Script worked fine on Friday on a new server.
Today the script stops with the following…
INFO - 2013-08-24 22:37:25 - Started installation log in /root/virtualmin-install.log
DEBUG - 2013-08-24 22:37:25 - Install mode: full
DEBUG - 2013-08-24 22:37:25 - Product: Virtualmin GPL
DEBUG - 2013-08-24 22:37:25 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2013-08-24 22:37:25 - install.sh version: 1.1.0
INFO - 2013-08-24 22:37:25 - Checking for fully qualified hostname...
INFO - 2013-08-24 22:37:25 - Hostname OK: fully qualified as cp1.tvis.ca
INFO - 2013-08-24 22:37:25 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2013-08-24 22:37:25 - Loading OS selection library...
INFO - 2013-08-24 22:37:25 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2013-08-24 22:37:26 - Loading OS list...
INFO - 2013-08-24 22:37:26 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2013-08-24 22:37:26 - Operating system name: CentOS Linux
INFO - 2013-08-24 22:37:26 - Operating system version: 6
INFO - 2013-08-24 22:37:26 - Configuring package manager for CentOS Linux 6...
INFO - 2013-08-24 22:37:26 - Disabling SELinux during installation...
INFO - 2013-08-24 22:37:26 - setenforce 0 failed: 1
INFO - 2013-08-24 22:37:27 - Download of http://software.virtualmin.com/gpl/rhel/6/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
INFO - 2013-08-24 22:37:27 - Succeeded.
INFO - 2013-08-24 22:37:27 - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
* base: centos.mirror.gtcomm.net
* extras: mirror.its.sfu.ca
* updates: mirror.its.sfu.ca
Setting up Install Process
Package 2:postfix-2.6.6-2.2.el6_1.x86_64 already installed and latest version
Package iptables-1.4.7-9.el6.x86_64 already installed and latest version
Package openssl-1.0.0-27.el6_4.2.x86_64 already installed and latest version
Package python-2.6.6-37.el6_4.x86_64 already installed and latest version
Package subversion-1.6.11-9.el6_4.x86_64 already installed and latest version
No package rh-postgresql available.
No package rh-postgresql-server available.
Package logrotate-3.7.8-16.el6.x86_64 already installed and latest version
No package mod_python available.
Package cyrus-sasl-2.1.23-13.el6_3.1.x86_64 already installed and latest version
Resolving Dependencies
--> Running transaction check
---> Package bind.x86_64 32:9.8.2-0.17.rc1.el6_4.5 will be installed
--> Processing Dependency: bind-libs = 32:9.8.2-0.17.rc1.el6_4.5 for package: 32:bind-9.8.2-0.17.rc1.el6_4.5.x86_64
--> Processing Dependency: portreserve for package: 32:bind-9.8.2-0.17.rc1.el6_4.5.x86_64
--> Processing Dependency: liblwres.so.80()(64bit) for package: 32:bind-9.8.2-0.17.rc1.el6_4.5.x86_64
--> Processing Dependency: libisccfg.so.82()(64bit) for package: 32:bind-9.8.2-0.17.rc1.el6_4.5.x86_64
--> Processing Dependency: libisccc.so.80()(64bit) for package: 32:bind-9.8.2-0.17.rc1.el6_4.5.x86_64
--> Processing Dependency: libisc.so.83()(64bit) for package: 32:bind-9.8.2-0.17.rc1.el6_4.5.x86_64
--> Processing Dependency: libdns.so.81()(64bit) for package: 32:bind-9.8.2-0.17.rc1.el6_4.5.x86_64
--> Processing Dependency: libbind9.so.80()(64bit) for package: 32:bind-9.8.2-0.17.rc1.el6_4.5.x86_64
---> Package bind-utils.x86_64 32:9.8.2-0.17.rc1.el6_4.5 will be installed
