Well, if you have access to all your files, it may be possible to get things working again
You may want to try setting up an identical OS somewhere else, and begin copying relevant files from your current hard drive to your new system.
Your web files and email are all in /home.
Your databases are in /var/lib/mysql.
Your users are in /etc/passwd, /etc/shadow, and /etc/group.
All the Webmin/Virtualmin configuration is in /etc/webmin.
You’ll also have various other config files throughout /etc for the various services that were running – the Apache config, BIND config, and so on – you’ll want to copy that as well.
Well, the problem is that the Virtualmin backups really do a lot of work in order to back things up correctly
The Virtualmin backup process goes through every relevant config file, pulls out the section related to a given domain, and associates that with the backup for that domain. That happens for Apache, BIND, Postfix, and so on.
Without Virtualmin backups, you’ll have to do that entire process manually, which will be quite a bit of work. Though I do believe it’s possible
Since you’re trying to restore everything, what that means is that copying over the full config file for every service configured by Virtualmin should work for you (along with all the other files and directories mentioned above).
I have a old back up which was done with virtualmin, if I upload that get it to restore everything than copy over the datebases and files via winSCP think that would work?
If you have full backups, even older ones, that would really help.
You could first restore those backups – then copy the files from /home, and then the databases from /var/lib/mysql – and after that you should largely be in good shape!
edit that, there all coming up with datebase errors
A Database Error Occurred
Error Number: 1194
Table ‘nova_sessions’ is marked as crashed and should be repaired
SELECT * FROM (nova_sessions) WHERE session_id = ‘1ce927d0f573d3b0da037e76f81ba338’ AND ip_address = ‘86.6.56.216’ AND user_agent = ‘Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/536.5 (KHTML, like Gecko) Chrome/19.0.1084.52 Safari/536.5’
Filename: libraries/Session.php
Line Number: 213
Database error in vBulletin 4.1.2:
Invalid SQL:
UPDATE cache
SET locktime = 1339085299
WHERE cacheid = 'forumblock.04ccc27af4d69954fd7b5153c6cc5822';
MySQL Error : Table ‘cache’ is marked as crashed and should be repaired
Error Number : 1194
Request Date : Thursday, June 7th 2012 @ 05:08:19 PM
Error Date : Thursday, June 7th 2012 @ 05:08:20 PM
Script : http://mana4x2rpg.com/
Referrer :
IP Address : 86.6.56.216
Error Number: 1036
Table ‘nova_sessions’ is read only
INSERT INTO nova_sessions (session_id, ip_address, user_agent, last_activity, user_data) VALUES (‘6825126ec9a6e758cc3e208bf7f2495c’, ‘86.6.56.216’, ‘Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/536.5 (KHTML, like Gecko) Chrome/19.0.1084.52 Safari/536.5’, 1339085305, ‘’)
Still the same eric same errors ive jsut done a full reinstall (well I was doing it before you posted) as I thought I copyed over some “stuff” I shouldn’t have. But its just the same.
in one error its saying its read only? is there some thing I need to do after I copy the new sql files ?
nova_b5.nova_characters_data
Error : File ‘./nova_b5/nova_characters_data.MYD’ not found (Errcode: 13)
Error : Table ‘nova_characters_data’ is read only
error : Corrupt
nova_b5.nova_posts
Error : File ‘./nova_b5/nova_posts.MYD’ not found (Errcode: 13)
Error : Table ‘nova_posts’ is read only
error : Corrupt
nova_b5.nova_wiki_drafts
Error : File ‘./nova_b5/nova_wiki_drafts.MYD’ not found (Errcode: 13)
Error : Table ‘nova_wiki_drafts’ is read only
error : Corrupt
nova_fbi.nova_characters_data
Error : File ‘./nova_fbi/nova_characters_data.MYD’ not found (Errcode: 13)
error : Corrupt
nova_fbi.nova_posts
