => AE
[5] => ARE
[6] => AF
[7] => AF
[8] => AFG
[9] => AG
[10] => AG
[11] => ATG
[12] => AI
[13] => AI
[14] => AIA
[15] => AL
[16] => AL
[17] => ALB
[18] => AM
[19] => AM
[20] => ARM
[21] => AN
[22] => AN
[23] => ANT
[24] => AO
[25] => AO
[26] => AGO
[27] => AQ
[28] => AQ
[29] => ATA
[30] => AR
[31] => AR
[32] => ARG
[33] => AS
[34] => AS
[35] => ASM
[36] => AT
[37] => AT
[38] => AUT
[39] => AU
[40] => AU
[41] => AUS
[42] => AW
[43] => AW
[44] => ABW
[45] => AX
[46] => AX
[47] => ALA
[48] => AZ
[49] => AZ
[50] => AZE
[51] => BA
[52] => BA
[53] => BIH
[54] => BB
[55] => BB
[56] => BRB
[57] => BD
[58] => BD
[59] => BGD
[60] => BE
[61] => BE
[62] => BEL
[63] => BF
[64] => BF
[65] => BFA
[66] => BG
[67] => BG
[68] => BGR
[69] => BH
[70] => BH
[71] => BHR
[72] => BI
[73] => BI
[74] => BDI
[75] => BJ
[76] => BJ
[77] => BEN
[78] => BL
[79] => BL
[80] => BLM
[81] => BM
[82] => BM
[83] => BMU
[84] => BN
[85] => BN
[86] => BRN
[87] => BO
[88] => BO
[89] => BOL
[90] => BR
[91] => BR
[92] => BRA
[93] => BS
[94] => BS
[95] => BHS
[96] => BT
[97] => BT
[98] => BTN
[99] => BV
[100] => BV
[101] => BVT
[102] => BW
[103] => BW
[104] => BWA
[105] => BY
[106] => BY
[107] => BLR
[108] => BZ
[109] => BZ
[110] => BLZ
[111] => CA
[112] => CA
[113] => CAN
[114] => CC
[115] => CC
[116] => CCK
[117] => CD
[118] => CD
[119] => COD
[120] => CF
[121] => CF
[122] => CAF
[123] => CG
[124] => CG
[125] => COG
[126] => CH
[127] => CH
[128] => CHE
[129] => CI
[130] => CI
[131] => CIV
[132] => CK
[133] => CK
[134] => COK
[135] => CL
[136] => CL
[137] => CHL
[138] => CM
[139] => CM
[140] => CMR
[141] => CN
[142] => CN
[143] => CHN
[144] => CO
[145] => CO
[146] => COL
[147] => CR
[148] => CR
[149] => CRI
[150] => CU
[151] => CU
[152] => CUB
[153] => CV
[154] => CV
[155] => CPV
[156] => CX
[157] => CX
[158] => CXR
[159] => CY
[160] => CY
[161] => CYP
[162] => CZ
[163] => CZ
[164] => CZE
[165] => DE
[166] => DE
[167] => DEU
[168] => DJ
[169] => DJ
[170] => DJI
[171] => DK
[172] => DK
[173] => DNK
[174] => DM
[175] => DM
[176] => DMA
[177] => DO
[178] => DO
[179] => DOM
[180] => DZ
[181] => DZ
[182] => DZA
[183] => EC
[184] => EC
[185] => ECU
[186] => EE
[187] => EE
[188] => EST
[189] => EG
[190] => EG
[191] => EGY
[192] => EH
[193] => EH
[194] => ESH
[195] => ER
[196] => ER
[197] => ERI
[198] => ES
[199] => ES
[200] => ESP
[201] => ET
[202] => ET
[203] => ETH
[204] => FI
[205] => FI
[206] => FIN
[207] => FJ
[208] => FJ
[209] => FJI
[210] => FK
[211] => FK
[212] => FLK
[213] => FM
[214] => FM
[215] => FSM
[216] => FO
[217] => FO
[218] => FRO
[219] => FR
[220] => FR
[221] => FRA
[222] => GA
[223] => GA
[224] => GAB
[225] => GB
[226] => GB
[227] => GBR
[228] => GD
[229] => GD
[230] => GRD
[231] => GE
[232] => GE
[233] => GEO
[234] => GF
[235] => GF
[236] => GUF
[237] => GG
[238] => GG
[239] => GGY
[240] => GH
[241] => GH
[242] => GHA
[243] => GI
[244] => GI
[245] => GIB
[246] => GL
[247] => GL
[248] => GRL
[249] => GM
[250] => GM
[251] => GMB
[252] => GN
[253] => GN
[254] => GIN
[255] => GP
[256] => GP
[257] => GLP
[258] => GQ
[259] => GQ
[260] => GNQ
[261] => GR
[262] => GR
[263] => GRC
[264] => GS
[265] => GS
[266] => SGS
[267] => GT
[268] => GT
[269] => GTM
[270] => GU
[271] => GU
[272] => GUM
[273] => GW
[274] => GW
[275] => GNB
[276] => GY
[277] => GY
[278] => GUY
[279] => HK
[280] => HK
[281] => HKG
[282] => HM
[283] => HM
[284] => HMD
[285] => HN
[286] => HN
[287] => HND
[288] => HR
[289] => HR
[290] => HRV
[291] => HT
[292] => HT
[293] => HTI
[294] => HU
[295] => HU
[296] => HUN
[297] => ID
[298] => ID
[299] => IDN
[300] => IE
[301] => IE
[302] => IRL
[303] => IL
[304] => IL
[305] => ISR
[306] => IM
[307] => IM
[308] => IMN
[309] => IN
[310] => IN
[311] => IND
[312] => IO
[313] => IO
[314] => IOT
[315] => IQ
[316] => IQ
[317] => IRQ
[318] => IR
[319] => IR
[320] => IRN
[321] => IS
[322] => IS
[323] => ISL
[324] => IT
[325] => IT
[326] => ITA
[327] => JE
[328] => JE
[329] => JEY
[330] => JM
[331] => JM
[332] => JAM
[333] => JO
[334] => JO
[335] => JOR
[336] => JP
[337] => JP
[338] => JPN
[339] => KE
[340] => KE
[341] => KEN
[342] => KG
[343] => KG
[344] => KGZ
[345] => KH
[346] => KH
[347] => KHM
[348] => KI
[349] => KI
[350] => KIR
[351] => KM
[352] => KM
[353] => COM
[354] => KN
[355] => KN
[356] => KNA
[357] => KP
[358] => KP
[359] => PRK
[360] => KR
[361] => KR
[362] => KOR
[363] => KW
[364] => KW
[365] => KWT
[366] => KY
[367] => KY
[368] => CYM
[369] => KZ
[370] => KZ
[371] => KAZ
[372] => LA
[373] => LA
[374] => LAO
[375] => LB
[376] => LB
[377] => LBN
[378] => LC
[379] => LC
[380] => LCA
[381] => LI
[382] => LI
[383] => LIE
[384] => LK
[385] => LK
[386] => LKA
[387] => LR
[388] => LR
[389] => LBR
[390] => LS
[391] => LS
[392] => LSO
[393] => LT
[394] => LT
[395] => LTU
[396] => LU
[397] => LU
[398] => LUX
[399] => LV
[400] => LV
[401] => LVA
[402] => LY
[403] => LY
[404] => LBY
[405] => MA
[406] => MA
[407] => MAR
[408] => MC
[409] => MC
[410] => MCO
[411] => MD
[412] => MD
[413] => MDA
[414] => ME
[415] => ME
[416] => MNE
[417] => MF
[418] => MF
[419] => MAF
[420] => MG
[421] => MG
[422] => MDG
[423] => MH
[424] => MH
[425] => MHL
[426] => MK
[427] => MK
[428] => MKD
[429] => ML
[430] => ML
[431] => MLI
[432] => MM
[433] => MM
[434] => MMR
[435] => MN
[436] => MN
[437] => MNG
[438] => MO
[439] => MO
[440] => MAC
[441] => MP
[442] => MP
[443] => MNP
[444] => MQ
[445] => MQ
[446] => MTQ
[447] => MR
[448] => MR
[449] => MRT
[450] => MS
[451] => MS
[452] => MSR
[453] => MT
[454] => MT
[455] => MLT
[456] => MU
[457] => MU
[458] => MUS
[459] => MV
[460] => MV
[461] => MDV
[462] => MW
[463] => MW
[464] => MWI
[465] => MX
[466] => MX
[467] => MEX
[468] => MY
[469] => MY
[470] => MYS
[471] => MZ
[472] => MZ
[473] => MOZ
[474] => NA
[475] => NA
[476] => NAM
[477] => NC
[478] => NC
[479] => NCL
[480] => NE
[481] => NE
[482] => NER
[483] => NF
[484] => NF
[485] => NFK
[486] => NG
[487] => NG
[488] => NGA
[489] => NI
[490] => NI
[491] => NIC
[492] => NL
[493] => NL
[494] => NLD
[495] => NO
[496] => NO
[497] => NOR
[498] => NP
[499] => NP
[500] => NPL
[501] => NR
[502] => NR
[503] => NRU
[504] => NU
[505] => NU
[506] => NIU
[507] => NZ
[508] => NZ
[509] => NZL
[510] => OM
[511] => OM
[512] => OMN
[513] => PA
[514] => PA
[515] => PAN
[516] => PE
[517] => PE
[518] => PER
[519] => PF
[520] => PF
[521] => PYF
[522] => PG
[523] => PG
[524] => PNG
[525] => PH
[526] => PH
[527] => PHL
[528] => PK
[529] => PK
[530] => PAK
[531] => PL
[532] => PL
[533] => POL
[534] => PM
[535] => PM
[536] => SPM
[537] => PN
[538] => PN
[539] => PCN
[540] => PR
[541] => PR
[542] => PRI
[543] => PS
[544] => PS
[545] => PSE
[546] => PT
[547] => PT
[548] => PRT
[549] => PW
[550] => PW
[551] => PLW
[552] => PY
[553] => PY
[554] => PRY
[555] => QA
[556] => QA
[557] => QAT
[558] => RE
[559] => RE
[560] => REU
[561] => RO
[562] => RO
[563] => ROU
[564] => RS
[565] => RS
[566] => SRB
[567] => RU
[568] => RU
[569] => RUS
[570] => RW
[571] => RW
[572] => RWA
[573] => SA
[574] => SA
[575] => SAU
[576] => SB
[577] => SB
[578] => SLB
[579] => SC
[580] => SC
[581] => SYC
[582] => SD
[583] => SD
[584] => SDN
[585] => SE
[586] => SE
[587] => SWE
[588] => SG
[589] => SG
[590] => SGP
[591] => SH
[592] => SH
[593] => SHN
[594] => SI
[595] => SI
[596] => SVN
[597] => SJ
[598] => SJ
[599] => SJM
[600] => SK
[601] => SK
[602] => SVK
[603] => SL
[604] => SL
[605] => SLE
[606] => SM
[607] => SM
[608] => SMR
[609] => SN
[610] => SN
[611] => SEN
[612] => SO
[613] => SO
[614] => SOM
[615] => SR
[616] => SR
[617] => SUR
[618] => ST
[619] => ST
[620] => STP
[621] => SV
[622] => SV
[623] => SLV
[624] => SY
[625] => SY
[626] => SYR
[627] => SZ
[628] => SZ
[629] => SWZ
[630] => TC
[631] => TC
[632] => TCA
[633] => TD
[634] => TD
[635] => TCD
[636] => TF
[637] => TF
[638] => ATF
[639] => TG
[640] => TG
[641] => TGO
[642] => TH
[643] => TH
[644] => THA
[645] => TJ
[646] => TJ
[647] => TJK
[648] => TK
[649] => TK
[650] => TKL
[651] => TL
[652] => TL
[653] => TLS
[654] => TM
[655] => TM
[656] => TKM
[657] => TN
[658] => TN
[659] => TUN
[660] => TO
[661] => TO
[662] => TON
[663] => TR
[664] => TR
[665] => TUR
[666] => TT
[667] => TT
[668] => TTO
[669] => TV
[670] => TV
[671] => TUV
[672] => TW
[673] => TW
[674] => TWN
[675] => TZ
[676] => TZ
[677] => TZA
[678] => UA
[679] => UA
[680] => UKR
[681] => UG
[682] => UG
[683] => UGA
[684] => UM
[685] => UM
[686] => UMI
[687] => US
[688] => US
[689] => USA
[690] => UY
[691] => UY
[692] => URY
[693] => UZ
[694] => UZ
[695] => UZB
[696] => VA
[697] => VA
[698] => VAT
[699] => VC
[700] => VC
[701] => VCT
[702] => VE
[703] => VE
[704] => VEN
[705] => VG
[706] => VG
[707] => VGB
[708] => VI
[709] => VI
[710] => VIR
[711] => VN
[712] => VN
[713] => VNM
[714] => VU
[715] => VU
[716] => VUT
[717] => WF
[718] => WF
[719] => WLF
[720] => WS
[721] => WS
[722] => WSM
[723] => YE
[724] => YE
[725] => YEM
[726] => YT
[727] => YT
[728] => MYT
[729] => ZA
[730] => ZA
[731] => ZAF
[732] => ZM
[733] => ZM
[734] => ZMB
[735] => ZW
[736] => ZW
[737] => ZWE
[2] => Array
[file] => /home/verleihnix/public_html/app/code/core/Zend/Db/Statement.php
[line] => 291
[class] => Varien_Db_Statement_Pdo_Mysql
[type] => ->
[args] => Array
[0] => Array
[0] => AD
[1] => AD
[2] => AND
[3] => AE
[4] => AE
[5] => ARE
[6] => AF
