#EDIT#
What am I doing wrong?
It looks like my 2 errors at this point are:
[code:1]rhinov:~# apt-get install libapache2-mod-ruby:
Reading package lists… Done
Building dependency tree… Done
E: Couldn’t find package libapache2-mod-ruby:
rhinov:~# apt-get install libcrypt-ssleay-perl
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libcrypt-ssleay-perl: Depends: libc6 (>= 2.5-5) but 2.3.6.ds1-13etch7 is to be installed
Depends: libssl0.9.8 (>= 0.9.8e-1) but 0.9.8c-4etch3 is to be installed
E: Broken packages
[/code:1]
I have a lisence and am using the copy pasted command line to install Virtual min and it fails as such, what am I missing? It was failing worse until I added universe repos:
deb http://ca.archive.ubuntu.com/ubuntu/ hardy universe
deb-src http://ca.archive.ubuntu.com/ubuntu/ hardy universe
deb http://ca.archive.ubuntu.com/ubuntu/ hardy-updates universe
deb-src http://ca.archive.ubuntu.com/ubuntu/ hardy-updates universe
And imported the keys for those repos. It got to the same point but with more errors. So now I am at this:
[code:1]
Resolving software.virtualmin.com… 70.86.4.226
Connecting to software.virtualmin.com|70.86.4.226|:80… connected.
HTTP request sent, awaiting response… 200 OK
Length: unspecified [text/plain]
[ <=> ] 40,697 144.46K/s
04:05:35 (144.04 KB/s) - `install.sh’ saved [40697]
Welcome to the Virtualmin Professional installer, version 1.0.0
The installation is quite stable and functional when run on a freshly
installed supported Operating System, but upgrades from existing .wbm-
based systems, or systems that already have Apache VirtualHost
directives or mail users, will very likely run into numerous problems.
Please read the Virtualmin Installation guide before proceeding if
your system is not a freshly installed and supported OS.
This script is not intended to update your system! It should only be
used to install Virtualmin Professional, on a supported OS. If you have
previously installed Virtualmin via this script or the GPL version of
this script, upgrades and updates should be handled within Virtualmin
itself. Once Virtualmin is installed, you never need to run this script
again.
The systems currently supported by install.sh are:
Fedora Core 5-8 on i386 and x86_64
CentOS and RHEL 3-5 on i386 and x86_64
OpenSUSE 10.0 on i586 and x86_64
Debian 3.1 and 4.0 on i386 and amd64
Ubuntu 6.06 LTS and 8.04 LTS on i386 and amd64
FreeBSD 7-RELEASE on i386 and amd64
If your OS is not listed above, this script will fail. More details
about the systems supported by the script can be found here:
http://www.virtualmin.com/os-support.html
Continue? (y/n) y
Checking for HTTP client…found /usr/bin/wget -nv
Checking for perl…found /usr/bin/perl
04:05:40 URL:http://software.virtualmin.com/lib/spinner [579/579] -> “spinner” [1]
Loading log4sh logging library…
04:05:41 URL:http://software.virtualmin.com/lib/log4sh [21395/21395] -> “log4sh” [1]
INFO - Started installation log in /root/virtualmin-install.log
INFO - Checking for fully qualified hostname…
INFO - Hostname OK: fully qualified as rhinov.rhinov.myabitat.net
INFO - Installing serial number and license key into /etc/virtualmin-license
INFO - Loading OS selection library…
04:05:47 URL:http://software.virtualmin.com/lib/oschooser.pl [4448/4448] -> “oschooser.pl” [1]
INFO - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - Loading OS list…
04:05:48 URL:http://software.virtualmin.com/lib/os_list.txt [3549/3549] -> “os_list.txt” [1]
INFO - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - Operating system name: Debian Linux
INFO - Operating system version: 4.0
INFO - Configuring package manager for Debian Linux 4.0…
INFO - Enabling universe repositories, if not already available…
INFO - Disabling cdrom repositories…
Get:1 http://ftp3.nrc.ca etch Release.gpg [386B]
Hit http://ftp3.nrc.ca etch Release
Get:2 http://security.debian.org etch/updates Release.gpg [189B]
