SYSTEM INFORMATION | |
OS type and version | Ubuntu 20.04 |
Virtualmin version | 6.17-3 |
Hi everyone,
Just a bit of background. I have around 6 wordpress sites hosted with hostgator shared services, and a bunch of 301 redirects, and I’m using the mail services as well for the 6 WP sites, plus 4 other sub domains for mail only. The shared server keeps getting hacked affecting my sites, I figured, maybe I can run my own VPS with cpanel type of admin panel and was recommended to use virtualmin. I’m a total noob, just started using it today.
All of my sites are quite lightweight, and they actually perform fine on the lowest baby HostGator plan. But, I literally only tried migrating one WP site over to virtualmin and it’s not working out for me. The site basically can’t stay online for more than a few mins, and mysql keeps crashing. I’m hosting on hetzner with the CPX11 server. Would this spec server be enough to host what I need?
When the site crashes, I need to do a sudo service mysql start to get it working again, but it only works for a couple mins before it crashes again.
SQL logs have some errors:
2022-04-12T01:00:23.291334Z 8 [ERROR] [MY-013134] [Server] Table ‘./mydomain/wp_options’ is marked as crashed and should be repaired
2022-04-12T01:00:23.294988Z 8 [Warning] [MY-010756] [Server] Checking table: ‘./mydomain/wp_options’
2022-04-12T01:00:23.613175Z 8 [ERROR] [MY-013134] [Server] Table ‘./mydomain/wp_usermeta’ is marked as crashed and should be repaired
2022-04-12T01:00:23.635012Z 8 [Warning] [MY-010756] [Server] Checking table: ‘./mydomain/wp_usermeta’
2022-04-12T01:00:36.077896Z 0 [System] [MY-010116] [Server] /usr/sbin/mysqld (mysqld 8.0.28-0ubuntu0.20.04.3) starting as process 101823
2022-04-12T01:00:36.096837Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
2022-04-12T01:00:36.681750Z 1 [System] [MY-013577] [InnoDB] InnoDB initialization has ended.
2022-04-12T01:00:39.829262Z 0 [System] [MY-010229] [Server] Starting XA crash recovery…
2022-04-12T01:00:40.619660Z 0 [System] [MY-010116] [Server] /usr/sbin/mysqld (mysqld 8.0.28-0ubuntu0.20.04.3) starting as process 101866
2022-04-12T01:00:40.632143Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
2022-04-12T01:00:41.211932Z 1 [System] [MY-013577] [InnoDB] InnoDB initialization has ended.
2022-04-12T01:00:44.432086Z 0 [System] [MY-010229] [Server] Starting XA crash recovery…
2022-04-12T01:00:45.323856Z 0 [System] [MY-010116] [Server] /usr/sbin/mysqld (mysqld 8.0.28-0ubuntu0.20.04.3) starting as process 101909
2022-04-12T01:00:45.336517Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
2022-04-12T01:00:46.431996Z 1 [System] [MY-013577] [InnoDB] InnoDB initialization has ended.
2022-04-12T01:00:47.178661Z 0 [System] [MY-010229] [Server] Starting XA crash recovery…
2022-04-12T01:00:47.216010Z 0 [System] [MY-010232] [Server] XA crash recovery finished.
It also complains about some tables:
2022-04-12T01:01:07.972977Z 0 [System] [MY-013602] [Server] Channel mysql_main configured to support TLS. Encrypted connections are now supported for this channel.
2022-04-12T01:01:08.005713Z 0 [System] [MY-011323] [Server] X Plugin ready for connections. Bind-address: ‘127.0.0.1’ port: 33060, socket: /var/run/mysqld/mysqlx.sock
2022-04-12T01:01:08.005753Z 0 [System] [MY-010931] [Server] /usr/sbin/mysqld: ready for connections. Version: ‘8.0.28-0ubuntu0.20.04.3’ socket: ‘/var/run/mysqld/mysqld.sock’ port: 3306 (Ubuntu).
2022-04-12T01:04:14.553301Z 10 [ERROR] [MY-013134] [Server] Table ‘./mydomain/wp_options’ is marked as crashed and should be repaired
2022-04-12T01:04:14.556930Z 10 [Warning] [MY-010756] [Server] Checking table: ‘./mydomain/wp_options’
2022-04-12T01:07:42.587293Z 19 [ERROR] [MY-013134] [Server] Table ‘./mydomain/wp_wc_admin_note_actions’ is marked as crashed and should be repaired
2022-04-12T01:07:42.591157Z 19 [Warning] [MY-010756] [Server] Checking table: ‘./mydomain/wp_wc_admin_note_actions’
2022-04-12T01:08:46.824272Z 21 [ERROR] [MY-013134] [Server] Table ‘./mydomain/wp_actionscheduler_claims’ is marked as crashed and should be repaired
2022-04-12T01:08:46.827113Z 21 [Warning] [MY-010756] [Server] Checking table: ‘./mydomain/wp_actionscheduler_claims’
sql status when the site fails:
sudo service mysql status
● mysql.service - MySQL Community Server
Loaded: loaded (/lib/systemd/system/mysql.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: signal) since Tue 2022-04-12 01:32:02 UTC; 15ms ago
Process: 106829 ExecStartPre=/usr/share/mysql/mysql-systemd-start pre (code=exited, status=0/SUCCESS)
Process: 106867 ExecStart=/usr/sbin/mysqld (code=killed, signal=KILL)
Main PID: 106867 (code=killed, signal=KILL)
Status: “Server startup in progress”
Apr 12 01:32:02 mydomain systemd[1]: mysql.service: Failed with result ‘signal’.
Apr 12 01:32:02 mydomain systemd[1]: Failed to start MySQL Community Server.
The site actually works fine on my existing shared server. Anyone have any idea, maybe something I didn’t set up right?
Thanks!
