Checking for missing features …
… WARNING - The following features were enabled for one or more
domains in the backup, but do not exist on this system. Some
functions of the restored domains may not work : Mail for domain
Restoring backup for virtual server testdomain.com …
Restoring virtual server password, quota and other details …
… done
Updating administration password and quotas ..
.. done
Restoring Cron jobs ..
.. done
Extracting TAR file of home directory ..
I checked extracting the backup file manually and it was almost instantaneous being that it is a very small account. The entire backup folder is only 6.4MB.
Hmm, that’s an odd one! I don’t imagine you see any errors in /var/webmin/miniserv.error when that happens?
If not – I’d be curious what output you see if you run the “strace” command in the beginning of your backup command. Seeing the last 30 lines or so from that output would be helpful.
If I manually run the command it executes without error.
cd \/home\/mytestaccount && cat \/home\/mytestaccount\/virtualmin\-backup\/mytestaccount\.tar\.gz | gunzip -c | /usr/bin/tar xvfX - /tmp/.webmin/660139_1649_4_restore-domain.pl
x ./
x ./public_html/
x ./cgi-bin/
x ./logs/
x ./homes/
x ./.backup.lock
x ./.virtualmin-src
x ./logs/access_log
x ./logs/error_log
x ./public_html/index.php
x ./public_html/license.txt
x ./public_html/readme.html
x ./public_html/wp-activate.php
x ./public_html/wp-admin/
x ./public_html/wp-admin/js/nav-menu.js
x ./public_html/wp-admin/js/edit-comments.min.js
x ./public_html/wp-admin/js/customize-controls.min.js
x ./public_html/wp-admin/js/press-this.js
x ./public_html/wp-admin/js/customize-widgets.js
x ./public_html/wp-admin/js/inline-edit-tax.js
x ./public_html/wp-admin/js/xfn.min.js
x ./public_html/wp-admin/js/wp-fullscreen-stub.min.js
x ./public_html/wp-admin/js/wp-fullscreen-stub.js
x ./public_html/wp-admin/js/customize-nav-menus.min.js
x ./public_html/wp-admin/js/customize-nav-menus.js
As an update on the initial post my system is now running FreeBSD 10.3 with Webmin 1.791 and Virtualmin 5.0