---> Package cyrus-sasl-gssapi.x86_64 0:2.1.23-13.el6_3.1 will be installed
---> Package dovecot.x86_64 1:2.0.9-5.el6 will be installed
---> Package httpd.x86_64 0:2.2.15-29.el6.centos will be updated
---> Package httpd.x86_64 1:2.2.15-29.el6.vm will be an update
--> Processing Dependency: httpd-tools = 2.2.15-29.el6.vm for package: 1:httpd-2.2.15-29.el6.vm.x86_64
---> Package mailman.x86_64 3:2.1.12-18.el6 will be installed
---> Package mlocate.x86_64 0:0.22.2-4.el6 will be installed
---> Package mod_dav_svn.x86_64 0:1.6.11-9.el6_4 will be installed
---> Package mod_perl.x86_64 0:2.0.4-10.el6 will be installed
--> Processing Dependency: perl(ExtUtils::MakeMaker) for package: mod_perl-2.0.4-10.el6.x86_64
--> Processing Dependency: perl(BSD::Resource) for package: mod_perl-2.0.4-10.el6.x86_64
---> Package mod_ssl.x86_64 2:2.2.15-29.el6.vm will be installed
---> Package mysql.x86_64 0:5.1.69-1.el6_4 will be installed
---> Package mysql-devel.x86_64 0:5.1.69-1.el6_4 will be installed
--> Processing Dependency: openssl-devel for package: mysql-devel-5.1.69-1.el6_4.x86_64
---> Package mysql-server.x86_64 0:5.1.69-1.el6_4 will be installed
--> Processing Dependency: perl-DBI for package: mysql-server-5.1.69-1.el6_4.x86_64
--> Processing Dependency: perl(DBI) for package: mysql-server-5.1.69-1.el6_4.x86_64
---> Package perl-Crypt-SSLeay.x86_64 0:0.57-16.el6 will be installed
---> Package perl-DBD-MySQL.x86_64 0:4.013-3.el6 will be installed
---> Package perl-DBD-Pg.x86_64 0:2.15.1-4.el6_3 will be installed
--> Processing Dependency: libpq.so.5()(64bit) for package: perl-DBD-Pg-2.15.1-4.el6_3.x86_64
---> Package perl-XML-Simple.noarch 0:2.18-6.el6 will be installed
---> Package php.x86_64 0:5.3.3-23.el6_4 will be installed
--> Processing Dependency: php-common(x86-64) = 5.3.3-23.el6_4 for package: php-5.3.3-23.el6_4.x86_64
--> Processing Dependency: php-cli(x86-64) = 5.3.3-23.el6_4 for package: php-5.3.3-23.el6_4.x86_64
---> Package php-gd.x86_64 0:5.3.3-23.el6_4 will be installed
--> Processing Dependency: libXpm.so.4()(64bit) for package: php-gd-5.3.3-23.el6_4.x86_64
---> Package php-imap.x86_64 0:5.3.3-23.el6_4 will be installed
--> Processing Dependency: libc-client.so.2007()(64bit) for package: php-imap-5.3.3-23.el6_4.x86_64
---> Package php-mbstring.x86_64 0:5.3.3-23.el6_4 will be installed
---> Package php-mysql.x86_64 0:5.3.3-23.el6_4 will be installed
--> Processing Dependency: php-pdo(x86-64) for package: php-mysql-5.3.3-23.el6_4.x86_64
---> Package php-odbc.x86_64 0:5.3.3-23.el6_4 will be installed
--> Processing Dependency: libodbc.so.2()(64bit) for package: php-odbc-5.3.3-23.el6_4.x86_64
---> Package php-pear.noarch 1:1.9.4-4.el6 will be installed
---> Package php-pgsql.x86_64 0:5.3.3-23.el6_4 will be installed
---> Package php-snmp.x86_64 0:5.3.3-23.el6_4 will be installed
--> Processing Dependency: net-snmp for package: php-snmp-5.3.3-23.el6_4.x86_64
--> Processing Dependency: libnetsnmp.so.20()(64bit) for package: php-snmp-5.3.3-23.el6_4.x86_64
---> Package php-xml.x86_64 0:5.3.3-23.el6_4 will be installed
--> Processing Dependency: libxslt.so.1(LIBXML2_1.0.24)(64bit) for package: php-xml-5.3.3-23.el6_4.x86_64
--> Processing Dependency: libxslt.so.1(LIBXML2_1.0.22)(64bit) for package: php-xml-5.3.3-23.el6_4.x86_64
