Hi, anytime somone sends us an email, it gets kicked back with the following error:
mail for gordon loops back to myself
here is whats in the details.txt file
Reporting-MTA: dns; gordon.atiptopcomputer.com
X-Postfix-Queue-ID: 6B0691222AA
X-Postfix-Sender: rfc822; **************@gmail.com
Arrival-Date: Mon, 29 Mar 2010 01:29:25 -0600 (MDT)
Final-Recipient: rfc822; ***********
Original-Recipient: rfc822****************
Action: failed
Status: 5.4.6
Diagnostic-Code: X-Postfix; mail for gordon loops back to myself
How can I resolve this?
Many thanks
Eric
March 29, 2010, 2:17pm
2
Something like that can happen if Postfix gets confused as to whether it’s actually the final destination for your email.
You may want to make sure of a few things:
Set your hostname to an actual “FQDN” – something like “gordon.atiptopcomputer.com ” rather than just “gordon”. You can check/set that with the “hostname” command on the command line.
Whatever your hostname is set to, make sure that appears next to your IP address in /etc/hosts
Also make sure that your hostname is listed in the mydestination line of /etc/postfix/main.cf.
I tried those and am still getting the issue, any other ideas?
Eric
March 30, 2010, 2:50am
4
Hrm, something about that error message is fishy.
Just for fun, could you paste in the output for the following:
Thanks!
output of hostname is: gordon.atiptopcomputer.com
/etc/hosts is
127.0.0.1 localhost
10.32.64.13 gordon gordon
The following lines are desirable for IPv6 capable hosts
::1 localhost ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
ff02::3 ip6-allhosts
postconf -n output:
append_dot_mydomain = no
biff = no
config_directory = /etc/postfix
home_mailbox = Maildir/
inet_interfaces = all
mailbox_size_limit = 0
mydestination = gordon.atiptopcomputer.com , localhost.atiptopcomputer.com , , localhost
myhostname = gordon.atiptopcomputer.com
mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
myorigin = /etc/mailname
readme_directory = no
recipient_delimiter = +
relayhost =
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
smtpd_sasl_auth_enable = yes
smtpd_tls_cert_file = /etc/ssl/certs/ssl-cert-snakeoil.pem
smtpd_tls_key_file = /etc/ssl/private/ssl-cert-snakeoil.key
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
smtpd_use_tls = yes
Eric
March 30, 2010, 3:01am
6
Aha!
This /etc/hosts entry is your problem:
Your hostname isn’t gordon, it’s “gordon.atiptopcomputer.com ”. So Postfix is getting confused.
Try changing that line to read:
10.32.64.13 gordon.atiptopcomputer.com gordon
made that change and still doing the same thing