Error : File ‘./nova_fbi/nova_posts.MYD’ not found (Errcode: 13)
error : Corrupt
nova_sgc.nova_characters_data
Error : File ‘./nova_sgc/nova_characters_data.MYD’ not found (Errcode: 13)
error : Corrupt
nova_sgc.nova_missions
Error : File ‘./nova_sgc/nova_missions.MYD’ not found (Errcode: 13)
Error : Table ‘nova_missions’ is read only
error : Corrupt
nova_sgc.nova_posts
Error : File ‘./nova_sgc/nova_posts.MYD’ not found (Errcode: 13)
error : Corrupt
rpgrealm.wp_frm_fields
Error : File ‘./rpgrealm/wp_frm_fields.MYD’ not found (Errcode: 13)
Error : Table ‘wp_frm_fields’ is read only
error : Corrupt
rpgrealm.wp_options
Error : File ‘./rpgrealm/wp_options.MYD’ not found (Errcode: 13)
Error : Table ‘wp_options’ is read only
error : Corrupt
rpgrealm.wp_postmeta
Error : Table ‘wp_postmeta’ is read only
error : Corrupt
rpgrealm.wp_posts
Error : File ‘./rpgrealm/wp_posts.MYD’ not found (Errcode: 13)
Error : Table ‘wp_posts’ is read only
error : Corrupt
shieldomega.nova_access_groups
error : Table ‘shieldomega.nova_access_groups’ is read only
shieldomega.nova_access_pages
error : Table ‘shieldomega.nova_access_pages’ is read only
shieldomega.nova_access_roles
error : Table ‘shieldomega.nova_access_roles’ is read only
shieldomega.nova_applications
error : Table ‘shieldomega.nova_applications’ is read only
shieldomega.nova_awards
error : Table ‘shieldomega.nova_awards’ is read only
shieldomega.nova_awards_queue
error : Table ‘shieldomega.nova_awards_queue’ is read only
shieldomega.nova_awards_received
error : Table ‘shieldomega.nova_awards_received’ is read only
shieldomega.nova_bans
error : Table ‘shieldomega.nova_bans’ is read only
shieldomega.nova_catalogue_ranks
error : Table ‘shieldomega.nova_catalogue_ranks’ is read only
shieldomega.nova_catalogue_skins
error : Table ‘shieldomega.nova_catalogue_skins’ is read only
shieldomega.nova_catalogue_skinsecs
error : Table ‘shieldomega.nova_catalogue_skinsecs’ is read only
shieldomega.nova_characters
error : Table ‘shieldomega.nova_characters’ is read only
shieldomega.nova_characters_data
error : Table ‘shieldomega.nova_characters_data’ is read only
shieldomega.nova_characters_fields
error : Table ‘shieldomega.nova_characters_fields’ is read only
shieldomega.nova_characters_promotions
error : Table ‘shieldomega.nova_characters_promotions’ is read only
shieldomega.nova_characters_sections
error : Table ‘shieldomega.nova_characters_sections’ is read only
shieldomega.nova_characters_tabs
error : Table ‘shieldomega.nova_characters_tabs’ is read only
shieldomega.nova_characters_values
error : Table ‘shieldomega.nova_characters_values’ is read only
shieldomega.nova_coc
error : Table ‘shieldomega.nova_coc’ is read only
shieldomega.nova_departments_blk
error : Table ‘shieldomega.nova_departments_blk’ is read only
shieldomega.nova_docking
error : Table ‘shieldomega.nova_docking’ is read only
shieldomega.nova_docking_data
error : Table ‘shieldomega.nova_docking_data’ is read only
shieldomega.nova_docking_fields
error : Table ‘shieldomega.nova_docking_fields’ is read only
shieldomega.nova_docking_sections
error : Table ‘shieldomega.nova_docking_sections’ is read only
shieldomega.nova_docking_values
error : Table ‘shieldomega.nova_docking_values’ is read only
shieldomega.nova_login_attempts
error : Table ‘shieldomega.nova_login_attempts’ is read only
shieldomega.nova_manifests
error : Table ‘shieldomega.nova_manifests’ is read only
shieldomega.nova_menu_categories
error : Table ‘shieldomega.nova_menu_categories’ is read only
shieldomega.nova_menu_items
error : Table ‘shieldomega.nova_menu_items’ is read only
shieldomega.nova_messages
error : Table ‘shieldomega.nova_messages’ is read only
shieldomega.nova_mission_groups
error : Table ‘shieldomega.nova_mission_groups’ is read only
shieldomega.nova_missions
error : Table ‘shieldomega.nova_missions’ is read only
shieldomega.nova_news
