ip addresses
To put a site on a different IP, do I need to do anything first or do I just need to type the ip address in the create virtual server page ? ("network interface": "virtual ip with: __"
As the other ips that my host assigned to me at the moment don’t even load.
Personally, I first add the IP address to the server first (which causes the IP to load on bootup), and then I setup the Virtual Server to use it.
In your case, I’d be curious if what you said might work – adding it to the “Virtual IP with ___” line, and see if that causes .it to bring up a new interface with that IP.
If not, you’ll simply need to add a new interface first. You can do that in Webmin -> Networking -> Network Interfaces, and add a new interface in there.
