Ignore Validate Records, not ignoring
OS type and version Ubuntu Linux 22.04.1
Webmin version 2.001
Virtualmin version 7.2-1
Perl version 5.034000
Path to Perl /usr/bin/perl
Python version 3.10.6
Path to Python /bin/python3
BIND version 9.18
Postfix version 3.6.4
Mail injection command /usr/lib/sendmail -t
Apache version 2.4.52
PHP versions 8.1.2
Logrotate version 3.19.0
MariaDB version 10.6.7
SpamAssassin version 3.4.6
What I did was upon Virtual Server creation, I did not put the external IP I wanted to use in, so I attempted to change it in DNS below.
In Virtualmin > Server Configuration > DNS Records, If I need to change IP addresses and I uncheck the Validate Records, it still gives me an error due to validation error. So it is not ignoring validation like I am asking.
What I ended up doing to get around this was to delete the Virtual Server and then re-create it with the correct IP I wanted.
I am Pre-Setting up this server for migration, so while the information “will” be correct, it currently is NOT, but that is not my concern since I am aware of what I am doing.
This is a “non-issue” right now for me, I just wanted you to be aware of it, I just ran into this while setting up a fresh instance of Ubuntu v22.04
Thanks for the heads up.
The right place to update virtual server’s IP is using example.com - Server Configuration ⇾ Change IP Address page.