--> Processing Dependency: libxslt.so.1(LIBXML2_1.0.18)(64bit) for package: php-xml-5.3.3-23.el6_4.x86_64
--> Processing Dependency: libxslt.so.1(LIBXML2_1.0.13)(64bit) for package: php-xml-5.3.3-23.el6_4.x86_64
--> Processing Dependency: libxslt.so.1(LIBXML2_1.0.11)(64bit) for package: php-xml-5.3.3-23.el6_4.x86_64
--> Processing Dependency: libxslt.so.1()(64bit) for package: php-xml-5.3.3-23.el6_4.x86_64
--> Processing Dependency: libexslt.so.0()(64bit) for package: php-xml-5.3.3-23.el6_4.x86_64
---> Package php-xmlrpc.x86_64 0:5.3.3-23.el6_4 will be installed
---> Package postgresql.x86_64 0:8.4.13-1.el6_3 will be installed
---> Package postgresql-server.x86_64 0:8.4.13-1.el6_3 will be installed
---> Package procmail.x86_64 0:3.22-25.1.el6 will be installed
---> Package quota.x86_64 1:3.17-18.el6 will be installed
--> Processing Dependency: tcp_wrappers for package: 1:quota-3.17-18.el6.x86_64
--> Processing Dependency: libnl.so.1()(64bit) for package: 1:quota-3.17-18.el6.x86_64
---> Package ruby.x86_64 0:1.8.7.352-12.el6_4 will be installed
--> Processing Dependency: ruby-libs = 1.8.7.352-12.el6_4 for package: ruby-1.8.7.352-12.el6_4.x86_64
--> Processing Dependency: libruby.so.1.8()(64bit) for package: ruby-1.8.7.352-12.el6_4.x86_64
---> Package ruby-devel.x86_64 0:1.8.7.352-12.el6_4 will be installed
---> Package rubygems.noarch 0:1.3.7-1.el6 will be installed
--> Processing Dependency: ruby-rdoc for package: rubygems-1.3.7-1.el6.noarch
---> Package spamassassin.x86_64 0:3.3.1-2.el6 will be installed
--> Processing Dependency: perl(NetAddr::IP) >= 4.000 for package: spamassassin-3.3.1-2.el6.x86_64
--> Processing Dependency: perl(IO::Zlib) >= 1.04 for package: spamassassin-3.3.1-2.el6.x86_64
--> Processing Dependency: perl(Archive::Tar) >= 1.23 for package: spamassassin-3.3.1-2.el6.x86_64
--> Processing Dependency: perl(Time::HiRes) for package: spamassassin-3.3.1-2.el6.x86_64
--> Processing Dependency: perl(Net::DNS) for package: spamassassin-3.3.1-2.el6.x86_64
--> Processing Dependency: perl(Mail::DKIM) for package: spamassassin-3.3.1-2.el6.x86_64
--> Processing Dependency: perl(IO::Socket::SSL) for package: spamassassin-3.3.1-2.el6.x86_64
--> Processing Dependency: perl(IO::Socket::INET6) for package: spamassassin-3.3.1-2.el6.x86_64
--> Processing Dependency: perl(Encode::Detect) for package: spamassassin-3.3.1-2.el6.x86_64
--> Processing Dependency: perl(Archive::Tar) for package: spamassassin-3.3.1-2.el6.x86_64
---> Package webalizer.x86_64 0:2.21_02-3.3.el6 will be installed
--> Processing Dependency: libgd.so.2()(64bit) for package: webalizer-2.21_02-3.3.el6.x86_64
---> Package bind-libs.x86_64 32:9.8.2-0.17.rc1.el6_4.5 will be installed
---> Package gd.x86_64 0:2.0.35-11.el6 will be installed
---> Package libXpm.x86_64 0:3.5.10-2.el6 will be installed
---> Package libc-client.x86_64 0:2007e-11.el6 will be installed
---> Package libnl.x86_64 0:1.1.4-1.el6_4 will be installed
---> Package libxslt.x86_64 0:1.1.26-2.el6_3.1 will be installed
---> Package net-snmp.x86_64 1:5.5-44.el6_4.4 will be installed
--> Processing Dependency: libsensors.so.4()(64bit) for package: 1:net-snmp-5.5-44.el6_4.4.x86_64
---> Package net-snmp-libs.x86_64 1:5.5-44.el6_4.4 will be installed