error : Table ‘shieldomega.nova_news’ is read only
shieldomega.nova_news_categories
error : Table ‘shieldomega.nova_news_categories’ is read only
shieldomega.nova_news_comments
error : Table ‘shieldomega.nova_news_comments’ is read only
shieldomega.nova_personallogs
error : Table ‘shieldomega.nova_personallogs’ is read only
shieldomega.nova_personallogs_comments
error : Table ‘shieldomega.nova_personallogs_comments’ is read only
shieldomega.nova_positions_blk
error : Table ‘shieldomega.nova_positions_blk’ is read only
shieldomega.nova_posts
error : Table ‘shieldomega.nova_posts’ is read only
shieldomega.nova_posts_comments
error : Table ‘shieldomega.nova_posts_comments’ is read only
shieldomega.nova_privmsgs
error : Table ‘shieldomega.nova_privmsgs’ is read only
shieldomega.nova_privmsgs_to
error : Table ‘shieldomega.nova_privmsgs_to’ is read only
shieldomega.nova_ranks_blk
error : Table ‘shieldomega.nova_ranks_blk’ is read only
shieldomega.nova_security_questions
error : Table ‘shieldomega.nova_security_questions’ is read only
shieldomega.nova_sessions
error : Table ‘shieldomega.nova_sessions’ is read only
shieldomega.nova_settings
error : Table ‘shieldomega.nova_settings’ is read only
shieldomega.nova_sim_type
error : Table ‘shieldomega.nova_sim_type’ is read only
shieldomega.nova_specs
error : Table ‘shieldomega.nova_specs’ is read only
shieldomega.nova_specs_data
error : Table ‘shieldomega.nova_specs_data’ is read only
shieldomega.nova_specs_fields
error : Table ‘shieldomega.nova_specs_fields’ is read only
shieldomega.nova_specs_sections
error : Table ‘shieldomega.nova_specs_sections’ is read only
shieldomega.nova_specs_values
error : Table ‘shieldomega.nova_specs_values’ is read only
shieldomega.nova_system_components
error : Table ‘shieldomega.nova_system_components’ is read only
shieldomega.nova_system_info
error : Table ‘shieldomega.nova_system_info’ is read only
shieldomega.nova_system_versions
error : Table ‘shieldomega.nova_system_versions’ is read only
shieldomega.nova_tour
error : Table ‘shieldomega.nova_tour’ is read only
shieldomega.nova_tour_data
error : Table ‘shieldomega.nova_tour_data’ is read only
shieldomega.nova_tour_decks
error : Table ‘shieldomega.nova_tour_decks’ is read only
shieldomega.nova_tour_fields
error : Table ‘shieldomega.nova_tour_fields’ is read only
shieldomega.nova_tour_values
error : Table ‘shieldomega.nova_tour_values’ is read only
shieldomega.nova_uploads
error : Table ‘shieldomega.nova_uploads’ is read only
shieldomega.nova_user_loa
error : Table ‘shieldomega.nova_user_loa’ is read only
shieldomega.nova_user_prefs
error : Table ‘shieldomega.nova_user_prefs’ is read only
shieldomega.nova_user_prefs_values
error : Table ‘shieldomega.nova_user_prefs_values’ is read only
shieldomega.nova_users
error : Table ‘shieldomega.nova_users’ is read only
shieldomega.nova_wiki_categories
error : Table ‘shieldomega.nova_wiki_categories’ is read only
shieldomega.nova_wiki_comments
error : Table ‘shieldomega.nova_wiki_comments’ is read only
shieldomega.nova_wiki_drafts
error : Table ‘shieldomega.nova_wiki_drafts’ is read only
shieldomega.nova_wiki_pages
error : Table ‘shieldomega.nova_wiki_pages’ is read only
shieldomega.nova_wiki_restrictions
error : Table ‘shieldomega.nova_wiki_restrictions’ is read only
uss_nova.nova_characters_data
Error : File ‘./uss_nova/nova_characters_data.MYD’ not found (Errcode: 13)
error : Corrupt
uss_nova.nova_wiki_drafts
Error : File ‘./uss_nova/nova_wiki_drafts.MYD’ not found (Errcode: 13)
error : Corrupt
ussmarauder.wp_frm_fields
Error : File ‘./ussmarauder/wp_frm_fields.MYD’ not found (Errcode: 13)
error : Corrupt
ussmarauder.wp_options
Error : File ‘./ussmarauder/wp_options.MYD’ not found (Errcode: 13)
error : Corrupt
ussmarauder.wp_posts
Error : File ‘./ussmarauder/wp_posts.MYD’ not found (Errcode: 13)
error : Corrupt
