long way here
i have a centos 5.3 vps. in the begining the installation of webmin + virtualmin went good. then when i was playing with it, i tried to add a new virtual host and i got an error regarding perl. i had to uninstall webmin, reinstall webmin, install virtualmin through the webmin module manager.
i have 2 domains : maindomain.com and hosteddomain.com
the document root for the maindomain.com is : /var/www/html
the document root for hosteddomain is : /home/123/public_html
i seeing the same page on the maindomain.com as on the hosteddomain.com , i see the page from /home/123/public_html on both of my domains. if i delete the hosteddomain.com, then i can see the page from /var/www/html .
im having an error :
The Suexec command on your system is configured to only run scripts under /var/www, but the Virtualmin base directory is /home. CGI and PHP scripts run as domain owners will not be executed.
( in fact my system is ready to use virtualmin, i hosted hosteddomain.com, i made a php script and php works )
if i comment # the line in httpd.conf where the suexec module is loaded, then the phenomen explained earlier ( on my main domain i see the page from the hosted domain ) is reversed. now i see on the hosted domain the page from the main domain.
my problem is simple : i have a path for the document root that is not followed. its like i have 2 different types of juice bottles, but the juice is the same in both of them.<br><br>Post edited by: paxnwo, at: 2009/04/24 15:58
Whoah! Back up the truck! That’s an insane over-reaction to a Perl error. It was probably just a mismatch between Webmin and Virtualmin versions.
This indicates you didn’t install using our automated install script, so you’ve opted to handle configuration and installation of all of the services manually. This is a very long and complicated process (several hours, if you know a lot about your OS and configuring Apache, Postfix, Dovecot, MySQL, procmail, BIND, etc., or several days or weeks, if you’re just learning)…are you sure you don’t want to use install.sh and let the script do things for you?
PHP working doesn’t indicate that suexec is working. The two are orthogonal issues. If you’re executing your scripts via mod_php, suexec never comes into play, and scripts are run as the Apache user.
I have no idea what this means. :wink:
But, I strongly suspect you have beliefs about how Apache works that are incorrect. Apache has two modes of operation…Virtualmin manages the name-based hosting mode of operation. Once you put Apache into virtual hosting mode, it no longer has any respect for a “default” DocumentRoot, which is what I suspect you’ve got for /var/www/html.
See the troubleshooting guide here:
http://www.virtualmin.com/component/option,com_openwiki/Itemid,48/id,troubleshooting_common_problems/#the_wrong_site_shows_up
that didnt help. now i have 3 domains : main, hosted1 and hosted2.
hosted2 seems to have no interfierence with the other two. i can start host on it. but on main and hosted1, i still see the same page, wrong website. the main domain, i dont know how, shows the page from the hosted1 domain.
any help ? some retard guide avaible ?
Okay, so here’s my hunch as to what’s going on.
See, in your /etc/httpd/conf/httpd.conf (the Apache config), there’s a series of sections towards the end of the file that should begin with a line like this:
[code:1]<VirtualHost x.y.z.q:80>[/code:1]
(where x.y.z.q is your systems IP address)
However, I think an incorrect line snuck in there. The incorrect line probably looks like this:
[code:1]<VirtualHost *:80>[/code:1]
So the incorrect way has a "*" in the VirtualHost section, the correct way uses the IP address instead.
Before doing anything, backup your Apache config (just in case!)
And then, look in the config file for lines beginning with "<VirtualHost", and make sure they all use your IP address, and not a "*" in there.
If you see a *, change it to your IP – and when you’re all done, restart Apache and give it another shot.
i cant modify my previous post. that is my httpd conf file. take a look at it. maybe is something wrong in there. there are no * . i looked for it.
Okay, that looks good, though to be sure I only see two active domains in there.
However, if you take what you have there, apply that to your config (after saving the original), and restart Apache (/etc/init.d/httpd restart), does that resolve your problem?
Ahh, I typed that out before seeing your second message.
Yeah, the forum can be obnoxious sometimes :slight_smile: Joe’s working on a new site for us though!
I have a feeling there’s some sort of configuration somewhere that’s throwing it off, though I’m not sure what at the moment if the above is your config. Either I’m overlooking it, or there’s something else in /etc/httpd/conf.d/ that’s causing the trouble.
Would you mind if I logged in to take a quick peek?
If that’s okay, you can use the remote support module to enable remote access if you’re using VM Pro, or you can just email me your root login details at eric@virtualmin.com. Be sure to include a link to this post, as well as your IP address.
do you use some IM apps ? lets have a talk there.
yahoo : paxnwo
skype : yudonsyme
( i dont see any private message button ;p )
do you have teamviewer ? i emailed you the detailes
Sorry, I don’t have those :wink:
I’m just looking to take a quick peek over SSH.
It’s okay if you aren’t comfortable with that or don’t have SSH available, but what I’d need to see are the other config files that Apache is including.
Could you tar or zip up your /etc/httpd/ directory, and either attach it to a post, or email it to me?
i emailed you the download link.
Yeah, your Apache config looks fine, I’m not really seeing a problem there.
If you restart Apache (/etc/init.d/httpd restart), do you see any errors or warnings? Do any errors show up in /var/log/httpd/error_log, or in any of the logs in /var/log/virtualmin/ ?
i emailed you the links.
Well, my attempts to access each of those sites shows up in the access log for them. That’s what I’d expect.
Are you sure that each isn’t working as they’re supposed to?
Do you have content posted in the public_html dirs for both?
Make sure you have some kind of content, even if it’s just a dummy “index.html”, in both.
the page from nullbyte.info show up on sech0st.com. the page from xgamess.com is fine. as sech0st.com is my main domain, it has it’s document root in /var/www/html . i dont know why it show up the index from /home/666/public_html . that’s the problem. maybe i must edit something at the bind server ?
since you are on a VPS a clean install would be simplest, depending on your RAM.
