My SO is Debian 8. I already setup letsencrypt certificates for 3 virtual domains without problems with older versions of virtualmin.
Yesterday, i updated to 1.791 and created a new virtual domain. Now, when try to install the letsecrypt certificate from “manage ssl certificate” section the i get an error:
Updating letsencrypt and virtual environment dependencies...Retrying (Retry(total=4, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<pip._vendor.requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0xb695cf2c>: Failed to establish a new connection: [Errno -2] Name or service not known',)': /simple/setuptools/ After a lot retrials the process stops and get this error: ConnectionError: HTTPSConnectionPool(host='acme-v01.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0xb65bd04c>: Failed to establish a new connection: [Errno -2] Name or service not known',)) i can't find any info about this error and im really lost. Port 443 is open and can establish https connection with the website domain using self-signed certificate. The folder .well-known is created and has domain user and group owner which i think is right. Any help i really appreciate. Thanks.
