installation issues?
Failed to save enabled features : The Apache module mod_actions is either not installed or not enabled.
Which distribution/version is it that you’re using there?
Sorry -
System hostname webserver05 (127.0.1.1)
Operating system Ubuntu Linux 14.04.3
Webmin version 1.760
Virtualmin version 4.18.gpl
Apache Webserver
Apache version 2.4.7
Virtualmin Virtual Servers
Version 4.18.gpl, master admin mode
I had a similar issue with changes not being saved.
It turns out that mailman requires a mailman list and save actions apparently wanted to send an e-mail vial mailrunner which failed because mailman list did not exist. Not real obvious.
I created a mailman list and then changes started to be saved.
See:
http://www.askdavetaylor.com/why_is_mailman_complaining_site_list_is_missing_mailman/
newlist mailman email ... for list: youremail@yourdomain.com password: (put something here)
Note: I did not set up the mail alias but I was just interested in getting things so I could start mailman.
After doing this start mailman
After starting mailman then try to save changes and see if they work.
Hope this helps.
johnh…