If it has min. of 256 MB the install.sh should go without problems.
just watch out that the OS template doesn’t have any odd repos in it, look in /etc/yum.repos.d
You need just the Centos and not any DAG repo. then install will be fine.
the domains will be created under /home as expected.
a reinstall would take less then an hour including virtualmin.
if you have less than 256MB RAM problems will stay.
Ahh there’s the problem.
There is no VirtualHost section in your Apache config for the domain "sech0st.com".
You’ll need to have a VirtualHost section (ie, a Virtual Server) for every domain you want to use – any domain without a Virtual Host section will fall back to a default Virtual Host. Which probably isn’t what you want :slight_smile:
( the domains and ips have been modified )
This is the main Apache server configuration file. It contains the
configuration directives that give the server its instructions.
See <URL:http://httpd.apache.org/docs/2.2/> for detailed information.
In particular, see
<URL:http://httpd.apache.org/docs/2.2/mod/directives.html>
for a discussion of each configuration directive.
Do NOT simply read the instructions in here without understanding
what they do. They’re here only as hints or reminders. If you are unsure
consult the online docs. You have been warned.
The configuration directives are grouped into three basic sections:
1. Directives that control the operation of the Apache server process as a
whole (the ‘global environment’).
2. Directives that define the parameters of the ‘main’ or ‘default’ server,
which responds to requests that aren’t handled by a virtual host.
These directives also provide default values for the settings
of all virtual hosts.
3. Settings for virtual hosts, which allow Web requests to be sent to
different IP addresses or hostnames and have them handled by the
same Apache server process.
Configuration and logfile names: If the filenames you specify for many
of the server’s control files begin with “/” (or “drive:/” for Win32), the
server will use that explicit path. If the filenames do not begin
with "/", the value of ServerRoot is prepended – so "logs/foo.log"
with ServerRoot set to "/etc/httpd" will be interpreted by the
server as "/etc/httpd/logs/foo.log".
Section 1: Global Environment
The directives in this section affect the overall operation of Apache,
such as the number of concurrent requests it can handle or where it
can find its configuration files.
Don’t give away too much information about all the subcomponents
we are running. Comment out this line if you don’t mind remote sites
finding out what major optional modules you are running
ServerTokens Prod
ServerRoot: The top of the directory tree under which the server’s
configuration, error, and log files are kept.
NOTE! If you intend to place this on an NFS (or otherwise network)
mounted filesystem then please read the LockFile documentation
(available at <URL:http://httpd.apache.org/docs/2.2/mod/mpm_common.html#lockfile>);
you will save yourself a lot of trouble.
Do NOT add a slash at the end of the directory path.
ServerRoot "/etc/httpd"
PidFile: The file in which the server should record its process
identification number when it starts.
PidFile run/httpd.pid
Timeout: The number of seconds before receives and sends time out.
Timeout 120
KeepAlive: Whether or not to allow persistent connections (more than
one request per connection). Set to "Off" to deactivate.
KeepAlive Off
MaxKeepAliveRequests: The maximum number of requests to allow
during a persistent connection. Set to 0 to allow an unlimited amount.
We recommend you leave this number high, for maximum performance.
MaxKeepAliveRequests 100
KeepAliveTimeout: Number of seconds to wait for the next request from the
same client on the same connection.
KeepAliveTimeout 15
Server-Pool Size Regulation (MPM specific)
prefork MPM
StartServers: number of server processes to start
MinSpareServers: minimum number of server processes which are kept spare
MaxSpareServers: maximum number of server processes which are kept spare
ServerLimit: maximum value for MaxClients for the lifetime of the server
MaxClients: maximum number of server processes allowed to start
MaxRequestsPerChild: maximum number of requests a server process serves
<IfModule prefork.c>
StartServers 8
MinSpareServers 5
MaxSpareServers 20
ServerLimit 256
MaxClients 256
MaxRequestsPerChild 4000
</IfModule>
worker MPM
StartServers: initial number of server processes to start
MaxClients: maximum number of simultaneous client connections
MinSpareThreads: minimum number of worker threads which are kept spare
MaxSpareThreads: maximum number of worker threads which are kept spare
ThreadsPerChild: constant number of worker threads in each server process
<IfModule worker.c>
StartServers 2
MaxClients 150
MinSpareThreads 25
MaxSpareThreads 75
ThreadsPerChild 25
MaxRequestsPerChild 0
</IfModule>
Listen: Allows you to bind Apache to specific IP addresses and/or
ports, in addition to the default. See also the <VirtualHost>
directive.
Change this to Listen on specific IP addresses as shown below to
prevent Apache from glomming onto all bound IP addresses (0.0.0.0)
#Listen 12.34.56.78:80
Listen 80
Dynamic Shared Object (DSO) Support
To be able to use the functionality of a module which was built as a DSO you
have to place corresponding `LoadModule’ lines at this location so the
directives contained in it are actually available before they are used.
Statically compiled modules (those listed by `httpd -l’) do not need
to be loaded here.
