I wish to set up my DNS and the Users so that I can have two resllers that can set up their own virtual servers. The clients (owners of the VS) should see their respective reseller as the nameserver and if possible also see that name in the System Hostname.
Background:
I have a dedicated server from Rackmounted.
They have given me two IP addresses. 75.23.139.44 and 75.23.139.47
I have registered many names with iPower.com and they use opensrs.net to manage the domain names including assigning the name servers.
I have registered a name that I wish to use as the main account. main-dom.com
i think it would not be a problem if you add several nameservers on the same IP’s if you’ll add them as virtual interfaces and put them in the hostaddresses…I’m not 100% sure though, you’ll have to try it out.
Then you can create server templates and define the (resellers) nameservers for that template. So you will have 2 server templates for two resellers.
Then make the reseller accounts and assign the domains to them and the server template you want them to use.
I don’t think you can “mask” the systems hostname.
I do think you should just set it up and take a trial and error path and per haps others will chip in here too.
I will have three pairs of name servers, thats 6 nameservers
Quote: "A DNS server runs special-purpose networking software, features a public IP address,and contains a database of network names and addresses for other Internet hosts."
Will this cause a big overhead on memory or CPU power ?
Wow. Why are you making it all so complicated? That kinda makes no sense.
BIND is reasonably lightweight, though it depends on how heavily it is used…DNS is a very cache focused service, and so if the server is used for many domains and many outgoing queries (for requests from local clients, like email), then it could grow to 100MB, or so. Only the primary would do that, though. All the others would be a few MB each…maybe 16MB? I dunno. It’s been a while since I’ve had a purely authoritative name server without at least some caching name server duties.
