I’m trying to restore a backup from a Virtualmin Pro installation to a Virtualmin GPL installation to retrieve some files, however when I try and run the restore, I get an error message referring to Reseller accounts (I have a few accounts on the Pro install).
Can I not restore from Pro to GPL if reseller account is present?
One thing to add is that it is a sub domain, so i have created the top level domain and now the error message is related only to the missing reseller account.
I’ll talk to Jamie about that… it may not be possible to restore a Virtual Server that has reseller info in it on a Virtualmin GPL server. Jamie may know of a workaround though, I’ll let you know what he says.
I have tried that but all that appears inside the tar file is loads of folders, and trying to find the correct folder is difficult. Unless I’m doing something incorrectly?
You should see all the folders that were part of your Virtual Server… for example, the public_html folder.
If the file you wanted was within the public_html folder, you could untar the backup file, and then go into the public_html folder to find your file.
If you have your backup file in a temporary directory, and it’s named “domain.tar.gz”, you can untar it by typing “tar zxvf domain.tar.gz”. All the files and directories within that will start appearing in your current directory.