---> Package openssl-devel.x86_64 0:1.0.0-27.el6_4.2 will be installed
--> Processing Dependency: zlib-devel for package: openssl-devel-1.0.0-27.el6_4.2.x86_64
--> Processing Dependency: krb5-devel for package: openssl-devel-1.0.0-27.el6_4.2.x86_64
---> Package perl-Archive-Tar.x86_64 0:1.58-131.el6_4 will be installed
--> Processing Dependency: perl(Package::Constants) for package: perl-Archive-Tar-1.58-131.el6_4.x86_64
---> Package perl-BSD-Resource.x86_64 0:1.29.03-3.el6 will be installed
---> Package perl-DBI.x86_64 0:1.609-4.el6 will be installed
---> Package perl-Encode-Detect.x86_64 0:1.01-2.el6 will be installed
---> Package perl-ExtUtils-MakeMaker.x86_64 0:6.55-131.el6_4 will be installed
--> Processing Dependency: perl-devel for package: perl-ExtUtils-MakeMaker-6.55-131.el6_4.x86_64
--> Processing Dependency: perl(Test::Harness) for package: perl-ExtUtils-MakeMaker-6.55-131.el6_4.x86_64
---> Package perl-IO-Socket-INET6.noarch 0:2.56-4.el6 will be installed
--> Processing Dependency: perl(Socket6) for package: perl-IO-Socket-INET6-2.56-4.el6.noarch
---> Package perl-IO-Socket-SSL.noarch 0:1.31-2.el6 will be installed
--> Processing Dependency: perl(Net::SSLeay) >= 1.21 for package: perl-IO-Socket-SSL-1.31-2.el6.noarch
--> Processing Dependency: perl(Net::LibIDN) for package: perl-IO-Socket-SSL-1.31-2.el6.noarch
---> Package perl-IO-Zlib.x86_64 1:1.09-131.el6_4 will be installed
---> Package perl-Mail-DKIM.noarch 0:0.37-2.el6 will be installed
--> Processing Dependency: perl(Mail::Address) for package: perl-Mail-DKIM-0.37-2.el6.noarch
--> Processing Dependency: perl(Digest::SHA) for package: perl-Mail-DKIM-0.37-2.el6.noarch
--> Processing Dependency: perl(Crypt::OpenSSL::RSA) for package: perl-Mail-DKIM-0.37-2.el6.noarch
---> Package perl-Net-DNS.x86_64 0:0.65-4.el6 will be installed
--> Processing Dependency: perl(Digest::HMAC_MD5) for package: perl-Net-DNS-0.65-4.el6.x86_64
---> Package perl-NetAddr-IP.x86_64 0:4.027-7.el6 will be installed
---> Package perl-Time-HiRes.x86_64 4:1.9721-131.el6_4 will be installed
---> Package php-cli.x86_64 0:5.3.3-23.el6_4 will be installed
---> Package php-common.x86_64 0:5.3.3-23.el6_4 will be installed
---> Package php-pdo.x86_64 0:5.3.3-23.el6_4 will be installed
---> Package portreserve.x86_64 0:0.0.4-9.el6 will be installed
---> Package postgresql-libs.x86_64 0:8.4.13-1.el6_3 will be installed
---> Package ruby-libs.x86_64 0:1.8.7.352-12.el6_4 will be installed
--> Processing Dependency: libreadline.so.5()(64bit) for package: ruby-libs-1.8.7.352-12.el6_4.x86_64
---> Package ruby-rdoc.x86_64 0:1.8.7.352-12.el6_4 will be installed
--> Processing Dependency: ruby-irb = 1.8.7.352-12.el6_4 for package: ruby-rdoc-1.8.7.352-12.el6_4.x86_64
---> Package tcp_wrappers.x86_64 0:7.6-57.el6 will be installed
---> Package unixODBC.x86_64 0:2.2.14-12.el6_3 will be installed
--> Processing Dependency: libltdl.so.7()(64bit) for package: unixODBC-2.2.14-12.el6_3.x86_64
---> Package compat-readline5.x86_64 0:5.2-17.1.el6 will be installed
---> Package krb5-devel.x86_64 0:1.10.3-10.el6_4.4 will be installed
--> Processing Dependency: libselinux-devel for package: krb5-devel-1.10.3-10.el6_4.4.x86_64
--> Processing Dependency: libcom_err-devel for package: krb5-devel-1.10.3-10.el6_4.4.x86_64
