Hi!
Could you help me to resolve this issue?
httpd-devel on CenOS 6.5 fail
Error: Package: httpd-devel-2.2.15-29.el6.centos.x86_64 (base)
Requires: httpd = 2.2.15-29.el6.centos
Installed: 1:httpd-2.2.15-28.el6.vm.2.x86_64 (@virtualmin)
httpd = 1:2.2.15-28.el6.vm.2
Available: httpd-2.2.15-29.el6.centos.x86_64 (base)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
… install failed!
Thank you,
Installing package(s) with command yum -y install httpd-devel …
Loaded plugins: fastestmirror, presto
Loading mirror speeds from cached hostfile
- base: mirror.umd.edu
- extras: centos.mirror.nac.net
- updates: centos.mirror.nac.net
Setting up Install Process
Resolving Dependencies
→ Running transaction check
—> Package httpd-devel.x86_64 0:2.2.15-29.el6.centos will be installed
→ Processing Dependency: httpd = 2.2.15-29.el6.centos for package: httpd-devel-2.2.15-29.el6.centos.x86_64
→ Processing Dependency: apr-util-devel for package: httpd-devel-2.2.15-29.el6.centos.x86_64
—> Package apr-util-devel.x86_64 0:1.3.9-3.el6_0.1 will be installed
→ Processing Dependency: openldap-devel for package: apr-util-devel-1.3.9-3.el6_0.1.x86_64
→ Processing Dependency: expat-devel for package: apr-util-devel-1.3.9-3.el6_0.1.x86_64
—> Package expat-devel.x86_64 0:2.0.1-11.el6_2 will be installed
—> Package openldap-devel.x86_64 0:2.4.23-34.el6_5.1 will be installed
→ Processing Dependency: cyrus-sasl-devel >= 2.1 for package: openldap-devel-2.4.23-34.el6_5.1.x86_64
—> Package cyrus-sasl-devel.x86_64 0:2.1.23-13.el6_3.1 will be installed
→ Finished Dependency Resolution
… install failed!