[7] => AF
[8] => AFG
[9] => AG
[10] => AG
[11] => ATG
[12] => AI
[13] => AI
[14] => AIA
[15] => AL
[16] => AL
[17] => ALB
[18] => AM
[19] => AM
[20] => ARM
[21] => AN
[22] => AN
[23] => ANT
[24] => AO
[25] => AO
[26] => AGO
[27] => AQ
[28] => AQ
[29] => ATA
[30] => AR
[31] => AR
[32] => ARG
[33] => AS
[34] => AS
[35] => ASM
[36] => AT
[37] => AT
[38] => AUT
[39] => AU
[40] => AU
[41] => AUS
[42] => AW
[43] => AW
[44] => ABW
[45] => AX
[46] => AX
[47] => ALA
[48] => AZ
[49] => AZ
[50] => AZE
[51] => BA
[52] => BA
[53] => BIH
[54] => BB
[55] => BB
[56] => BRB
[57] => BD
[58] => BD
[59] => BGD
[60] => BE
[61] => BE
[62] => BEL
[63] => BF
[64] => BF
[65] => BFA
[66] => BG
[67] => BG
[68] => BGR
[69] => BH
[70] => BH
[71] => BHR
[72] => BI
[73] => BI
[74] => BDI
[75] => BJ
[76] => BJ
[77] => BEN
[78] => BL
[79] => BL
[80] => BLM
[81] => BM
[82] => BM
[83] => BMU
[84] => BN
[85] => BN
[86] => BRN
[87] => BO
[88] => BO
[89] => BOL
[90] => BR
[91] => BR
[92] => BRA
[93] => BS
[94] => BS
[95] => BHS
[96] => BT
[97] => BT
[98] => BTN
[99] => BV
[100] => BV
[101] => BVT
[102] => BW
[103] => BW
[104] => BWA
[105] => BY
[106] => BY
[107] => BLR
[108] => BZ
[109] => BZ
[110] => BLZ
[111] => CA
[112] => CA
[113] => CAN
[114] => CC
[115] => CC
[116] => CCK
[117] => CD
[118] => CD
[119] => COD
[120] => CF
[121] => CF
[122] => CAF
[123] => CG
[124] => CG
[125] => COG
[126] => CH
[127] => CH
[128] => CHE
[129] => CI
[130] => CI
[131] => CIV
[132] => CK
[133] => CK
[134] => COK
[135] => CL
[136] => CL
[137] => CHL
[138] => CM
[139] => CM
[140] => CMR
[141] => CN
[142] => CN
[143] => CHN
[144] => CO
[145] => CO
[146] => COL
[147] => CR
[148] => CR
[149] => CRI
[150] => CU
[151] => CU
[152] => CUB
[153] => CV
[154] => CV
[155] => CPV
[156] => CX
[157] => CX
[158] => CXR
[159] => CY
[160] => CY
[161] => CYP
[162] => CZ
[163] => CZ
[164] => CZE
[165] => DE
[166] => DE
[167] => DEU
[168] => DJ
[169] => DJ
[170] => DJI
[171] => DK
[172] => DK
[173] => DNK
[174] => DM
[175] => DM
[176] => DMA
[177] => DO
[178] => DO
[179] => DOM
[180] => DZ
[181] => DZ
[182] => DZA
[183] => EC
[184] => EC
[185] => ECU
[186] => EE
[187] => EE
[188] => EST
[189] => EG
[190] => EG
[191] => EGY
[192] => EH
[193] => EH
[194] => ESH
[195] => ER
[196] => ER
[197] => ERI
[198] => ES
[199] => ES
[200] => ESP
[201] => ET
[202] => ET
[203] => ETH
[204] => FI
[205] => FI
[206] => FIN
[207] => FJ
[208] => FJ
[209] => FJI
[210] => FK
[211] => FK
[212] => FLK
[213] => FM
[214] => FM
[215] => FSM
[216] => FO
[217] => FO
[218] => FRO
[219] => FR
[220] => FR
[221] => FRA
[222] => GA
[223] => GA
[224] => GAB
[225] => GB
[226] => GB
[227] => GBR
[228] => GD
[229] => GD
[230] => GRD
[231] => GE
[232] => GE
[233] => GEO
[234] => GF
[235] => GF
[236] => GUF
[237] => GG
[238] => GG
[239] => GGY
[240] => GH
[241] => GH
[242] => GHA
[243] => GI
[244] => GI
[245] => GIB
[246] => GL
[247] => GL
[248] => GRL
[249] => GM
[250] => GM
[251] => GMB
[252] => GN
[253] => GN
[254] => GIN
[255] => GP
[256] => GP
[257] => GLP
[258] => GQ
[259] => GQ
[260] => GNQ
[261] => GR
[262] => GR
[263] => GRC
[264] => GS
[265] => GS
[266] => SGS
[267] => GT
[268] => GT
[269] => GTM
[270] => GU
[271] => GU
[272] => GUM
[273] => GW
[274] => GW
[275] => GNB
[276] => GY
[277] => GY
[278] => GUY
[279] => HK
[280] => HK
[281] => HKG
[282] => HM
[283] => HM
[284] => HMD
[285] => HN
[286] => HN
[287] => HND
[288] => HR
[289] => HR
[290] => HRV
[291] => HT
[292] => HT
[293] => HTI
[294] => HU
[295] => HU
[296] => HUN
[297] => ID
[298] => ID
[299] => IDN
[300] => IE
[301] => IE
[302] => IRL
[303] => IL
[304] => IL
[305] => ISR
[306] => IM
[307] => IM
[308] => IMN
[309] => IN
[310] => IN
[311] => IND
[312] => IO
[313] => IO
[314] => IOT
[315] => IQ
[316] => IQ
[317] => IRQ
[318] => IR
[319] => IR
[320] => IRN
[321] => IS
[322] => IS
[323] => ISL
[324] => IT
[325] => IT
[326] => ITA
[327] => JE
[328] => JE
[329] => JEY
[330] => JM
[331] => JM
[332] => JAM
[333] => JO
[334] => JO
[335] => JOR
[336] => JP
[337] => JP
[338] => JPN
[339] => KE
[340] => KE
[341] => KEN
[342] => KG
[343] => KG
[344] => KGZ
[345] => KH
[346] => KH
[347] => KHM
[348] => KI
[349] => KI
[350] => KIR
[351] => KM
[352] => KM
[353] => COM
[354] => KN
[355] => KN
[356] => KNA
[357] => KP
[358] => KP
[359] => PRK
[360] => KR
[361] => KR
[362] => KOR
[363] => KW
[364] => KW
[365] => KWT
[366] => KY
[367] => KY
[368] => CYM
[369] => KZ
[370] => KZ
[371] => KAZ
[372] => LA
[373] => LA
[374] => LAO
[375] => LB
[376] => LB
[377] => LBN
[378] => LC
[379] => LC
[380] => LCA
[381] => LI
[382] => LI
[383] => LIE
[384] => LK
[385] => LK
[386] => LKA
[387] => LR
[388] => LR
[389] => LBR
[390] => LS
[391] => LS
[392] => LSO
[393] => LT
[394] => LT
[395] => LTU
[396] => LU
[397] => LU
[398] => LUX
[399] => LV
[400] => LV
[401] => LVA
[402] => LY
[403] => LY
[404] => LBY
[405] => MA
[406] => MA
[407] => MAR
[408] => MC
[409] => MC
[410] => MCO
[411] => MD
[412] => MD
[413] => MDA
[414] => ME
[415] => ME
[416] => MNE
[417] => MF
[418] => MF
[419] => MAF
[420] => MG
[421] => MG
[422] => MDG
[423] => MH
[424] => MH
[425] => MHL
[426] => MK
[427] => MK
[428] => MKD
[429] => ML
[430] => ML
[431] => MLI
[432] => MM
[433] => MM
[434] => MMR
[435] => MN
[436] => MN
[437] => MNG
[438] => MO
[439] => MO
[440] => MAC
[441] => MP
[442] => MP
[443] => MNP
[444] => MQ
[445] => MQ
[446] => MTQ
[447] => MR
[448] => MR
[449] => MRT
[450] => MS
[451] => MS
[452] => MSR
[453] => MT
[454] => MT
[455] => MLT
[456] => MU
[457] => MU
[458] => MUS
[459] => MV
[460] => MV
[461] => MDV
[462] => MW
[463] => MW
[464] => MWI
[465] => MX
[466] => MX
[467] => MEX
[468] => MY
[469] => MY
[470] => MYS
[471] => MZ
[472] => MZ
[473] => MOZ
[474] => NA
[475] => NA
[476] => NAM
[477] => NC
[478] => NC
[479] => NCL
[480] => NE
[481] => NE
[482] => NER
[483] => NF
[484] => NF
[485] => NFK
[486] => NG
[487] => NG
[488] => NGA
[489] => NI
[490] => NI
[491] => NIC
[492] => NL
[493] => NL
[494] => NLD
[495] => NO
[496] => NO
[497] => NOR
[498] => NP
[499] => NP
[500] => NPL
[501] => NR
[502] => NR
[503] => NRU
[504] => NU
[505] => NU
[506] => NIU
[507] => NZ
[508] => NZ
[509] => NZL
[510] => OM
[511] => OM
[512] => OMN
[513] => PA
[514] => PA
[515] => PAN
[516] => PE
[517] => PE
[518] => PER
[519] => PF
[520] => PF
[521] => PYF
[522] => PG
[523] => PG
[524] => PNG
[525] => PH
[526] => PH
[527] => PHL
[528] => PK
[529] => PK
[530] => PAK
[531] => PL
[532] => PL
[533] => POL
[534] => PM
[535] => PM
[536] => SPM
[537] => PN
[538] => PN
[539] => PCN
[540] => PR
[541] => PR
[542] => PRI
[543] => PS
[544] => PS
[545] => PSE
[546] => PT
[547] => PT
[548] => PRT
[549] => PW
[550] => PW
[551] => PLW
[552] => PY
[553] => PY
[554] => PRY
[555] => QA
[556] => QA
[557] => QAT
[558] => RE
[559] => RE
[560] => REU
[561] => RO
[562] => RO
[563] => ROU
[564] => RS
[565] => RS
[566] => SRB
[567] => RU
[568] => RU
[569] => RUS
[570] => RW
[571] => RW
[572] => RWA
[573] => SA
[574] => SA
[575] => SAU
[576] => SB
[577] => SB
[578] => SLB
[579] => SC
[580] => SC
[581] => SYC
[582] => SD
[583] => SD
[584] => SDN
[585] => SE
[586] => SE
[587] => SWE
[588] => SG
[589] => SG
[590] => SGP
[591] => SH
[592] => SH
[593] => SHN
[594] => SI
[595] => SI
[596] => SVN
[597] => SJ
[598] => SJ
[599] => SJM
[600] => SK
[601] => SK
[602] => SVK
[603] => SL
[604] => SL
[605] => SLE
[606] => SM
[607] => SM
[608] => SMR
[609] => SN
[610] => SN
[611] => SEN
[612] => SO
[613] => SO
[614] => SOM
[615] => SR
[616] => SR
[617] => SUR
[618] => ST
[619] => ST
[620] => STP
[621] => SV
[622] => SV
[623] => SLV
[624] => SY
[625] => SY
[626] => SYR
[627] => SZ
[628] => SZ
[629] => SWZ
[630] => TC
[631] => TC
[632] => TCA
[633] => TD
[634] => TD
[635] => TCD
[636] => TF
[637] => TF
[638] => ATF
[639] => TG
[640] => TG
[641] => TGO
[642] => TH
[643] => TH
[644] => THA
[645] => TJ
[646] => TJ
[647] => TJK
[648] => TK
[649] => TK
[650] => TKL
[651] => TL
[652] => TL
[653] => TLS
[654] => TM
[655] => TM
[656] => TKM
[657] => TN
[658] => TN
[659] => TUN
[660] => TO
[661] => TO
[662] => TON
[663] => TR
[664] => TR
[665] => TUR
[666] => TT
[667] => TT
[668] => TTO
[669] => TV
[670] => TV
[671] => TUV
[672] => TW
[673] => TW
[674] => TWN
[675] => TZ
[676] => TZ
[677] => TZA
[678] => UA
[679] => UA
[680] => UKR
[681] => UG
[682] => UG
[683] => UGA
[684] => UM
[685] => UM
[686] => UMI
[687] => US
[688] => US
[689] => USA
[690] => UY
[691] => UY
[692] => URY
[693] => UZ
[694] => UZ
[695] => UZB
[696] => VA
[697] => VA
[698] => VAT
[699] => VC
[700] => VC
[701] => VCT
[702] => VE
[703] => VE
[704] => VEN
[705] => VG
[706] => VG
[707] => VGB
[708] => VI
[709] => VI
[710] => VIR
[711] => VN
[712] => VN
[713] => VNM
[714] => VU
[715] => VU
[716] => VUT
[717] => WF
[718] => WF
[719] => WLF
[720] => WS
[721] => WS
[722] => WSM
[723] => YE
[724] => YE
[725] => YEM
[726] => YT
[727] => YT
[728] => MYT
[729] => ZA
[730] => ZA
[731] => ZAF
[732] => ZM
[733] => ZM
[734] => ZMB
[735] => ZW
[736] => ZW
[737] => ZWE
[3] => Array
[file] => /home/verleihnix/public_html/lib/Zend/Db/Adapter/Abstract.php
[line] => 480
[function] => execute
[type] => ->
[args] => Array
[0] => Array
[0] => AD
[1] => AD
[2] => AND
[3] => AE
[4] => AE
[5] => ARE
[6] => AF
[7] => AF
[8] => AFG
[9] => AG
[10] => AG
[11] => ATG
