I have a new dedicated server which came with a very restrictive control panel so am trying to get web/virtualmin up and running.
My first attempt worked ok but was unable to connect to mysql so I set about uninstalling all related packages and trying again. In the process I discovered I was inside a chroot jail and broke out of this.
Unfortunately using a fresh OS install is not a preferred option since I will be charged for this and cant (as far as I am aware) do this remotely without losing my SSH access required to reconfigure things.
So with apache, mysql, clamav, dovecote, php, postresql, proftpd, spamassassin, bind, procmail and postfix and anything that looked non-standard/essential removed I ran the install script.
Then I hit an error
Unpacking virtualmin-base (from…/virtualmin-base_1.0-20_all.deb) …
/var/cache/apt/archives/webalizer_2.01.10-32.1_amd64.deb
FATAL -2010-01-30 06:47:07 - Fatal Error Occurred: Installation failed: 0
FATAL -2010-01-30 06:47:07 - Cannot continue installation.
FATAL -2010-01-30 06:47:07 - Attempting to remove virtualmin reprository configuration, so the installation can be
FATAL -2010-01-30 06:47:07 - re-attempted after any problems have been resolved.
FATAL -2010-01-30 06:47:07 - Removing temporary directory and files
Looking at the system webmin seems to have been installed and is indeed working.
webmin
webmin-security-updates
webmin-virtual-server
webmin-virtual-server-theme
webmin-virtualmin-dav
webmin-virtualmin-htpasswd
webmin-virtualmin-mailman
webmin-virtualmin-svn
However virtualmin is not working.
What would be the best next step to get virtualmin working?
Remove everything, fix thecause of the previous prob and reinstall from script?
Or just try and fix the prob and install the components manually?
Does anyone know the likely cause of the error listed above?
Um, I can’t help you much but I know there will be two questions asked and you might save some time by answering those sooner rather than later. Then, the next person who comes along might have the answers.
Hrm, I’m going to take a shot in the dark here, but are you by chance using a VPS with a small amount of RAM and perhaps no swap?
There’s been some folks lately running into the strangest of issues, and some of it was coming down to the idea that there just wasn’t enough RAM available to do what they were hoping to do.
If you log into your server and type “free”, what do you see?
mount
/dev/sda1 on / type ext3 (rw,relatime,errors=remount-ro)
proc on /proc type proc (rw,noexec,nosuid,nodev)
/sys on /sys type sysfs (rw,noexec,nosuid,nodev)
varrun on /var/run type tmpfs (rw,noexec,nosuid,nodev,mode=0755)
varlock on /var/lock type tmpfs (rw,noexec,nosuid,nodev,mode=1777)
udev on /dev type tmpfs (rw,mode=0755)
devshm on /dev/shm type tmpfs (rw)
devpts on /dev/pts type devpts (rw,gid=5,mode=620)
proc on /usr/fs/proc type proc (rw)
sysfs on /usr/fs/sys type sysfs (rw)
devpts on /usr/fs/dev/pts type devpts (rw,mode=0620,gid=5)
securityfs on /sys/kernel/security type securityfs (rw)