Example:
LoadModule foo_module modules/mod_foo.so
LoadModule auth_basic_module modules/mod_auth_basic.so
LoadModule auth_digest_module modules/mod_auth_digest.so
LoadModule authn_file_module modules/mod_authn_file.so
LoadModule authn_alias_module modules/mod_authn_alias.so
LoadModule authn_anon_module modules/mod_authn_anon.so
LoadModule authn_dbm_module modules/mod_authn_dbm.so
LoadModule authn_default_module modules/mod_authn_default.so
LoadModule authz_host_module modules/mod_authz_host.so
LoadModule authz_user_module modules/mod_authz_user.so
LoadModule authz_owner_module modules/mod_authz_owner.so
LoadModule authz_groupfile_module modules/mod_authz_groupfile.so
LoadModule authz_dbm_module modules/mod_authz_dbm.so
LoadModule authz_default_module modules/mod_authz_default.so
LoadModule ldap_module modules/mod_ldap.so
LoadModule authnz_ldap_module modules/mod_authnz_ldap.so
LoadModule include_module modules/mod_include.so
LoadModule log_config_module modules/mod_log_config.so
LoadModule logio_module modules/mod_logio.so
LoadModule env_module modules/mod_env.so
LoadModule ext_filter_module modules/mod_ext_filter.so
LoadModule mime_magic_module modules/mod_mime_magic.so
LoadModule expires_module modules/mod_expires.so
LoadModule deflate_module modules/mod_deflate.so
LoadModule headers_module modules/mod_headers.so
LoadModule usertrack_module modules/mod_usertrack.so
LoadModule setenvif_module modules/mod_setenvif.so
LoadModule mime_module modules/mod_mime.so
LoadModule dav_module modules/mod_dav.so
LoadModule status_module modules/mod_status.so
LoadModule autoindex_module modules/mod_autoindex.so
LoadModule info_module modules/mod_info.so
LoadModule dav_fs_module modules/mod_dav_fs.so
LoadModule vhost_alias_module modules/mod_vhost_alias.so
LoadModule negotiation_module modules/mod_negotiation.so
LoadModule dir_module modules/mod_dir.so
LoadModule actions_module modules/mod_actions.so
LoadModule speling_module modules/mod_speling.so
LoadModule userdir_module modules/mod_userdir.so
LoadModule alias_module modules/mod_alias.so
LoadModule rewrite_module modules/mod_rewrite.so
LoadModule proxy_module modules/mod_proxy.so
LoadModule proxy_balancer_module modules/mod_proxy_balancer.so
LoadModule proxy_ftp_module modules/mod_proxy_ftp.so
LoadModule proxy_http_module modules/mod_proxy_http.so
LoadModule proxy_connect_module modules/mod_proxy_connect.so
LoadModule cache_module modules/mod_cache.so
LoadModule suexec_module modules/mod_suexec.so
LoadModule disk_cache_module modules/mod_disk_cache.so
LoadModule file_cache_module modules/mod_file_cache.so
LoadModule mem_cache_module modules/mod_mem_cache.so
LoadModule cgi_module modules/mod_cgi.so
LoadModule version_module modules/mod_version.so
LoadModule unique_id_module modules/mod_unique_id.so
The following modules are not loaded by default:
#LoadModule cern_meta_module modules/mod_cern_meta.so
#LoadModule asis_module modules/mod_asis.so
LoadModule evasive20_module /usr/lib64/httpd/modules/mod_evasive20.so
Load config files from the config directory "/etc/httpd/conf.d".
Include conf.d/*.conf
ExtendedStatus controls whether Apache will generate "full" status
information (ExtendedStatus On) or just basic information (ExtendedStatus
Off) when the "server-status" handler is called. The default is Off.
#ExtendedStatus On
If you wish httpd to run as a different user or group, you must run
httpd as root initially and it will switch.
User/Group: The name (or #number) of the user/group to run httpd as.
. On SCO (ODT 3) use "User nouser" and "Group nogroup".
. On HPUX you may not be able to use shared memory as nobody, and the
suggested workaround is to create a user www and use that user.
NOTE that some kernels refuse to setgid(Group) or semctl(IPC_SET)
when the value of (unsigned)Group is above 60000;
don’t use Group #-1 on these systems!
User apache
Group apache
Section 2: ‘Main’ server configuration
The directives in this section set up the values used by the ‘main’
server, which responds to any requests that aren’t handled by a
<VirtualHost> definition. These values also provide defaults for
any <VirtualHost> containers you may define later in the file.
All of these directives may appear inside <VirtualHost> containers,
in which case these default settings will be overridden for the
virtual host being defined.
ServerAdmin: Your address, where problems with the server should be
e-mailed. This address appears on some server-generated pages, such
as error documents. e.g. admin@your-domain.com
ServerAdmin paxnwo@yahoo.com
ServerName gives the name and port that the server uses to identify itself.
This can often be determined automatically, but we recommend you specify
it explicitly to prevent problems during startup.
If this is not set to valid DNS name for your host, server-generated
redirections will not work. See also the UseCanonicalName directive.
If your host doesn’t have a registered DNS name, enter its IP address here.
You will have to access it by its address anyway, and this will make
redirections work in a sensible way.
ServerName www.maindomain.com:80
UseCanonicalName: Determines how Apache constructs self-referencing
URLs and the SERVER_NAME and SERVER_PORT variables.
When set "Off", Apache will use the Hostname and Port supplied
by the client. When set "On", Apache will use the value of the
ServerName directive.
UseCanonicalName Off
DocumentRoot: The directory out of which you will serve your
documents. By default, all requests are taken from this directory, but
symbolic links and aliases may be used to point to other locations.
DocumentRoot "/var/www/html"
Each directory to which Apache has access can be configured with respect
to which services and features are allowed and/or disabled in that
directory (and its subdirectories).
First, we configure the "default" to be a very restrictive set of
features.
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
Note that from this point forward you must specifically allow
particular features to be enabled - so if something’s not working as
you might expect, make sure that you have specifically enabled it
below.
This should be changed to whatever you set DocumentRoot to.
<Directory "/var/www/html">
Possible values for the Options directive are "None", "All",
or any combination of:
Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
Note that "MultiViews" must be named explicitly — "Options All"
doesn’t give it to you.
The Options directive is both complicated and important. Please see
http://httpd.apache.org/docs/2.2/mod/core.html#options
for more information.
Options Indexes FollowSymLinks
AllowOverride controls what directives may be placed in .htaccess files.
It can be "All", "None", or any combination of the keywords:
Options FileInfo AuthConfig Limit
AllowOverride None
Controls who can get stuff from this server.
