When I was waiting for it completion , i was received a system restart signal at my remote console.
Probably the technical people from hosting force a restart remotely.
Then I lost my connection and I can’t connect to the server for a while.
When I am able to connect to the server again, I checked the log and found some error message regarding quotas
Setting Webmin theme
Setting Usermin theme
Error occurred while setting Usermin theme: Failed to open PID file at …/web-li
b-funcs.pl line 1340.
Configuring Postfix
Enabling Postfix and disabling Sendmail
Setting up freshclam
ClamAV update process started at Fri Jan 14 11:29:45 2011
main.cvd is up to date (version: 53, sigs: 846214, f-level: 53, builder: sven)
Downloading daily.cvd [ 4%]
Downloading daily.cvd [ 7%]
Downloading daily.cvd [ 11%]
Downloading daily.cvd [ 14%]
Downloading daily.cvd [ 18%]
Downloading daily.cvd [ 22%]
Downloading daily.cvd [ 25%]
Downloading daily.cvd [ 28%]
Downloading
Downloading daily.cvd [ 35%]
Downloading daily.cvd [ 39%]
Downloading daily.cvd [ 42%]
Downloading daily.cvd [ 45%]
Downloading daily.cvd [ 49%]
Downloading daily.cvd [ 53%]
Downloading daily.cvd [ 56%]
Downloading daily.cvd [ 60%]
Downloading daily.cvd [ 63%]
Downloading daily.cvd [ 66%]
Downloading daily.cvd [ 70%]
Downloading daily.cvd [ 73%]
Downloading daily.cvd [ 76%]
Downloading daily.cvd [ 80%]
Downloading daily.cvd [ 83%]
Downloading daily.cvd [ 87%]
Downloading daily.cvd [ 91%]
Downloading daily.cvd [ 94%]
Downloading daily.cvd [ 97%]
Downloading daily.cvd [100%]
daily.cvd updated (version: 12519, sigs: 16125, f-level: 58, builder: ccordes)
Downloading bytecode.cvd [ 21%]
Downloading bytecode.cvd [ 32%]
Downloading bytecode.cvd [ 43%]
Downloading bytecode.cvd [ 56%]
Downloading bytecode.cvd [ 67%]
Downloading bytecode.cvd [ 82%]
Downloading bytecode.cvd [ 96%]
Downloading bytecode.cvd [100%]
bytecode.cvd updated (version: 117, sigs: 29, f-level: 58, builder: edwin)
Database updated (862368 signatures) from database.clamav.net (IP: 58.64.137.62)
Configuring Dovecot for POP3 and IMAP
Enabling Dovecot POP3 and IMAP servers
Enabling ProFTPd
Starting proftpd: [ OK ]
Enabling SMTP authentication
Starting saslauthd: [ OK ]
Configuring Virtualmin
Configuring Procmail
Configuring Webalizer
Updating /etc/shells
Enabling MySQL and PostgreSQL
Enabling Apache
Configuring and enabling BIND
Configuring resolv.conf to use local DNS server
Configuring and enabling Mailman
Enabling status monitoring
Hiding the Webmin upgrade page
Error occurred hiding Webmin upgrade page:
convertquota: Quota file not found or has wrong format.
convertquota: Can’t open old format file for users on /
error: %post(virtualmin-base-1.0-61.rh.noarch) scriptlet failed, signal 1
It looks like it did complete, but that it wasn’t able to setup quotas on your server.
I’m not sure why that is… that’s an issue that sometimes comes up on certain VPS’s, but you mentioned that you’re using a dedicated server. Another possibility is that something is unusual about the filesystem your server has, and that Virtualmin doesn’t support it. You’d have to run the two commands I mentioned above for me to figure out that possibility though
/dev/hda3 on / type ext3 (rw,grpquota,usrquota)
proc on /proc type proc (rw)
sysfs on /sys type sysfs (rw)
devpts on /dev/pts type devpts (rw,gid=5,mode=620)
/dev/hda1 on /boot type ext3 (rw)
tmpfs on /dev/shm type tmpfs (rw)
none on /proc/sys/fs/binfmt_misc type binfmt_misc (rw)
sunrpc on /var/lib/nfs/rpc_pipefs type rpc_pipefs (rw)
Are you certain you’re working with a dedicated server and not a VPS?
Also, what yum repositories are setup there? You can determine that by looking in /etc/yum.repos.d. The MySQL error you’re seeing is what you’d typically receive after performing a major MySQL upgrade… which wouldn’t make sense when performing a typical install. But I might expect that sort of thing if a third party repository containing a newer MySQL were enabled…