--> Processing Dependency: keyutils-libs-devel for package: krb5-devel-1.10.3-10.el6_4.4.x86_64
---> Package libtool-ltdl.x86_64 0:2.2.6-15.5.el6 will be installed
---> Package lm_sensors-libs.x86_64 0:3.1.1-17.el6 will be installed
---> Package perl-Crypt-OpenSSL-RSA.x86_64 0:0.25-10.1.el6 will be installed
--> Processing Dependency: perl(Crypt::OpenSSL::Random) for package: perl-Crypt-OpenSSL-RSA-0.25-10.1.el6.x86_64
--> Processing Dependency: perl(Crypt::OpenSSL::Bignum) for package: perl-Crypt-OpenSSL-RSA-0.25-10.1.el6.x86_64
---> Package perl-Digest-HMAC.noarch 0:1.01-22.el6 will be installed
--> Processing Dependency: perl(Digest::SHA1) for package: perl-Digest-HMAC-1.01-22.el6.noarch
---> Package perl-Digest-SHA.x86_64 1:5.47-131.el6_4 will be installed
---> Package perl-MailTools.noarch 0:2.04-4.el6 will be installed
--> Processing Dependency: perl(Date::Parse) for package: perl-MailTools-2.04-4.el6.noarch
--> Processing Dependency: perl(Date::Format) for package: perl-MailTools-2.04-4.el6.noarch
---> Package perl-Net-LibIDN.x86_64 0:0.12-3.el6 will be installed
---> Package perl-Net-SSLeay.x86_64 0:1.35-9.el6 will be installed
---> Package perl-Package-Constants.x86_64 1:0.02-131.el6_4 will be installed
---> Package perl-Socket6.x86_64 0:0.23-3.el6 will be installed
---> Package perl-Test-Harness.x86_64 0:3.17-131.el6_4 will be installed
---> Package perl-devel.x86_64 4:5.10.1-131.el6_4 will be installed
--> Processing Dependency: perl(ExtUtils::ParseXS) for package: 4:perl-devel-5.10.1-131.el6_4.x86_64
---> Package ruby-irb.x86_64 0:1.8.7.352-12.el6_4 will be installed
---> Package zlib-devel.x86_64 0:1.2.3-29.el6 will be installed
---> Package keyutils-libs-devel.x86_64 0:1.4-4.el6 will be installed
---> Package libcom_err-devel.x86_64 0:1.41.12-14.el6_4.2 will be installed
---> Package libselinux-devel.x86_64 0:2.0.94-5.3.el6_4.1 will be installed
--> Processing Dependency: libsepol-devel >= 2.0.32-1 for package: libselinux-devel-2.0.94-5.3.el6_4.1.x86_64
--> Processing Dependency: pkgconfig(libsepol) for package: libselinux-devel-2.0.94-5.3.el6_4.1.x86_64
---> Package perl-Crypt-OpenSSL-Bignum.x86_64 0:0.04-8.1.el6 will be installed
---> Package perl-Crypt-OpenSSL-Random.x86_64 0:0.04-9.1.el6 will be installed
---> Package perl-Digest-SHA1.x86_64 0:2.12-2.el6 will be installed
---> Package perl-ExtUtils-ParseXS.x86_64 1:2.2003.0-131.el6_4 will be installed
---> Package perl-TimeDate.noarch 1:1.16-11.1.el6 will be installed
---> Package libsepol-devel.x86_64 0:2.0.41-4.el6 will be installed
--> Finished Dependency Resolution
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
FATAL - 2013-08-24 22:37:33 - Fatal Error Occurred: Something went wrong during installation: 0
FATAL - 2013-08-24 22:37:33 - Cannot continue installation.
FATAL - 2013-08-24 22:37:33 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2013-08-24 22:37:33 - re-attempted after any problems have been resolved.
FATAL - 2013-08-24 22:37:33 - Removing temporary directory and files.
FATAL - 2013-08-24 22:37:33 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2013-08-24 22:37:33 - in /root/virtualmin-install.log
Can’t remove httpd-manual as it is not installed yet.