Order allow,deny
Allow from all
</Directory>
UserDir: The name of the directory that is appended onto a user’s home
directory if a ~user request is received.
The path to the end user account ‘public_html’ directory must be
accessible to the webserver userid. This usually means that ~userid
must have permissions of 711, ~userid/public_html must have permissions
of 755, and documents contained therein must be world-readable.
Otherwise, the client will only receive a "403 Forbidden" message.
See also: http://httpd.apache.org/docs/misc/FAQ.html#forbidden
<IfModule mod_userdir.c>
# UserDir is disabled by default since it can confirm the presence
# of a username on the system (depending on home directory
# permissions).
UserDir disable root
# To enable requests to /~user/ to serve the user's public_html
# directory, remove the &quot;UserDir disable&quot; line above, and uncomment
# the following line instead:
#UserDir public_html
</IfModule>
Control access to UserDir directories. The following is an example
for a site where these directories are restricted to read-only.
#<Directory /home/*/public_html>
AllowOverride FileInfo AuthConfig Limit
Options MultiViews Indexes SymLinksIfOwnerMatch IncludesNoExec
<Limit GET POST OPTIONS>
Order allow,deny
Allow from all
</Limit>
<LimitExcept GET POST OPTIONS>
Order deny,allow
Deny from all
</LimitExcept>
#</Directory>
DirectoryIndex: sets the file that Apache will serve if a directory
is requested.
The index.html.var file (a type-map) is used to deliver content-
negotiated documents. The MultiViews Option can be used for the
same purpose, but it is much slower.
DirectoryIndex index.html index.html.var
AccessFileName: The name of the file to look for in each directory
for additional configuration directives. See also the AllowOverride
directive.
AccessFileName .htaccess
The following lines prevent .htaccess and .htpasswd files from being
viewed by Web clients.
<Files ~ "^.ht">
Order allow,deny
Deny from all
</Files>
TypesConfig describes where the mime.types file (or equivalent) is
to be found.
TypesConfig /etc/mime.types
DefaultType is the default MIME type the server will use for a document
if it cannot otherwise determine one, such as from filename extensions.
If your server contains mostly text or HTML documents, "text/plain" is
a good value. If most of your content is binary, such as applications
or images, you may want to use "application/octet-stream" instead to
keep browsers from trying to display binary files as though they are
text.
DefaultType text/plain
The mod_mime_magic module allows the server to use various hints from the
contents of the file itself to determine its type. The MIMEMagicFile
directive tells the module where the hint definitions are located.
<IfModule mod_mime_magic.c>
MIMEMagicFile /usr/share/magic.mime
MIMEMagicFile conf/magic
</IfModule>
HostnameLookups: Log the names of clients or just their IP addresses
e.g., www.apache.org (on) or 204.62.129.132 (off).
The default is off because it’d be overall better for the net if people
had to knowingly turn this feature on, since enabling it means that
each client request will result in AT LEAST one lookup request to the
nameserver.
HostnameLookups Off
EnableMMAP: Control whether memory-mapping is used to deliver
files (assuming that the underlying OS supports it).
The default is on; turn this off if you serve from NFS-mounted
filesystems. On some systems, turning it off (regardless of
filesystem) can improve performance; for details, please see
http://httpd.apache.org/docs/2.2/mod/core.html#enablemmap
#EnableMMAP off
EnableSendfile: Control whether the sendfile kernel support is
used to deliver files (assuming that the OS supports it).
filesystems. Please see
http://httpd.apache.org/docs/2.2/mod/core.html#enablesendfile
#EnableSendfile off
ErrorLog: The location of the error log file.
If you do not specify an ErrorLog directive within a <VirtualHost>
container, error messages relating to that virtual host will be
logged here. If you do define an error logfile for a <VirtualHost>
container, that host’s errors will be logged there and not here.
ErrorLog logs/error_log
LogLevel: Control the number of messages logged to the error_log.
Possible values include: debug, info, notice, warn, error, crit,
alert, emerg.
LogLevel warn
The following directives define some format nicknames for use with
a CustomLog directive (see below).
LogFormat "%h %l %u %t &quot;%r&quot; %>s %b &quot;%{Referer}i&quot; &quot;%{User-Agent}i&quot;" combined
LogFormat "%h %l %u %t &quot;%r&quot; %>s %b" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
"combinedio" includes actual counts of actual bytes received (%I) and sent (%O); this
requires the mod_logio module to be loaded.
#LogFormat "%h %l %u %t &quot;%r&quot; %>s %b &quot;%{Referer}i&quot; &quot;%{User-Agent}i&quot; %I %O" combinedio
The location and format of the access logfile (Common Logfile Format).
If you do not define any access logfiles within a <VirtualHost>
container, they will be logged here. Contrariwise, if you do
define per-<VirtualHost> access logfiles, transactions will be
logged therein and not in this file.
#CustomLog logs/access_log common
If you would like to have separate agent and referer logfiles, uncomment
the following directives.
#CustomLog logs/referer_log referer
#CustomLog logs/agent_log agent
For a single logfile with access, agent, and referer information
(Combined Logfile Format), use the following directive:
CustomLog logs/access_log combined
Optionally add a line containing the server version and virtual host
name to server-generated pages (internal error documents, FTP directory
listings, mod_status and mod_info output etc., but not CGI generated
documents or custom error documents).
Set to "EMail" to also include a mailto: link to the ServerAdmin.
Set to one of: On | Off | EMail
ServerSignature Off
Aliases: Add here as many aliases as you need (with no limit). The format is
Alias fakename realname
Note that if you include a trailing / on fakename then the server will
require it to be present in the URL. So “/icons” isn’t aliased in this
example, only "/icons/". If the fakename is slash-terminated, then the
realname must also be slash terminated, and if the fakename omits the
trailing slash, the realname must also omit it.
