Http2 on admin panel
OS type and version Debian 10 (10.13)
Virtualmin version 7.5
Hello to everyone.
I did enable http2 for my websites (using apache2) a long time ago and was checking something on the virtualmin panel when I noticed that http2 is not used for the panel itself.
So I was wondering why the panel isn’t loaded via http2 when the rest is.
Is there something that needs to be done separately for the panel (webmin, virtualmin, usermin) when doing it in general for apache2?
Did I miss something or is the panel (all of them) currently not useable via http2?
I did try to check the docs and use the search function, but didn’t find an answer to that specific “issue”.
Thanks in advance. :slight_smile:
As far as I am aware vmin/webmin uses it’s own web server and not apache/nginx so you will not see that enabled I guess
That is something I did had in mind when I rechecked my settings, but wasn’t sure about it.
Question is if it is possible to add http2 to it/them.
Webmin and Usermin do not run under Apache or nginx. There is no http2 support in miniserv.pl, the app server we use.
Okay, thanks. :slight_smile: That was the answer I was looking for.
