Running Debian Lenny (x64) on my server, and I’m at a loss here. When I run the install.sh script, it gets almost all the way through and then it spits out this message:
Displaying the last 15 lines of /root/virtualmin-install.log to help troubleshoot this problem: subprocess post-installation script returned error exit status 1 dpkg: dependency problems prevent configuration of postgresql: postgresql depends on postgresql-8.3; however: Package postgresql-8.3 is not configured yet. dpkg: error processing postgresql (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of virtualmin-base: virtualmin-base depends on postgresql; however: Package postgresql is not configured yet. dpkg: error processing virtualmin-base (--configure): dependency problems - leaving unconfigured Errors were encountered while processing: postgresql-8.3 postgresql virtualmin-baseFATAL - Fatal Error Occurred: Installation failed: 0
It looks like it’s hanging up on postgresql with dependency problems, and I don’t know what I have to do to make it install the rest of the way. Are there extra sources I need to put in sources.lst to make postgresql install properly?
I’ve searched through these forums as best I can and googled it in general, but I haven’t found anything that I understand in the way of fixing the problem. Here’s hoping someone sees this and knows the way to fix it.