We include the /icons/ alias for FancyIndexed directory listings. If you
do not use FancyIndexing, you may comment this out.
Alias /icons/ "/var/www/icons/"
<Directory "/var/www/icons">
Options Indexes MultiViews
AllowOverride None
Order allow,deny
Allow from all
</Directory>
WebDAV module configuration section.
<IfModule mod_dav_fs.c>
# Location of the WebDAV lock database.
DAVLockDB /var/lib/dav/lockdb
</IfModule>
ScriptAlias: This controls which directories contain server scripts.
ScriptAliases are essentially the same as Aliases, except that
documents in the realname directory are treated as applications and
run by the server when requested rather than as documents sent to the client.
The same rules about trailing "/" apply to ScriptAlias directives as to
Alias.
ScriptAlias /cgi-bin/ "/var/www/cgi-bin/"
"/var/www/cgi-bin" should be changed to whatever your ScriptAliased
CGI directory exists, if you have that configured.
<Directory / >
AllowOverride None
Options None
Order allow,deny
Allow from all
</Directory>
Redirect allows you to tell clients about documents which used to exist in
your server’s namespace, but do not anymore. This allows you to tell the
clients where to look for the relocated document.
Example:
Redirect permanent /foo http://www.example.com/bar
Directives controlling the display of server-generated directory listings.
IndexOptions: Controls the appearance of server-generated directory
listings.
IndexOptions FancyIndexing VersionSort NameWidth=* HTMLTable
AddIcon* directives tell the server which icon to show for different
files or filename extensions. These are only displayed for
FancyIndexed directories.
AddIconByEncoding (CMP,/icons/compressed.gif) x-compress x-gzip
AddIconByType (TXT,/icons/text.gif) text/*
AddIconByType (IMG,/icons/image2.gif) image/*
AddIconByType (SND,/icons/sound2.gif) audio/*
AddIconByType (VID,/icons/movie.gif) video/*
AddIcon /icons/binary.gif .bin .exe
AddIcon /icons/binhex.gif .hqx
AddIcon /icons/tar.gif .tar
AddIcon /icons/world2.gif .wrl .wrl.gz .vrml .vrm .iv
AddIcon /icons/compressed.gif .Z .z .tgz .gz .zip
AddIcon /icons/a.gif .ps .ai .eps
AddIcon /icons/layout.gif .html .shtml .htm .pdf
AddIcon /icons/text.gif .txt
AddIcon /icons/c.gif .c
AddIcon /icons/p.gif .pl .py
AddIcon /icons/f.gif .for
AddIcon /icons/dvi.gif .dvi
AddIcon /icons/uuencoded.gif .uu
AddIcon /icons/script.gif .conf .sh .shar .csh .ksh .tcl
AddIcon /icons/tex.gif .tex
AddIcon /icons/bomb.gif core
AddIcon /icons/back.gif …
AddIcon /icons/hand.right.gif README
AddIcon /icons/folder.gif ^^DIRECTORY^^
AddIcon /icons/blank.gif ^^BLANKICON^^
DefaultIcon is which icon to show for files which do not have an icon
explicitly set.
DefaultIcon /icons/unknown.gif
AddDescription allows you to place a short description after a file in
server-generated indexes. These are only displayed for FancyIndexed
directories.
Format: AddDescription "description" filename
#AddDescription "GZIP compressed document" .gz
#AddDescription "tar archive" .tar
#AddDescription "GZIP compressed tar archive" .tgz
ReadmeName is the name of the README file the server will look for by
default, and append to directory listings.
HeaderName is the name of a file which should be prepended to
directory indexes.
ReadmeName README.html
HeaderName HEADER.html
IndexIgnore is a set of filenames which directory indexing should ignore
and not include in the listing. Shell-style wildcarding is permitted.
IndexIgnore .??* ~ # HEADER README RCS CVS *,v *,t
DefaultLanguage and AddLanguage allows you to specify the language of
a document. You can then use content negotiation to give a browser a
file in a language the user can understand.
Specify a default language. This means that all data
going out without a specific language tag (see below) will
be marked with this one. You probably do NOT want to set
this unless you are sure it is correct for all cases.
* It is generally better to not mark a page as
* being a certain language than marking it with the wrong
* language!
DefaultLanguage nl
Note 1: The suffix does not have to be the same as the language
keyword — those with documents in Polish (whose net-standard
language code is pl) may wish to use "AddLanguage pl .po" to
avoid the ambiguity with the common suffix for perl scripts.
Note 2: The example entries below illustrate that in some cases
the two character ‘Language’ abbreviation is not identical to
the two character ‘Country’ code for its country,
E.g. ‘Danmark/dk’ versus ‘Danish/da’.
Note 3: In the case of ‘ltz’ we violate the RFC by using a three char
specifier. There is ‘work in progress’ to fix this and get
the reference data for rfc1766 cleaned up.
Catalan (ca) - Croatian (hr) - Czech (cs) - Danish (da) - Dutch (nl)
English (en) - Esperanto (eo) - Estonian (et) - French (fr) - German (de)
Greek-Modern (el) - Hebrew (he) - Italian (it) - Japanese (ja)
Korean (ko) - Luxembourgeois* (ltz) - Norwegian Nynorsk (nn)
Norwegian (no) - Polish (pl) - Portugese (pt)
Brazilian Portuguese (pt-BR) - Russian (ru) - Swedish (sv)
Simplified Chinese (zh-CN) - Spanish (es) - Traditional Chinese (zh-TW)
AddLanguage ca .ca
AddLanguage cs .cz .cs
AddLanguage da .dk
AddLanguage de .de
AddLanguage el .el
AddLanguage en .en
AddLanguage eo .eo
AddLanguage es .es
AddLanguage et .et
AddLanguage fr .fr
AddLanguage he .he
AddLanguage hr .hr
AddLanguage it .it
AddLanguage ja .ja
AddLanguage ko .ko
AddLanguage ltz .ltz
AddLanguage nl .nl
AddLanguage nn .nn
AddLanguage no .no
AddLanguage pl .po
AddLanguage pt .pt
AddLanguage pt-BR .pt-br
AddLanguage ru .ru
AddLanguage sv .sv
AddLanguage zh-CN .zh-cn
AddLanguage zh-TW .zh-tw
LanguagePriority allows you to give precedence to some languages
in case of a tie during content negotiation.
