i have a name server NS2 but i want to rebuild this on a new box, im thinking of :
Install Centos on new box configure the networking the same as NS2 download install Virtuialmin, restore webmin backup from NS2 then restore Virtualmin Backup of NS2 to the new server shutdown old NS2 server, new server should then be up and running as NS2 ?
so acording to that document i dont have to back up the webmin part and restore the back up to the new server only the backup and restore of the virtualmin part ?
Well, to clarify – if you made changes to Webmin settings, you would want to copy those over as well.
The Virtual Server backup/restore only handles Virtualmin settings.
So, you have a good point, you’d want to restore those Webmin settings too
Though, if you’re changing distros – note that not all Webmin settings can move cleanly from one distribution to another.
I’m actually in the midst of doing some testing on Webmin settings, and will work on adding that component to the migration instructions over the next few days
ok cool… i just restored the webmin setting first from a back up i took from the other system and got PID error… i have restarted the box and also now restored the Virtualmin settings and again restarted and all seems fine with the box… though i will test it somemore …
any idea about the PID error …
also i only use CentOS 5.5 32 BIt as i dont like the 65 Bit version and some ftp stuff dont work correctly …
Well, we can help, but you’ll need to tell us the full errors that you’re seeing there
As far as FTP goes – FTP should work on both 32bit and 64bit systems. Let us know exactly what symptoms you’re seeing, including any error messages, and we’ll try to help.
the error i get when i restore from a web min back on a fresh install from another system is
Restore failed : Incorrect Webmin PID 3230
how what i do is restore the Webmin back up, restart the server, restore the virtualmin backup, restart the server and all seems fine… but i am checking stuff…
ok i have built the new server imported the webmin backup and virtualmin backup and apache will not start now i get the error
Failed to start apache :
Starting httpd: Syntax error on line 1011 of /etc/httpd/conf/httpd.conf:
can’t get fastcgi file info: /home/DOMAIN.COM/fcgi-bin/php5.fcgi(/home/DOMAIN.COM/fcgi-bin/php5.fcgi), errno: 13
though if i look in the dir i see the file and the contense its moaning about … any ideas to fix this ?
ok i have done some testing (lots of coffee and redbull!!!) and virtualmin phpcgifast does not seem to like running in a XenServer centos5.5 32bit installation
testing:
i have setup a virtualbox on my computer with virtualmin installed and centos5.5 32bit created a domain stopped apache and started it and all works no problems i set up a domain restarted apache and all was fine output of ls -la of the testdomain folder :
[root@ns2 ~]# ls -la /home/testssssss/fcgi-bin/
total 12
drwxr-xr-x 2 testssssss testssssss 4096 Jun 15 10:39 .
drwxr-x— 13 testssssss testssssss 4096 Jun 15 10:39 …
-rwxr-xr-x 1 testssssss testssssss 161 Jun 15 10:39 php5.fcgi
[root@ns2 ~]#
i set up a XenServer installation of centos 5.5 32bit virtualmin did the same thing created a domain stop apache and restarted it and i got the same apache error about cgi, ls -ls output below
[root@ns1 ~]# ls -la /home/test/fcgi-bin/
total 24
drwxr-xr-x 2 test test 4096 Jun 15 10:21 .
drwxr-x— 11 test test 4096 Jun 15 10:21 …
-rwxr-xr-x 1 test test 161 Jun 15 10:21 php5.fcgi
[root@ns1 ~]#
both machines where configured the same side by side and apart from the IP address and host name being differantthe configuration of both Centos 5.5 and virtual min are defaul, not other options entered.
so does this mean that apache has some problem with Xenserver???
my plan was to have 2 NS servers on Xenserver configured with some domains … could you see whats going on … if you need 2 test boxes i have set up please ask…
ok this is strange i have just switched my virtualbox machine on on that had a perfect config and fcgid is not working on this eithernow and i have done noting to this box … i have had a look around and in the apache config i can not see any referance to mod_fchid or anything like that …
Yeah, I’m not sure what’s going on, the problems you’re describing are pretty atypical. I can’t think of a reason why the VPS type you’re using would cause that sort of trouble. Any userspace application should run just fine, whether it’s Virtualbox or Xenserver shouldn’t matter.
The only thing I can think of is that some folks do run into really strange issues when there isn’t enough RAM allocated to the guest… how much RAM do you have there? You can determine that by running the command “free -m”.
As far as FCGID configuration goes – FCGID on CentOS would normally be configured in the file /etc/httpd/conf.d/fcgid.conf.
ok so i downloaded centos 5.3 32 bit and used the templete in xenserver to install centos i have installed xs tools, installed virtualmin created a test domain restarted apache and got the same error… i gave the vm 1.5gb ram and free theres 794MB free…
ok i have now installed a fresh box but using Ubuntu 10.4 Server LTS 32 Bit with the same paramiters as i did with centos and FCGID works fine… this is in a XenServer VM with 512MB ram i uploaded a restore of a domain that had the FCGID errors restarted the box set the website options thing to CGI restarted Apache, then set it back to FCGId restarted apache and all worked fine, so if there a problem with FCGI on Centos 5.5 32 Bit ?
