system with over 250 sites… the / disk “was” 50G but now down to 10G…
Doing backups the server filled up the drive / SLAP FULL / “no space left on device”…
/tmp/.webmin/ was full…
Can we figure a way to get it to do one site at a time? I found a folder with every site it was trying to backup was in a tar file waiting for something… You can not put all /home in /tmp …
I did from 20 to 50 sites at a time to get the backup’ to run… !!!
Unless I’m mistaken, that’s how it actually works.
Also note that you can change Webmin’s temporary directory (for example to put it on another partition such as /home) over there: Webmin > Webmin Configuration > Advanced Options > Temporary files directory