Just list the languages in decreasing order of preference. We have
more or less alphabetized them here. You probably want to change this.
LanguagePriority en ca cs da de el eo es et fr he hr it ja ko ltz nl nn no pl pt pt-BR ru sv zh-CN zh-TW
ForceLanguagePriority allows you to serve a result page rather than
MULTIPLE CHOICES (Prefer) [in case of a tie] or NOT ACCEPTABLE (Fallback)
[in case no accepted languages matched the available variants]
ForceLanguagePriority Prefer Fallback
Specify a default charset for all content served; this enables
interpretation of all content as UTF-8 by default. To use the
default browser choice (ISO-8859-1), or to allow the META tags
in HTML content to override this choice, comment out this
directive:
AddDefaultCharset UTF-8
AddType allows you to add to or override the MIME configuration
file mime.types for specific file types.
#AddType application/x-tar .tgz
AddEncoding allows you to have certain browsers uncompress
information on the fly. Note: Not all browsers support this.
Despite the name similarity, the following Add* directives have nothing
to do with the FancyIndexing customization directives above.
#AddEncoding x-compress .Z
#AddEncoding x-gzip .gz .tgz
If the AddEncoding directives above are commented-out, then you
probably should define those extensions to indicate media types:
AddType application/x-compress .Z
AddType application/x-gzip .gz .tgz
AddHandler allows you to map certain file extensions to "handlers":
actions unrelated to filetype. These can be either built into the server
or added with the Action directive (see below)
To use CGI scripts outside of ScriptAliased directories:
(You will also need to add "ExecCGI" to the "Options" directive.)
#AddHandler cgi-script .cgi
For files that include their own HTTP headers:
#AddHandler send-as-is asis
For type maps (negotiated resources):
(This is enabled by default to allow the Apache "It Worked" page
to be distributed in multiple languages.)
AddHandler type-map var
Filters allow you to process content before it is sent to the client.
To parse .shtml files for server-side includes (SSI):
(You will also need to add "Includes" to the "Options" directive.)
AddType text/html .shtml
AddOutputFilter INCLUDES .shtml
Action lets you define media types that will execute a script whenever
a matching file is called. This eliminates the need for repeated URL
pathnames for oft-used CGI file processors.
Format: Action media/type /cgi-script/location
Format: Action handler-name /cgi-script/location
Customizable error responses come in three flavors:
1) plain text 2) local redirects 3) external redirects
Some examples:
#ErrorDocument 500 "The server made a boo boo."
#ErrorDocument 404 /missing.html
#ErrorDocument 404 "/cgi-bin/missing_handler.pl"
#ErrorDocument 402 http://www.example.com/subscription_info.html
Putting this all together, we can internationalize error responses.
We use Alias to redirect any /error/HTTP_<error>.html.var response to
our collection of by-error message multi-language collections. We use
includes to substitute the appropriate text.
You can modify the messages’ appearance without changing any of the
default HTTP_<error>.html.var files by adding the line:
Alias /error/include/ "/your/include/path/"
which allows you to create your own set of files by starting with the
/var/www/error/include/ files and
copying them to /your/include/path/, even on a per-VirtualHost basis.
Alias /error/ "/var/www/error/"
<IfModule mod_negotiation.c>
<IfModule mod_include.c>
<Directory "/var/www/error">
AllowOverride None
Options IncludesNoExec
AddOutputFilter Includes html
Order allow,deny
Allow from all
LanguagePriority en es de fr
</Directory>
ErrorDocument 400 /error/HTTP_BAD_REQUEST.html.var
ErrorDocument 401 /error/HTTP_UNAUTHORIZED.html.var
ErrorDocument 403 /error/HTTP_FORBIDDEN.html.var
ErrorDocument 404 /error/HTTP_NOT_FOUND.html.var
ErrorDocument 405 /error/HTTP_METHOD_NOT_ALLOWED.html.var
ErrorDocument 408 /error/HTTP_REQUEST_TIME_OUT.html.var
ErrorDocument 410 /error/HTTP_GONE.html.var
ErrorDocument 411 /error/HTTP_LENGTH_REQUIRED.html.var
ErrorDocument 412 /error/HTTP_PRECONDITION_FAILED.html.var
ErrorDocument 413 /error/HTTP_REQUEST_ENTITY_TOO_LARGE.html.var
ErrorDocument 414 /error/HTTP_REQUEST_URI_TOO_LARGE.html.var
ErrorDocument 415 /error/HTTP_UNSUPPORTED_MEDIA_TYPE.html.var
ErrorDocument 500 /error/HTTP_INTERNAL_SERVER_ERROR.html.var
ErrorDocument 501 /error/HTTP_NOT_IMPLEMENTED.html.var
ErrorDocument 502 /error/HTTP_BAD_GATEWAY.html.var
ErrorDocument 503 /error/HTTP_SERVICE_UNAVAILABLE.html.var
ErrorDocument 506 /error/HTTP_VARIANT_ALSO_VARIES.html.var
</IfModule>
</IfModule>
The following directives modify normal HTTP response behavior to
handle known problems with browser implementations.
