Linux server.discusswire.com 2.6.18-308.el5.028stab099.3 #1 SMP Wed Mar 7 15:56:00 MSK 2012 i686 i686 i386 GNU/Linux
i found that there are 5 httpd same process running when checked running processes, each consuming 70 MB RAM
Why this,
Ram consumption increases regularl
i need mail box functionality, so shall i need postfix with devcot, or anyother low memmory substitution
can i disable awstate and weblizer, or shall i need both
Sure… but what does “free -m” show? That’ll help us understand what is going on with your server.
That’s a good! We definitely want to be using 32 bit and not 64 bit on a system with only 512MB of RAM.
i need mail box functionality, so shall i need postfix with devcot, or anyother low memmory substitution can i disable awstate and weblizer, or shall i need both
Awstats and Webalizer are just for generating statistics. Although they don’t use much memory, it certainly can’t hurt to disable them if you don’t need them.
If you haven’t already, I’d also recommend reviewing the low-memory documentation that I mentioned earlier, it makes some suggestions as to what services can be stopped.
It’s normal for processes to use more memory the longer they run. The low-memory documentation reviews some methods of reducing how much memory Apache requires.
