system
December 11, 2011, 12:50pm
1
Hi.
I am getting this error on one of my scripts:
Could not Insert to CB_MAIN (update)Got a packet bigger than ‘max_allowed_packet’ bytes
I guess that I need to increase the ‘max_allowed_packet’ byte value in MySQL
With VirtualMin there is the option to change “MySQL System Variables”
In there I find that ‘max_allowed_packet’ is set to : 1048576
What is a reasonable figure to increase it to ?
Also why ıs it 1048576 and not 1,000,000 ?
I am going to double the number up to 2,097,152
and see what happens !
Is there any other variable that should also be adjusted ?
system
December 13, 2011, 10:12am
2
Anyone have knowledge on this ?
Eric
December 13, 2011, 5:53pm
3
I’m unfortunately not familiar with that setting – however, there’s a page over at mysql.com that describes the problem you’re running into as well as the details of changing that parameter here:
http://dev.mysql.com/doc/refman/5.5/en/packet-too-large.html
You can edit the setting like this:
Webmin > Servers > MySQL Database Server > MySQL Server Configuration,
Change the value in “Maximum packet size” box,
Click “Save and Restart My SQL”.
