> My question is now that I have a compiler installed is it bad to just leave it there? Should I uninstall it? If so how?
It’s a convenience versus security thing.
If you don’t think you need a compiler, some might suggest removing it so you aren’t making it simpler for someone who might break in to compile anything they might want to run on your system.
If you think you may want the compiler later, you just have to weigh the benefit of having ready access to a compiler versus making it a pain for intruders to have their way with your system
As a whole, I tend to vote for removing unnecessary packages, you just have to decide what’s unnecessary
To remove a package, just type "rpm -e PACKAGENAME".
