wonderign if anybody has any qucik tips to solve the issue with server
thanks, I will see if I cna find any info
I did the httpd config check and came back with no errors
Brian
Operating system |CentOS Linux 7.8.2003|
Webmin version |1.955 |Virtualmin version |6.12.pro|
Linux 3.10.0-1127.19.1.el7.x86_64 on x86_64|
Redirecting to /bin/systemctl status httpd.service
● httpd.service - The Apache HTTP Server
Loaded: loaded (/usr/lib/systemd/system/httpd.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Sun 2020-10-11 15:31:12 BST; 13min ago
Docs: man:httpd(8)
man:apachectl(8)
Process: 5668 ExecReload=/usr/sbin/httpd $OPTIONS -k graceful (code=exited, status=0/SUCCESS)
Process: 10765 ExecStart=/usr/sbin/httpd $OPTIONS -DFOREGROUND (code=exited, status=1/FAILURE)
Main PID: 10765 (code=exited, status=1/FAILURE)
Oct 11 15:31:12 ns.01383.uk systemd[1]: Starting The Apache HTTP Server…
Oct 11 15:31:12 ns.01383.uk systemd[1]: httpd.service: main process exited, code=exited, status=1/FAILURE
Oct 11 15:31:12 ns.01383.uk systemd[1]: Failed to start The Apache HTTP Server.
Oct 11 15:31:12 ns.01383.uk systemd[1]: Unit httpd.service entered failed state.
Oct 11 15:31:12 ns.01383.uk systemd[1]: httpd.service failed.