[12] => AI
[13] => AI
[14] => AIA
[15] => AL
[16] => AL
[17] => ALB
[18] => AM
[19] => AM
[20] => ARM
[21] => AN
[22] => AN
[23] => ANT
[24] => AO
[25] => AO
[26] => AGO
[27] => AQ
[28] => AQ
[29] => ATA
[30] => AR
[31] => AR
[32] => ARG
[33] => AS
[34] => AS
[35] => ASM
[36] => AT
[37] => AT
[38] => AUT
[39] => AU
[40] => AU
[41] => AUS
[42] => AW
[43] => AW
[44] => ABW
[45] => AX
[46] => AX
[47] => ALA
[48] => AZ
[49] => AZ
[50] => AZE
[51] => BA
[52] => BA
[53] => BIH
[54] => BB
[55] => BB
[56] => BRB
[57] => BD
[58] => BD
[59] => BGD
[60] => BE
[61] => BE
[62] => BEL
[63] => BF
[64] => BF
[65] => BFA
[66] => BG
[67] => BG
[68] => BGR
[69] => BH
[70] => BH
[71] => BHR
[72] => BI
[73] => BI
[74] => BDI
[75] => BJ
[76] => BJ
[77] => BEN
[78] => BL
[79] => BL
[80] => BLM
[81] => BM
[82] => BM
[83] => BMU
[84] => BN
[85] => BN
[86] => BRN
[87] => BO
[88] => BO
[89] => BOL
[90] => BR
[91] => BR
[92] => BRA
[93] => BS
[94] => BS
[95] => BHS
[96] => BT
[97] => BT
[98] => BTN
[99] => BV
[100] => BV
[101] => BVT
[102] => BW
[103] => BW
[104] => BWA
[105] => BY
[106] => BY
[107] => BLR
[108] => BZ
[109] => BZ
[110] => BLZ
[111] => CA
[112] => CA
[113] => CAN
[114] => CC
[115] => CC
[116] => CCK
[117] => CD
[118] => CD
[119] => COD
[120] => CF
[121] => CF
[122] => CAF
[123] => CG
[124] => CG
[125] => COG
[126] => CH
[127] => CH
[128] => CHE
[129] => CI
[130] => CI
[131] => CIV
[132] => CK
[133] => CK
[134] => COK
[135] => CL
[136] => CL
[137] => CHL
[138] => CM
[139] => CM
[140] => CMR
[141] => CN
[142] => CN
[143] => CHN
[144] => CO
[145] => CO
[146] => COL
[147] => CR
[148] => CR
[149] => CRI
[150] => CU
[151] => CU
[152] => CUB
[153] => CV
[154] => CV
[155] => CPV
[156] => CX
[157] => CX
[158] => CXR
[159] => CY
[160] => CY
[161] => CYP
[162] => CZ
[163] => CZ
[164] => CZE
[165] => DE
[166] => DE
[167] => DEU
[168] => DJ
[169] => DJ
[170] => DJI
[171] => DK
[172] => DK
[173] => DNK
[174] => DM
[175] => DM
[176] => DMA
[177] => DO
[178] => DO
[179] => DOM
[180] => DZ
[181] => DZ
[182] => DZA
[183] => EC
[184] => EC
[185] => ECU
[186] => EE
[187] => EE
[188] => EST
[189] => EG
[190] => EG
[191] => EGY
[192] => EH
[193] => EH
[194] => ESH
[195] => ER
[196] => ER
[197] => ERI
[198] => ES
[199] => ES
[200] => ESP
[201] => ET
[202] => ET
[203] => ETH
[204] => FI
[205] => FI
[206] => FIN
[207] => FJ
[208] => FJ
[209] => FJI
[210] => FK
[211] => FK
[212] => FLK
[213] => FM
[214] => FM
[215] => FSM
[216] => FO
[217] => FO
[218] => FRO
[219] => FR
[220] => FR
[221] => FRA
[222] => GA
[223] => GA
[224] => GAB
[225] => GB
[226] => GB
[227] => GBR
[228] => GD
[229] => GD
[230] => GRD
[231] => GE
[232] => GE
[233] => GEO
[234] => GF
[235] => GF
[236] => GUF
[237] => GG
[238] => GG
[239] => GGY
[240] => GH
[241] => GH
[242] => GHA
[243] => GI
[244] => GI
[245] => GIB
[246] => GL
[247] => GL
[248] => GRL
[249] => GM
[250] => GM
[251] => GMB
[252] => GN
[253] => GN
[254] => GIN
[255] => GP
[256] => GP
[257] => GLP
[258] => GQ
[259] => GQ
[260] => GNQ
[261] => GR
[262] => GR
[263] => GRC
[264] => GS
[265] => GS
[266] => SGS
[267] => GT
[268] => GT
[269] => GTM
[270] => GU
[271] => GU
[272] => GUM
[273] => GW
[274] => GW
[275] => GNB
[276] => GY
[277] => GY
[278] => GUY
[279] => HK
[280] => HK
[281] => HKG
[282] => HM
[283] => HM
[284] => HMD
[285] => HN
[286] => HN
[287] => HND
[288] => HR
[289] => HR
[290] => HRV
[291] => HT
[292] => HT
[293] => HTI
[294] => HU
[295] => HU
[296] => HUN
[297] => ID
[298] => ID
[299] => IDN
[300] => IE
[301] => IE
[302] => IRL
[303] => IL
[304] => IL
[305] => ISR
[306] => IM
[307] => IM
[308] => IMN
[309] => IN
[310] => IN
[311] => IND
[312] => IO
[313] => IO
[314] => IOT
[315] => IQ
[316] => IQ
[317] => IRQ
[318] => IR
[319] => IR
[320] => IRN
[321] => IS
[322] => IS
[323] => ISL
[324] => IT
[325] => IT
[326] => ITA
[327] => JE
[328] => JE
[329] => JEY
[330] => JM
[331] => JM
[332] => JAM
[333] => JO
[334] => JO
[335] => JOR
[336] => JP
[337] => JP
[338] => JPN
[339] => KE
[340] => KE
[341] => KEN
[342] => KG
[343] => KG
[344] => KGZ
[345] => KH
[346] => KH
[347] => KHM
[348] => KI
[349] => KI
[350] => KIR
[351] => KM
[352] => KM
[353] => COM
[354] => KN
[355] => KN
[356] => KNA
[357] => KP
[358] => KP
[359] => PRK
[360] => KR
[361] => KR
[362] => KOR
[363] => KW
[364] => KW
[365] => KWT
[366] => KY
[367] => KY
[368] => CYM
[369] => KZ
[370] => KZ
[371] => KAZ
[372] => LA
[373] => LA
[374] => LAO
[375] => LB
[376] => LB
[377] => LBN
[378] => LC
[379] => LC
[380] => LCA
[381] => LI
[382] => LI
[383] => LIE
[384] => LK
[385] => LK
[386] => LKA
[387] => LR
[388] => LR
[389] => LBR
[390] => LS
[391] => LS
[392] => LSO
[393] => LT
[394] => LT
[395] => LTU
[396] => LU
[397] => LU
[398] => LUX
[399] => LV
[400] => LV
[401] => LVA
[402] => LY
[403] => LY
[404] => LBY
[405] => MA
[406] => MA
[407] => MAR
[408] => MC
[409] => MC
[410] => MCO
[411] => MD
[412] => MD
[413] => MDA
[414] => ME
[415] => ME
[416] => MNE
[417] => MF
[418] => MF
[419] => MAF
[420] => MG
[421] => MG
[422] => MDG
[423] => MH
[424] => MH
[425] => MHL
[426] => MK
[427] => MK
[428] => MKD
[429] => ML
[430] => ML
[431] => MLI
[432] => MM
[433] => MM
[434] => MMR
[435] => MN
[436] => MN
[437] => MNG
[438] => MO
[439] => MO
[440] => MAC
[441] => MP
[442] => MP
[443] => MNP
[444] => MQ
[445] => MQ
[446] => MTQ
[447] => MR
[448] => MR
[449] => MRT
[450] => MS
[451] => MS
[452] => MSR
[453] => MT
[454] => MT
[455] => MLT
[456] => MU
[457] => MU
[458] => MUS
[459] => MV
[460] => MV
[461] => MDV
[462] => MW
[463] => MW
[464] => MWI
[465] => MX
[466] => MX
[467] => MEX
[468] => MY
[469] => MY
[470] => MYS
[471] => MZ
[472] => MZ
[473] => MOZ
[474] => NA
[475] => NA
[476] => NAM
[477] => NC
[478] => NC
[479] => NCL
[480] => NE
[481] => NE
[482] => NER
[483] => NF
[484] => NF
[485] => NFK
[486] => NG
[487] => NG
[488] => NGA
[489] => NI
[490] => NI
[491] => NIC
[492] => NL
[493] => NL
[494] => NLD
[495] => NO
[496] => NO
[497] => NOR
[498] => NP
[499] => NP
[500] => NPL
[501] => NR
[502] => NR
[503] => NRU
[504] => NU
[505] => NU
[506] => NIU
[507] => NZ
[508] => NZ
[509] => NZL
[510] => OM
[511] => OM
[512] => OMN
[513] => PA
[514] => PA
[515] => PAN
[516] => PE
[517] => PE
[518] => PER
[519] => PF
[520] => PF
[521] => PYF
[522] => PG
[523] => PG
[524] => PNG
[525] => PH
[526] => PH
[527] => PHL
[528] => PK
[529] => PK
[530] => PAK
[531] => PL
[532] => PL
[533] => POL
[534] => PM
[535] => PM
[536] => SPM
[537] => PN
[538] => PN
[539] => PCN
[540] => PR
[541] => PR
[542] => PRI
[543] => PS
[544] => PS
[545] => PSE
[546] => PT
[547] => PT
[548] => PRT
[549] => PW
[550] => PW
[551] => PLW
[552] => PY
[553] => PY
[554] => PRY
[555] => QA
[556] => QA
[557] => QAT
[558] => RE
[559] => RE
[560] => REU
[561] => RO
[562] => RO
[563] => ROU
[564] => RS
[565] => RS
[566] => SRB
[567] => RU
[568] => RU
[569] => RUS
[570] => RW
[571] => RW
[572] => RWA
[573] => SA
[574] => SA
[575] => SAU
[576] => SB
[577] => SB
[578] => SLB
[579] => SC
[580] => SC
[581] => SYC
[582] => SD
[583] => SD
[584] => SDN
[585] => SE
[586] => SE
[587] => SWE
[588] => SG
[589] => SG
[590] => SGP
[591] => SH
[592] => SH
[593] => SHN
[594] => SI
[595] => SI
[596] => SVN
[597] => SJ
[598] => SJ
[599] => SJM
[600] => SK
[601] => SK
[602] => SVK
[603] => SL
[604] => SL
[605] => SLE
[606] => SM
[607] => SM
[608] => SMR
[609] => SN
[610] => SN
[611] => SEN
[612] => SO
[613] => SO
[614] => SOM
[615] => SR
[616] => SR
[617] => SUR
[618] => ST
[619] => ST
[620] => STP
[621] => SV
[622] => SV
[623] => SLV
[624] => SY
[625] => SY
[626] => SYR
[627] => SZ
[628] => SZ
[629] => SWZ
[630] => TC
[631] => TC
[632] => TCA
[633] => TD
[634] => TD
[635] => TCD
[636] => TF
[637] => TF
[638] => ATF
[639] => TG
[640] => TG
[641] => TGO
[642] => TH
[643] => TH
[644] => THA
[645] => TJ
[646] => TJ
[647] => TJK
[648] => TK
[649] => TK
[650] => TKL
[651] => TL
[652] => TL
[653] => TLS
[654] => TM
[655] => TM
[656] => TKM
[657] => TN
[658] => TN
[659] => TUN
[660] => TO
[661] => TO
[662] => TON
[663] => TR
[664] => TR
[665] => TUR
[666] => TT
[667] => TT
[668] => TTO
[669] => TV
[670] => TV
[671] => TUV
[672] => TW
[673] => TW
[674] => TWN
[675] => TZ
[676] => TZ
[677] => TZA
[678] => UA
[679] => UA
[680] => UKR
[681] => UG
[682] => UG
[683] => UGA
[684] => UM
[685] => UM
[686] => UMI
[687] => US
[688] => US
[689] => USA
[690] => UY
[691] => UY
[692] => URY
[693] => UZ
[694] => UZ
[695] => UZB
[696] => VA
[697] => VA
[698] => VAT
[699] => VC
[700] => VC
[701] => VCT
[702] => VE
[703] => VE
[704] => VEN
[705] => VG
[706] => VG
[707] => VGB
[708] => VI
[709] => VI
[710] => VIR
[711] => VN
[712] => VN
[713] => VNM
[714] => VU
[715] => VU
[716] => VUT
[717] => WF
[718] => WF
[719] => WLF
[720] => WS
[721] => WS
[722] => WSM
[723] => YE
[724] => YE
[725] => YEM
[726] => YT
[727] => YT
[728] => MYT
[729] => ZA
[730] => ZA
[731] => ZAF
[732] => ZM
[733] => ZM
[734] => ZMB
[735] => ZW
[736] => ZW
[737] => ZWE
[4] => Array
[file] => /home/verleihnix/public_html/lib/Zend/Db/Adapter/Pdo/Abstract.php
[line] => 238
[function] => query
[class] => Zend_Db_Adapter_Abstract
[type] => ->
[args] => Array
[0] => INSERT INTO `magento_directory_country` (`country_id`,`iso2_code`,`iso3_code`) VALUES (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?)
