You only need that if your server is acting as a nameserver. If the DNS for your domains is setup elsewhere, then it’s no problem to disable the BIND feature and turn off the service.
It’s not always possible remove BIND entirely though, as on most distributions it’s listed as a Virtualmin dependency. However, it shouldn’t cause any problems if the service is stopped.
