Hi guys, I have specified an SSH server as a secondary destination for my backup. The SSH server is listening on a port other than 22. How to configure my backup to use the non-standard port?
In the hostname field, you can specify your hostname as “backup.server.tld:PORT”.
That is, just add your port number to the end of the hostname you’re sending the backups to.
Thanks as always Eric. For some reason I never got an update and hence the delay in my thanking you.
