I’ve set up gitlab on a virtualmin server and I want to add a LetsEncrypt SSL cert so I can access it via HTTPS without warnings.
I created a “sub-server” git.mydomain.com to keep it separate from my primary domain (which also has an SSL cert installed), and added a LetsEncrypt certificate for git.mydomain.com successfully through the interface, but it’s not securing port 8180 where I have gitlab running.
Does anyone know how I can configure the LetsEncrypt cert to work for port 8180?
Thanks for the reply. I should have mentioned, the main website uses Apache which gitlab is using nginx on port 8180.
There’s no error as such - The 8180 port is simply not secure when I load it in a browser (the cert is not loaded).
The settings on the SSL tab in Virtualmin look as they do when a letsencrypt cert is installed. It shows letsencrypt as the cert provider and shows paths to the certs. The cert is working fine on the sub-server on port 80 from what I can tell.
The VirtualHost looks just as you would expect:
SuexecUserGroup “#1075” “#1051”
ServerName git.mydomain.com
ServerAlias www.git.mydomain.com
ServerAlias mail.git.mydomain.com
ServerAlias webmail.git.mydomain.com
ServerAlias admin.git.mydomain.com
DocumentRoot /home/myuser/domains/git.mydomain.com/public_html
ErrorLog /var/log/virtualmin/git.mydomain.com_error_log
CustomLog /var/log/virtualmin/git.mydomain.com_access_log combined
ScriptAlias /cgi-bin/ /home/myuser/domains/git.mydomain.com/cgi-bin/
<Directory /home/myuser/domains/git.mydomain.com/public_html>
Options -Indexes +IncludesNOEXEC +SymLinksIfOwnerMatch
allow from all
Require all granted
<Directory /home/myuser/domains/git.mydomain.com/cgi-bin>
allow from all
Require all granted
I couldnt get ngnix working with the SSL cert so I configured gitlab to use apache rather than ngnix. I had to make a few manual tweaks to the apache VirtualHost for git.mydomain.com but as soon as I saved, everything sprang into life! Thanks for the help