[1] => Array
[0] => AD
[1] => AD
[2] => AND
[3] => AE
[4] => AE
[5] => ARE
[6] => AF
[7] => AF
[8] => AFG
[9] => AG
[10] => AG
[11] => ATG
[12] => AI
[13] => AI
[14] => AIA
[15] => AL
[16] => AL
[17] => ALB
[18] => AM
[19] => AM
[20] => ARM
[21] => AN
[22] => AN
[23] => ANT
[24] => AO
[25] => AO
[26] => AGO
[27] => AQ
[28] => AQ
[29] => ATA
[30] => AR
[31] => AR
[32] => ARG
[33] => AS
[34] => AS
[35] => ASM
[36] => AT
[37] => AT
[38] => AUT
[39] => AU
[40] => AU
[41] => AUS
[42] => AW
[43] => AW
[44] => ABW
[45] => AX
[46] => AX
[47] => ALA
[48] => AZ
[49] => AZ
[50] => AZE
[51] => BA
[52] => BA
[53] => BIH
[54] => BB
[55] => BB
[56] => BRB
[57] => BD
[58] => BD
[59] => BGD
[60] => BE
[61] => BE
[62] => BEL
[63] => BF
[64] => BF
[65] => BFA
[66] => BG
[67] => BG
[68] => BGR
[69] => BH
[70] => BH
[71] => BHR
[72] => BI
[73] => BI
[74] => BDI
[75] => BJ
[76] => BJ
[77] => BEN
[78] => BL
[79] => BL
[80] => BLM
[81] => BM
[82] => BM
[83] => BMU
[84] => BN
[85] => BN
[86] => BRN
[87] => BO
[88] => BO
[89] => BOL
[90] => BR
[91] => BR
[92] => BRA
[93] => BS
[94] => BS
[95] => BHS
[96] => BT
[97] => BT
[98] => BTN
[99] => BV
[100] => BV
[101] => BVT
[102] => BW
[103] => BW
[104] => BWA
[105] => BY
[106] => BY
[107] => BLR
[108] => BZ
[109] => BZ
[110] => BLZ
[111] => CA
[112] => CA
[113] => CAN
[114] => CC
[115] => CC
[116] => CCK
[117] => CD
[118] => CD
[119] => COD
[120] => CF
[121] => CF
[122] => CAF
[123] => CG
[124] => CG
[125] => COG
[126] => CH
[127] => CH
[128] => CHE
[129] => CI
[130] => CI
[131] => CIV
[132] => CK
[133] => CK
[134] => COK
[135] => CL
[136] => CL
[137] => CHL
[138] => CM
[139] => CM
[140] => CMR
[141] => CN
[142] => CN
[143] => CHN
[144] => CO
[145] => CO
[146] => COL
[147] => CR
[148] => CR
[149] => CRI
[150] => CU
[151] => CU
[152] => CUB
[153] => CV
[154] => CV
[155] => CPV
[156] => CX
[157] => CX
[158] => CXR
[159] => CY
[160] => CY
[161] => CYP
[162] => CZ
[163] => CZ
[164] => CZE
[165] => DE
[166] => DE
[167] => DEU
[168] => DJ
[169] => DJ
[170] => DJI
[171] => DK
[172] => DK
[173] => DNK
[174] => DM
[175] => DM
[176] => DMA
[177] => DO
[178] => DO
[179] => DOM
[180] => DZ
[181] => DZ
[182] => DZA
[183] => EC
[184] => EC
[185] => ECU
[186] => EE
[187] => EE
[188] => EST
[189] => EG
[190] => EG
[191] => EGY
[192] => EH
[193] => EH
[194] => ESH
[195] => ER
[196] => ER
[197] => ERI
[198] => ES
[199] => ES
[200] => ESP
[201] => ET
[202] => ET
[203] => ETH
[204] => FI
[205] => FI
[206] => FIN
[207] => FJ
[208] => FJ
[209] => FJI
[210] => FK
[211] => FK
[212] => FLK
[213] => FM
[214] => FM
[215] => FSM
[216] => FO
[217] => FO
[218] => FRO
[219] => FR
[220] => FR
[221] => FRA
[222] => GA
[223] => GA
[224] => GAB
[225] => GB
[226] => GB
[227] => GBR
[228] => GD
[229] => GD
[230] => GRD
[231] => GE
[232] => GE
[233] => GEO
[234] => GF
[235] => GF
[236] => GUF
[237] => GG
[238] => GG
[239] => GGY
[240] => GH
[241] => GH
[242] => GHA
[243] => GI
[244] => GI
[245] => GIB
[246] => GL
[247] => GL
[248] => GRL
[249] => GM
[250] => GM
[251] => GMB
[252] => GN
[253] => GN
[254] => GIN
[255] => GP
[256] => GP
[257] => GLP
[258] => GQ
[259] => GQ
[260] => GNQ
[261] => GR
[262] => GR
[263] => GRC
[264] => GS
[265] => GS
[266] => SGS
[267] => GT
[268] => GT
[269] => GTM
[270] => GU
[271] => GU
[272] => GUM
[273] => GW
[274] => GW
[275] => GNB
[276] => GY
[277] => GY
[278] => GUY
[279] => HK
[280] => HK
[281] => HKG
[282] => HM
[283] => HM
[284] => HMD
[285] => HN
[286] => HN
[287] => HND
[288] => HR
[289] => HR
[290] => HRV
[291] => HT
[292] => HT
[293] => HTI
[294] => HU
[295] => HU
[296] => HUN
[297] => ID
[298] => ID
[299] => IDN
[300] => IE
[301] => IE
[302] => IRL
[303] => IL
[304] => IL
[305] => ISR
[306] => IM
[307] => IM
[308] => IMN
[309] => IN
[310] => IN
[311] => IND
[312] => IO
[313] => IO
[314] => IOT
[315] => IQ
[316] => IQ
[317] => IRQ
[318] => IR
[319] => IR
[320] => IRN
[321] => IS
[322] => IS
[323] => ISL
[324] => IT
[325] => IT
[326] => ITA
[327] => JE
[328] => JE
[329] => JEY
[330] => JM
[331] => JM
[332] => JAM
[333] => JO
[334] => JO
[335] => JOR
[336] => JP
[337] => JP
[338] => JPN
[339] => KE
[340] => KE
[341] => KEN
[342] => KG
[343] => KG
[344] => KGZ
[345] => KH
[346] => KH
[347] => KHM
[348] => KI
[349] => KI
[350] => KIR
[351] => KM
[352] => KM
[353] => COM
[354] => KN
[355] => KN
[356] => KNA
[357] => KP
[358] => KP
[359] => PRK
[360] => KR
[361] => KR
[362] => KOR
[363] => KW
[364] => KW
[365] => KWT
[366] => KY
[367] => KY
[368] => CYM
[369] => KZ
[370] => KZ
[371] => KAZ
[372] => LA
[373] => LA
[374] => LAO
[375] => LB
[376] => LB
[377] => LBN
[378] => LC
[379] => LC
[380] => LCA
[381] => LI
[382] => LI
[383] => LIE
[384] => LK
[385] => LK
[386] => LKA
[387] => LR
[388] => LR
[389] => LBR
[390] => LS
[391] => LS
[392] => LSO
[393] => LT
[394] => LT
[395] => LTU
[396] => LU
[397] => LU
[398] => LUX
[399] => LV
[400] => LV
[401] => LVA
[402] => LY
[403] => LY
[404] => LBY
[405] => MA
[406] => MA
[407] => MAR
[408] => MC
[409] => MC
[410] => MCO
[411] => MD
[412] => MD
[413] => MDA
[414] => ME
[415] => ME
[416] => MNE
[417] => MF
[418] => MF
[419] => MAF
[420] => MG
[421] => MG
[422] => MDG
[423] => MH
[424] => MH
[425] => MHL
[426] => MK
[427] => MK
[428] => MKD
[429] => ML
[430] => ML
[431] => MLI
[432] => MM
[433] => MM
[434] => MMR
[435] => MN
[436] => MN
[437] => MNG
[438] => MO
[439] => MO
[440] => MAC
[441] => MP
[442] => MP
[443] => MNP
[444] => MQ
[445] => MQ
[446] => MTQ
[447] => MR
[448] => MR
[449] => MRT
[450] => MS
[451] => MS
[452] => MSR
[453] => MT
[454] => MT
[455] => MLT
[456] => MU
[457] => MU
[458] => MUS
[459] => MV
[460] => MV
[461] => MDV
[462] => MW
[463] => MW
[464] => MWI
[465] => MX
[466] => MX
[467] => MEX
[468] => MY
[469] => MY
[470] => MYS
[471] => MZ
[472] => MZ
[473] => MOZ
[474] => NA
[475] => NA
[476] => NAM
[477] => NC
[478] => NC
[479] => NCL
[480] => NE
[481] => NE
[482] => NER
[483] => NF
[484] => NF
[485] => NFK
[486] => NG
[487] => NG
[488] => NGA
[489] => NI
[490] => NI
[491] => NIC
[492] => NL
[493] => NL
[494] => NLD
[495] => NO
[496] => NO
[497] => NOR
[498] => NP
[499] => NP
[500] => NPL
[501] => NR
[502] => NR
[503] => NRU
[504] => NU
[505] => NU
[506] => NIU
[507] => NZ
[508] => NZ
[509] => NZL
[510] => OM
[511] => OM
[512] => OMN
[513] => PA
[514] => PA
[515] => PAN
[516] => PE
[517] => PE
[518] => PER
[519] => PF
[520] => PF
[521] => PYF
[522] => PG
[523] => PG
[524] => PNG
[525] => PH
[526] => PH
[527] => PHL
[528] => PK
[529] => PK
[530] => PAK
[531] => PL
[532] => PL
[533] => POL
[534] => PM
[535] => PM
[536] => SPM
[537] => PN
[538] => PN
[539] => PCN
[540] => PR
[541] => PR
[542] => PRI
[543] => PS
[544] => PS
[545] => PSE
[546] => PT
[547] => PT
[548] => PRT
[549] => PW
[550] => PW
[551] => PLW
[552] => PY
[553] => PY
[554] => PRY
[555] => QA
[556] => QA
[557] => QAT
[558] => RE
[559] => RE
[560] => REU
[561] => RO
[562] => RO
[563] => ROU
[564] => RS
[565] => RS
[566] => SRB
[567] => RU
[568] => RU
[569] => RUS
[570] => RW
[571] => RW
[572] => RWA
[573] => SA
[574] => SA
[575] => SAU
[576] => SB
[577] => SB
[578] => SLB
[579] => SC
[580] => SC
[581] => SYC
[582] => SD
[583] => SD
[584] => SDN
[585] => SE
[586] => SE
[587] => SWE
[588] => SG
[589] => SG
[590] => SGP
[591] => SH
[592] => SH
[593] => SHN
[594] => SI
[595] => SI
[596] => SVN
[597] => SJ
[598] => SJ
[599] => SJM
[600] => SK
[601] => SK
[602] => SVK
[603] => SL
[604] => SL
[605] => SLE
[606] => SM
[607] => SM
[608] => SMR
[609] => SN
[610] => SN
[611] => SEN
[612] => SO
[613] => SO
[614] => SOM
[615] => SR
[616] => SR
[617] => SUR
[618] => ST
[619] => ST
[620] => STP
[621] => SV
[622] => SV
[623] => SLV
[624] => SY
[625] => SY
[626] => SYR
[627] => SZ
[628] => SZ
[629] => SWZ
[630] => TC
[631] => TC
[632] => TCA
[633] => TD
[634] => TD
[635] => TCD
[636] => TF
[637] => TF
[638] => ATF
[639] => TG
[640] => TG
[641] => TGO
[642] => TH
[643] => TH
[644] => THA
[645] => TJ
[646] => TJ
[647] => TJK
[648] => TK
[649] => TK
[650] => TKL
[651] => TL
[652] => TL
[653] => TLS
[654] => TM
[655] => TM
[656] => TKM
[657] => TN
[658] => TN
[659] => TUN
[660] => TO
[661] => TO
[662] => TON
[663] => TR
[664] => TR
[665] => TUR
