Hi All,
Does anyone know how to make virtualmin play nice with nagios and cacti on the same box? the default install works fine but I would ideally like them in their own virtualhosts
i.e.
and
however if I manually edit the default apache config files for nagios and cacti to make them virtualhosts it works but breaks the default site. if i try to change it virtualmin says it cant handle the swap
failed : Cannot handle swap between /etc/apache2/sites-available/
Any ideas? it does seam i can create two new virtualhosts and copy the content of the default files to it. then delete the symlinks in /etc/apache2/conf.d but not sure if that will mess up apt package managment
