hi,
the letsencrypt integrated in virtualmin use
CA Issuers - URI:http://cert.int-x2.letsencrypt.org/
but lets encrypt use curently
CA Issuers - URI:http://cert.int-x3.letsencrypt.org/
This is the current one.
One way to use the right one is to read the cert it indicates:
CA Issuers - URI:http://cert.int-x3.letsencrypt.org/ so you could use this embeded info in the certificate to automaticaly download the right one each time instead of hardcoding it.
**Also modifying the domain later on does not fill the VIRTUALSERVER_SSL_CA variable making external script fails to have a complete chain configured. My action upon server creation is therefor not working for ssl created with letsencrypt. **
It would be great to have a script hook also for ssl modification and not only host modification has this change external proxy/filter config as well.
best regards,
Ghislain.
