Those are all packages provided by your distro, not by Virtualmin… Virtualmin just aids in making them easy to install
Today, CentOS 5.6 came out. So if you upgraded all your packages, that may mean you’ve upgraded from CentOS 5.5 to 5.6.
And then, CentOS is made by folks who take the source packages from RedHat, recompile them, and distribute them.
So, it’s not surprising that the next version of a distro would use more RAM than the previous one. But if you’re unhappy with it, you’d have to take that up with the folks at RedHat
Well, all I can offer is that the amount of RAM processes take up isn’t a constant It may be a web app requiring more resources, BIND might have grown, or any of the system updates could have caused some additional RAM usage.
Also, if one of your sites saw some traffic, Apache would need to spawn additional processes to handle that load. That could can certainly account for what you’re seeing.
And any incoming email will run procmail, and a spam and virus scanning process, amongst other things.
There’s a lot of possible causes for a difference of 70MB of RAM and 25 processes, that’s not considered a particularly large change. My own server just jumped 10 processes in the last 2 minutes.
So, I wouldn’t be particularly concerned about that
Virtualmin is reading it the values wrong. But that seems odd, it’s unlikely it would just make numbers up
There are two sections in the httpd.conf that deal with processes and limits – one is for Apache’s worker mode, and the the other is for Prefork mode. However, both sections look really similar. Is it possible that you’re looking at the wrong section in your httpd.conf? If you’re using Apache’s Prefork, be sure to look at the section the begins with “IfModule mpm_prefork_module”.
I’m not sure the section you’re editing in the Apache config is the one for the Prefork mode… if you search in the config, there should be two different “MaxClients” settings – one for Prefork, one for Worker.
Do you see two settings for MaxClients in your config? There should be some sort of description above it that tells whether that group is for Prefork or Worker mode.
From there, the only thing I’d be concerned about is how high MaxClients is set. You need to look at how much RAM one Apache process consumes. Once you figure that out – you need to make sure that if MaxClients is reached, that you’ll still have RAM left over in your server. If not, you need to lower MaxClients
If one Apache process takes 30MB of RAM, and MaxClients is set to 50, that means you need 1.5 GB of RAM to support that configuration.
So, review how much RAM one Apache process takes, and modify your MaxClients accordingly. I’m not sure how much RAM you have – but folks running on a VPS with low amounts of memory will often need to set MaxClients well under 50.
So what you’re saying is that with 256 max clients, theres no way our server would be able to handle the load with only 752 mb ram if each httpd process takes about 35 mb?
Yup, it’s just figuring out some math there… if each process takes 35MB, and you have 752MB of RAM, that means you can handle 21 simultaneous Apache processes (MaxClients) – if absolutely nothing else is running.
Being as other processes are sure to be running, you’d need to account for those when determining your MaxClients.
It’s unlikely to be related to anything we’ve talked about so far… my guess is that someone’s just doing something in the Virtualmin/Webmin GUI, and it’s an active process that’s doing something.
Could this be a security problem? We got a warning in virtualmin that the index_cpu.cgi was trying to be accessed remotely and that we should visit Webmin > Webmin Configuration > Trusted Referrers and check Trust links from unknown referrers
We seem to have a webmin user called anonymous, should we delete?
You can review if there’s a password set for that user in Webmin -> Webmin -> Webmin Users -> Anonymous. There isn’t by default, it’s not normally something to worry about.
