NOTE: Towards the bottom step by step example how you might be able to install.
I’m running 12.04, but I keep getting an issue which I’ve posted about in a separate post,
http://www.virtualmin.com/node/22983
When it searched for ‘States to display’, select Only new
, it found the following:
Package name webmin-server-manager
Update system APT
Package description Webmin module for ‘Cloudmin GPL for KVM’
Current state Running latest 6.4.kvm
Installed version 6.4.kvm
Available version 6.4.kvm
Installation source Virtualmin
Uninstalling, I get:
The following modules have been successfully deleted from your Webmin installation :
Cloudmin GPL for KVM in /usr/share/webmin/server-manager (6896 kB)
On trying to re-install, I get what you get!
Looking at the log from when I installed previously, it shows:
Building complete list of updates ..
Now installing webmin-server-manager ..
Installing package(s) with command apt-get -y install webmin-server-manager ..
Reading package lists…
Building dependency tree…
Reading state information…
The following packages were automatically installed and are no longer required:
linux-headers-3.2.0-23-generic linux-headers-3.2.0-23
Use ‘apt-get autoremove’ to remove them.
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 1295 kB of archives.
After this operation, 7168 B of additional disk space will be used.
Get:1 http://cloudmin.virtualmin.com/kvm/debian/ binary/ webmin-server-manager 6.4.kvm [1295 kB]
Fetched 1295 kB in 1s (700 kB/s)
Selecting previously unselected package webmin-server-manager.
(Reading database … 177090 files and directories currently installed.)
Unpacking webmin-server-manager (from …/webmin-server-manager_6.4.kvm_all.deb) …
Setting up webmin-server-manager (6.4.kvm) …
server-manager
… install complete.
Ok, so I tried sudo apt-get install webmin-server-manager
and it says webmin-server-manager is already the newest version.
I tried re-install from sudo ./cloudmin-kvm-debian-install.sh
and got Unable to locate package libdigest-sha1-perl
sudo reboot
sudo apt-get remove webmin-server-manager
Logged out of Webmin and back in.
Clicked on System Information
on the left.
Clicked on All installed packages are up to date
Clicked on Only new
Typed in cloudmin
and pressed Search.
Found 1 matching packages …
Select all. | Invert selection.
Package Description Status Source
webmin-server-manager Webmin module for ‘Cloudmin GPL for KVM’ Available for installation Virtualmin