[666] => TT
[667] => TT
[668] => TTO
[669] => TV
[670] => TV
[671] => TUV
[672] => TW
[673] => TW
[674] => TWN
[675] => TZ
[676] => TZ
[677] => TZA
[678] => UA
[679] => UA
[680] => UKR
[681] => UG
[682] => UG
[683] => UGA
[684] => UM
[685] => UM
[686] => UMI
[687] => US
[688] => US
[689] => USA
[690] => UY
[691] => UY
[692] => URY
[693] => UZ
[694] => UZ
[695] => UZB
[696] => VA
[697] => VA
[698] => VAT
[699] => VC
[700] => VC
[701] => VCT
[702] => VE
[703] => VE
[704] => VEN
[705] => VG
[706] => VG
[707] => VGB
[708] => VI
[709] => VI
[710] => VIR
[711] => VN
[712] => VN
[713] => VNM
[714] => VU
[715] => VU
[716] => VUT
[717] => WF
[718] => WF
[719] => WLF
[720] => WS
[721] => WS
[722] => WSM
[723] => YE
[724] => YE
[725] => YEM
[726] => YT
[727] => YT
[728] => MYT
[729] => ZA
[730] => ZA
[731] => ZAF
[732] => ZM
[733] => ZM
[734] => ZMB
[735] => ZW
[736] => ZW
[737] => ZWE
[5] => Array
[file] => /home/verleihnix/public_html/lib/Varien/Db/Adapter/Pdo/Mysql.php
[line] => 428
[function] => query
[class] => Zend_Db_Adapter_Pdo_Abstract
[type] => ->
[args] => Array
[1] => Array
[0] => AD
[1] => AD
[2] => AND
[3] => AE
[4] => AE
[5] => ARE
[6] => AF
[7] => AF
[8] => AFG
[9] => AG
[10] => AG
[11] => ATG
[12] => AI
[13] => AI
[14] => AIA
[15] => AL
[16] => AL
[17] => ALB
[18] => AM
[19] => AM
[20] => ARM
[21] => AN
[22] => AN
[23] => ANT
[24] => AO
[25] => AO
[26] => AGO
[27] => AQ
[28] => AQ
[29] => ATA
[30] => AR
[31] => AR
[32] => ARG
[33] => AS
[34] => AS
[35] => ASM
[36] => AT
[37] => AT
[38] => AUT
[39] => AU
[40] => AU
[41] => AUS
[42] => AW
[43] => AW
[44] => ABW
[45] => AX
[46] => AX
[47] => ALA
[48] => AZ
[49] => AZ
[50] => AZE
[51] => BA
[52] => BA
[53] => BIH
[54] => BB
[55] => BB
[56] => BRB
[57] => BD
[58] => BD
[59] => BGD
[60] => BE
[61] => BE
[62] => BEL
[63] => BF
[64] => BF
[65] => BFA
[66] => BG
[67] => BG
[68] => BGR
[69] => BH
[70] => BH
[71] => BHR
[72] => BI
[73] => BI
[74] => BDI
[75] => BJ
[76] => BJ
[77] => BEN
[78] => BL
[79] => BL
[80] => BLM
[81] => BM
[82] => BM
[83] => BMU
[84] => BN
[85] => BN
[86] => BRN
[87] => BO
[88] => BO
[89] => BOL
[90] => BR
[91] => BR
[92] => BRA
[93] => BS
[94] => BS
[95] => BHS
[96] => BT
[97] => BT
[98] => BTN
[99] => BV
[100] => BV
[101] => BVT
[102] => BW
[103] => BW
[104] => BWA
[105] => BY
[106] => BY
[107] => BLR
[108] => BZ
[109] => BZ
[110] => BLZ
[111] => CA
[112] => CA
[113] => CAN
[114] => CC
[115] => CC
[116] => CCK
[117] => CD
[118] => CD
[119] => COD
[120] => CF
[121] => CF
[122] => CAF
[123] => CG
[124] => CG
[125] => COG
[126] => CH
[127] => CH
[128] => CHE
[129] => CI
[130] => CI
[131] => CIV
[132] => CK
[133] => CK
[134] => COK
[135] => CL
[136] => CL
[137] => CHL
[138] => CM
[139] => CM
[140] => CMR
[141] => CN
[142] => CN
[143] => CHN
[144] => CO
[145] => CO
[146] => COL
[147] => CR
[148] => CR
[149] => CRI
[150] => CU
[151] => CU
[152] => CUB
[153] => CV
[154] => CV
[155] => CPV
[156] => CX
[157] => CX
[158] => CXR
[159] => CY
[160] => CY
[161] => CYP
[162] => CZ
[163] => CZ
[164] => CZE
[165] => DE
[166] => DE
[167] => DEU
[168] => DJ
[169] => DJ
[170] => DJI
[171] => DK
[172] => DK
[173] => DNK
[174] => DM
[175] => DM
[176] => DMA
[177] => DO
[178] => DO
[179] => DOM
[180] => DZ
[181] => DZ
[182] => DZA
[183] => EC
[184] => EC
[185] => ECU
[186] => EE
[187] => EE
[188] => EST
[189] => EG
[190] => EG
[191] => EGY
[192] => EH
[193] => EH
[194] => ESH
[195] => ER
[196] => ER
[197] => ERI
[198] => ES
[199] => ES
[200] => ESP
[201] => ET
[202] => ET
[203] => ETH
[204] => FI
[205] => FI
[206] => FIN
[207] => FJ
[208] => FJ
[209] => FJI
[210] => FK
[211] => FK
[212] => FLK
[213] => FM
[214] => FM
[215] => FSM
[216] => FO
[217] => FO
[218] => FRO
[219] => FR
[220] => FR
[221] => FRA
[222] => GA
[223] => GA
[224] => GAB
[225] => GB
[226] => GB
[227] => GBR
[228] => GD
[229] => GD
[230] => GRD
[231] => GE
[232] => GE
[233] => GEO
[234] => GF
[235] => GF
[236] => GUF
[237] => GG
[238] => GG
[239] => GGY
[240] => GH
[241] => GH
[242] => GHA
[243] => GI
[244] => GI
[245] => GIB
[246] => GL
[247] => GL
[248] => GRL
[249] => GM
[250] => GM
[251] => GMB
[252] => GN
[253] => GN
[254] => GIN
[255] => GP
[256] => GP
[257] => GLP
[258] => GQ
[259] => GQ
[260] => GNQ
[261] => GR
[262] => GR
[263] => GRC
[264] => GS
[265] => GS
[266] => SGS
[267] => GT
[268] => GT
[269] => GTM
[270] => GU
[271] => GU
[272] => GUM
[273] => GW
[274] => GW
[275] => GNB
[276] => GY
[277] => GY
[278] => GUY
[279] => HK
[280] => HK
[281] => HKG
[282] => HM
[283] => HM
[284] => HMD
[285] => HN
[286] => HN
[287] => HND
[288] => HR
[289] => HR
[290] => HRV
[291] => HT
[292] => HT
[293] => HTI
[294] => HU
[295] => HU
[296] => HUN
[297] => ID
[298] => ID
[299] => IDN
[300] => IE
[301] => IE
[302] => IRL
[303] => IL
[304] => IL
[305] => ISR
[306] => IM
[307] => IM
[308] => IMN
[309] => IN
[310] => IN
[311] => IND
[312] => IO
[313] => IO
[314] => IOT
[315] => IQ
[316] => IQ
[317] => IRQ
[318] => IR
[319] => IR
[320] => IRN
[321] => IS
[322] => IS
[323] => ISL
[324] => IT
[325] => IT
[326] => ITA
[327] => JE
[328] => JE
[329] => JEY
[330] => JM
[331] => JM
[332] => JAM
[333] => JO
[334] => JO
[335] => JOR
[336] => JP
[337] => JP
[338] => JPN
[339] => KE
[340] => KE
[341] => KEN
[342] => KG
[343] => KG
[344] => KGZ
[345] => KH
[346] => KH
[347] => KHM
[348] => KI
[349] => KI
[350] => KIR
[351] => KM
[352] => KM
[353] => COM
[354] => KN
[355] => KN
[356] => KNA
[357] => KP
[358] => KP
[359] => PRK
[360] => KR
[361] => KR
[362] => KOR
[363] => KW
[364] => KW
[365] => KWT
[366] => KY
[367] => KY
[368] => CYM
[369] => KZ
[370] => KZ
[371] => KAZ
[372] => LA
[373] => LA
[374] => LAO
[375] => LB
[376] => LB
[377] => LBN
[378] => LC
[379] => LC
[380] => LCA
[381] => LI
[382] => LI
[383] => LIE
[384] => LK
[385] => LK
[386] => LKA
[387] => LR
[388] => LR
[389] => LBR
[390] => LS
[391] => LS
[392] => LSO
[393] => LT
[394] => LT
[395] => LTU
[396] => LU
[397] => LU
[398] => LUX
[399] => LV
[400] => LV
[401] => LVA
[402] => LY
[403] => LY
[404] => LBY
[405] => MA
[406] => MA
[407] => MAR
[408] => MC
[409] => MC
[410] => MCO
[411] => MD
[412] => MD
[413] => MDA
[414] => ME
[415] => ME
[416] => MNE
[417] => MF
[418] => MF
[419] => MAF
[420] => MG
[421] => MG
[422] => MDG
[423] => MH
[424] => MH
[425] => MHL
[426] => MK
[427] => MK
[428] => MKD
[429] => ML
[430] => ML
[431] => MLI
[432] => MM
[433] => MM
[434] => MMR
[435] => MN
[436] => MN
[437] => MNG
[438] => MO
[439] => MO
[440] => MAC
[441] => MP
[442] => MP
[443] => MNP
[444] => MQ
[445] => MQ
[446] => MTQ
[447] => MR
[448] => MR
[449] => MRT
[450] => MS
[451] => MS
[452] => MSR
[453] => MT
[454] => MT
[455] => MLT
[456] => MU
[457] => MU
[458] => MUS
[459] => MV
[460] => MV
[461] => MDV
[462] => MW
[463] => MW
[464] => MWI
[465] => MX
[466] => MX
[467] => MEX
[468] => MY
[469] => MY
[470] => MYS
[471] => MZ
[472] => MZ
[473] => MOZ
[474] => NA
[475] => NA
[476] => NAM
[477] => NC
[478] => NC
[479] => NCL
[480] => NE
[481] => NE
[482] => NER
[483] => NF
[484] => NF
[485] => NFK
[486] => NG
[487] => NG
[488] => NGA
[489] => NI
[490] => NI
[491] => NIC
[492] => NL
[493] => NL
[494] => NLD
[495] => NO
[496] => NO
[497] => NOR
[498] => NP
[499] => NP
[500] => NPL
[501] => NR
[502] => NR
[503] => NRU
[504] => NU
[505] => NU
[506] => NIU
[507] => NZ
[508] => NZ
[509] => NZL
[510] => OM
[511] => OM
[512] => OMN
[513] => PA
[514] => PA
[515] => PAN
[516] => PE
[517] => PE
[518] => PER
[519] => PF
[520] => PF
[521] => PYF
[522] => PG
[523] => PG
[524] => PNG
[525] => PH
[526] => PH
[527] => PHL
[528] => PK
[529] => PK
[530] => PAK
[531] => PL
[532] => PL
[533] => POL
[534] => PM
[535] => PM
[536] => SPM
[537] => PN
[538] => PN
[539] => PCN
[540] => PR
[541] => PR
[542] => PRI
[543] => PS
[544] => PS
[545] => PSE
[546] => PT
[547] => PT
[548] => PRT
[549] => PW
[550] => PW
[551] => PLW
[552] => PY
[553] => PY
[554] => PRY
[555] => QA
[556] => QA
[557] => QAT
[558] => RE
[559] => RE
[560] => REU
[561] => RO
[562] => RO
[563] => ROU
[564] => RS
[565] => RS
[566] => SRB
[567] => RU
[568] => RU
[569] => RUS
[570] => RW
[571] => RW
[572] => RWA
[573] => SA
[574] => SA
[575] => SAU
[576] => SB
[577] => SB