BrowserMatch "Mozilla/2" nokeepalive
BrowserMatch "MSIE 4.0b2;" nokeepalive downgrade-1.0 force-response-1.0
BrowserMatch "RealPlayer 4.0" force-response-1.0
BrowserMatch "Java/1.0" force-response-1.0
BrowserMatch "JDK/1.0" force-response-1.0
The following directive disables redirects on non-GET requests for
a directory that does not include the trailing slash. This fixes a
problem with Microsoft WebFolders which does not appropriately handle
redirects for folders with DAV methods.
Same deal with Apple’s DAV filesystem and Gnome VFS support for DAV.
BrowserMatch "Microsoft Data Access Internet Publishing Provider" redirect-carefully
BrowserMatch "MS FrontPage" redirect-carefully
BrowserMatch "^WebDrive" redirect-carefully
BrowserMatch "^WebDAVFS/1.[0123]" redirect-carefully
BrowserMatch "^gnome-vfs/1.0" redirect-carefully
BrowserMatch "^XML Spy" redirect-carefully
BrowserMatch "^Dreamweaver-WebDAV-SCM1" redirect-carefully
Allow server status reports generated by mod_status,
with the URL of http://servername/server-status
Change the ".example.com" to match your domain to enable.
#<Location /server-status>
SetHandler server-status
Order deny,allow
Deny from all
Allow from .example.com
#</Location>
Allow remote server configuration reports, with the URL of
http://servername/server-info (requires that mod_info.c be loaded).
#<Location /server-info>
SetHandler server-info
Order deny,allow
Deny from all
#</Location>
Proxy Server directives. Uncomment the following lines to
enable the proxy server:
#<IfModule mod_proxy.c>
#ProxyRequests On
#<Proxy *>
Order deny,allow
Deny from all
#</Proxy>
Enable/disable the handling of HTTP/1.1 "Via:" headers.
("Full" adds the server version; "Block" removes all outgoing Via: headers)
Set to one of: Off | On | Full | Block
#ProxyVia On
To enable a cache of proxied content, uncomment the following lines.
See http://httpd.apache.org/docs/2.2/mod/mod_cache.html for more details.
#<IfModule mod_disk_cache.c>
CacheEnable disk /
CacheRoot "/var/cache/mod_proxy"
#</IfModule>
#</IfModule>
End of proxy directives.
Section 3: Virtual Hosts
VirtualHost: If you want to maintain multiple domains/hostnames on your
machine you can setup VirtualHost containers for them. Most configurations
use only name-based virtual hosts so the server doesn’t need to worry about
IP addresses. This is indicated by the asterisks in the directives below.
Please see the documentation at
<URL:http://httpd.apache.org/docs/2.2/vhosts/>
for further details before you try to setup virtual hosts.
You may use the command line option ‘-S’ to verify your virtual host
configuration.
Use name-based virtual hosting.
#NameVirtualHost *:80
NOTE: NameVirtualHost cannot be used without a port specifier
(e.g. :80) if mod_ssl is being used, due to the nature of the
SSL protocol.
VirtualHost example:
Almost any Apache directive may go into a VirtualHost container.
The first VirtualHost section is used for requests without a known
server name.
#<VirtualHost *:80>
ServerAdmin webmaster@dummy-host.example.com
DocumentRoot /www/docs/dummy-host.example.com
ServerName dummy-host.example.com
ErrorLog logs/dummy-host.example.com-error_log
CustomLog logs/dummy-host.example.com-access_log common
#</VirtualHost>
<FilesMatch ".(inc|.sql|.~)$">
Order allow,deny
Deny from all
</FilesMatch>
NameVirtualHost 87.55.210.176:80
<IfModule mod_evasive20.c>
DOSHashTableSize 3097
DOSPageCount 2
DOSSiteCount 50
DOSPageInterval 1
DOSSiteInterval 1
DOSBlockingPeriod 10
</IfModule>
<VirtualHost 87.55.210.176:80>
SuexecUserGroup "#503" "#502"
ServerName hosted1.com
ServerAlias www.hosted1.com
ServerAlias webmail.hosted1.com
ServerAlias admin.hosted1.com
DocumentRoot /home/666/public_html
ErrorLog /var/log/virtualmin/hosted1.com_error_log
CustomLog /var/log/virtualmin/hosted1.com_access_log combined
ScriptAlias /cgi-bin/ /home/666/cgi-bin/
<Directory /home/666/public_html>
Options -Indexes IncludesNOEXEC FollowSymLinks
allow from all
AllowOverride All
</Directory>
<Directory /home/666/cgi-bin>
allow from all
</Directory>
RewriteEngine on
RewriteCond %{HTTP_HOST} =webmail.hosted1.com
RewriteRule ^(.) https://hosted1.com:20000/ [R]
RewriteCond %{HTTP_HOST} =admin.hosted1.com
RewriteRule ^(.
) https://hosted1.com:10000/ [R]
</VirtualHost>
SuexecUserGroup "#502" "#501"
ServerName hosted2.com
ServerAlias www.hosted2.com
ServerAlias webmail.hosted2.com
ServerAlias admin.hosted2.com
DocumentRoot /home/123/public_html
ErrorLog /var/log/virtualmin/hosted2.com_error_log
CustomLog /var/log/virtualmin/hosted2.com_access_log combined
ScriptAlias /cgi-bin/ /home/123/cgi-bin/
<Directory /home/123/public_html>
allow from all
AllowOverride All
</Directory>
<Directory /home/123/cgi-bin>
allow from all
</Directory>
RewriteEngine on
RewriteCond %{HTTP_HOST} =webmail.hosted2.com
RewriteRule ^(.) https://hosted2.com:20000/ [R]
RewriteCond %{HTTP_HOST} =admin.hosted2.com
RewriteRule ^(.
) https://hosted2.com:10000/ [R]
</VirtualHost>
In particular, see
ServerTokens Prod
Timeout 120
KeepAlive Off
KeepAliveTimeout 15
prefork MPM
StartServers 8
MinSpareServers 5
MaxSpareServers 20
ServerLimit 256
MaxClients 256
</IfModule>
worker MPM
<IfModule worker.c>
StartServers 2
MaxClients 150
MinSpareThreads 25
MaxSpareThreads 75
ThreadsPerChild 25
</IfModule>
directive.
