I got a vps from ovh with the idea to migrate from public to private. I’ve installed virtualmin but doing the post setting installation questionnaire, I got stocked in the sql question, cause after checking the options ( yes first, no second) I got a notice that I had to install a sql module to make it work. After doing that, apparently the server is denying the accces to webmin. I’ve reinstalled the vps, changed the passwords and I could get to the login page, but once inside I got a blank page in the midle right side, with a little sad face telling me that the access was denied.
I’ve seen somewhere that this was a kind of normal thing when there is not yet any data base withing the vps, but I lost trace of that.
If you could help me with this it will be highly appreciated !
Regards,
JC
