i have been trying to install Virtuamin GPL on my Virtual Private Server…using the install.sh
but the installer gives me errors
Configuration file `/etc/apache2/mods-available/dav_svn.load’, does not exist on system.
Installing new config file as you request.
Configuration file `/etc/apache2/mods-available/dav_svn.conf’, does not exist on system.
Considering dependency dav for dav_svn:
Enabling module dav.
Enabling module dav_svn.
Run ‘/etc/init.d/apache2 restart’ to activate new configuration!
Setting up linux-libc-dev (2.6.26-15lenny2) …
Setting up libc6-dev (2.7-18) …
Setting up libdbd-pg-perl (2.8.7-1) …
Setting up libdigest-sha1-perl (2.11-2+b1) …
Setting up libdigest-hmac-perl (1.01-7) …
Setting up liberror-perl (0.17-1) …
Setting up libhtml-template-perl (2.9-1) …
Setting up libsocket6-perl (0.20-1) …
Setting up libio-socket-inet6-perl (2.54-1) …
Setting up libnetaddr-ip-perl (4.007+dfsg-2+b1) …
Setting up libnet-ip-perl (1.25-2) …
Setting up libnet-dns-perl (0.63-2) …
Setting up libmail-spf-perl (2.005-1) …
Setting up libnet-xwhois-perl (0.90-3) …
Setting up libpg-perl (1:2.1.1-4) …
Setting up libsasl2-modules (2.1.22.dfsg1-23) …
Setting up libsys-hostname-long-perl (1.4-2) …
Setting up libsys-syslog-perl (0.26-1) …
Setting up libterm-readkey-perl (2.30-4) …
Setting up mysql-client (5.0.51a-24+lenny1) …
Setting up mysql-server (5.0.51a-24+lenny1) …
Setting up php5-cli (5.2.6.dfsg.1-1+lenny3) …
Creating config file /etc/php5/cli/php.ini with new version
Setting up php-pear (5.2.6.dfsg.1-1+lenny3) …
Configuration file `/etc/pear/pear.conf’, does not exist on system.
Setting up php5-cgi (5.2.6.dfsg.1-1+lenny3) …
Creating config file /etc/php5/cgi/php.ini with new version
Setting up php5 (5.2.6.dfsg.1-1+lenny3) …
Setting up postgresql-client-common (94lenny1) …
Configuration file `/etc/postgresql-common/user_clusters’, does not exist on sys tem.
Setting up postgresql-client-8.3 (8.3.7-0lenny1) …
Setting up postgresql-common (94lenny1) …
Configuration file `/etc/logrotate.d/postgresql-common’, does not exist on syste m.
Configuration file `/etc/postgresql-common/autovacuum.conf’, does not exist on s ystem.
Configuration file `/etc/cron.d/postgresql-common’, does not exist on system.
supported_versions: WARNING: Unknown Debian release: 5.0
Adding user postgres to group ssl-cert
Setting up postgresql-8.3 (8.3.7-0lenny1) …
Configuration file `/etc/init.d/postgresql-8.3’, does not exist on system.
Creating new cluster (configuration: /etc/postgresql/8.3/main, data: /var/lib/po stgresql/8.3/main)…
Moving configuration file /var/lib/postgresql/8.3/main/postgresql.conf to /etc/p ostgresql/8.3/main…
Moving configuration file /var/lib/postgresql/8.3/main/pg_hba.conf to /etc/postg resql/8.3/main…
Moving configuration file /var/lib/postgresql/8.3/main/pg_ident.conf to /etc/pos tgresql/8.3/main…
Configuring postgresql.conf to use port 5432…
Starting PostgreSQL 8.3 database server: main.
Setting up postgresql (8.3.7-0lenny1) …
Setting up procmail-wrapper (1.0-2) …
Setting up proftpd-basic (1.3.1-17lenny2) …
Configuration file `/etc/default/proftpd’, does not exist on system.
Configuration file `/etc/ftpusers’, does not exist on system.
Configuration file `/etc/pam.d/proftpd’, does not exist on system.
Configuration file `/etc/cron.monthly/proftpd’, does not exist on system.
Configuration file `/etc/init.d/proftpd’, does not exist on system.
--------- IMPORTANT INFORMATION FOR XINETD USERS ----------
The following line will be added to your /etc/inetd.conf file:
ftp stream tcp nowait root /usr/sbin/tcpd /usr/sbin/proftpd
If you are indeed using xinetd, you will have to convert the
above into /etc/xinetd.conf format, and add it manually. See
/usr/share/doc/xinetd/README.Debian for more information.
