Shutting down postfix: [ OK ]
Starting postfix: [ OK ]
and the log i got those
Mar 15 09:37:10 server postfix/postfix-script[30451]: stopping the Postfix mail system
Mar 15 09:37:10 server postfix/master[8731]: terminating on signal 15
Mar 15 09:37:11 server postfix/postfix-script[30523]: starting the Postfix mail system
Mar 15 09:37:11 server postfix/master[30524]: daemon started – version 2.6.6, configuration /etc/postfix
i wanna ask mynetworks
mynetworks = 168.100.189.0/28, 127.0.0.0/8
should i change 168.100.189.0 to my VPS IP addresse ?
Mar 15 09:50:28 server postfix/qmgr[30752]: 65DC811A0AD1: from=, size=457, nrcpt=1 (queue active)
Mar 15 09:50:28 server postfix/qmgr[30752]: warning: connect to transport private/scan: No such file or directory
Mar 15 09:50:28 server postfix/error[30996]: 65DC811A0AD1: to=<***email***>, relay=none, delay=50779, delays=50779/0.01/0/0.01, dsn=4.3.0, status=deferred (mail transport unavailable)
Mar 15 09:55:00 server postfix/pickup[30751]: 91F8B11A0B37: uid=0 from=
Mar 15 09:55:00 server postfix/cleanup[31111]: 91F8B11A0B37: message-id=<20150315085500.91F8B11A0B37@server.*****.com>
Mar 15 09:55:00 server postfix/qmgr[30752]: 91F8B11A0B37: from=, size=450, nrcpt=1 (queue active)
Mar 15 09:55:00 server postfix/qmgr[30752]: warning: connect to transport private/scan: No such file or directory
Mar 15 09:55:00 server postfix/error[31113]: 91F8B11A0B37: to=<******>, relay=none, delay=0.38, delays=0.35/0.01/0/0.02, dsn=4.3.0, status=deferred (mail transport unavailable)
Hmm, the error “warning: connect to transport private/scan: No such file or directory” is a curious one. Could you paste in the contents of your /etc/postfix/master.cf file? I’m wondering if there’s something in there that’s causing the problem.
That said, it wouldn’t hurt to make sure your server’s IP or network shows up in the “mynetworks” line.
# Postfix master process configuration file. For details on the format
# of the file, see the master(5) manual page (command: "man 5 master").
# Do not forget to execute "postfix reload" after editing this file.
# service type private unpriv chroot wakeup maxproc command + args
# (yes) (yes) (yes) (never) (100)
smtp inet n - n - - smtpd
#submission inet n - n - - smtpd
# -o smtpd_tls_security_level=encrypt
# -o smtpd_sasl_auth_enable=yes
# -o smtpd_client_restrictions=permit_sasl_authenticated,reject
# -o milter_macro_daemon_name=ORIGINATING
#smtps inet n - n - - smtpd
# -o smtpd_tls_wrappermode=yes
#628 inet n - n - - qmqpd
pickup fifo n - n 60 1 pickup
cleanup unix n - n - 0 cleanup
qmgr fifo n - n 300 1 qmgr
#qmgr fifo n - n 300 1 oqmgr
tlsmgr unix - - n 1000? 1 tlsmgr
rewrite unix - - n - - trivial-rewrite
bounce unix - - n - 0 bounce
defer unix - - n - 0 bounce
trace unix - - n - 0 bounce
verify unix - - n - 1 verify
flush unix n - n 1000? 0 flush
proxymap unix - - n - - proxymap
proxywrite unix - - n - 1 proxymap
smtp unix - - n - - smtp
# When relaying mail as backup MX, disable fallback_relay to avoid MX loops
relay unix - - n - - smtp
-o smtp_fallback_relay=
# -o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq unix n - n - - showq
error unix - - n - - error
retry unix - - n - - error
discard unix - - n - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - n - - lmtp
anvil unix - - n - 1 anvil
scache unix - - n - 1 scache
# Interfaces to non-Postfix software. Be sure to examine the manual
# pages of the non-Postfix software to find out what options it wants.
# Many of the following services use the Postfix pipe(8) delivery
# agent. See the pipe(8) man page for information about ${recipient}
# and other message envelope options.
# maildrop. See the Postfix MAILDROP_README file for details.
# Also specify in main.cf: maildrop_destination_recipient_limit=1
#maildrop unix - n n - - pipe
# flags=DRhu user=vmail argv=/usr/local/bin/maildrop -d ${recipient}
# The Cyrus deliver program has changed incompatibly, multiple times.
#old-cyrus unix - n n - - pipe
# flags=R user=cyrus argv=/usr/lib/cyrus-imapd/deliver -e -m ${extension} ${user}
# Cyrus 2.1.5 (Amos Gouaux)
# Also specify in main.cf: cyrus_destination_recipient_limit=1
#cyrus unix - n n - - pipe
# user=cyrus argv=/usr/lib/cyrus-imapd/deliver -e -r ${sender} -m ${extension} ${user}
# See the Postfix UUCP_README file for configuration details.
#uucp unix - n n - - pipe
# flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
# Other external delivery methods.
#ifmail unix - n n - - pipe
# flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
#bsmtp unix - n n - - pipe
# flags=Fq. user=bsmtp argv=/usr/local/sbin/bsmtp -f $sender $nexthop $recipient
#scalemail-backend unix - n n - 2 pipe
# flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store
# ${nexthop} ${user} ${extension}
#mailman unix - n n - - pipe
# flags=FR user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py
# add follows to the end
I wrapped the config file above in “code” tags, which makes it look nicer. Joe is working on a migration to Drupal 7 though, which will come with an improved Forum.
It took me a few looks to notice this, but I think I see what might be causing the problem you’re experiencing… I think it’s related to this line that was added to the Postfix config:
content_filter = scan:127.0.0.1:10025
Try commenting that out, restart Postfix, and see if that resolve the issue for you.
What do you mean by the emails come to junk mail – is it emails being sent to users on your server end up in the spam folder? Or is that emails originating from your server end up in the junk folder on remote systems?
Hotmail, Gmail and many others will automatically mark your email as junk or spam if you miss any of this three options DKIM, SPF and rDNS. This site https://www.unlocktheinbox.com/resources/emailauthentication/ is great if you want to check your email and see if everything is in order. Last but not lease, like Eric suggested check if your domain or IP are on the black list.
