Hi getting a problem on the install
I’ve tried the options given below.
I had difficulty getting installed in first place, (unable to use the install.sh. listed in the licence page)
had to install webmin first then tried to perforum upgrade.
I installed form here:
http://www.webmin.com/rpm.html
that installed webmin and onlyu webmin, and I need to install virtualmin, but am unsure how to do that.
thanks Brian
Continue? (y/n) Checking for HTTP client…found /usr/bin/curl -s -O
Checking for perl…found /usr/bin/perl
Loading log4sh logging library…
INFO - Started installation log in /root/virtualmin-install.log
INFO - Checking for fully qualified hostname…
INFO - Hostname OK: fully qualified as ns3.fife.eu
INFO - Installing serial number and license key into /etc/virtualmin-license
INFO - Loading OS selection library…
INFO - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - Loading OS list…
INFO - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - Operating system name: CentOS Linux
INFO - Operating system version: 6
INFO - Configuring package manager for CentOS Linux 6…
INFO - Disabling SELinux during installation…
INFO - Download of http://55xxxx0:poxxxxxxmo@software.virtualmin.com/rhel/6/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
INFO - Succeeded.
INFO - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay
…in progress, please wait…
-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\e[0m/usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay failed. Error (if any): 0
Displaying the last 15 lines of /root/virtualmin-install.log to help troubleshoot this problem:
—> Package libcom_err-devel.x86_64 0:1.41.12-14.el6_4.2 will be installed
—> Package libselinux-devel.x86_64 0:2.0.94-5.3.el6_4.1 will be installed
–> Processing Dependency: libsepol-devel >= 2.0.32-1 for package: libselinux-devel-2.0.94-5.3.el6_4.1.x86_64
–> Processing Dependency: pkgconfig(libsepol) for package: libselinux-devel-2.0.94-5.3.el6_4.1.x86_64
—> Package perl-Crypt-OpenSSL-Bignum.x86_64 0:0.04-8.1.el6 will be installed
—> Package perl-Crypt-OpenSSL-Random.x86_64 0:0.04-9.1.el6 will be installed
—> Package perl-Digest-SHA1.x86_64 0:2.12-2.el6 will be installed
—> Package perl-TimeDate.noarch 1:1.16-11.1.el6 will be installed
–> Running transaction check
—> Package httpd-manual.noarch 1:2.2.15-15.el6.vm will be an update
–> Processing Dependency: httpd = 1:2.2.15-15.el6.vm for package: 1:httpd-manual-2.2.15-15.el6.vm.noarch
—> Package libsepol-devel.x86_64 0:2.0.41-4.el6 will be installed
–> Finished Dependency Resolution
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
FATAL - Fatal Error Occurred: Something went wrong during installation: 0