Suggested entry (automatically converted using itox):
service ftp
socket_type = stream
protocol = tcp
wait = no
user = root
You must use option -daemon_dir if you use tcpd
Adding system user proftpd' (UID 112) ... Adding new user
proftpd’ (UID 112) with group nogroup' ... Not creating home directory
/var/run/proftpd’.
Adding system user ftp' (UID 113) ... Adding new user
ftp’ (UID 113) with group nogroup' ... Creating home directory
/home/ftp’ …
/usr/share/proftpd/templates/welcome.msg' ->
/home/ftp/welcome.msg.proftpd-new ’
Starting ftp server: proftpd.
Setting up proftpd-mod-mysql (1.3.1-17lenny2) …
Setting up proftpd-mod-pgsql (1.3.1-17lenny2) …
Setting up proftpd-mod-ldap (1.3.1-17lenny2) …
Setting up proftpd (1.3.1-17lenny2) …
Setting up rdoc1.8 (1.8.7.72-3) …
Setting up rdoc (4.2) …
Setting up re2c (0.13.5-1) …
Setting up ri1.8 (1.8.7.72-3) …
Setting up ri (4.2) …
Setting up scponly (4.6-1.3) …
Configuration file `/etc/scponly/debuglevel’, does not exist on system.
Setting up spamassassin (3.2.5-2) …
Configuration file `/etc/default/spamassassin’, does not exist on system.
Configuration file `/etc/cron.daily/spamassassin’, does not exist on system.
Configuration file `/etc/spamassassin/local.cf’, does not exist on system.
Configuration file `/etc/spamassassin/v320.pre’, does not exist on system.
Configuration file `/etc/spamassassin/v310.pre’, does not exist on system.
Configuration file `/etc/spamassassin/init.pre’, does not exist on system.
Configuration file `/etc/spamassassin/v312.pre’, does not exist on system.
Configuration file `/etc/spamassassin/65_debian.cf’, does not exist on system.
Configuration file `/etc/init.d/spamassassin’, does not exist on system.
SpamAssassin Mail Filter Daemon: disabled, see /etc/default/spamassassin
Setting up spamc (3.2.5-2) …
Setting up subversion (1.5.1dfsg1-2) …
Configuration file `/etc/emacs/site-start.d/50psvn.el’, does not exist on system .
Configuration file `/etc/subversion/config’, does not exist on system.
Configuration file `/etc/subversion/servers’, does not exist on system.
Configuration file `/etc/bash_completion.d/subversion’, does not exist on system .
Setting up apache2-suexec-custom (2.2.9-10+lenny2) …
Configuration file `/etc/apache2/suexec/www-data’, does not exist on system.
Setting up virtualmin-base (1.0-25) …
Setting Webmin theme
Setting Usermin theme
Configuring Postfix
Error occurred while configuring Postfix: Failed to query Postfix config command to get the current value of parameter sender_bcc_maps: <tt></tt> at …/web-lib- funcs.pl line 1311.
Enabling Postfix and disabling Sendmail
Error occurred while enabling Postfix and disabling Sendmail: Failed to query Po stfix config command to get the current value of parameter queue_directory: <tt> </tt> at …/web-lib-funcs.pl line 1311.
Configuring Dovecot for POP3 and IMAP
Enabling Dovecot POP3 and IMAP servers
Enabling ProFTPd
dpkg: error processing virtualmin-base (–configure):
subprocess post-installation script killed by signal (Broken pipe)
virtualmin-base
FATAL - 2009-05-18 16:21:43 - Fatal Error Occurred: Installation failed: 0
FATAL - 2009-05-18 16:21:43 - Cannot continue installation.
FATAL - 2009-05-18 16:21:43 - Attempting to remove virtualmin repository configu ration, so the installation can be
FATAL - 2009-05-18 16:21:43 - re-attempted after any problems have been resolved .
FATAL - 2009-05-18 16:21:43 - Removing temporary directory and files.
FATAL - 2009-05-18 16:21:43 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2009-05-18 16:21:43 - in /root/virtualmin-install.log
i am no terminal basher…and i really cant tell what i am doing wrong… im installing on a fresh debian install…
i have tryed both 4.0 and 5.0
could anyone help me out, maybe make me a bit wiser
fingers crossed
