Hi:
sorry but this has worked before, already 2 times with different domains letsencrypt renewal error. In the last few months.
DNS is external and working though for autoconfig.problemdomain.com and autodiscover and also ping is working correct while as said, before working no problems.
See :
Last successful renewal 01/15/2018 1:27 PM
So problems are with autodiscover and autoconfig , manualy and automatic renewal. This wasn’t before as id did write and say
Only solving is possible with putting the domains and subdomains manual in the list below the automatic, then not the autoconfig in it. ( so have to remove the autoconfig) so putingt everything in the Domain names listed here without the autoconfig. While ssl.CertificateError: hostname ‘http://www.autoconfig.problemdomain.com’ doesn’t match either of 'autoconfig.servermaindomain.de
The Virtualmin server was installed August/September 2017 with version 6x and CENTOS 7.3 at that time
So something has changed for autoconfig. domain… it seems to try to renew the autoconfig for the hostname LE cert ‘vp.servermaindomain.de’ as you can read in the end of the error message below…
System hostname vp.servermaindomain.de Operating system CentOS Linux 7.4.1708
Webmin version 1.881
Usermin version 1.734
Virtualmin version 6.02 Theme version Authentic Theme 19.11.
SNI so same IP v4 as serverhostname.
Server hostname has also resoving IPv6 that problemdomains don’t have IP6 adress!
see
An error occurred requesting a new certificate for problemdomain.com, http://www.problemdomain.com, autoconfig.problemdomain.com, autodiscover.problemdomain.com from Let’s Encrypt : Web-based validation failed : Failed to request certificate :
File “/usr/libexec/webmin/webmin/acme_tiny.py”, line 250, in
main(sys.argv[1:])
File “/usr/libexec/webmin/webmin/acme_tiny.py”, line 246, in main
signed_crt = get_crt(args.account_key, args.csr, args.acme_dir, args.dns_hook, args.cleanup_hook, log=LOGGER, CA=args.ca)
File “/usr/libexec/webmin/webmin/acme_tiny.py”, line 154, in get_crt
resp = urlopen(wellknown_url)
File “/usr/lib64/python2.7/urllib2.py”, line 154, in urlopen
return opener.open(url, data, timeout)
File “/usr/lib64/python2.7/urllib2.py”, line 437, in open
response = meth(req, response)
File “/usr/lib64/python2.7/urllib2.py”, line 550, in http_response
‘http’, request, response, code, msg, hdrs)
File “/usr/lib64/python2.7/urllib2.py”, line 469, in error
result = self._call_chain(*args)
File “/usr/lib64/python2.7/urllib2.py”, line 409, in _call_chain
result = func(*args)
File “/usr/lib64/python2.7/urllib2.py”, line 656, in http_error_302
return self.parent.open(new, timeout=req.timeout)
File “/usr/lib64/python2.7/urllib2.py”, line 431, in open
response = self._open(req, data)
File “/usr/lib64/python2.7/urllib2.py”, line 449, in _open
‘_open’, req)
File “/usr/lib64/python2.7/urllib2.py”, line 1258, in https_open
context=self._context, check_hostname=self._check_hostname)
File “/usr/lib64/python2.7/urllib2.py”, line 1211, in do_open
h.request(req.get_method(), req.get_selector(), req.data, headers)
File “/usr/lib64/python2.7/httplib.py”, line 1017, in request
self._send_request(method, url, body, headers)
File “/usr/lib64/python2.7/httplib.py”, line 1051, in _send_request
self.endheaders(body)
File “/usr/lib64/python2.7/httplib.py”, line 1013, in endheaders
self._send_output(message_body)
File “/usr/lib64/python2.7/httplib.py”, line 864, in _send_output
self.send(msg)
File “/usr/lib64/python2.7/httplib.py”, line 826, in send
self.connect()
File “/usr/lib64/python2.7/httplib.py”, line 1236, in connect
server_hostname=sni_hostname)
File “/usr/lib64/python2.7/ssl.py”, line 350, in wrap_socket
_context=self)
File “/usr/lib64/python2.7/ssl.py”, line 611, in init
self.do_handshake()
File “/usr/lib64/python2.7/ssl.py”, line 841, in do_handshake
match_hostname(self.getpeercert(), self.server_hostname)
File “/usr/lib64/python2.7/ssl.py”, line 269, in match_hostname
% (hostname, ', '.join(map(repr, dnsnames))))
ssl.CertificateError: hostname ‘http://www.autoconfig.problemdomain.com’ doesn’t match either of ‘autoconfig.servermaindomain.de’, ‘autodiscover.servermaindomain.de’, ‘mail.servermaindomain.de’, ‘mail.vp.servermaindomain.de’, ‘servermaindomain.de’, ‘vp.servermaindomain.de’, ‘webmin.servermaindomain.de’, ‘webmin.vp.servermaindomain.de’, ‘http://www.servermaindomain.de’
