I have several domains on this server and I just created 2 new virtual servers today 1 no issues, the other nothing but hell with several attempts. I’m confused because all others on the server work except my system has a bias against this domain name - my domain name, so I guess it really does hate me… LOL.
Remove names that you don’t need certs for or that don’t have a valid http configuration. mail/autoconfig/autodiscover seem likely to be causing your problems.
So I chose " Domain names listed here" and not the default "Domains associated with this server.
I did just the domainname.com and WWW and it went through. I left off “mail”, “autoconfig”, and “autodiscover”
I had no issues with the other domain I setup prior to this one seconds before creating this one, the other day. The other one did take some time though, longer than usual.
As mentioned I have not had to do this before. And you bring up a GREAT point which made me take notice… I just noticed that there are now 5 domains being requested BY DEFAULT, not 3 - some recent upgrade obviously caused this as I never explicitly set this up this way. Use to be just:
“autoconfig” and “autodiscover” are NEW hosts being added by DNS on domain creation.
Did something change in the versions I’m running? and do I need to put in a BUG report?
Operating system = CentOS Linux 7.7.1908
Webmin version = 1.930
Usermin version = 1.780
Virtualmin version = 6.07
Authentic theme version = 19.39-2
Also caught this post while researching my reply above - so something wacky is going on with others too (no clue how to escalate this to the company if there is indeed an issue) https://virtualmin.com/node/65673
The autoconfig and autodiscover subdomains are there for the purpose of enabling mail clients to find out the server name, protocol and user name for a domain. If you’ve ever seen a mail client offer to configure itself automatically, that’s how it’s done. They aren’t “new hosts”; the subdomain names are picked up by apache in your normal domain configuration. Search /etc/apache2/sites-available/* for ‘autoconfig’ and ‘autodiscover’ and you can see how they get redirected to a configuration script.
If you don’t need autoconfiguration for mail clients that will connect to your server, you can remove them.
Letsencrypt sets them up for me OK though. I doubt they are the cause of your Letsencrypt problem.
