The error seems clear? The Let’s Encrypt validation server can’t reach that file on your server. Could be a variety of causes. Maybe DNS doesn’t resolve to the right IP, maybe your web server isn’t running, maybe you’ve got an application or redirect rule or proxy rule sucking up requests and so it can’t reach that file.
Make sure that directory (.well-known) is reachable on your server, and Let’s Encrypt validation will probably work.
How much time does normally take to request new certificate? When I started using LE (in Virtualmin) few year ago it took few seconds. Lately it took few minutes. Was this normal or is it maybe a part of my problem which I am facing now? My server is behind Fortinet gateway and I am waiting for administrator to turn off SSL inspection to try if it’s maybe connected to my problem.
it is stated on le website - just read it. I think but cannot say for sure, it should be full 5 working days, if not sure check it on their website or error logs on your server.
Reinstalled Certbot and problem is fixed. And now it takes 5 seconds to renew, before this error it took few minutes always… idk what that was. Thanks anyway.
hi, with updated to debian 10 today I discovered that apt install certobot is no option - gave me tons of email about fails… if you updated your distro , can you check it out again please and let me know? massive thanks