Get:3 http://packages.medibuntu.org hardy Release.gpg [189B]
Ign http://ftp3.nrc.ca etch/main Packages/DiffIndex
Hit http://security.debian.org etch/updates Release
Ign http://ftp3.nrc.ca etch/main Sources/DiffIndex
Hit http://ftp3.nrc.ca etch/main Packages
Ign http://security.debian.org etch/updates/main Packages/DiffIndex
Hit http://ftp3.nrc.ca etch/main Sources
Ign http://security.debian.org etch/updates/contrib Packages/DiffIndex
Ign http://security.debian.org etch/updates/main Sources/DiffIndex
Get:4 http://packages.medibuntu.org hardy Release [9335B]
Ign http://security.debian.org etch/updates/contrib Sources/DiffIndex
Hit http://security.debian.org etch/updates/main Packages
Hit http://security.debian.org etch/updates/contrib Packages
Hit http://security.debian.org etch/updates/main Sources
Hit http://security.debian.org etch/updates/contrib Sources
Ign http://packages.medibuntu.org hardy/free Packages/DiffIndex
Ign http://packages.medibuntu.org hardy/non-free Packages/DiffIndex
Hit http://packages.medibuntu.org hardy/free Packages
Hit http://packages.medibuntu.org hardy/non-free Packages
Get:5 http://ca.archive.ubuntu.com hardy Release.gpg [189B]
Get:6 http://ca.archive.ubuntu.com hardy-updates Release.gpg [189B]
Hit http://ca.archive.ubuntu.com hardy Release
Hit http://ca.archive.ubuntu.com hardy-updates Release
Ign http://ca.archive.ubuntu.com hardy/universe Packages/DiffIndex
Ign http://ca.archive.ubuntu.com hardy/universe Sources/DiffIndex
Hit http://ca.archive.ubuntu.com hardy/universe Packages
Hit http://ca.archive.ubuntu.com hardy/universe Sources
Ign http://ca.archive.ubuntu.com hardy-updates/universe Packages/DiffIndex
Ign http://ca.archive.ubuntu.com hardy-updates/universe Sources/DiffIndex
Hit http://ca.archive.ubuntu.com hardy-updates/universe Packages
Hit http://ca.archive.ubuntu.com hardy-updates/universe Sources
Fetched 9340B in 1m40s (93B/s)
INFO - Cleaning up apt headers and packages, so we can start fresh…
INFO -
04:07:33 URL:http://software.virtualmin.com/lib/apt.conf.noninteractive [243/243] -> “apt.conf.noninteractive” [1]
INFO - Download of http://software.virtualmin.com/lib/apt.conf.noninteractive Succeeded.
INFO - Installing Webmin and Virtualmin package signing keys…
04:07:34 URL:http://software.virtualmin.com/lib/RPM-GPG-KEY-virtualmin [1690/1690] -> “RPM-GPG-KEY-virtualmin” [1]
INFO - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-virtualmin Succeeded.
04:07:35 URL:http://software.virtualmin.com/lib/RPM-GPG-KEY-webmin [1320/1320] -> “RPM-GPG-KEY-webmin” [1]
INFO - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-webmin Succeeded.
INFO - OK
INFO - OK
INFO - Get:1
INFO - Removing Debian standard Webmin package, if they exist (because they’re broken)…
INFO - Removing Debian apache packages…
INFO - Installing dependencies using command: /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install postfix postfix-pcre webmin usermin ruby libapache2-mod-ruby libxml-simple-perl libcrypt-ssleay-perl unzip zip
…in progress, please wait… |E: Broken packages /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install postfix postfix-pcre webmin usermin ruby libapache2-mod-ruby libxml-simple-perl libcrypt-ssleay-perl unzip zip failed. Error (if any): 0
Displaying the last 15 lines of /root/virtualmin-install.log to help troubleshoot this problem:
ruby is already the newest version.
libxml-simple-perl is already the newest version.
unzip is already the newest version.
libapache2-mod-ruby: Depends: libc6 (>= 2.7-1) but 2.3.6.ds1-13etch7 is to be installed
Depends: libruby1.8 (>= 1.8.6.111) but 1.8.5-4etch2 is to be installed
FATAL - Fatal Error Occurred: Something went wrong during installation: 0
FATAL - File a ticket in the Virtualmin bugs and issues tracker for further assistance.
[/code:1]
Post edited by: AbitatSupport, at: 2008/10/31 07:26
Post edited by: AbitatSupport, at: 2008/10/31 07:27<br><br>Post edited by: AbitatSupport, at: 2008/10/31 08:25
