awesome, thanx The admin settings solved the problem. But now I need to figure out how to get the database that I created as root in Webmin into this client’s VirtualMin. Any suggestion on that?
I unfortunately don’t know of a good way to do this, you’d likely need to manually edit the config files in /etc/webmin/ in order to add it.
It might be simpler to use mysqldump to dump the database contents, delete the database, then have Virtualmin add it… at which point you could then import the data back in.
No, it’s not seamless by any stretch of the imagination, but it would work