Listen 80
to be loaded here.
Example:
#ExtendedStatus On
User apache
Group apache
features.
<Directory />
AllowOverride None
</Directory>
below.
AllowOverride None
Order allow,deny
Allow from all
</Directory>
# permissions).
</IfModule>
Order allow,deny
Allow from all
</Limit>
Order deny,allow
Deny from all
</LimitExcept>
#</Directory>
is requested.
directive.
<Files ~ "^.ht">
Order allow,deny
Deny from all
</Files>
to be found.
text.
</IfModule>
nameserver.
HostnameLookups Off
#EnableMMAP off
#EnableSendfile off
alert, emerg.
LogLevel warn
ServerSignature Off
AllowOverride None
Order allow,deny
Allow from all
</Directory>
</IfModule>
Alias.
<Directory / >
AllowOverride None
Options None
Order allow,deny
Allow from all
</Directory>
Example:
listings.
explicitly set.
directories.
directory indexes.
* language!
DefaultLanguage nl
AddLanguage ca .ca
AddLanguage da .dk
AddLanguage de .de
AddLanguage el .el
AddLanguage en .en
AddLanguage eo .eo
AddLanguage es .es
AddLanguage et .et
AddLanguage fr .fr
AddLanguage he .he
AddLanguage hr .hr
AddLanguage it .it
AddLanguage ja .ja
AddLanguage ko .ko
AddLanguage nl .nl
AddLanguage nn .nn
AddLanguage no .no
AddLanguage pl .po
AddLanguage pt .pt
AddLanguage ru .ru
AddLanguage sv .sv
directive:
Some examples:
AllowOverride None
Order allow,deny
Allow from all
</Directory>
</IfModule>
</IfModule>
Order deny,allow
Deny from all
#</Location>
Order deny,allow
Deny from all
#</Location>
#ProxyRequests On
#<Proxy *>
Order deny,allow
Deny from all
#</Proxy>
#ProxyVia On
CacheEnable disk /
#</IfModule>
#</IfModule>
configuration.
SSL protocol.
server name.
#<VirtualHost *:80>
#</VirtualHost>
Order allow,deny
Deny from all
</FilesMatch>
DOSPageCount 2
DOSSiteCount 50
DOSPageInterval 1
DOSSiteInterval 1
</IfModule>
allow from all
AllowOverride All
</Directory>
allow from all
</Directory>
RewriteEngine on
RewriteRule ^(.
</VirtualHost>
allow from all
AllowOverride All
</Directory>
allow from all
</Directory>
RewriteEngine on
RewriteRule ^(.
</VirtualHost>
In particular, see
ServerTokens Prod
Timeout 120
KeepAlive Off
KeepAliveTimeout 15
prefork MPM
StartServers 8
MinSpareServers 5
MaxSpareServers 20
ServerLimit 256
MaxClients 256
</IfModule>
worker MPM
<IfModule worker.c>
StartServers 2
MaxClients 150
MinSpareThreads 25
MaxSpareThreads 75
ThreadsPerChild 25
</IfModule>
directive.
Listen 80
to be loaded here.
Example:
#ExtendedStatus On
User apache
Group apache
features.
<Directory />
AllowOverride None
</Directory>
below.
AllowOverride None
Order allow,deny
Allow from all
</Directory>
# permissions).
</IfModule>
Order allow,deny
Allow from all
</Limit>
Order deny,allow
Deny from all
</LimitExcept>
#</Directory>
is requested.
directive.
<Files ~ "^.ht">
Order allow,deny
Deny from all
</Files>
to be found.
text.
</IfModule>
nameserver.
HostnameLookups Off
#EnableMMAP off
#EnableSendfile off
alert, emerg.
LogLevel warn
ServerSignature Off
AllowOverride None
Order allow,deny
Allow from all
</Directory>
</IfModule>
Alias.
<Directory / >
AllowOverride None
Options None
Order allow,deny
Allow from all
</Directory>
Example:
listings.
explicitly set.
directories.
directory indexes.
* language!
DefaultLanguage nl
AddLanguage ca .ca
AddLanguage da .dk
AddLanguage de .de
AddLanguage el .el
AddLanguage en .en
AddLanguage eo .eo
AddLanguage es .es
AddLanguage et .et
AddLanguage fr .fr
AddLanguage he .he
AddLanguage hr .hr
AddLanguage it .it
AddLanguage ja .ja
AddLanguage ko .ko
AddLanguage nl .nl
AddLanguage nn .nn
AddLanguage no .no
AddLanguage pl .po
AddLanguage pt .pt
AddLanguage ru .ru
AddLanguage sv .sv
directive:
Some examples:
AllowOverride None
Order allow,deny
Allow from all
</Directory>
</IfModule>
</IfModule>
Order deny,allow
Deny from all
#</Location>
Order deny,allow
Deny from all
#</Location>
#ProxyRequests On
#<Proxy *>
Order deny,allow
Deny from all
#</Proxy>
#ProxyVia On
CacheEnable disk /
#</IfModule>
#</IfModule>
configuration.
SSL protocol.
server name.
#<VirtualHost *:80>
#</VirtualHost>
Order allow,deny
Deny from all
</FilesMatch>
DOSPageCount 2
DOSSiteCount 50
DOSPageInterval 1
DOSSiteInterval 1
</IfModule>
allow from all
AllowOverride All
</Directory>
allow from all
</Directory>
RewriteEngine on
RewriteRule ^(.
</VirtualHost>
allow from all
AllowOverride All
</Directory>
allow from all
</Directory>
RewriteEngine on
RewriteRule ^(.
</VirtualHost>
