Installer script fails trying to configure mysql on RHEL
Operating system: RHEL
OS version: 8.3
When I try to install virtualmin using the install script, it always fails configuring mysql with the error
Error: Systemd service mysqld cannot be created unless a command is given
When I enable debug, it doesn’t tell me anything related to the error.
I have tried installing on 3 different servers, all running RHEL 8.3, all failing at the same part during installiton with the same error.
If you search this error in the forum, you will find the solution. It’s been discussed.
Thank you, the solution in the other thread worked.
I hadn’t thought of searching the forum, I had only used google.