[578] => SLB
[579] => SC
[580] => SC
[581] => SYC
[582] => SD
[583] => SD
[584] => SDN
[585] => SE
[586] => SE
[587] => SWE
[588] => SG
[589] => SG
[590] => SGP
[591] => SH
[592] => SH
[593] => SHN
[594] => SI
[595] => SI
[596] => SVN
[597] => SJ
[598] => SJ
[599] => SJM
[600] => SK
[601] => SK
[602] => SVK
[603] => SL
[604] => SL
[605] => SLE
[606] => SM
[607] => SM
[608] => SMR
[609] => SN
[610] => SN
[611] => SEN
[612] => SO
[613] => SO
[614] => SOM
[615] => SR
[616] => SR
[617] => SUR
[618] => ST
[619] => ST
[620] => STP
[621] => SV
[622] => SV
[623] => SLV
[624] => SY
[625] => SY
[626] => SYR
[627] => SZ
[628] => SZ
[629] => SWZ
[630] => TC
[631] => TC
[632] => TCA
[633] => TD
[634] => TD
[635] => TCD
[636] => TF
[637] => TF
[638] => ATF
[639] => TG
[640] => TG
[641] => TGO
[642] => TH
[643] => TH
[644] => THA
[645] => TJ
[646] => TJ
[647] => TJK
[648] => TK
[649] => TK
[650] => TKL
[651] => TL
[652] => TL
[653] => TLS
[654] => TM
[655] => TM
[656] => TKM
[657] => TN
[658] => TN
[659] => TUN
[660] => TO
[661] => TO
[662] => TON
[663] => TR
[664] => TR
[665] => TUR
[666] => TT
[667] => TT
[668] => TTO
[669] => TV
[670] => TV
[671] => TUV
[672] => TW
[673] => TW
[674] => TWN
[675] => TZ
[676] => TZ
[677] => TZA
[678] => UA
[679] => UA
[680] => UKR
[681] => UG
[682] => UG
[683] => UGA
[684] => UM
[685] => UM
[686] => UMI
[687] => US
[688] => US
[689] => USA
[690] => UY
[691] => UY
[692] => URY
[693] => UZ
[694] => UZ
[695] => UZB
[696] => VA
[697] => VA
[698] => VAT
[699] => VC
[700] => VC
[701] => VCT
[702] => VE
[703] => VE
[704] => VEN
[705] => VG
[706] => VG
[707] => VGB
[708] => VI
[709] => VI
[710] => VIR
[711] => VN
[712] => VN
[713] => VNM
[714] => VU
[715] => VU
[716] => VUT
[717] => WF
[718] => WF
[719] => WLF
[720] => WS
[721] => WS
[722] => WSM
[723] => YE
[724] => YE
[725] => YEM
[726] => YT
[727] => YT
[728] => MYT
[729] => ZA
[730] => ZA
[731] => ZAF
[732] => ZM
[733] => ZM
[734] => ZMB
[735] => ZW
[736] => ZW
[737] => ZWE
[6] => Array
[line] => 1998
[function] => query
[class] => Varien_Db_Adapter_Pdo_Mysql
[type] => ->
[args] => Array
[1] => Array
[0] => AD
[1] => AD
[2] => AND
[3] => AE
[4] => AE
[5] => ARE
[6] => AF
[7] => AF
[8] => AFG
[9] => AG
[10] => AG
[11] => ATG
[12] => AI
[13] => AI
[14] => AIA
[15] => AL
[16] => AL
[17] => ALB
[18] => AM
[19] => AM
[20] => ARM
[21] => AN
[22] => AN
[23] => ANT
[24] => AO
[25] => AO
[26] => AGO
[27] => AQ
[28] => AQ
[29] => ATA
[30] => AR
[31] => AR
[32] => ARG
[33] => AS
[34] => AS
[35] => ASM
[36] => AT
[37] => AT
[38] => AUT
[39] => AU
[40] => AU
[41] => AUS
[42] => AW
[43] => AW
[44] => ABW
[45] => AX
[46] => AX
[47] => ALA
[48] => AZ
[49] => AZ
[50] => AZE
[51] => BA
[52] => BA
[53] => BIH
[54] => BB
[55] => BB
[56] => BRB
[57] => BD
[58] => BD
[59] => BGD
[60] => BE
[61] => BE
[62] => BEL
[63] => BF
[64] => BF
[65] => BFA
[66] => BG
[67] => BG
[68] => BGR
[69] => BH
[70] => BH
[71] => BHR
[72] => BI
[73] => BI
[74] => BDI
[75] => BJ
[76] => BJ
[77] => BEN
[78] => BL
[79] => BL
[80] => BLM
[81] => BM
[82] => BM
[83] => BMU
[84] => BN
[85] => BN
[86] => BRN
[87] => BO
[88] => BO
[89] => BOL
[90] => BR
[91] => BR
[92] => BRA
[93] => BS
[94] => BS
[95] => BHS
[96] => BT
[97] => BT
[98] => BTN
[99] => BV
[100] => BV
[101] => BVT
[102] => BW
[103] => BW
[104] => BWA
[105] => BY
[106] => BY
[107] => BLR
[108] => BZ
[109] => BZ
[110] => BLZ
[111] => CA
[112] => CA
[113] => CAN
[114] => CC
[115] => CC
[116] => CCK
[117] => CD
[118] => CD
[119] => COD
[120] => CF
[121] => CF
[122] => CAF
[123] => CG
[124] => CG
[125] => COG
[126] => CH
[127] => CH
[128] => CHE
[129] => CI
[130] => CI
[131] => CIV
[132] => CK
[133] => CK
[134] => COK
[135] => CL
[136] => CL
[137] => CHL
[138] => CM
[139] => CM
[140] => CMR
[141] => CN
[142] => CN
[143] => CHN
[144] => CO
[145] => CO
[146] => COL
[147] => CR
[148] => CR
[149] => CRI
[150] => CU
[151] => CU
[152] => CUB
[153] => CV
[154] => CV
[155] => CPV
[156] => CX
[157] => CX
[158] => CXR
[159] => CY
[160] => CY
[161] => CYP
[162] => CZ
[163] => CZ
[164] => CZE
[165] => DE
[166] => DE
[167] => DEU
[168] => DJ
[169] => DJ
[170] => DJI
[171] => DK
[172] => DK
[173] => DNK
[174] => DM
[175] => DM
[176] => DMA
[177] => DO
[178] => DO
[179] => DOM
[180] => DZ
[181] => DZ
[182] => DZA
[183] => EC
[184] => EC
[185] => ECU
[186] => EE
[187] => EE
[188] => EST
[189] => EG
[190] => EG
[191] => EGY
[192] => EH
[193] => EH
[194] => ESH
[195] => ER
[196] => ER
[197] => ERI
[198] => ES
[199] => ES
[200] => ESP
[201] => ET
[202] => ET
[203] => ETH
[204] => FI
[205] => FI
[206] => FIN
[207] => FJ
[208] => FJ
[209] => FJI
[210] => FK
[211] => FK
[212] => FLK
[213] => FM
[214] => FM
[215] => FSM
[216] => FO
[217] => FO
[218] => FRO
[219] => FR
[220] => FR
[221] => FRA
[222] => GA
[223] => GA
[224] => GAB
[225] => GB
[226] => GB
[227] => GBR
[228] => GD
[229] => GD
[230] => GRD
[231] => GE
[232] => GE
[233] => GEO
[234] => GF
[235] => GF
[236] => GUF
[237] => GG
[238] => GG
[239] => GGY
[240] => GH
[241] => GH
[242] => GHA
[243] => GI
[244] => GI
[245] => GIB
[246] => GL
[247] => GL
[248] => GRL
[249] => GM
[250] => GM
[251] => GMB
[252] => GN
[253] => GN
[254] => GIN
[255] => GP
[256] => GP
[257] => GLP
[258] => GQ
[259] => GQ
[260] => GNQ
[261] => GR
[262] => GR
[263] => GRC
[264] => GS
[265] => GS
[266] => SGS
[267] => GT
[268] => GT
[269] => GTM
[270] => GU
[271] => GU
[272] => GUM
[273] => GW
[274] => GW
[275] => GNB
[276] => GY
[277] => GY
[278] => GUY
[279] => HK
[280] => HK
[281] => HKG
[282] => HM
[283] => HM
[284] => HMD
[285] => HN
[286] => HN
[287] => HND
[288] => HR
[289] => HR
[290] => HRV
[291] => HT
[292] => HT
[293] => HTI
[294] => HU
[295] => HU
[296] => HUN
[297] => ID
[298] => ID
[299] => IDN
[300] => IE
[301] => IE
[302] => IRL
[303] => IL
[304] => IL
[305] => ISR
[306] => IM
[307] => IM
[308] => IMN
[309] => IN
[310] => IN
[311] => IND
[312] => IO
[313] => IO
[314] => IOT
[315] => IQ
[316] => IQ
[317] => IRQ
[318] => IR
[319] => IR
[320] => IRN
[321] => IS
[322] => IS
[323] => ISL
[324] => IT
[325] => IT
[326] => ITA
[327] => JE
[328] => JE
[329] => JEY
[330] => JM
[331] => JM
[332] => JAM
[333] => JO
[334] => JO
[335] => JOR
[336] => JP
[337] => JP
[338] => JPN
[339] => KE
[340] => KE
[341] => KEN
[342] => KG
[343] => KG
[344] => KGZ
[345] => KH
[346] => KH
[347] => KHM
[348] => KI
[349] => KI
[350] => KIR
[351] => KM
[352] => KM
[353] => COM
[354] => KN
[355] => KN
[356] => KNA
[357] => KP
[358] => KP
[359] => PRK
[360] => KR
[361] => KR
[362] => KOR
[363] => KW
[364] => KW
[365] => KWT
[366] => KY
[367] => KY
[368] => CYM
[369] => KZ
[370] => KZ
[371] => KAZ
[372] => LA
[373] => LA
[374] => LAO
[375] => LB
[376] => LB
[377] => LBN
[378] => LC
[379] => LC
[380] => LCA
[381] => LI
[382] => LI
[383] => LIE
[384] => LK
[385] => LK
[386] => LKA
[387] => LR
[388] => LR
[389] => LBR
[390] => LS
[391] => LS
[392] => LSO
[393] => LT
[394] => LT
[395] => LTU
[396] => LU
[397] => LU
[398] => LUX
[399] => LV
[400] => LV
[401] => LVA
[402] => LY
[403] => LY
[404] => LBY
[405] => MA
[406] => MA
[407] => MAR
[408] => MC
[409] => MC
[410] => MCO
[411] => MD
[412] => MD
[413] => MDA
[414] => ME
[415] => ME
[416] => MNE
[417] => MF
[418] => MF
[419] => MAF
[420] => MG
[421] => MG
[422] => MDG
[423] => MH
[424] => MH
[425] => MHL
[426] => MK
[427] => MK
[428] => MKD
[429] => ML
[430] => ML
[431] => MLI
[432] => MM
[433] => MM
[434] => MMR
[435] => MN
[436] => MN
[437] => MNG
[438] => MO
[439] => MO
[440] => MAC
[441] => MP
[442] => MP
[443] => MNP
[444] => MQ
[445] => MQ
[446] => MTQ
[447] => MR
[448] => MR
[449] => MRT
[450] => MS
[451] => MS
[452] => MSR
[453] => MT
[454] => MT
[455] => MLT
[456] => MU
[457] => MU
[458] => MUS
[459] => MV
[460] => MV
[461] => MDV
[462] => MW
[463] => MW
[464] => MWI
[465] => MX
[466] => MX
[467] => MEX
[468] => MY
[469] => MY
[470] => MYS
[471] => MZ
[472] => MZ
[473] => MOZ
[474] => NA
[475] => NA
[476] => NAM
[477] => NC
[478] => NC
[479] => NCL
[480] => NE
[481] => NE
[482] => NER
[483] => NF
[484] => NF
[485] => NFK
[486] => NG
[487] => NG
[488] => NGA
[489] => NI
[490] => NI
[491] => NIC
[492] => NL
[493] => NL
[494] => NLD
[495] => NO
[496] => NO
