My system does not have enough resources and yum causes it to crawl when it tries to run (30-60 seconds to login with SSH using RSA key for example). TOP command confirms YUM is using the resources.
I already removed yum-updatesd,
Changed Virtualmin Package Updates to No, wasn’t sure if each catagory of updates was different, but all Check for updates on schedule? are set as No.
Searching and looking for answers to this, other then removing YUM, I have not found a good solution.
Where is the setting causing this to run at seemingly random times?
If you go into System Settings -> Virtualmin Config -> Status Collection, you can set “Interval between status collection job runs” to a higher number, or disable it altogether – as that’s just for collecting stats on the system, including checking for new packages.
