Ignorance regarding Name Servers
Well I set them up and then forget them. Use Cloudflare as cdn and rrgistrar also so it sutes me perfect
If you’ve only got a few, it doesn’t much matter, but if you have hundreds or thousands, the problem starts to look different.
You’ll note I qualified what I said as the reply was directed to someone trying to understand DNS and how it is used in Virtualmin. You are welcome to add some tips about your setup to help the new guy out. :slight_smile:
Well in that case i dont think bind in virtualmin would be the solution