[497] => NOR
[498] => NP
[499] => NP
[500] => NPL
[501] => NR
[502] => NR
[503] => NRU
[504] => NU
[505] => NU
[506] => NIU
[507] => NZ
[508] => NZ
[509] => NZL
[510] => OM
[511] => OM
[512] => OMN
[513] => PA
[514] => PA
[515] => PAN
[516] => PE
[517] => PE
[518] => PER
[519] => PF
[520] => PF
[521] => PYF
[522] => PG
[523] => PG
[524] => PNG
[525] => PH
[526] => PH
[527] => PHL
[528] => PK
[529] => PK
[530] => PAK
[531] => PL
[532] => PL
[533] => POL
[534] => PM
[535] => PM
[536] => SPM
[537] => PN
[538] => PN
[539] => PCN
[540] => PR
[541] => PR
[542] => PRI
[543] => PS
[544] => PS
[545] => PSE
[546] => PT
[547] => PT
[548] => PRT
[549] => PW
[550] => PW
[551] => PLW
[552] => PY
[553] => PY
[554] => PRY
[555] => QA
[556] => QA
[557] => QAT
[558] => RE
[559] => RE
[560] => REU
[561] => RO
[562] => RO
[563] => ROU
[564] => RS
[565] => RS
[566] => SRB
[567] => RU
[568] => RU
[569] => RUS
[570] => RW
[571] => RW
[572] => RWA
[573] => SA
[574] => SA
[575] => SAU
[576] => SB
[577] => SB
[578] => SLB
[579] => SC
[580] => SC
[581] => SYC
[582] => SD
[583] => SD
[584] => SDN
[585] => SE
[586] => SE
[587] => SWE
[588] => SG
[589] => SG
[590] => SGP
[591] => SH
[592] => SH
[593] => SHN
[594] => SI
[595] => SI
[596] => SVN
[597] => SJ
[598] => SJ
[599] => SJM
[600] => SK
[601] => SK
[602] => SVK
[603] => SL
[604] => SL
[605] => SLE
[606] => SM
[607] => SM
[608] => SMR
[609] => SN
[610] => SN
[611] => SEN
[612] => SO
[613] => SO
[614] => SOM
[615] => SR
[616] => SR
[617] => SUR
[618] => ST
[619] => ST
[620] => STP
[621] => SV
[622] => SV
[623] => SLV
[624] => SY
[625] => SY
[626] => SYR
[627] => SZ
[628] => SZ
[629] => SWZ
[630] => TC
[631] => TC
[632] => TCA
[633] => TD
[634] => TD
[635] => TCD
[636] => TF
[637] => TF
[638] => ATF
[639] => TG
[640] => TG
[641] => TGO
[642] => TH
[643] => TH
[644] => THA
[645] => TJ
[646] => TJ
[647] => TJK
[648] => TK
[649] => TK
[650] => TKL
[651] => TL
[652] => TL
[653] => TLS
[654] => TM
[655] => TM
[656] => TKM
[657] => TN
[658] => TN
[659] => TUN
[660] => TO
[661] => TO
[662] => TON
[663] => TR
[664] => TR
[665] => TUR
[666] => TT
[667] => TT
[668] => TTO
[669] => TV
[670] => TV
[671] => TUV
[672] => TW
[673] => TW
[674] => TWN
[675] => TZ
[676] => TZ
[677] => TZA
[678] => UA
[679] => UA
[680] => UKR
[681] => UG
[682] => UG
[683] => UGA
[684] => UM
[685] => UM
[686] => UMI
[687] => US
[688] => US
[689] => USA
[690] => UY
[691] => UY
[692] => URY
[693] => UZ
[694] => UZ
[695] => UZB
[696] => VA
[697] => VA
[698] => VAT
[699] => VC
[700] => VC
[701] => VCT
[702] => VE
[703] => VE
[704] => VEN
[705] => VG
[706] => VG
[707] => VGB
[708] => VI
[709] => VI
[710] => VIR
[711] => VN
[712] => VN
[713] => VNM
[714] => VU
[715] => VU
[716] => VUT
[717] => WF
[718] => WF
[719] => WLF
[720] => WS
[721] => WS
[722] => WSM
[723] => YE
[724] => YE
[725] => YEM
[726] => YT
[727] => YT
[728] => MYT
[729] => ZA
[730] => ZA
[731] => ZAF
[732] => ZM
[733] => ZM
[734] => ZMB
[735] => ZW
[736] => ZW
[737] => ZWE
[7] => Array
[file] => /home/verleihnix/public_html/app/code/core/Mage/Directory/data/directory_setup/data-install-1.6.0.0.php
[line] => 99
[function] => insertArray
[type] => ->
[args] => Array
[0] => magento_directory_country
[1] => Array
[0] => country_id
[1] => iso2_code
[2] => iso3_code
[2] => Array
[0] => Array
[0] => AD
[1] => AD
[2] => AND
[1] => Array
[0] => AE
[1] => AE
[2] => ARE
[2] => Array
[0] => AF
[1] => AF
[2] => AFG
[3] => Array
[0] => AG
[1] => AG
[2] => ATG
[4] => Array
[0] => AI
[1] => AI
[2] => AIA
[5] => Array
[0] => AL
[1] => AL
[2] => ALB
[6] => Array
[0] => AM
[1] => AM
[2] => ARM
[7] => Array
[0] => AN
[1] => AN
[2] => ANT
[8] => Array
[0] => AO
[1] => AO
[2] => AGO
[9] => Array
[0] => AQ
[1] => AQ
[2] => ATA
[10] => Array
[0] => AR
[1] => AR
[2] => ARG
[11] => Array
[0] => AS
[1] => AS
[2] => ASM
[12] => Array
[0] => AT
[1] => AT
[2] => AUT
[13] => Array
[0] => AU
[1] => AU
[2] => AUS
[14] => Array
[0] => AW
[1] => AW
[2] => ABW
[15] => Array
[0] => AX
[1] => AX
[2] => ALA
[16] => Array
[0] => AZ
[1] => AZ
[2] => AZE
[17] => Array
[0] => BA
[1] => BA
[2] => BIH
[18] => Array
[0] => BB
[1] => BB
[2] => BRB
[19] => Array
[0] => BD
[1] => BD
[2] => BGD
[20] => Array
[0] => BE
[1] => BE
[2] => BEL
[21] => Array
[0] => BF
[1] => BF
[2] => BFA
[22] => Array
[0] => BG
[1] => BG
[2] => BGR
[23] => Array
[0] => BH
[1] => BH
[2] => BHR
[24] => Array
[0] => BI
[1] => BI
[2] => BDI
[25] => Array
[0] => BJ
[1] => BJ
[2] => BEN
[26] => Array
[0] => BL
[1] => BL
[2] => BLM
[27] => Array
[0] => BM
[1] => BM
[2] => BMU
[28] => Array
[0] => BN
[1] => BN
[2] => BRN
[29] => Array
[0] => BO
[1] => BO
[2] => BOL
[30] => Array
[0] => BR
[1] => BR
[2] => BRA
[31] => Array
[0] => BS
[1] => BS
[2] => BHS
[32] => Array
[0] => BT
[1] => BT
[2] => BTN
[33] => Array
[0] => BV
[1] => BV
[2] => BVT
[34] => Array
[0] => BW
[1] => BW
[2] => BWA
[35] => Array
[0] => BY
[1] => BY
[2] => BLR
[36] => Array
[0] => BZ
[1] => BZ
[2] => BLZ
[37] => Array
[0] => CA
[1] => CA
[2] => CAN
[38] => Array
[0] => CC
[1] => CC
[2] => CCK
[39] => Array
[0] => CD
[1] => CD
[2] => COD
[40] => Array
[0] => CF
[1] => CF
[2] => CAF
[41] => Array
[0] => CG
[1] => CG
[2] => COG
[42] => Array
[0] => CH
[1] => CH
[2] => CHE
[43] => Array
[0] => CI
[1] => CI
[2] => CIV
[44] => Array
[0] => CK
[1] => CK
[2] => COK
[45] => Array
[0] => CL
[1] => CL
[2] => CHL
[46] => Array
[0] => CM
[1] => CM
[2] => CMR
[47] => Array
[0] => CN
[1] => CN
[2] => CHN
[48] => Array
[0] => CO
[1] => CO
[2] => COL
[49] => Array
[0] => CR
[1] => CR
[2] => CRI
[50] => Array
[0] => CU
[1] => CU
[2] => CUB
[51] => Array
[0] => CV
[1] => CV
[2] => CPV
[52] => Array
[0] => CX
[1] => CX
[2] => CXR
[53] => Array
[0] => CY
[1] => CY
[2] => CYP
[54] => Array
[0] => CZ
[1] => CZ
[2] => CZE
[55] => Array
[0] => DE
[1] => DE
[2] => DEU
[56] => Array
[0] => DJ
[1] => DJ
[2] => DJI
[57] => Array
[0] => DK
[1] => DK
[2] => DNK
[58] => Array
[0] => DM
[1] => DM
[2] => DMA
[59] => Array
[0] => DO
[1] => DO
[2] => DOM
[60] => Array
[0] => DZ
[1] => DZ
[2] => DZA
[61] => Array
[0] => EC
[1] => EC
[2] => ECU
[62] => Array
[0] => EE
[1] => EE
[2] => EST
[63] => Array
[0] => EG
[1] => EG
[2] => EGY
[64] => Array
[0] => EH
[1] => EH
[2] => ESH
[65] => Array
[0] => ER
[1] => ER
[2] => ERI
[66] => Array
[0] => ES
[1] => ES
[2] => ESP
[67] => Array
[0] => ET
[1] => ET
[2] => ETH
[68] => Array
[0] => FI
[1] => FI
[2] => FIN
[69] => Array
[0] => FJ
[1] => FJ
[2] => FJI
[70] => Array
[0] => FK
[1] => FK
[2] => FLK
[71] => Array
[0] => FM
[1] => FM
[2] => FSM
[72] => Array
[0] => FO
[1] => FO
[2] => FRO
[73] => Array
[0] => FR
[1] => FR
[2] => FRA
[74] => Array
[0] => GA
[1] => GA
[2] => GAB
[75] => Array
[0] => GB
[1] => GB
[2] => GBR
[76] => Array
[0] => GD
[1] => GD
[2] => GRD
[77] => Array
[0] => GE
[1] => GE
[2] => GEO
[78] => Array
[0] => GF
[1] => GF
[2] => GUF
[79] => Array
[0] => GG
[1] => GG
[2] => GGY
[80] => Array
[0] => GH
[1] => GH
[2] => GHA
[81] => Array
[0] => GI
[1] => GI
[2] => GIB
[82] => Array
[0] => GL
[1] => GL
[2] => GRL
[83] => Array
[0] => GM
[1] => GM
[2] => GMB
[84] => Array
[0] => GN
[1] => GN
[2] => GIN
[85] => Array
[0] => GP
[1] => GP
[2] => GLP
[86] => Array
[0] => GQ
[1] => GQ
[2] => GNQ
[87] => Array
[0] => GR
[1] => GR
[2] => GRC
[88] => Array
[0] => GS
[1] => GS
[2] => SGS
[89] => Array
[0] => GT
[1] => GT
[2] => GTM
[90] => Array
[0] => GU
[1] => GU
[2] => GUM
[91] => Array
[0] => GW
[1] => GW
[2] => GNB
[92] => Array
[0] => GY
[1] => GY
[2] => GUY
[93] => Array
[0] => HK
[1] => HK
[2] => HKG
[94] => Array
[0] => HM
[1] => HM
[2] => HMD
[95] => Array
[0] => HN
[1] => HN
[2] => HND
[96] => Array
[0] => HR
[1] => HR
[2] => HRV
[97] => Array
[0] => HT
[1] => HT
[2] => HTI
[98] => Array
[0] => HU
[1] => HU
[2] => HUN
[99] => Array
[0] => ID
[1] => ID
[2] => IDN
[100] => Array
[0] => IE
[1] => IE
[2] => IRL
[101] => Array
[0] => IL
[1] => IL
[2] => ISR
[102] => Array
[0] => IM
[1] => IM
[2] => IMN
[103] => Array
[0] => IN
[1] => IN
[2] => IND
[104] => Array
[0] => IO
[1] => IO
[2] => IOT
[105] => Array
[0] => IQ
[1] => IQ
[2] => IRQ
[106] => Array
[0] => IR
[1] => IR
[2] => IRN
[107] => Array
[0] => IS
