I’m setting up a dedicated server for the first time, purchased virtualmin, and got this from the installer, keys and hostname removed:
Checking for curl or wget…found /usr/bin/curl -s -O
Checking for perl…found /usr/bin/perl
Loading log4sh logging library…
INFO - Started installation log in virtualmin-install.log
INFO - Checking for fully qualified hostname…
INFO - Hostname OK: fully qualified as <removed>
INFO - Installing serial number and license key into /etc/virtualmin-license
INFO - Loading OS selection library…
INFO - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - Loading OS list…
INFO - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - Operating system name: CentOS Linux
INFO - Operating system version: 5
INFO - Installing virtualmin-release package for CentOS Linux 5…
INFO - Disabling SELinux during installation…
/usr/sbin/setenforce: SELinux is disabled
INFO - setenforce 0 failed: 1
error: /usr/share/rhn/RPM-GPG-KEY: import read failed(-1).
INFO - Download of http://<removed>@software.virtualmin.com/rhel/5/i386/virtualmin-release-latest.noarch.rpm Succeeded.
Running updatedb so locate works…this will take a little while.
Attempting to import various system RPM-GPG-KEY files…Errors may occur,
if you’ve already imported them. It is safe to ignore these errors.
INFO - Succeeded.
INFO - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix bind spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion ruby rdoc ri mysql mysql-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-domxl php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby rubygems perl-XML-Simple perl-Crypt-SSLeay
INFO - …in progress, please wait… /Error: Missing Dependency: ruby = 1.8.5-5.el5 is needed by package ruby-ri
Error: Missing Dependency: ruby = 1.8.5-5.el5 is needed by package ruby-rdoc
Error: Missing Dependency: ruby = 1.8.5-5.el5 is needed by package ruby-irb …in progress, please wait… failed. Error (if any): 0
Displaying the last 15 lines of the install.log to help troubleshoot this problem:
–> Restarting Dependency Resolution with new changes.
–> Populating transaction set with selected packages. Please wait.
—> Package perl-Digest-HMAC.noarch 0:1.01-15 set to be updated
—> Package perl-Compress-Zlib.i386 0:1.42-1.fc6 set to be updated
—> Package perl-Socket6.i386 0:0.19-3.fc6 set to be updated
—> Package lm_sensors.i386 0:2.10.0-3.1 set to be updated
—> Package perl-IO-Zlib.noarch 0:1.04-4.2.1 set to be updated
—> Package perl-HTML-Tagset.noarch 0:3.10-2.1.1 set to be updated
—> Package perl-Net-IP.noarch 0:1.25-2.fc6 set to be updated
—> Package perl-Net-SSLeay.i386 0:1.30-4.fc6 set to be updated
–> Running transaction check
–> Processing Dependency: ruby = 1.8.5-5.el5 for package: ruby-rdoc
–> Processing Dependency: ruby = 1.8.5-5.el5 for package: ruby-ri
–> Processing Dependency: ruby = 1.8.5-5.el5 for package: ruby-irb
–> Finished Dependency Resolution
FATAL - Fatal Error Occurred: Something went wrong during installation: 1
warning: /etc/yum.repos.d/virtualmin.repo saved as /etc/yum.repos.d/virtualmin.repo.rpmsave
FATAL - in /root/virtualmin-install.log.
My guess is Ruby didn’t install when it should have, or the install script assumes Ruby is there when it isn’t. Any further ideas, and tips for resolving this?
Excuse my newishness.
Thanks.