[1] => IS
[2] => ISL
[108] => Array
[0] => IT
[1] => IT
[2] => ITA
[109] => Array
[0] => JE
[1] => JE
[2] => JEY
[110] => Array
[0] => JM
[1] => JM
[2] => JAM
[111] => Array
[0] => JO
[1] => JO
[2] => JOR
[112] => Array
[0] => JP
[1] => JP
[2] => JPN
[113] => Array
[0] => KE
[1] => KE
[2] => KEN
[114] => Array
[0] => KG
[1] => KG
[2] => KGZ
[115] => Array
[0] => KH
[1] => KH
[2] => KHM
[116] => Array
[0] => KI
[1] => KI
[2] => KIR
[117] => Array
[0] => KM
[1] => KM
[2] => COM
[118] => Array
[0] => KN
[1] => KN
[2] => KNA
[119] => Array
[0] => KP
[1] => KP
[2] => PRK
[120] => Array
[0] => KR
[1] => KR
[2] => KOR
[121] => Array
[0] => KW
[1] => KW
[2] => KWT
[122] => Array
[0] => KY
[1] => KY
[2] => CYM
[123] => Array
[0] => KZ
[1] => KZ
[2] => KAZ
[124] => Array
[0] => LA
[1] => LA
[2] => LAO
[125] => Array
[0] => LB
[1] => LB
[2] => LBN
[126] => Array
[0] => LC
[1] => LC
[2] => LCA
[127] => Array
[0] => LI
[1] => LI
[2] => LIE
[128] => Array
[0] => LK
[1] => LK
[2] => LKA
[129] => Array
[0] => LR
[1] => LR
[2] => LBR
[130] => Array
[0] => LS
[1] => LS
[2] => LSO
[131] => Array
[0] => LT
[1] => LT
[2] => LTU
[132] => Array
[0] => LU
[1] => LU
[2] => LUX
[133] => Array
[0] => LV
[1] => LV
[2] => LVA
[134] => Array
[0] => LY
[1] => LY
[2] => LBY
[135] => Array
[0] => MA
[1] => MA
[2] => MAR
[136] => Array
[0] => MC
[1] => MC
[2] => MCO
[137] => Array
[0] => MD
[1] => MD
[2] => MDA
[138] => Array
[0] => ME
[1] => ME
[2] => MNE
[139] => Array
[0] => MF
[1] => MF
[2] => MAF
[140] => Array
[0] => MG
[1] => MG
[2] => MDG
[141] => Array
[0] => MH
[1] => MH
[2] => MHL
[142] => Array
[0] => MK
[1] => MK
[2] => MKD
[143] => Array
[0] => ML
[1] => ML
[2] => MLI
[144] => Array
[0] => MM
[1] => MM
[2] => MMR
[145] => Array
[0] => MN
[1] => MN
[2] => MNG
[146] => Array
[0] => MO
[1] => MO
[2] => MAC
[147] => Array
[0] => MP
[1] => MP
[2] => MNP
[148] => Array
[0] => MQ
[1] => MQ
[2] => MTQ
[149] => Array
[0] => MR
[1] => MR
[2] => MRT
[150] => Array
[0] => MS
[1] => MS
[2] => MSR
[151] => Array
[0] => MT
[1] => MT
[2] => MLT
[152] => Array
[0] => MU
[1] => MU
[2] => MUS
[153] => Array
[0] => MV
[1] => MV
[2] => MDV
[154] => Array
[0] => MW
[1] => MW
[2] => MWI
[155] => Array
[0] => MX
[1] => MX
[2] => MEX
[156] => Array
[0] => MY
[1] => MY
[2] => MYS
[157] => Array
[0] => MZ
[1] => MZ
[2] => MOZ
[158] => Array
[0] => NA
[1] => NA
[2] => NAM
[159] => Array
[0] => NC
[1] => NC
[2] => NCL
[160] => Array
[0] => NE
[1] => NE
[2] => NER
[161] => Array
[0] => NF
[1] => NF
[2] => NFK
[162] => Array
[0] => NG
[1] => NG
[2] => NGA
[163] => Array
[0] => NI
[1] => NI
[2] => NIC
[164] => Array
[0] => NL
[1] => NL
[2] => NLD
[165] => Array
[0] => NO
[1] => NO
[2] => NOR
[166] => Array
[0] => NP
[1] => NP
[2] => NPL
[167] => Array
[0] => NR
[1] => NR
[2] => NRU
[168] => Array
[0] => NU
[1] => NU
[2] => NIU
[169] => Array
[0] => NZ
[1] => NZ
[2] => NZL
[170] => Array
[0] => OM
[1] => OM
[2] => OMN
[171] => Array
[0] => PA
[1] => PA
[2] => PAN
[172] => Array
[0] => PE
[1] => PE
[2] => PER
[173] => Array
[0] => PF
[1] => PF
[2] => PYF
[174] => Array
[0] => PG
[1] => PG
[2] => PNG
[175] => Array
[0] => PH
[1] => PH
[2] => PHL
[176] => Array
[0] => PK
[1] => PK
[2] => PAK
[177] => Array
[0] => PL
[1] => PL
[2] => POL
[178] => Array
[0] => PM
[1] => PM
[2] => SPM
[179] => Array
[0] => PN
[1] => PN
[2] => PCN
[180] => Array
[0] => PR
[1] => PR
[2] => PRI
[181] => Array
[0] => PS
[1] => PS
[2] => PSE
[182] => Array
[0] => PT
[1] => PT
[2] => PRT
[183] => Array
[0] => PW
[1] => PW
[2] => PLW
[184] => Array
[0] => PY
[1] => PY
[2] => PRY
[185] => Array
[0] => QA
[1] => QA
[2] => QAT
[186] => Array
[0] => RE
[1] => RE
[2] => REU
[187] => Array
[0] => RO
[1] => RO
[2] => ROU
[188] => Array
[0] => RS
[1] => RS
[2] => SRB
[189] => Array
[0] => RU
[1] => RU
[2] => RUS
[190] => Array
[0] => RW
[1] => RW
[2] => RWA
[191] => Array
[0] => SA
[1] => SA
[2] => SAU
[192] => Array
[0] => SB
[1] => SB
[2] => SLB
[193] => Array
[0] => SC
[1] => SC
[2] => SYC
[194] => Array
[0] => SD
[1] => SD
[2] => SDN
[195] => Array
[0] => SE
[1] => SE
[2] => SWE
[196] => Array
[0] => SG
[1] => SG
[2] => SGP
[197] => Array
[0] => SH
[1] => SH
[2] => SHN
[198] => Array
[0] => SI
[1] => SI
[2] => SVN
[199] => Array
[0] => SJ
[1] => SJ
[2] => SJM
[200] => Array
[0] => SK
[1] => SK
[2] => SVK
[201] => Array
[0] => SL
[1] => SL
[2] => SLE
[202] => Array
[0] => SM
[1] => SM
[2] => SMR
[203] => Array
[0] => SN
[1] => SN
[2] => SEN
[204] => Array
[0] => SO
[1] => SO
[2] => SOM
[205] => Array
[0] => SR
[1] => SR
[2] => SUR
[206] => Array
[0] => ST
[1] => ST
[2] => STP
[207] => Array
[0] => SV
[1] => SV
[2] => SLV
[208] => Array
[0] => SY
[1] => SY
[2] => SYR
[209] => Array
[0] => SZ
[1] => SZ
[2] => SWZ
[210] => Array
[0] => TC
[1] => TC
[2] => TCA
[211] => Array
[0] => TD
[1] => TD
[2] => TCD
[212] => Array
[0] => TF
[1] => TF
[2] => ATF
[213] => Array
[0] => TG
[1] => TG
[2] => TGO
[214] => Array
[0] => TH
[1] => TH
[2] => THA
[215] => Array
[0] => TJ
[1] => TJ
[2] => TJK
[216] => Array
[0] => TK
[1] => TK
[2] => TKL
[217] => Array
[0] => TL
[1] => TL
[2] => TLS
[218] => Array
[0] => TM
[1] => TM
[2] => TKM
[219] => Array
[0] => TN
[1] => TN
[2] => TUN
[220] => Array
[0] => TO
[1] => TO
[2] => TON
[221] => Array
[0] => TR
[1] => TR
[2] => TUR
[222] => Array
[0] => TT
[1] => TT
[2] => TTO
[223] => Array
[0] => TV
[1] => TV
[2] => TUV
[224] => Array
[0] => TW
[1] => TW
[2] => TWN
[225] => Array
[0] => TZ
[1] => TZ
[2] => TZA
[226] => Array
[0] => UA
[1] => UA
[2] => UKR
[227] => Array
[0] => UG
[1] => UG
[2] => UGA
[228] => Array
[0] => UM
[1] => UM
[2] => UMI
[229] => Array
[0] => US
[1] => US
[2] => USA
[230] => Array
[0] => UY
[1] => UY
[2] => URY
[231] => Array
[0] => UZ
[1] => UZ
[2] => UZB
[232] => Array
[0] => VA
[1] => VA
[2] => VAT
[233] => Array
[0] => VC
[1] => VC
[2] => VCT
[234] => Array
[0] => VE
[1] => VE
[2] => VEN
[235] => Array
[0] => VG
[1] => VG
[2] => VGB
[236] => Array
[0] => VI
[1] => VI
[2] => VIR
[237] => Array
[0] => VN
[1] => VN
[2] => VNM
[238] => Array
[0] => VU
[1] => VU
[2] => VUT
[239] => Array
[0] => WF
[1] => WF
[2] => WLF
[240] => Array
[0] => WS
[1] => WS
[2] => WSM
[241] => Array
[0] => YE
[1] => YE
[2] => YEM
[242] => Array
[0] => YT
[1] => YT
[2] => MYT
[243] => Array
[0] => ZA
[1] => ZA
[2] => ZAF
[244] => Array
[0] => ZM
[1] => ZM
[2] => ZMB
[245] => Array
[0] => ZW
[1] => ZW
[2] => ZWE
[8] => Array
[file] => /home/verleihnix/public_html/app/code/core/Mage/Core/Model/Resource/Setup.php
[line] => 624
[args] => Array
[0] => /home/verleihnix/public_html/app/code/core/Mage/Directory/data/directory_setup/data-install-1.6.0.0.php
[function] => include
[9] => Array
[line] => 391
[function] => _modifyResourceDb
[class] => Mage_Core_Model_Resource_Setup
[type] => ->
[args] => Array
[0] => data-install
[1] =>
[2] => 1.6.0.2
[10] => Array
[line] => 289
[function] => _installData
[type] => ->
[args] => Array
[0] => 1.6.0.2
[11] => Array
[line] => 269
[function] => applyDataUpdates
[type] => ->
[args] => Array
[12] => Array
[file] => /home/verleihnix/public_html/app/code/core/Mage/Install/Model/Installer/Console.php
[line] => 383
[function] => applyAllDataUpdates
[type] => ::
[args] => Array
[13] => Array
[file] => /home/verleihnix/public_html/install.php
[line] => 136
[function] => install
[class] => Mage_Install_Model_Installer_Console
[type] => ->
[args] => Array
[previous:Exception:private] =>
[errorInfo] => Array
[0] => 23000
[1] => 1062
[2] => Duplicate entry 'AD' for key 'PRIMARY'
</pre>
FAILED
ERROR: Error in file: "/home/verleihnix/public_html/app/code/core/Mage/Directory/data/directory_setup/data-install-1.6.0.0.php" - SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry 'AD' for key 'PRIMARY', query was: INSERT INTO `magento_directory_country` (`country_id`,`iso2_code`,`iso3_code`) VALUES (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?), (?, ?, ?)
More information on using this script can be found at http://www.magentocommerce.com/.
… Installation war nur partiell komplett.
Webserver wird neu gestartet … Bitte überprüfen Sie dies ggfs zusätzlich manuell auf einer Unix-Konsole!
… Fertig!
